[PATCH v2 5/8] fbd: Import from FreeBSD
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri Aug 2 21:00:07 UTC 2019
 freebsd/sys/dev/fb/fb.c                   | 762 ++++++++++++++++++++++
 freebsd/sys/dev/fb/fbd.c                  | 372 +++++++++++
 freebsd/sys/dev/fb/fbreg.h                | 345 ++++++++++
 freebsd/sys/dev/vt/colors/vt_termcolors.h |  63 ++
 freebsd/sys/dev/vt/hw/fb/vt_fb.h          |  54 ++
 freebsd/sys/dev/vt/vt.h                   | 474 ++++++++++++++
 freebsd/sys/teken/teken.h                 | 221 +++++++
 7 files changed, 2291 insertions(+)
 create mode 100644 freebsd/sys/dev/fb/fb.c
 create mode 100644 freebsd/sys/dev/fb/fbd.c
 create mode 100644 freebsd/sys/dev/fb/fbreg.h
 create mode 100644 freebsd/sys/dev/vt/colors/vt_termcolors.h
 create mode 100644 freebsd/sys/dev/vt/hw/fb/vt_fb.h
 create mode 100644 freebsd/sys/dev/vt/vt.h
 create mode 100644 freebsd/sys/teken/teken.h
diff --git a/freebsd/sys/dev/fb/fb.c b/freebsd/sys/dev/fb/fb.c
new file mode 100644
index 00000000..a3263c91
--- /dev/null
+++ b/freebsd/sys/dev/fb/fb.c
@@ -0,0 +1,762 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 1999 Kazutaka YOKOTA <yokota at zodiac.mech.utsunomiya-u.ac.jp>
+ * All rights reserved.
+ * are met:
+ *    notice, this list of conditions and the following disclaimer as
+ *    the first lines of this file unmodified.
+ * 3. The name of the author may not be used to endorse or promote products
+ *    derived from this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/local/opt_fb.h>
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/conf.h>
+#include <sys/bus.h>
+#include <sys/kernel.h>
+#include <sys/malloc.h>
+#include <sys/module.h>
+#include <sys/uio.h>
+#include <sys/fbio.h>
+#include <sys/linker_set.h>
+#include <vm/vm.h>
+#include <vm/pmap.h>
+#include <dev/fb/fbreg.h>
+SET_DECLARE(videodriver_set, const video_driver_t);
+/* local arrays */
+ * We need at least one entry each in order to initialize a video card
+ * for the kernel console.  The arrays will be increased dynamically
+ * when necessary.
+static int		vid_malloc;
+static int		adapters = 1;
+static video_adapter_t	*adp_ini;
+static video_adapter_t	**adapter = &adp_ini;
+static video_switch_t	*vidsw_ini;
+       video_switch_t	**vidsw = &vidsw_ini;
+#ifdef FB_INSTALL_CDEV
+static struct cdevsw	*vidcdevsw_ini;
+static struct cdevsw	**vidcdevsw = &vidcdevsw_ini;
+#endif
+#define ARRAY_DELTA	4
+static int
+vid_realloc_array(void)
+	video_adapter_t **new_adp;
+	video_switch_t **new_vidsw;
+	struct cdevsw **new_cdevsw;
+#endif
+	int newsize;
+	int s;
+	if (!vid_malloc)
+		return ENOMEM;
+	s = spltty();
+	newsize = rounddown(adapters + ARRAY_DELTA, ARRAY_DELTA);
+	new_adp = malloc(sizeof(*new_adp)*newsize, M_DEVBUF, M_WAITOK | M_ZERO);
+	new_vidsw = malloc(sizeof(*new_vidsw)*newsize, M_DEVBUF,
+	    M_WAITOK | M_ZERO);
+	new_cdevsw = malloc(sizeof(*new_cdevsw)*newsize, M_DEVBUF,
+#endif
+	bcopy(adapter, new_adp, sizeof(*adapter)*adapters);
+	bcopy(vidsw, new_vidsw, sizeof(*vidsw)*adapters);
+	bcopy(vidcdevsw, new_cdevsw, sizeof(*vidcdevsw)*adapters);
+#endif
+	if (adapters > 1) {
+		free(adapter, M_DEVBUF);
+		free(vidsw, M_DEVBUF);
+		free(vidcdevsw, M_DEVBUF);
+#endif
+	adapter = new_adp;
+	vidsw = new_vidsw;
+	vidcdevsw = new_cdevsw;
+#endif
+	adapters = newsize;
+	splx(s);
+	if (bootverbose)
+		printf("fb: new array size %d\n", adapters);
+	return 0;
+static void
+vid_malloc_init(void *arg)
+	vid_malloc = TRUE;
+SYSINIT(vid_mem, SI_SUB_KMEM, SI_ORDER_ANY, vid_malloc_init, NULL);
+ * Low-level frame buffer driver functions
+ * frame buffer subdrivers, such as the VGA driver, call these functions
+ * to initialize the video_adapter structure and register it to the virtual
+ * frame buffer driver `fb'.
+/* initialize the video_adapter_t structure */
+void
+vid_init_struct(video_adapter_t *adp, char *name, int type, int unit)
+	adp->va_flags = 0;
+	adp->va_name = name;
+	adp->va_type = type;
+	adp->va_unit = unit;
+/* Register a video adapter */
+int
+vid_register(video_adapter_t *adp)
+	const video_driver_t **list;
+	const video_driver_t *p;
+	int index;
+	for (index = 0; index < adapters; ++index) {
+		if (adapter[index] == NULL)
+			break;
+	if (index >= adapters) {
+		if (vid_realloc_array())
+			return -1;
+	adp->va_index = index;
+	adp->va_token = NULL;
+	SET_FOREACH(list, videodriver_set) {
+		p = *list;
+		if (strcmp(p->name, adp->va_name) == 0) {
+			adapter[index] = adp;
+			vidsw[index] = p->vidsw;
+			return index;
+	return -1;
+int
+vid_unregister(video_adapter_t *adp)
+	if ((adp->va_index < 0) || (adp->va_index >= adapters))
+		return ENOENT;
+	if (adapter[adp->va_index] != adp)
+		return ENOENT;
+	adapter[adp->va_index] = NULL;
+	vidsw[adp->va_index] = NULL;
+	return 0;
+/* Get video I/O function table */
+video_switch_t
+*vid_get_switch(char *name)
+		p = *list;
+		if (strcmp(p->name, name) == 0)
+			return p->vidsw;
+	return NULL;
+ * Video card client functions
+ * Video card clients, such as the console driver `syscons' and the frame
+ * buffer cdev driver, use these functions to claim and release a card for
+ * exclusive use.
