rtems-libbsd build error
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Tue Apr 9 16:12:35 UTC 2019
Hi,
I have imported and ported the the drivers in 2 pairs(import and port) of
commits
for each one. Please have a look at this branch
https://github.com/thelunatic/rtems-libbsd/commits/tda19988
I have also tried running the media01.exe and have seen it running fine
without
throwing any exceptions.
I have used the fb.c and iicbus.c codes from the freebsd source. From what
I
understand, I think the next big steps would be to write an RTEMS
implementation layer for these portions of the code? And then a test in the
libbsd, like media01, to write to the /dev/fb0
Can you please help me chalk out a rough outline of the next set of
actions? :)
Thanks
On Tue, Apr 9, 2019 at 5:28 AM Chris Johns <chrisj at rtems.org> wrote:
> On 8/4/19 12:30 am, Vijay Kumar Banerjee wrote:
> > On Sun, Apr 7, 2019 at 6:24 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> >     Am 07.04.19 um 14:50 schrieb Vijay Kumar Banerjee:
> >     > On Sun, Apr 7, 2019 at 6:08 PM Christian Mauderer <
> >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> >     >     Am 07.04.19 um 14:35 schrieb Vijay Kumar Banerjee:
> >     >     > On Sun, Apr 7, 2019 at 5:37 PM Christian Mauderer
> >     >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> >     >     >     Am 07.04.19 um 13:08 schrieb Vijay Kumar Banerjee:
> >     I don't think that there are a lot of docs for how to test. Although
> I'm
> >     sure that there are some scripts to run a number of libbsd tests, I'm
> >     not sure where. Maybe in the RTEMS tester but I think that is mainly
> for
> >     the core tests?
> The documentation for testing can be found here ...
>  https://docs.rtems.org/branches/master/user/testing/index.html
> > so far I know, RTEMS Tester is only for core tests.
> The `rtems-test` command checks the for test start and end banners. I am
> not
> sure if libbsd supports the test banners. Maybe it could now with
> Sebastian's
> movement of the test support code into libtest.
> > I'll ask in the devel if there's some way to run libbsd test with the
> tester.
> There is the `rtems-run` command which has similar args to `rtems-test`.
> It does
> suffer from a limitation I have not fixed which is stdin is not passed
> through
> to the console of the target. I also think the command has a timeout
> running,
> but I am not sure about this one.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190409/9c812815/attachment-0002.html>
