rtems-libbsd build error
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Apr 12 14:26:50 UTC 2019
On Wed, Apr 10, 2019 at 12:50 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Am 09.04.19 um 18:12 schrieb Vijay Kumar Banerjee:
> > Hi,
> > I have imported and ported the the drivers in 2 pairs(import and port)
> > of commits
> > for each one. Please have a look at this branch
> > https://github.com/thelunatic/rtems-libbsd/commits/tda19988
> One detail: You have a commit named "tda19988.c: import from FreeBSD".
> Please remove the ".c".
> Noted.
> Maybe it would be a good idea to split of the I2C part and put it in
> front of the other two parts. You can develop and test that independent
> with a test that just accesses some of the I2C devices on the board via
> the FreeBSD API and the translation driver discussed below.
> This is a good idea, I'll import iicbus separately and add the other
two on top of it.
> > I have also tried running the media01.exe and have seen it running fine
> > without
> > throwing any exceptions.
> > I have used the fb.c and iicbus.c codes from the freebsd source. From
> > what I
> > understand, I think the next big steps would be to write an RTEMS
> > implementation layer for these portions of the code? And then a test in
> the
> > libbsd, like media01, to write to the /dev/fb0
> > Can you please help me chalk out a rough outline of the next set of
> > actions? :)
> As far as I can tell, there are two possible I2C buses here:
> 1. The one between the AM335x and the TDA19988.
> 2. The one directly on the HDMI connector (called HDMI_DSCL and
> HDMI_DSDA). I assume that's an I2C bus too.
> For 1. the RTEMS driver should be used. You'll need some code that
> translates the FreeBSD API to the one used in RTEMS. Basically that will
> just be a FreeBSD-I2C-driver.
> For 2: If that even is an independent I2C bus, you can use the driver
> provided by FreeBSD. I don't think that it is necessary to translate to
> the RTEMS API here.
> I had a look at the iic and iicbus codes in freebsd and the bbb-i2c.c
This looks very confusing to me. Are we looking for something like a
rtems-iicbus.c in the rtemsbsd that works like a wrapper to the bbb-i2c
code, and uses the freebsd api of DEVMETHODs?
I've not been able to figure out at one look, how to relate them and
get a wrapper like that. Any suggestions on how to approach this?
Can we not totally use the iicbus in the freebsd source?
> > Thanks
> > On Tue, Apr 9, 2019 at 5:28 AM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> > On 8/4/19 12:30 am, Vijay Kumar Banerjee wrote:
> > > On Sun, Apr 7, 2019 at 6:24 PM Christian Mauderer
> > <list at c-mauderer.de <mailto:list at c-mauderer.de>
> > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> > > Am 07.04.19 um 14:50 schrieb Vijay Kumar Banerjee:
> > > > On Sun, Apr 7, 2019 at 6:08 PM Christian Mauderer
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> > > > Am 07.04.19 um 14:35 schrieb Vijay Kumar Banerjee:
> > > > > On Sun, Apr 7, 2019 at 5:37 PM Christian Mauderer
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
> > > > > Am 07.04.19 um 13:08 schrieb Vijay Kumar Banerjee:
> > > I don't think that there are a lot of docs for how to test.
> > Although I'm
> > > sure that there are some scripts to run a number of libbsd
> > tests, I'm
> > > not sure where. Maybe in the RTEMS tester but I think that is
> > mainly for
> > > the core tests?
> > The documentation for testing can be found here ...
> > https://docs.rtems.org/branches/master/user/testing/index.html
> > > so far I know, RTEMS Tester is only for core tests.
> > The `rtems-test` command checks the for test start and end banners.
> > I am not
> > sure if libbsd supports the test banners. Maybe it could now with
> > Sebastian's
> > movement of the test support code into libtest.
> > > I'll ask in the devel if there's some way to run libbsd test with
> > the tester.
> > There is the `rtems-run` command which has similar args to
> > `rtems-test`. It does
> > suffer from a limitation I have not fixed which is stdin is not
> > passed through
> > to the console of the target. I also think the command has a timeout
> > running,
> > but I am not sure about this one.
> > Chris
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190412/93da1386/attachment-0002.html>
