I2C adaption layer driver for libbsd (was: Re: rtems-libbsd build error)
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Thu Apr 18 19:11:13 UTC 2019
On Thu, Apr 18, 2019 at 12:39 AM Christian Mauderer <list at c-mauderer.de>
wrote:
> First: Please note that I changed the toppic. The old one just didn't
> represent the content any more.
> Am 17.04.19 um 20:40 schrieb Vijay Kumar Banerjee:
> > > > Am 09.04.19 um 18:12 schrieb Vijay Kumar Banerjee:
> > > > > Hi,
> > > > > I have imported and ported the the drivers in 2
> > pairs(import
> > > and port)
> > > > > of commits
> > > > > for each one. Please have a look at this branch
> > https://github.com/thelunatic/rtems-libbsd/commits/tda19988
> > > > One detail: You have a commit named "tda19988.c: import
> from
> > > FreeBSD".
> > > > Please remove the ".c".
> > > > Noted.
> > > > Maybe it would be a good idea to split of the I2C part
> > and put
> > > it in
> > > > front of the other two parts. You can develop and test
> that
> > > independent
> > > > with a test that just accesses some of the I2C devices
> > on the
> > > board via
> > > > the FreeBSD API and the translation driver discussed
> below.
> > > > This is a good idea, I'll import iicbus separately and add
> > the other
> > > > two on top of it.
> > > > > I have also tried running the media01.exe and have
> seen it
> > > running
> > > > fine
> > > > > without
> > > > > throwing any exceptions.
> > > > > I have used the fb.c and iicbus.c codes from the
> > > freebsd source. From
> > > > > what I
> > > > > understand, I think the next big steps would be to
> > write an
> > > RTEMS
> > > > > implementation layer for these portions of the code?
> > And then a
> > > > test in the
> > > > > libbsd, like media01, to write to the /dev/fb0
> > > > > Can you please help me chalk out a rough outline of
> > the next
> > > set of
> > > > > actions? :)
> > > > As far as I can tell, there are two possible I2C buses
> here:
> > > > 1. The one between the AM335x and the TDA19988.
> > > > 2. The one directly on the HDMI connector (called
> > HDMI_DSCL and
> > > > HDMI_DSDA). I assume that's an I2C bus too.
> > > > For 1. the RTEMS driver should be used. You'll need some
> > code that
> > > > translates the FreeBSD API to the one used in RTEMS.
> > Basically
> > > that will
> > > > just be a FreeBSD-I2C-driver.
> > > > For 2: If that even is an independent I2C bus, you can
> > use the
> > > driver
> > > > provided by FreeBSD. I don't think that it is necessary
> to
> > > translate to
> > > > the RTEMS API here.
> > > > I had a look at the iic and iicbus codes in freebsd and the
> > bbb-i2c.c
> > > > This looks very confusing to me. Are we looking for
> > something like a
> > > > rtems-iicbus.c in the rtemsbsd that works like a wrapper to
> the
> > > bbb-i2c
> > > > code, and uses the freebsd api of DEVMETHODs?
> > > Yes correct. Basically it would be necessary to have a I2C
> > device driver
> > > for FreeBSD that translates to the RTEMS API.
> > > > I've not been able to figure out at one look, how to relate
> > them and
> > > > get a wrapper like that. Any suggestions on how to approach
> > this?
> > > I haven't had a look at the FreeBSD drivers yet. The first
> > part that I
> > > would have a look at is the description of the user facing
> > FreeBSD API:
> https://www.freebsd.org/cgi/man.cgi?query=iic&apropos=0&sektion=0&manpath=FreeBSD+12.0-RELEASE+and+Ports&arch=default&format=html
> > > Nice thing: They use a struct iic_msg that is compatible with
> > Linux's
> > > struct i2c_msg (according to the man page). We are Linux
> > compatible too.
> > > Can be a big advantage.
> > > Then take a look at the simplest i2c driver that you can find
> > in FreeBSD
> > > that uses the transfer API.
> > > freebsd-org/sys/dev/drm2/radeon/atombios_i2c.c looks good to
> me.
> > > Basically you have to implement the following functions
> (replace
> > > radeon_atom... by a useful prefix):
> > > static device_method_t radeon_atom_hw_i2c_methods[] = {
> > > DEVMETHOD(device_probe,
> radeon_atom_hw_i2c_probe),
> > > DEVMETHOD(device_attach,
> > radeon_atom_hw_i2c_attach),
> > > DEVMETHOD(device_detach,
> > radeon_atom_hw_i2c_detach),
> > > DEVMETHOD(iicbus_reset,
> radeon_atom_hw_i2c_reset),
> > > DEVMETHOD(iicbus_transfer,
> radeon_atom_hw_i2c_xfer),
> > > DEVMETHOD_END
> > > The iicbus_transfer function seems to get a struct iic_msg as a
> > > parameter. Now that's really lucky.
