Run time linker allocator locking hangs RTEMS
    Chris Johns
    chrisj at rtems.org
    Sun Apr 28 12:34:19 UTC 2019
> On 28 Apr 2019, at 7:18 pm, dufault at hda.com wrote:
> I think you might need to do two passes if that’s straight-forward.  Then you can count, lock, allocate, unlock, read.
Or grouping the allocations together then the loading however doing this has tripped a bug in dl09 on the PowerPC I am looking into. Something with a symbol look up for reloc rec 33 in the second object file loaded. The other arches are ok.
