RISCV BSP
Fri Aug 2 08:03:52 UTC 2019
On 02/08/2019 09:50, Vaibhav Gupta wrote:
> Hello,
> I was about to test the testsuite code, need to confirm
> on which RISCV BSP we are going to work?
> For example, for ARM I was asked for xilinx-zynq
> So is there any specific one for riscv too, or should I build any of it?
While you work on this, please review the documentation.
https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html
Feel free to send documentation patches. There is support for some
RISC-V BSPs in the RTEMS Tester:
./tester/rtems/testing/bsps/griscv-sis.ini
./tester/rtems/testing/bsps/griscv.ini
./tester/rtems/testing/bsps/griscv-sis-cov.ini
./tester/rtems/testing/bsps/rv32imac_spike.ini
./tester/rtems/testing/bsps/rv64imafdc_spike.ini
./tester/rtems/testing/bsps/rv64imafd_spike.ini
./tester/rtems/testing/bsps/rv64imafd_medany.ini
./tester/rtems/testing/bsps/rv64imafd_medany_spike.ini
./tester/rtems/testing/bsps/rv32imafc_spike.ini
./tester/rtems/testing/bsps/rv32imafd_spike.ini
./tester/rtems/testing/bsps/rv64imac_medany_spike.ini
./tester/rtems/testing/bsps/rv32im_spike.ini
./tester/rtems/testing/bsps/rv64imac_spike.ini
./tester/rtems/testing/bsps/rv32imafdc_spike.ini
./tester/rtems/testing/bsps/rv32iac_spike.ini
./tester/rtems/testing/bsps/rv64imafdc_medany_spike.ini
./tester/rtems/testing/bsps/rv32i_spike.ini
I would test on a 32-bit and 64-bit variant. Also with hardware FP and
without.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