+/* find the video card specified by a driver name and a unit number */
+int
+vid_find_adapter(char *driver, int unit)
+	int i;
+	for (i = 0; i < adapters; ++i) {
+		if (adapter[i] == NULL)
+			continue;
+		if (strcmp("*", driver) && strcmp(adapter[i]->va_name, driver))
+			continue;
+		if ((unit != -1) && (adapter[i]->va_unit != unit))
+			continue;
+		return i;
+	return -1;
+/* allocate a video card */
+int
+vid_allocate(char *driver, int unit, void *id)
+	int index;
+	int s;
+	s = spltty();
+	index = vid_find_adapter(driver, unit);
+	if (index >= 0) {
+		if (adapter[index]->va_token) {
+			splx(s);
+			return -1;
+		adapter[index]->va_token = id;
+	splx(s);
+	return index;
+int
+vid_release(video_adapter_t *adp, void *id)
+	int error;
+	int s;
+	s = spltty();
+	if (adp->va_token == NULL) {
+		error = EINVAL;
+	} else if (adp->va_token != id) {
+		error = EPERM;
+	} else {
+		error = 0;
+	splx(s);
+	return error;
+/* Get a video adapter structure */
+video_adapter_t
+*vid_get_adapter(int index)
+	if ((index < 0) || (index >= adapters))
+		return NULL;
+	return adapter[index];
+/* Configure drivers: this is a backdoor for the console driver XXX */
+int
+vid_configure(int flags)
+		p = *list;
+		if (p->configure != NULL)
+			(*p->configure)(flags);
+	return 0;
+ * Virtual frame buffer cdev driver functions
+ * The virtual frame buffer driver dispatches driver functions to
+ * appropriate subdrivers.
+#define FB_DRIVER_NAME	"fb"
+#if 0 /* experimental */
+static devclass_t	fb_devclass;
+static int		fbprobe(device_t dev);
+static int		fbattach(device_t dev);
+static device_method_t fb_methods[] = {
+	DEVMETHOD(device_probe,		fbprobe),
+	DEVMETHOD(device_attach,	fbattach),
+	DEVMETHOD_END
+static driver_t fb_driver = {
+	FB_DRIVER_NAME,
+	fb_methods,
+	0,
+static int
+fbprobe(device_t dev)
+	int unit;
+	unit = device_get_unit(dev);
+	if (unit >= adapters)
+		return ENXIO;
+	if (adapter[unit] == NULL)
+		return ENXIO;
+	device_set_desc(dev, "generic frame buffer");
+	return 0;
+static int
+fbattach(device_t dev)
+	printf("fbattach: about to attach children\n");
+	bus_generic_attach(dev);
+	return 0;
+#endif
+#define FB_UNIT(dev)	dev2unit(dev)
+#define FB_MKMINOR(unit) (u)
+static d_open_t		fbopen;
+static d_close_t	fbclose;
+static d_read_t		fbread;
+static d_write_t	fbwrite;
+static d_ioctl_t	fbioctl;
+static d_mmap_t		fbmmap;
+static struct cdevsw fb_cdevsw = {
+	.d_version =	D_VERSION,
+	.d_flags =	D_NEEDGIANT,
+	.d_open =	fbopen,
+	.d_close =	fbclose,
+	.d_read =	fbread,
+	.d_write =	fbwrite,
+	.d_ioctl =	fbioctl,
+	.d_mmap =	fbmmap,
+	.d_name =	FB_DRIVER_NAME,
+#endif
+static int
+fb_modevent(module_t mod, int type, void *data)
+	switch (type) {
+	case MOD_LOAD:
+		break;
+	case MOD_UNLOAD:
+		printf("fb module unload - not possible for this module type\n");
+		return EINVAL;
+	default:
+		return EOPNOTSUPP;
+	return 0;
+static moduledata_t fb_mod = {
+	"fb",
+	fb_modevent,
+	NULL
+DECLARE_MODULE(fb, fb_mod, SI_SUB_PSEUDO, SI_ORDER_ANY);
+int
+fb_attach(int unit, video_adapter_t *adp, struct cdevsw *cdevsw)
+	int s;
+	if (adp->va_index >= adapters)
+		return EINVAL;
+		return EINVAL;
+	s = spltty();
+	adp->va_minor = unit;
+	vidcdevsw[adp->va_index] = cdevsw;
+	splx(s);
+	printf("fb%d at %s%d\n", adp->va_index, adp->va_name, adp->va_unit);
+	return 0;
+int
+fb_detach(int unit, video_adapter_t *adp, struct cdevsw *cdevsw)
+	int s;
+		return EINVAL;
+		return EINVAL;
+	if (vidcdevsw[adp->va_index] != cdevsw)
+		return EINVAL;
+	s = spltty();
+	vidcdevsw[adp->va_index] = NULL;
+	splx(s);
+	return 0;
+ * Generic frame buffer cdev driver functions
+ * Frame buffer subdrivers may call these functions to implement common
+ * driver functions.
+int genfbopen(genfb_softc_t *sc, video_adapter_t *adp, int flag, int mode,
+	      struct thread *td)
+	int s;
+	s = spltty();
+	if (!(sc->gfb_flags & FB_OPEN))
+		sc->gfb_flags |= FB_OPEN;
+	splx(s);
+	return 0;
+int genfbclose(genfb_softc_t *sc, video_adapter_t *adp, int flag, int mode,
+	int s;
+	s = spltty();
+	sc->gfb_flags &= ~FB_OPEN;
+	splx(s);
+	return 0;
+int genfbread(genfb_softc_t *sc, video_adapter_t *adp, struct uio *uio,
+	      int flag)
+	int size;
+	int offset;
+	int error;
+	int len;
+	error = 0;
+	size = adp->va_buffer_size/adp->va_info.vi_planes;
+	while (uio->uio_resid > 0) {
+		if (uio->uio_offset >= size)
+			break;
+		offset = uio->uio_offset%adp->va_window_size;
+		len = imin(uio->uio_resid, size - uio->uio_offset);
+		len = imin(len, adp->va_window_size - offset);
+		if (len <= 0)
+			break;
+		vidd_set_win_org(adp, uio->uio_offset);
+		error = uiomove((caddr_t)(adp->va_window + offset), len, uio);
+		if (error)
+			break;
+	return error;
+int genfbwrite(genfb_softc_t *sc, video_adapter_t *adp, struct uio *uio,
+	       int flag)
+	return ENODEV;
+int genfbioctl(genfb_softc_t *sc, video_adapter_t *adp, u_long cmd,
+	       caddr_t arg, int flag, struct thread *td)
+	int error;
+	if (adp == NULL)	/* XXX */
+		return ENXIO;
+	error = vidd_ioctl(adp, cmd, arg);
+	if (error == ENOIOCTL)
+		error = ENODEV;
+	return error;
+int genfbmmap(genfb_softc_t *sc, video_adapter_t *adp, vm_ooffset_t offset,
+	      vm_offset_t *paddr, int prot, vm_memattr_t *memattr)
+	return vidd_mmap(adp, offset, paddr, prot, memattr);
+#endif /* FB_INSTALL_CDEV */
+static char
+*adapter_name(int type)
+    static struct {
+	int type;
+	char *name;
+    } names[] = {
+	{ KD_MONO,	"MDA" },
+	{ KD_HERCULES,	"Hercules" },
+	{ KD_CGA,	"CGA" },
+	{ KD_EGA,	"EGA" },
+	{ KD_VGA,	"VGA" },
+	{ KD_TGA,	"TGA" },
+	{ -1,		"Unknown" },
+    int i;
+    for (i = 0; names[i].type != -1; ++i)
+	if (names[i].type == type)
+	    break;
+    return names[i].name;
+ * Generic low-level frame buffer functions
+ * The low-level functions in the frame buffer subdriver may use these
+ * functions.
