GSoC Project | Basic Support for Trace Compass
Ravindra Kumar Meena
rmeena840 at gmail.com
Fri Aug 2 16:09:55 UTC 2019
> I just checked out the original version with some minor edits. This output
> should be enough to figure out how it works.
> You have to extend the switch case in print_item() to check for
> RTEMS_RECORD_THREAD_ID and RTEMS_RECORD_THREAD_NAME. The thread name events
> contain the bytes in the data field. For the encoding see:
Thanks for the clarification.
I tried to check if we are getting RTEMS_RECORD_THREAD_ID in prtin_item()
or not.
I did following thing in print_item() but nothing is shown in the console
output:
if(item->event == RTEMS_RECORD_THREAD_ID){
printf("this thing is present\n");
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190802/1ce73bde/attachment.html>
