Run Time linker and relocation of multiple local labels
Thu Apr 25 22:02:58 UTC 2019
On 26/4/19 2:04 am, dufault at hda.com wrote:
> In a given object file for "NOTYPE LOCAL” entries in a data segment with zero
> size that don’t start with ‘$’ could you append text based on the Num field for
> the rtems_rtl_obj symbol lookup in cpukit/libdl/rtl-sym.c?  Right now it’s a
> linear lookup on e.g. “.LC2” and stops at the first hit.  I haven’t checked that
> consumers of the lookup can generate the correct name, that is, always have the
> “Num” field value.
I would like to understand at the ELF level what is happening before considering
solutions. As I indicated in my other email if the symbols are local and in
different sections it could be something in the handling of the relocation
records for a section that needs to consider the symbol section used for local
symbols. If the symbols are in the same section and match then I would question
why `ld` is doing this.
> You’d wind up with mangled lookups such as:
>     22: 0000002c     0 NOTYPE  LOCAL  DEFAULT    3 .LC2.Num22
>     44: 0000013c     0 NOTYPE  LOCAL  DEFAULT    3 .LC2.Num44
>  This is from one of my relocatable files grepping for NOTYPE LOCAL.  I’ve
> verified large files also work.
This means the local symbol table now has different entries. How do you know
which one a relocation record is pointing too?
>  Num:    Value  Size Type    Bind   Vis      Ndx Name
>      0: 00000000     0 NOTYPE  LOCAL  DEFAULT  UND
>     14: 00000000     0 NOTYPE  LOCAL  DEFAULT    3 $d
>     15: 00000000     0 NOTYPE  LOCAL  DEFAULT    4 $d
>     17: 00000000     0 NOTYPE  LOCAL  DEFAULT    6 $d
>     18: 00000000  2048 NOTYPE  LOCAL  DEFAULT    6 env_entries
>     20: 00000800     4 NOTYPE  LOCAL  DEFAULT    6 env_initialized
>     21: 00000008     0 NOTYPE  LOCAL  DEFAULT    3 .LC1
>     23: 00000030     0 NOTYPE  LOCAL  DEFAULT    3 .LC3
>     25: 00000000     0 NOTYPE  LOCAL  DEFAULT    1 $t
>     28: 00000050     0 NOTYPE  LOCAL  DEFAULT    3 .LC4
>     29: 00000058     0 NOTYPE  LOCAL  DEFAULT    3 .LC5
>     30: 00000080     0 NOTYPE  LOCAL  DEFAULT    3 .LC6
>     32: 00000094     0 NOTYPE  LOCAL  DEFAULT    3 .LC7
>     33: 000000c4     0 NOTYPE  LOCAL  DEFAULT    3 .LC8
>     34: 000000cc     0 NOTYPE  LOCAL  DEFAULT    3 .LC9
>     35: 000000f4     0 NOTYPE  LOCAL  DEFAULT    3 .LC10
>     37: 00000130     0 NOTYPE  LOCAL  DEFAULT    3 $d
>     38: 0000000c     0 NOTYPE  LOCAL  DEFAULT    4 $d
>     40: 00000804     0 NOTYPE  LOCAL  DEFAULT    6 $d
>     41: 00000d14   520 NOTYPE  LOCAL  DEFAULT    6 putenv_trace_ptrs
>     42: 00000690     0 NOTYPE  LOCAL  DEFAULT    1 $t
>     43: 00000138     0 NOTYPE  LOCAL  DEFAULT    3 .LC1
>     45: 0000014c     0 NOTYPE  LOCAL  DEFAULT    3 .LC3
>     47: 00000164     0 NOTYPE  LOCAL  DEFAULT    3 .LC4
>> On Apr 25, 2019, at 07:56 , Peter Dufault <dufault at hda.com
>> <mailto:dufault at hda.com>> wrote:
>> I’m porting a large vxWorks application and I’m trying to download “ld -r”
>> files as you can on vxWorks using the run-time loader.  At least on ARM I
>> can’t get it to work, it uses the first local address it sees for all occurrences.
>> Example: Label .LC2 is used in two places, once for the “r” in an fopen() and
>> later for a format string.  In both cases the address used is 0x419f14, the
>> address of “r”.
>> First is the readelf output, then the disassembly, then debugging output from
>> the RTL.
>> FIRST OCCURRENCE OF .LC2 used as “r” in fopen()
>> readelf:
>> 00000020  0000152f R_ARM_THM_MOVW_ABS_NC  00000008   .LC1
>> 00000024  00001530 R_ARM_THM_MOVT_ABS     00000008   .LC1
>> 0000002a  0000162f R_ARM_THM_MOVW_ABS_NC  0000002c   .LC2
>> 0000002e  00001630 R_ARM_THM_MOVT_ABS     0000002c   .LC2
>> 00000034  0000450a R_ARM_THM_CALL         00000000   fopen
>> Disassemble:
>>    if ((fd = fopen(string, "r")) == (0)) {
>>  2a:   f240 0100   movw    r1, #0
>>  2e:   f2c0 0100   movt    r1, #0
>>  32:   6878        ldr r0, [r7, #4]
>>  34:   f7ff fffe   bl  0 <fopen>
>> RTL:
>> rtl: THM_MOVT_ABS/THM_MOVW_ABS_NC 0x341f2c0 @ 0x4196dc in bad
>> rtl: rel: sym:.LC2(22)=00419f14 type:47 off:0000002a
>> rtl: THM_MOVT_ABS/THM_MOVW_ABS_NC 0x7114f649 @ 0x4196e2 in bad
>> rtl: rel: sym:.LC2(22)=00419f14 type:48 off:0000002e
>> rtl: THM_MOVT_ABS/THM_MOVW_ABS_NC 0x141f2c0 @ 0x4196e6 in bad
>> rtl: rel: sym:fopen(69)=000d33c1 type:10 off:00000034
>> SECOND OCCURRENCE of .LC2 used for the printf format string:
>> readelf:
>> 000007a8  00002c2f R_ARM_THM_MOVW_ABS_NC  0000013c   .LC2
>> 000007ac  00002c30 R_ARM_THM_MOVT_ABS     0000013c   .LC2
>> 000007b0  0000330a R_ARM_THM_CALL         00000000   printf
>> Disassemble:
>> 7a6:   68f9        ldr r1, [r7, #12]
>> 7a8:   f240 0000   movw    r0, #0
>> 7ac:   f2c0 0000   movt    r0, #0
>> 7b0:   f7ff fffe   bl  0 <printf>
>> RTL:
>> rtl: rel: sym:.LC2(44)=00419f14 type:47 off:000007a8
>> rtl: THM_MOVT_ABS/THM_MOVW_ABS_NC 0x7014f649 @ 0x419e60 in
>> /opt/flatland/arch/arm-stubs-vxstubs/bin/sys-bad
>> rtl: rel: sym:.LC2(44)=00419f14 type:48 off:000007ac
>> rtl: THM_MOVT_ABS/THM_MOVW_ABS_NC 0x41f2c0 @ 0x419e64 in
>> rtl: rel: sym:printf(51)=000daac9 type:10 off:000007b0
>> Peter
>> Peter Dufault
>> HD Associates, Inc.      Software and System Engineering
>> This email is delivered through the public internet using protocols subject to
>> interception and tampering.
>> devel mailing list
>> devel at rtems.org <mailto:devel at rtems.org>
> Peter
> Peter Dufault
> devel mailing list
> devel at rtems.org