+void
+fb_dump_adp_info(char *driver, video_adapter_t *adp, int level)
+    if (level <= 0)
+	return;
+    printf("%s%d: %s%d, %s, type:%s (%d), flags:0x%x\n",
+	   FB_DRIVER_NAME, adp->va_index, driver, adp->va_unit, adp->va_name,
+	   adapter_name(adp->va_type), adp->va_type, adp->va_flags);
+    printf("%s%d: port:0x%lx-0x%lx, crtc:0x%lx, mem:0x%lx 0x%x\n",
+	   FB_DRIVER_NAME, adp->va_index, (u_long)adp->va_io_base,
+	   (u_long)adp->va_io_base + adp->va_io_size - 1,
+	   (u_long)adp->va_crtc_addr, (u_long)adp->va_mem_base,
+	   adp->va_mem_size);
+    printf("%s%d: init mode:%d, bios mode:%d, current mode:%d\n",
+	   adp->va_initial_mode, adp->va_initial_bios_mode, adp->va_mode);
+    printf("%s%d: window:%p size:%dk gran:%dk, buf:%p size:%dk\n",
+	   (void *)adp->va_window, (int)adp->va_window_size/1024,
+	   (int)adp->va_window_gran/1024, (void *)adp->va_buffer,
+	   (int)adp->va_buffer_size/1024);
+void
+fb_dump_mode_info(char *driver, video_adapter_t *adp, video_info_t *info,
+		  int level)
+    if (level <= 0)
+	return;
+    printf("%s%d: %s, mode:%d, flags:0x%x ",
+	   driver, adp->va_unit, adp->va_name, info->vi_mode, info->vi_flags);
+    if (info->vi_flags & V_INFO_GRAPHICS)
+	printf("G %dx%dx%d, %d plane(s), font:%dx%d, ",
+	       info->vi_width, info->vi_height,
+	       info->vi_depth, info->vi_planes,
+	       info->vi_cwidth, info->vi_cheight);
+    else
+	printf("T %dx%d, font:%dx%d, ",
+    printf("win:0x%lx\n", (u_long)info->vi_window);
+int
+fb_type(int adp_type)
+	static struct {
+		int	fb_type;
+		int	va_type;
+	} types[] = {
+		{ FBTYPE_MDA,		KD_MONO },
+		{ FBTYPE_HERCULES,	KD_HERCULES },
+		{ FBTYPE_CGA,		KD_CGA },
+		{ FBTYPE_EGA,		KD_EGA },
+		{ FBTYPE_VGA,		KD_VGA },
+		{ FBTYPE_TGA,		KD_TGA },
+	int i;
+	for (i = 0; i < nitems(types); ++i) {
+		if (types[i].va_type == adp_type)
+			return types[i].fb_type;
+	return -1;
+int
+fb_commonioctl(video_adapter_t *adp, u_long cmd, caddr_t arg)
+	int error;
+	int s;
+	/* assert(adp != NULL) */
+	error = 0;
+	s = spltty();
+	switch (cmd) {
+	case FBIO_ADAPTER:	/* get video adapter index */
+		*(int *)arg = adp->va_index;
+		break;
+	case FBIO_ADPTYPE:	/* get video adapter type */
+		*(int *)arg = adp->va_type;
+		break;
+	case FBIO_ADPINFO:	/* get video adapter info */
+	        ((video_adapter_info_t *)arg)->va_index = adp->va_index;
+		((video_adapter_info_t *)arg)->va_type = adp->va_type;
+		bcopy(adp->va_name, ((video_adapter_info_t *)arg)->va_name,
+		      imin(strlen(adp->va_name) + 1,
+			   sizeof(((video_adapter_info_t *)arg)->va_name)));
+		((video_adapter_info_t *)arg)->va_unit = adp->va_unit;
+		((video_adapter_info_t *)arg)->va_flags = adp->va_flags;
+		((video_adapter_info_t *)arg)->va_io_base = adp->va_io_base;
+		((video_adapter_info_t *)arg)->va_io_size = adp->va_io_size;
+		((video_adapter_info_t *)arg)->va_crtc_addr = adp->va_crtc_addr;
+		((video_adapter_info_t *)arg)->va_mem_base = adp->va_mem_base;
+		((video_adapter_info_t *)arg)->va_mem_size = adp->va_mem_size;
+		((video_adapter_info_t *)arg)->va_window
+#if defined(__amd64__) || defined(__i386__)
+			= vtophys(adp->va_window);
+#else
+			= adp->va_window;
+#endif
+		((video_adapter_info_t *)arg)->va_window_size
+			= adp->va_window_size;
+		((video_adapter_info_t *)arg)->va_window_gran
+			= adp->va_window_gran;
+		((video_adapter_info_t *)arg)->va_window_orig
+			= adp->va_window_orig;
+		((video_adapter_info_t *)arg)->va_unused0
+			= adp->va_buffer != 0 ? vtophys(adp->va_buffer) : 0;
+#else
+			= adp->va_buffer;
+#endif
+		((video_adapter_info_t *)arg)->va_buffer_size
+			= adp->va_buffer_size;
+		((video_adapter_info_t *)arg)->va_mode = adp->va_mode;
+		((video_adapter_info_t *)arg)->va_initial_mode
+			= adp->va_initial_mode;
+		((video_adapter_info_t *)arg)->va_initial_bios_mode
+			= adp->va_initial_bios_mode;
+		((video_adapter_info_t *)arg)->va_line_width
+			= adp->va_line_width;
+		((video_adapter_info_t *)arg)->va_disp_start.x
+			= adp->va_disp_start.x;
+		((video_adapter_info_t *)arg)->va_disp_start.y
+			= adp->va_disp_start.y;
+		break;
+	case FBIO_MODEINFO:	/* get mode information */
+		error = vidd_get_info(adp,
+		    ((video_info_t *)arg)->vi_mode,
+		    (video_info_t *)arg);
+		if (error)
+			error = ENODEV;
+		break;
+	case FBIO_FINDMODE:	/* find a matching video mode */
+		error = vidd_query_mode(adp, (video_info_t *)arg);
+		break;
+	case FBIO_GETMODE:	/* get video mode */
+		*(int *)arg = adp->va_mode;
+		break;
+	case FBIO_SETMODE:	/* set video mode */
+		error = vidd_set_mode(adp, *(int *)arg);
+		if (error)
+			error = ENODEV;	/* EINVAL? */
+		break;
+	case FBIO_GETWINORG:	/* get frame buffer window origin */
+		*(u_int *)arg = adp->va_window_orig;
+		break;
+	case FBIO_GETDISPSTART:	/* get display start address */
+		((video_display_start_t *)arg)->x = adp->va_disp_start.x;
+		((video_display_start_t *)arg)->y = adp->va_disp_start.y;
+		break;
+	case FBIO_GETLINEWIDTH:	/* get scan line width in bytes */
+		*(u_int *)arg = adp->va_line_width;
+		break;
+	case FBIO_BLANK:	/* blank display */
+		error = vidd_blank_display(adp, *(int *)arg);
+		break;
+	case FBIO_GETPALETTE:	/* get color palette */
+	case FBIO_SETPALETTE:	/* set color palette */
+		/* XXX */
+	case FBIOPUTCMAP:
+	case FBIOGETCMAP:
+	case FBIOPUTCMAPI:
