Error during execution of testsuites on host OS, for ARM Architecture.
    Vaibhav Gupta
    vaibhavgupta40 at gmail.com
    Wed Apr 24 07:56:42 UTC 2019
Hello,
I have successfully build RTEMS for SPARC erc32, and have run the
testsuites, before.
This time I have build RTEMS for ARM xilinx_zynq_a9_qemu
But when I try to run the hello world example, it gives me following error:
$ arm-rtems5-gdb
~/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/hello.exe
GNU gdb (GDB) 8.2.1
Copyright (C) 2018 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "--host=x86_64-linux-gnu --target=arm-rtems5".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
    <http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from
/home/varodek/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/samples/hello.exe...done.
(gdb) tar sim
Connected to the simulator.
(gdb) load
Loading section .start, size 0xad0 lma 0x0
Loading section .text, size 0x1a5f8 lma 0xb00
Loading section .init, size 0xc lma 0x1b0f8
Loading section .fini, size 0xc lma 0x1b104
Loading section .rodata, size 0x1694 lma 0x1b110
Loading section .ARM.exidx, size 0x8 lma 0x1c7a4
Loading section .eh_frame, size 0x4 lma 0x1c7ac
Loading section .init_array, size 0x4 lma 0x1c7b0
Loading section .fini_array, size 0x4 lma 0x1c7b4
Loading section .rtemsroset, size 0x38 lma 0x1c7b8
Loading section .data, size 0x66c lma 0x101000
Start address 0x40
Transfer rate: 946528 bits in <1 sec.
(gdb) r
Starting program:
Unknown machine type '19'; please update sim_create_inferior.
[Inferior 1 (process 42000) exited with code 060]
I am not able to analyze the problem, why is it showing Unknown machine
type? The test runs were successful  for SPARC.
Thank You
Vaibhav Gupta
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190424/20292d52/attachment.html>
