Run Time linker and relocation of multiple local labels
dufault at hda.com dufault at hda.com
Thu Apr 25 16:04:51 UTC 2019
In a given object file for "NOTYPE LOCAL” entries in a data segment with zero size that don’t start with ‘$’ could you append text based on the Num field for the rtems_rtl_obj symbol lookup in cpukit/libdl/rtl-sym.c?  Right now it’s a linear lookup on e.g. “.LC2” and stops at the first hit.  I haven’t checked that consumers of the lookup can generate the correct name, that is, always have the “Num” field value.
You’d wind up with mangled lookups such as:
    22: 0000002c     0 NOTYPE  LOCAL  DEFAULT    3 .LC2.Num22
    44: 0000013c     0 NOTYPE  LOCAL  DEFAULT    3 .LC2.Num44
 This is from one of my relocatable files grepping for NOTYPE LOCAL.  I’ve verified large files also work.
 Num:    Value  Size Type    Bind   Vis      Ndx Name
     0: 00000000     0 NOTYPE  LOCAL  DEFAULT  UND
    14: 00000000     0 NOTYPE  LOCAL  DEFAULT    3 $d
    15: 00000000     0 NOTYPE  LOCAL  DEFAULT    4 $d
    17: 00000000     0 NOTYPE  LOCAL  DEFAULT    6 $d
    18: 00000000  2048 NOTYPE  LOCAL  DEFAULT    6 env_entries
    20: 00000800     4 NOTYPE  LOCAL  DEFAULT    6 env_initialized
    21: 00000008     0 NOTYPE  LOCAL  DEFAULT    3 .LC1
    23: 00000030     0 NOTYPE  LOCAL  DEFAULT    3 .LC3
    25: 00000000     0 NOTYPE  LOCAL  DEFAULT    1 $t
    28: 00000050     0 NOTYPE  LOCAL  DEFAULT    3 .LC4
    29: 00000058     0 NOTYPE  LOCAL  DEFAULT    3 .LC5
    30: 00000080     0 NOTYPE  LOCAL  DEFAULT    3 .LC6
    32: 00000094     0 NOTYPE  LOCAL  DEFAULT    3 .LC7
    33: 000000c4     0 NOTYPE  LOCAL  DEFAULT    3 .LC8
    34: 000000cc     0 NOTYPE  LOCAL  DEFAULT    3 .LC9
    35: 000000f4     0 NOTYPE  LOCAL  DEFAULT    3 .LC10
    37: 00000130     0 NOTYPE  LOCAL  DEFAULT    3 $d
    38: 0000000c     0 NOTYPE  LOCAL  DEFAULT    4 $d
    40: 00000804     0 NOTYPE  LOCAL  DEFAULT    6 $d
    41: 00000d14   520 NOTYPE  LOCAL  DEFAULT    6 putenv_trace_ptrs
    42: 00000690     0 NOTYPE  LOCAL  DEFAULT    1 $t
    43: 00000138     0 NOTYPE  LOCAL  DEFAULT    3 .LC1
    45: 0000014c     0 NOTYPE  LOCAL  DEFAULT    3 .LC3
    47: 00000164     0 NOTYPE  LOCAL  DEFAULT    3 .LC4
> On Apr 25, 2019, at 07:56 , Peter Dufault <dufault at hda.com> wrote:
> I’m porting a large vxWorks application and I’m trying to download “ld -r” files as you can on vxWorks using the run-time loader.  At least on ARM I can’t get it to work, it uses the first local address it sees for all occurrences.
> Example: Label .LC2 is used in two places, once for the “r” in an fopen() and later for a format string.  In both cases the address used is 0x419f14, the address of “r”.
> First is the readelf output, then the disassembly, then debugging output from the RTL.
> FIRST OCCURRENCE OF .LC2 used as “r” in fopen()
> readelf:
> 00000020  0000152f R_ARM_THM_MOVW_ABS_NC  00000008   .LC1
> 00000024  00001530 R_ARM_THM_MOVT_ABS     00000008   .LC1
> 0000002a  0000162f R_ARM_THM_MOVW_ABS_NC  0000002c   .LC2
> 0000002e  00001630 R_ARM_THM_MOVT_ABS     0000002c   .LC2
> 00000034  0000450a R_ARM_THM_CALL         00000000   fopen
> Disassemble:
>    if ((fd = fopen(string, "r")) == (0)) {
>  2a:   f240 0100   movw    r1, #0
>  2e:   f2c0 0100   movt    r1, #0
>  32:   6878        ldr r0, [r7, #4]
>  34:   f7ff fffe   bl  0 <fopen>
> RTL:
> rtl: THM_MOVT_ABS/THM_MOVW_ABS_NC 0x341f2c0 @ 0x4196dc in bad
> rtl: rel: sym:.LC2(22)=00419f14 type:47 off:0000002a
> rtl: THM_MOVT_ABS/THM_MOVW_ABS_NC 0x7114f649 @ 0x4196e2 in bad
> rtl: rel: sym:.LC2(22)=00419f14 type:48 off:0000002e
> rtl: THM_MOVT_ABS/THM_MOVW_ABS_NC 0x141f2c0 @ 0x4196e6 in bad
> rtl: rel: sym:fopen(69)=000d33c1 type:10 off:00000034
> SECOND OCCURRENCE of .LC2 used for the printf format string:
> readelf:
> 000007a8  00002c2f R_ARM_THM_MOVW_ABS_NC  0000013c   .LC2
> 000007ac  00002c30 R_ARM_THM_MOVT_ABS     0000013c   .LC2
> 000007b0  0000330a R_ARM_THM_CALL         00000000   printf
> Disassemble:
> 7a6:   68f9        ldr r1, [r7, #12]
> 7a8:   f240 0000   movw    r0, #0
> 7ac:   f2c0 0000   movt    r0, #0
> 7b0:   f7ff fffe   bl  0 <printf>
> RTL:
> rtl: rel: sym:.LC2(44)=00419f14 type:47 off:000007a8
> rtl: THM_MOVT_ABS/THM_MOVW_ABS_NC 0x7014f649 @ 0x419e60 in /opt/flatland/arch/arm-stubs-vxstubs/bin/sys-bad
> rtl: rel: sym:.LC2(44)=00419f14 type:48 off:000007ac
> rtl: THM_MOVT_ABS/THM_MOVW_ABS_NC 0x41f2c0 @ 0x419e64 in /opt/flatland/arch/arm-stubs-vxstubs/bin/sys-bad
> rtl: rel: sym:printf(51)=000daac9 type:10 off:000007b0
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
> This email is delivered through the public internet using protocols subject to interception and tampering.
> devel mailing list
> devel at rtems.org
Peter
Peter Dufault
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190425/93d8d88d/attachment-0002.html>