+	case FBIOGETCMAPI:
+		/* XXX */
+	case FBIO_SETWINORG:	/* set frame buffer window origin */
+	case FBIO_SETDISPSTART:	/* set display start address */
+	case FBIO_SETLINEWIDTH:	/* set scan line width in pixel */
+	case FBIOGTYPE:
+	case FBIOGATTR:
+	case FBIOSVIDEO:
+	case FBIOGVIDEO:
+	case FBIOVERTICAL:
+	case FBIOSCURSOR:
+	case FBIOGCURSOR:
+	case FBIOSCURPOS:
+	case FBIOGCURPOS:
+	case FBIOGCURMAX:
+	case FBIOMONINFO:
+	case FBIOGXINFO:
+	default:
+		error = ENODEV;
+		break;
+	splx(s);
+	return error;
diff --git a/freebsd/sys/dev/fb/fbd.c b/freebsd/sys/dev/fb/fbd.c
index 00000000..60ce4bc3
--- /dev/null
+++ b/freebsd/sys/dev/fb/fbd.c
@@ -0,0 +1,372 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2013 The FreeBSD Foundation
+ * This software was developed by Aleksandr Rybalko under sponsorship from the
+ * FreeBSD Foundation.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+/* Generic framebuffer */
+/* TODO unlink from VT(9) */
+/* TODO done normal /dev/fb methods */
+#include <sys/queue.h>
+#include <machine/bus.h>
+#include <dev/vt/vt.h>
+#include <dev/vt/hw/fb/vt_fb.h>
+#include <vm/vm.h>
+#include <rtems/bsd/local/fb_if.h>
+LIST_HEAD(fb_list_head_t, fb_list_entry) fb_list_head =
+    LIST_HEAD_INITIALIZER(fb_list_head);
+struct fb_list_entry {
+	struct fb_info	*fb_info;
+	struct cdev	*fb_si;
+	LIST_ENTRY(fb_list_entry) fb_list;
+struct fbd_softc {
+	device_t	sc_dev;
+	struct fb_info	*sc_info;
+static void fbd_evh_init(void *);
+/* SI_ORDER_SECOND, just after EVENTHANDLERs initialized. */
+SYSINIT(fbd_evh_init, SI_SUB_CONFIGURE, SI_ORDER_SECOND, fbd_evh_init, NULL);
+static d_open_t		fb_open;
+static d_close_t	fb_close;
+static d_read_t		fb_read;
+static d_write_t	fb_write;
+static d_ioctl_t	fb_ioctl;
+static d_mmap_t		fb_mmap;
+	.d_open =	fb_open,
+	.d_close =	fb_close,
+	.d_read =	fb_read,
+	.d_write =	fb_write,
+	.d_ioctl =	fb_ioctl,
+	.d_mmap =	fb_mmap,
+	.d_name =	"fb",
+static int framebuffer_dev_unit = 0;
+static int
+fb_open(struct cdev *dev, int oflags, int devtype, struct thread *td)
+	return (0);
+static int
+fb_close(struct cdev *dev, int fflag, int devtype, struct thread *td)
+	return (0);
+static int
+fb_ioctl(struct cdev *dev, u_long cmd, caddr_t data, int fflag,
+	struct fb_info *info;
+	int error;
+	error = 0;
+	info = dev->si_drv1;
+	switch (cmd) {
+	case FBIOGTYPE:
+		bcopy(info, (struct fbtype *)data, sizeof(struct fbtype));
+		break;
+		*(u_int *)data = 0;
+		break;
+		((video_display_start_t *)data)->x = 0;
+		((video_display_start_t *)data)->y = 0;
+		break;
+		*(u_int *)data = info->fb_stride;
+		break;
+		if (info->setblankmode != NULL)
+			error = info->setblankmode(info->fb_priv, *(int *)data);
+		break;
+	default:
+		error = ENOIOCTL;
+		break;
+	return (error);
+static int
+fb_read(struct cdev *dev, struct uio *uio, int ioflag)
+	return (0); /* XXX nothing to read, yet */
+static int
+fb_write(struct cdev *dev, struct uio *uio, int ioflag)
+	return (0); /* XXX nothing written */
+static int
+fb_mmap(struct cdev *dev, vm_ooffset_t offset, vm_paddr_t *paddr, int nprot,
+    vm_memattr_t *memattr)
+	if (info->fb_flags & FB_FLAG_NOMMAP)
+		return (ENODEV);
+	if (offset >= 0 && offset < info->fb_size) {
+		if (info->fb_pbase == 0)
+			*paddr = vtophys((uint8_t *)info->fb_vbase + offset);
+		else
+			*paddr = info->fb_pbase + offset;
+		if (info->fb_flags & FB_FLAG_MEMATTR)
+			*memattr = info->fb_memattr;
+		return (0);
+	return (EINVAL);
+static int
+fb_init(struct fb_list_entry *entry, int unit)
+	info = entry->fb_info;
+	entry->fb_si = make_dev(&fb_cdevsw, unit, UID_ROOT, GID_WHEEL,
+	    0600, "fb%d", unit);
+	entry->fb_si->si_drv1 = info;
+	info->fb_cdev = entry->fb_si;
+	return (0);
+int
+fbd_list()
+	struct fb_list_entry *entry;
+	if (LIST_EMPTY(&fb_list_head))
+		return (ENOENT);
+	LIST_FOREACH(entry, &fb_list_head, fb_list) {
+		printf("FB %s @%p\n", entry->fb_info->fb_name,
+		    (void *)entry->fb_info->fb_pbase);
+	return (0);
+static struct fb_list_entry *
+fbd_find(struct fb_info* info)
+	struct fb_list_entry *entry, *tmp;
+	LIST_FOREACH_SAFE(entry, &fb_list_head, fb_list, tmp) {
+		if (entry->fb_info == info) {
+			return (entry);
+	return (NULL);
+int
+fbd_register(struct fb_info* info)
+	int err, first;
+	first = 0;
+		first++;
+	entry = fbd_find(info);
+	if (entry != NULL) {
+		/* XXX Update framebuffer params */
+		return (0);
+	entry = malloc(sizeof(struct fb_list_entry), M_DEVBUF, M_WAITOK|M_ZERO);
+	entry->fb_info = info;
+	LIST_INSERT_HEAD(&fb_list_head, entry, fb_list);
+	err = fb_init(entry, framebuffer_dev_unit++);
+	if (err)
+		return (err);
+	if (first) {
+		err = vt_fb_attach(info);
+		if (err)
+			return (err);
+	return (0);
+int
+fbd_unregister(struct fb_info* info)
+			LIST_REMOVE(entry, fb_list);
+				vt_fb_detach(info);
+			free(entry, M_DEVBUF);
+			return (0);
+	return (ENOENT);
+static void
+register_fb_wrap(void *arg, void *ptr)
+	fbd_register((struct fb_info *)ptr);
+static void
+unregister_fb_wrap(void *arg, void *ptr)
+	fbd_unregister((struct fb_info *)ptr);
+static void
+fbd_evh_init(void *ctx)
+	EVENTHANDLER_REGISTER(register_framebuffer, register_fb_wrap, NULL,
+	    EVENTHANDLER_PRI_ANY);
+	EVENTHANDLER_REGISTER(unregister_framebuffer, unregister_fb_wrap, NULL,
+/* Newbus methods. */
+static int
+fbd_probe(device_t dev)