> > > With that you should be able to open the i2c device in RTEMS
> > and just
> > > pass the structure via the correct ioctl call to the RTEMS
> driver.
> > > Basically you just have to pass the bus to use as a parameter
> > to the
> > > driver. Take a look at some of the other drivers in
> > nexus-devices.h that
> > > have for example an address as a parameter to see how you can
> > do that.
> > > This gave a good idea of the objective. :)
> > > I had a look at the bbb-i2c.c code and how it's registering
> > > and setting up the i2c_bus struct with the transfer, set and
> destroy
> > > fucntions.
> > > I have a question from the fundamentals, the only function
> > > of bbb-i2c.c
> https://git.rtems.org/rtems/tree/bsps/arm/beagle/i2c/bbb-i2c.c#n414>
> > > that is 'accessible' with the header file is
> am335x_i2c_bus_register
> > > which basically sets the i2c_bus struct
> > > and calls the i2c_bus_register function from the dev/i2c.c .
> > > To use the DEVMETHOD api, we need to be able to call the
> > > transfer, destroy etc. functions of the bbb-i2c.c from the
> translation
> > > layer in rtemsbsd. How do I #include the bbb-i2c.c in the new
> > > translation driver that I'll write?
> > > Hope my question is stated clearly, please correct me if I'm
> getting
> > > some fundamentals wrong.
> > You are not fundamentally wrong but slightly off:
> > Regarding the question how you access transfer, destroy, ... of the
> > driver directly: Don't.
> > You basically don't need to have a look at the bbb-i2c.c file of
> RTEMS
> > for that driver. Where you should have a look is the Linux I2C API
> > (which has been the model for the RTEMS API).
> > Basically your drivers transfer function will do about the following:
> > - Open "/dev/i2c0" (or some other path - that will be a parameter to
> the
> > driver and has to be stored by probe or attach in some device
> > structure).
> > - Translate the "struct iic_msg" you get as an input to a "struct
> > i2c_msg". Most likely that's just a cast.
> > - Pass that via an ioctl call to the opened bus.
> > - Check return value and translate to the matching return of FreeBSD.
> > - Close "/dev/i2c0"
> > Some of the open / close might could move to attach / detach. But
> that
> > would be an optimization.
> > That driver will work on any BSP that implements the current i2c
> API. So
> > it's a generic translation layer.
> > Best regards
> > Christian
> > Hi!
> > I started writing the driver layer implementation in the rtemsbsd, is
> > this going in the right
> > direction
> > <https://gist.github.com/thelunatic/2d8a2bf2cbead5bf82abe09000afea56> ?
> Yes. That's the direction I had in mind.
> Regarding that part:
> //XXX: Open /dev/iic0
> strcpy(addr, "/dev/");
> strcat(addr, device_get_nameunit(dev));
> Sooner or later that should be received via a parameter. I just had a
> look at nexus-devices.h: It seems that there is currently only support
> for two kinds of "parameters": memory resources and interrupts.
> What would be necessary would be more of a string parameter like they
> are available via the device tree interface. This kind of parameters is
> normally retrieved in the driver with the OF_getprop_alloc() function.
> Problem is: The driver you currently write isn't one that is normally
> put into a device tree file. So some other source for the string
> parameter is necessary. I'll have to have a more detailed look at how
> the parameter could get into the driver in the next few days.
> I would suggest to start with a fixed string for now. Assume that it
> will somehow appear in the attach function (that would be the location
> where such parameters would be parsed most of the time).
> Hi,
I have updated the gist a bit, to use a macro for the path for now, and
also added
the probe and destroy function. This looks like a better outline now, I
haven't written
the attach function, you can have a detailed look at it and suggest ways to
parse the
path in the attach.
> > > > Can we not totally use the iicbus in the freebsd source?
> > > We already have a I2C driver for that BSP in RTEMS. If you
> > would use the
> > > FreeBSD code, they would fight for the hardware. Of course it
> > would be
> > > possible to replace the RTEMS driver by a FreeBSD one. But
> > that would
> > > potentially break some applications. Besides that I think that
> > a lot of
> > > RTEMS BSPs already have an I2C driver so a generic wrapper
> > could be
> > > helpful for other BSPs too.
> > > > > Thanks
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190419/a269ebab/attachment-0001.html>