+	return (BUS_PROBE_NOWILDCARD);
+static int
+fbd_attach(device_t dev)
+	struct fbd_softc *sc;
+	int err;
+	sc = device_get_softc(dev);
+	sc->sc_dev = dev;
+	sc->sc_info = FB_GETINFO(device_get_parent(dev));
+	if (sc->sc_info == NULL)
+		return (ENXIO);
+	err = fbd_register(sc->sc_info);
+	return (err);
+static int
+fbd_detach(device_t dev)
+	int err;
+	err = fbd_unregister(sc->sc_info);
+	return (err);
+static device_method_t fbd_methods[] = {
+	/* Device interface */
+	DEVMETHOD(device_probe,		fbd_probe),
+	DEVMETHOD(device_attach,	fbd_attach),
+	DEVMETHOD(device_detach,	fbd_detach),
+	DEVMETHOD(device_shutdown,	bus_generic_shutdown),
+	{ 0, 0 }
+driver_t fbd_driver = {
+	"fbd",
+	fbd_methods,
+	sizeof(struct fbd_softc)
+devclass_t	fbd_devclass;
+DRIVER_MODULE(fbd, fb, fbd_driver, fbd_devclass, 0, 0);
+DRIVER_MODULE(fbd, drmn, fbd_driver, fbd_devclass, 0, 0);
+DRIVER_MODULE(fbd, udl, fbd_driver, fbd_devclass, 0, 0);
+MODULE_VERSION(fbd, 1);
diff --git a/freebsd/sys/dev/fb/fbreg.h b/freebsd/sys/dev/fb/fbreg.h
index 00000000..d5bfd0da
--- /dev/null
+++ b/freebsd/sys/dev/fb/fbreg.h
@@ -0,0 +1,345 @@
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+ * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * $FreeBSD$
+#ifndef _DEV_FB_FBREG_H_
+#define _DEV_FB_FBREG_H_
+#ifdef _KERNEL
+#define V_MAX_ADAPTERS		8		/* XXX */
+/* some macros */
+static __inline void
+copyw(uint16_t *src, uint16_t *dst, size_t size)
+	size >>= 1;
+	while (size--)
+		*dst++ = *src++;
+#define bcopy_io(s, d, c)	copyw((void*)(s), (void*)(d), (c))
+#define bcopy_toio(s, d, c)	copyw((void*)(s), (void*)(d), (c))
+#define bcopy_fromio(s, d, c)	copyw((void*)(s), (void*)(d), (c))
+#define bzero_io(d, c)		bzero((void *)(d), (c))
+#define fill_io(p, d, c)	fill((p), (void *)(d), (c))
+#define fillw_io(p, d, c)	fillw((p), (void *)(d), (c))
+#elif defined(__sparc64__)
+fillw(int val, uint16_t *buf, size_t size)
+	while (size--)
+		*buf++ = val;
+#elif defined(__powerpc__)
+#define bcopy_io(s, d, c)	ofwfb_bcopy((void *)(s), (void *)(d), (c))
+#define bcopy_toio(s, d, c)	ofwfb_bcopy((void *)(s), (void *)(d), (c))
+#define bcopy_fromio(s, d, c)	ofwfb_bcopy((void *)(s), (void *)(d), (c))
+#define bzero_io(d, c)		ofwfb_bzero((void *)(d), (c))
+#define fillw(p, d, c)		ofwfb_fillw((p), (void *)(d), (c))
+#define fillw_io(p, d, c)	ofwfb_fillw((p), (void *)(d), (c))
+#define	readw(a)		ofwfb_readw((u_int16_t *)(a))
+#define	writew(a, v)		ofwfb_writew((u_int16_t *)(a), (v))
+void ofwfb_bcopy(const void *s, void *d, size_t c);
+void ofwfb_bzero(void *d, size_t c);
+void ofwfb_fillw(int pat, void *base, size_t cnt);
+u_int16_t ofwfb_readw(u_int16_t *addr);
+void ofwfb_writew(u_int16_t *addr, u_int16_t val);
+#elif defined(__mips__) || defined(__arm__)
+ * Use amd64/i386-like settings under the assumption that MIPS-based display
+ * drivers will have to add a level of indirection between a syscons-managed
+ * frame buffer and the actual video hardware.  We are forced to do this
+ * because syscons doesn't carry around required busspace handles and tags to
+ * use here.  This is only really a problem for true VGA devices hooked up to
+ * MIPS, as others will be performing a translation anyway.
+#define bcopy_io(s, d, c)	memcpy((void *)(d), (void *)(s), (c))
+#define bcopy_toio(s, d, c)	memcpy((void *)(d), (void *)(s), (c))
+#define bcopy_fromio(s, d, c)	memcpy((void *)(d), (void *)(s), (c))
+#define bzero_io(d, c)		memset((void *)(d), 0, (c))
+#define fill_io(p, d, c)	memset((void *)(d), (p), (c))
+	while (size--)
+		*buf++ = val;
+#if defined(__arm__)
+#define	readw(a)		(*(uint16_t*)(a))
+#define	writew(a, v)		(*(uint16_t*)(a) = (v))
+#endif
+#else /* !__i386__ && !__amd64__ && !__sparc64__ && !__powerpc__ */
+#define bcopy_io(s, d, c)	memcpy_io((d), (s), (c))
+#define bcopy_toio(s, d, c)	memcpy_toio((d), (void *)(s), (c))
+#define bcopy_fromio(s, d, c)	memcpy_fromio((void *)(d), (s), (c))
+#define bzero_io(d, c)		memset_io((d), 0, (c))
+#define fill_io(p, d, c)	memset_io((d), (p), (c))
+#define fillw(p, d, c)		memsetw((d), (p), (c))
+#define fillw_io(p, d, c)	memsetw_io((d), (p), (c))
+#endif /* !__i386__ */
+/* video function table */
+typedef int vi_probe_t(int unit, video_adapter_t **adpp, void *arg, int flags);
+typedef int vi_init_t(int unit, video_adapter_t *adp, int flags);
+typedef int vi_get_info_t(video_adapter_t *adp, int mode, video_info_t *info);
+typedef int vi_query_mode_t(video_adapter_t *adp, video_info_t *info);
+typedef int vi_set_mode_t(video_adapter_t *adp, int mode);
+typedef int vi_save_font_t(video_adapter_t *adp, int page, int size, int width,
+			   u_char *data, int c, int count);
+typedef int vi_load_font_t(video_adapter_t *adp, int page, int size, int width,
+typedef int vi_show_font_t(video_adapter_t *adp, int page);
+typedef int vi_save_palette_t(video_adapter_t *adp, u_char *palette);
+typedef int vi_load_palette_t(video_adapter_t *adp, u_char *palette);
+typedef int vi_set_border_t(video_adapter_t *adp, int border);
+typedef int vi_save_state_t(video_adapter_t *adp, void *p, size_t size);
+typedef int vi_load_state_t(video_adapter_t *adp, void *p);
+typedef int vi_set_win_org_t(video_adapter_t *adp, off_t offset);
+typedef int vi_read_hw_cursor_t(video_adapter_t *adp, int *col, int *row);
+typedef int vi_set_hw_cursor_t(video_adapter_t *adp, int col, int row);
+typedef int vi_set_hw_cursor_shape_t(video_adapter_t *adp, int base,
+				     int height, int celsize, int blink);
+typedef int vi_blank_display_t(video_adapter_t *adp, int mode);
+/* defined in sys/fbio.h
+#define V_DISPLAY_ON		0
+#define V_DISPLAY_BLANK		1
+#define V_DISPLAY_STAND_BY	2
+#define V_DISPLAY_SUSPEND	3
+typedef int vi_mmap_t(video_adapter_t *adp, vm_ooffset_t offset,
+		      vm_paddr_t *paddr, int prot, vm_memattr_t *memattr);
+typedef int vi_ioctl_t(video_adapter_t *adp, u_long cmd, caddr_t data);
+typedef int vi_clear_t(video_adapter_t *adp);
+typedef int vi_fill_rect_t(video_adapter_t *adp, int val, int x, int y,
+			   int cx, int cy);
+typedef int vi_bitblt_t(video_adapter_t *adp, ...);
+typedef int vi_diag_t(video_adapter_t *adp, int level);
+typedef int vi_save_cursor_palette_t(video_adapter_t *adp, u_char *palette);
+typedef int vi_load_cursor_palette_t(video_adapter_t *adp, u_char *palette);
+typedef int vi_copy_t(video_adapter_t *adp, vm_offset_t src, vm_offset_t dst,
+		      int n);
+typedef int vi_putp_t(video_adapter_t *adp, vm_offset_t off, u_int32_t p,
+		       u_int32_t a, int size, int bpp, int bit_ltor,
+		       int byte_ltor);
+typedef int vi_putc_t(video_adapter_t *adp, vm_offset_t off, u_int8_t c,
+		      u_int8_t a);
+typedef int vi_puts_t(video_adapter_t *adp, vm_offset_t off, u_int16_t *s,
+		       int len);
+typedef int vi_putm_t(video_adapter_t *adp, int x, int y, u_int8_t *pixel_image,
+		      u_int32_t pixel_mask, int size, int width);
+typedef struct video_switch {
+    vi_probe_t		*probe;
+    vi_init_t		*init;
+    vi_get_info_t	*get_info;
+    vi_query_mode_t	*query_mode;
+    vi_set_mode_t	*set_mode;
+    vi_save_font_t	*save_font;
+    vi_load_font_t	*load_font;
+    vi_show_font_t	*show_font;
+    vi_save_palette_t	*save_palette;
+    vi_load_palette_t	*load_palette;
+    vi_set_border_t	*set_border;
+    vi_save_state_t	*save_state;
+    vi_load_state_t	*load_state;
+    vi_set_win_org_t	*set_win_org;
+    vi_read_hw_cursor_t	*read_hw_cursor;
+    vi_set_hw_cursor_t	*set_hw_cursor;
+    vi_set_hw_cursor_shape_t *set_hw_cursor_shape;
+    vi_blank_display_t	*blank_display;
+    vi_mmap_t		*mmap;
+    vi_ioctl_t		*ioctl;
+    vi_clear_t		*clear;
+    vi_fill_rect_t	*fill_rect;
+    vi_bitblt_t		*bitblt;
+    int			(*reserved1)(void);
+    int			(*reserved2)(void);
+    vi_diag_t		*diag;
+    vi_save_cursor_palette_t	*save_cursor_palette;
+    vi_load_cursor_palette_t	*load_cursor_palette;
+    vi_copy_t		*copy;
+    vi_putp_t		*putp;
+    vi_putc_t		*putc;
+    vi_puts_t		*puts;
+    vi_putm_t		*putm;
+} video_switch_t;
+#define vidd_probe(unit, adpp, arg, flags)				\
+	(*vidsw[(adp)->va_index]->probe)((unit), (adpp), (arg), (flags))
+#define vidd_init(unit, adp, flags)					\
+	(*vidsw[(adp)->va_index]->init)((unit), (adp), (flags))
+#define vidd_get_info(adp, mode, info)					\
+	(*vidsw[(adp)->va_index]->get_info)((adp), (mode), (info))
+#define vidd_query_mode(adp, mode)					\
+	(*vidsw[(adp)->va_index]->query_mode)((adp), (mode))
+#define vidd_set_mode(adp, mode)					\
+	(*vidsw[(adp)->va_index]->set_mode)((adp), (mode))
+#define vidd_save_font(adp, page, size, width, data, c, count)		\
+	(*vidsw[(adp)->va_index]->save_font)((adp), (page), (size),	\
+	    (width), (data), (c), (count))
+#define vidd_load_font(adp, page, size, width, data, c, count)		\
+	(*vidsw[(adp)->va_index]->load_font)((adp), (page), (size),	\
+#define vidd_show_font(adp, page)					\
+	(*vidsw[(adp)->va_index]->show_font)((adp), (page))
+#define vidd_save_palette(adp, pallete)					\
+	(*vidsw[(adp)->va_index]->save_palette)((adp), (pallete))
+#define vidd_load_palette(adp, pallete)					\
+	(*vidsw[(adp)->va_index]->load_palette)((adp), (pallete))
+#define vidd_set_border(adp, border)					\
+	(*vidsw[(adp)->va_index]->set_border)((adp), (border))
+#define vidd_save_state(adp, p, size)					\
+	(*vidsw[(adp)->va_index]->save_state)((adp), (p), (size))
+#define vidd_load_state(adp, p)						\
+	(*vidsw[(adp)->va_index]->load_state)((adp), (p))
+#define vidd_set_win_org(adp, offset)					\
+	(*vidsw[(adp)->va_index]->set_win_org)((adp), (offset))
+#define vidd_read_hw_cursor(adp, col, row)				\
+	(*vidsw[(adp)->va_index]->read_hw_cursor)((adp), (col), (row))
+#define vidd_set_hw_cursor(adp, col, row)				\
+	(*vidsw[(adp)->va_index]->set_hw_cursor)((adp), (col), (row))
+#define vidd_set_hw_cursor_shape(adp, base, height, celsize, blink)	\
+	(*vidsw[(adp)->va_index]->set_hw_cursor_shape)((adp), (base),	\
+	    (height), (celsize), (blink))
+#define vidd_blank_display(adp, mode)					\
+	(*vidsw[(adp)->va_index]->blank_display)((adp), (mode))
+#define vidd_mmap(adp, offset, paddr, prot, memattr)			\
+	(*vidsw[(adp)->va_index]->mmap)((adp), (offset), (paddr),	\
+	    (prot), (memattr))
+#define vidd_ioctl(adp, cmd, data)					\
+	(*vidsw[(adp)->va_index]->ioctl)((adp), (cmd), (data))
+#define vidd_clear(adp)							\
+	(*vidsw[(adp)->va_index]->clear)((adp))
+#define vidd_fill_rect(adp, val, x, y, cx, cy)				\
+	(*vidsw[(adp)->va_index]->fill_rect)((adp), (val), (x), (y),	\
+	    (cx), (cy))
+#define vidd_bitblt(adp, ...)						\
+	(*vidsw[(adp)->va_index]->bitblt)(adp, __VA_ARGS__)
+#define vidd_diag(adp, level)						\
+	(*vidsw[(adp)->va_index]->diag)((adp), (level))
+#define vidd_save_cursor_palette(adp, palette)				\
+	(*vidsw[(adp)->va_index]->save_cursor_palette)((adp), (palette))
+#define vidd_load_cursor_palette(adp, palette)				\
+	(*vidsw[(adp)->va_index]->load_cursor_palette)((adp), (palette))
+#define vidd_copy(adp, src, dst, n)					\
+	(*vidsw[(adp)->va_index]->copy)((adp), (src), (dst), (n))
+#define vidd_putp(adp, offset, p, a, size, bpp, bit_ltor1, byte_ltor2)	\
+	(*vidsw[(adp)->va_index]->putp)((adp), (offset), (p), (a), 	\
+	    (size), (bpp), (bit_ltor1), (bit_ltor2))
+#define vidd_putc(adp, offset, c, a)					\
+	(*vidsw[(adp)->va_index]->putc)((adp), (offset), (c), (a))
+#define vidd_puts(adp, offset, s, len)					\
+	(*vidsw[(adp)->va_index]->puts)((adp), (offset), (s), (len))
+#define vidd_putm(adp, x, y, pixel_image, pixel_mask, size, width)	\
+	(*vidsw[(adp)->va_index]->putm)((adp), (x), (y), (pixel_image),	\
+	    (pixel_mask), (size), (width))
+/* video driver */
+typedef struct video_driver {
+    char		*name;
+    video_switch_t	*vidsw;
+    int			(*configure)(int); /* backdoor for the console driver */
+} video_driver_t;
+#define VIDEO_DRIVER(name, sw, config)			\
+	static struct video_driver name##_driver = {	\
+		#name, &sw, config			\
+	DATA_SET(videodriver_set, name##_driver);
+/* global variables */
+extern struct video_switch **vidsw;
+/* functions for the video card driver */
+int		vid_register(video_adapter_t *adp);
+int		vid_unregister(video_adapter_t *adp);
+video_switch_t	*vid_get_switch(char *name);
+void		vid_init_struct(video_adapter_t *adp, char *name, int type,
+				int unit);
+/* functions for the video card client */
+int		vid_allocate(char *driver, int unit, void *id);
+int		vid_release(video_adapter_t *adp, void *id);
+int		vid_find_adapter(char *driver, int unit);
+video_adapter_t	*vid_get_adapter(int index);
+/* a backdoor for the console driver to tickle the video driver XXX */
+int		vid_configure(int flags);
+#define VIO_PROBE_ONLY	(1 << 0)	/* probe only, don't initialize */
+/* virtual frame buffer driver functions */
+int		fb_attach(int unit, video_adapter_t *adp,
+			  struct cdevsw *cdevsw);
+int		fb_detach(int unit, video_adapter_t *adp,
+/* generic frame buffer cdev driver functions */
+typedef struct genfb_softc {
+	int		gfb_flags;	/* flag/status bits */
+#define FB_OPEN		(1 << 0)
+} genfb_softc_t;
+			  int flag, int mode, struct thread *td);
+			  struct uio *uio, int flag);
+			   u_long cmd, caddr_t arg, int flag, struct thread *td);
+			  vm_ooffset_t offset, vm_paddr_t *paddr,
+			  int prot, vm_memattr_t *memattr);
+/* generic low-level driver functions */
+void		fb_dump_adp_info(char *driver, video_adapter_t *adp, int level);
+void		fb_dump_mode_info(char *driver, video_adapter_t *adp,
+				  video_info_t *info, int level);
+int		fb_type(int adp_type);
+int		fb_commonioctl(video_adapter_t *adp, u_long cmd, caddr_t arg);
+#endif /* _KERNEL */
+#endif /* !_DEV_FB_FBREG_H_ */
diff --git a/freebsd/sys/dev/vt/colors/vt_termcolors.h b/freebsd/sys/dev/vt/colors/vt_termcolors.h
index 00000000..8a8c7b65
--- /dev/null
+++ b/freebsd/sys/dev/vt/colors/vt_termcolors.h
@@ -0,0 +1,63 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+enum vt_color_format {
+	COLOR_FORMAT_BW = 0,
+	COLOR_FORMAT_GRAY,
+	COLOR_FORMAT_VGA,		/* Color Index. */
+	COLOR_FORMAT_RGB,
+	COLOR_FORMAT_ARGB,
+        COLOR_FORMAT_CMYK,
+        COLOR_FORMAT_HSL,
+        COLOR_FORMAT_YUV,
+        COLOR_FORMAT_YCbCr,
+        COLOR_FORMAT_YPbPr,
+        COLOR_FORMAT_MAX = 15,
+#define NCOLORS	16
+ * Between console's palette and VGA's one:
+ *   - blue and red are swapped (1 <-> 4)
+ *   - yellow and cyan are swapped (3 <-> 6)
+static const int cons_to_vga_colors[NCOLORS] = {
+	0,  4,  2,  6,  1,  5,  3,  7,
+	8, 12, 10, 14,  9, 13, 11, 15
+/* Helper to fill color map used by driver */
+int vt_generate_cons_palette(uint32_t *palette, int format, uint32_t rmax,
+    int roffset, uint32_t gmax, int goffset, uint32_t bmax, int boffset);
diff --git a/freebsd/sys/dev/vt/hw/fb/vt_fb.h b/freebsd/sys/dev/vt/hw/fb/vt_fb.h
index 00000000..42b395e8
--- /dev/null
+++ b/freebsd/sys/dev/vt/hw/fb/vt_fb.h
@@ -0,0 +1,54 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _DEV_VT_HW_FB_VT_FB_H_
+#define	_DEV_VT_HW_FB_VT_FB_H_
+/* Generic framebuffer interface call vt_fb_attach to init VT(9) */
+int vt_fb_attach(struct fb_info *info);
+void vt_fb_resume(struct vt_device *vd);
+void vt_fb_suspend(struct vt_device *vd);
+int vt_fb_detach(struct fb_info *info);
+vd_init_t		vt_fb_init;
+vd_fini_t		vt_fb_fini;
+vd_blank_t		vt_fb_blank;
+vd_bitblt_text_t	vt_fb_bitblt_text;
+vd_invalidate_text_t	vt_fb_invalidate_text;
+vd_bitblt_bmp_t		vt_fb_bitblt_bitmap;
+vd_drawrect_t		vt_fb_drawrect;
+vd_setpixel_t		vt_fb_setpixel;
+vd_postswitch_t		vt_fb_postswitch;
+vd_fb_ioctl_t		vt_fb_ioctl;
+vd_fb_mmap_t		vt_fb_mmap;
+#endif /* _DEV_VT_HW_FB_VT_FB_H_ */
diff --git a/freebsd/sys/dev/vt/vt.h b/freebsd/sys/dev/vt/vt.h
index 00000000..34d4c228
--- /dev/null
+++ b/freebsd/sys/dev/vt/vt.h
@@ -0,0 +1,474 @@
+ * Copyright (c) 2009, 2013 The FreeBSD Foundation
+ * This software was developed by Ed Schouten under sponsorship from the
+ * Portions of this software were developed by Oleksandr Rybalko
+ * under sponsorship from the FreeBSD Foundation.
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _DEV_VT_VT_H_
+#define	_DEV_VT_VT_H_
+#include <sys/_lock.h>
+#include <sys/_mutex.h>
+#include <sys/callout.h>
+#include <sys/condvar.h>
+#include <sys/consio.h>
+#include <sys/kbio.h>
+#include <sys/mouse.h>
+#include <sys/terminal.h>
+#include <sys/sysctl.h>
+#include <rtems/bsd/local/opt_syscons.h>
+#include <rtems/bsd/local/opt_splash.h>
+#ifndef	VT_MAXWINDOWS
+#ifdef	MAXCONS
+#define	VT_MAXWINDOWS	MAXCONS
+#else
+#define	VT_MAXWINDOWS	12
+#endif
+#endif
+#ifndef VT_ALT_TO_ESC_HACK
+#define	VT_ALT_TO_ESC_HACK	1
+#endif
+#define	VT_CONSWINDOW	0
+#if defined(SC_TWOBUTTON_MOUSE) || defined(VT_TWOBUTTON_MOUSE)
+#define VT_MOUSE_PASTEBUTTON	MOUSE_BUTTON3DOWN	/* right button */
+#define VT_MOUSE_EXTENDBUTTON	MOUSE_BUTTON2DOWN	/* not really used */
+#else
+#define VT_MOUSE_PASTEBUTTON	MOUSE_BUTTON2DOWN	/* middle button */
+#define VT_MOUSE_EXTENDBUTTON	MOUSE_BUTTON3DOWN	/* right button */
+#endif /* defined(SC_TWOBUTTON_MOUSE) || defined(VT_TWOBUTTON_MOUSE) */
+#define	SC_DRIVER_NAME	"vt"
+#ifdef VT_DEBUG
+#define	DPRINTF(_l, ...)	if (vt_debug > (_l)) printf( __VA_ARGS__ )
+#define VT_CONSOLECTL_DEBUG
+#define VT_SYSMOUSE_DEBUG
+#else
+#define	DPRINTF(_l, ...)	do {} while (0)
+#endif
+#define	ISSIGVALID(sig)	((sig) > 0 && (sig) < NSIG)
+#define	VT_SYSCTL_INT(_name, _default, _descr)				\
+int vt_##_name = (_default);						\
+SYSCTL_INT(_kern_vt, OID_AUTO, _name, CTLFLAG_RWTUN, &vt_##_name, 0, _descr)
+struct vt_driver;
+void vt_allocate(const struct vt_driver *, void *);
+void vt_deallocate(const struct vt_driver *, void *);
+typedef unsigned int	vt_axis_t;
+ * List of locks
+ * (d)	locked by vd_lock
+ * (b)	locked by vb_lock
+ * (G)	locked by Giant
+ * (u)	unlocked, locked by higher levels
+ * (c)	const until freeing
+ * (?)	yet to be determined
+ * Per-device datastructure.
+#ifndef SC_NO_CUTPASTE
+struct vt_mouse_cursor;
+#endif
+struct vt_pastebuf {
+	term_char_t		*vpb_buf;	/* Copy-paste buffer. */
+	unsigned int		 vpb_bufsz;	/* Buffer size. */
+	unsigned int		 vpb_len;	/* Length of a last selection. */
+struct vt_device {
+	struct vt_window	*vd_windows[VT_MAXWINDOWS]; /* (c) Windows. */
+	struct vt_window	*vd_curwindow;	/* (d) Current window. */
+	struct vt_window	*vd_savedwindow;/* (?) Saved for suspend. */
+	struct vt_pastebuf	 vd_pastebuf;	/* (?) Copy/paste buf. */
+	const struct vt_driver	*vd_driver;	/* (c) Graphics driver. */
+	void			*vd_softc;	/* (u) Driver data. */
+	const struct vt_driver	*vd_prev_driver;/* (?) Previous driver. */
+	void			*vd_prev_softc;	/* (?) Previous driver data. */
+	device_t		 vd_video_dev;	/* (?) Video adapter. */
+	struct vt_mouse_cursor	*vd_mcursor;	/* (?) Cursor bitmap. */
+	term_color_t		 vd_mcursor_fg;	/* (?) Cursor fg color. */
+	term_color_t		 vd_mcursor_bg;	/* (?) Cursor bg color. */
+	vt_axis_t		 vd_mx_drawn;	/* (?) Mouse X and Y      */
+	vt_axis_t		 vd_my_drawn;	/*     as of last redraw. */
+	int			 vd_mshown;	/* (?) Mouse shown during */
+#endif						/*     last redrawn.      */
+	uint16_t		 vd_mx;		/* (?) Current mouse X. */
+	uint16_t		 vd_my;		/* (?) current mouse Y. */
+	uint32_t		 vd_mstate;	/* (?) Mouse state. */
+	vt_axis_t		 vd_width;	/* (?) Screen width. */
+	vt_axis_t		 vd_height;	/* (?) Screen height. */
+	size_t			 vd_transpose;	/* (?) Screen offset in FB */
+	struct mtx		 vd_lock;	/* Per-device lock. */
+	struct cv		 vd_winswitch;	/* (d) Window switch notify. */
+	struct callout		 vd_timer;	/* (d) Display timer. */
+	volatile unsigned int	 vd_timer_armed;/* (?) Display timer started.*/
+	int			 vd_flags;	/* (d) Device flags. */
+#define	VDF_TEXTMODE	0x01	/* Do text mode rendering. */
+#define	VDF_SPLASH	0x02	/* Splash screen active. */
+#define	VDF_ASYNC	0x04	/* vt_timer() running. */
+#define	VDF_INVALID	0x08	/* Entire screen should be re-rendered. */
+#define	VDF_DEAD	0x10	/* Early probing found nothing. */
+#define	VDF_INITIALIZED	0x20	/* vtterm_cnprobe already done. */
+#define	VDF_MOUSECURSOR	0x40	/* Mouse cursor visible. */
+#define	VDF_QUIET_BELL	0x80	/* Disable bell. */
+#define	VDF_SUSPENDED	0x100	/* Device has been suspended. */
+#define	VDF_DOWNGRADE	0x8000	/* The driver is being downgraded. */
+	int			 vd_keyboard;	/* (G) Keyboard index. */
+	unsigned int		 vd_kbstate;	/* (?) Device unit. */
+	unsigned int		 vd_unit;	/* (c) Device unit. */
+	int			 vd_altbrk;	/* (?) Alt break seq. state */
+	term_char_t		*vd_drawn;	/* (?) Most recent char drawn. */
+	term_color_t		*vd_drawnfg;	/* (?) Most recent fg color drawn. */
+	term_color_t		*vd_drawnbg;	/* (?) Most recent bg color drawn. */
+#define	VD_PASTEBUF(vd)	((vd)->vd_pastebuf.vpb_buf)
+#define	VD_PASTEBUFSZ(vd)	((vd)->vd_pastebuf.vpb_bufsz)
+#define	VD_PASTEBUFLEN(vd)	((vd)->vd_pastebuf.vpb_len)
+#define	VT_LOCK(vd)	mtx_lock(&(vd)->vd_lock)
+#define	VT_UNLOCK(vd)	mtx_unlock(&(vd)->vd_lock)
+#define	VT_LOCK_ASSERT(vd, what)	mtx_assert(&(vd)->vd_lock, what)
+void vt_resume(struct vt_device *vd);
+void vt_resume_flush_timer(struct vt_window *vw, int ms);
+void vt_suspend(struct vt_device *vd);
+ * Per-window terminal screen buffer.
+ * Because redrawing is performed asynchronously, the buffer keeps track
+ * of a rectangle that needs to be redrawn (vb_dirtyrect).  Because this
+ * approach seemed to cause suboptimal performance (when the top left
+ * and the bottom right of the screen are modified), it also uses a set
+ * of bitmasks to keep track of the rows and columns (mod 64) that have
+ * been modified.
+struct vt_buf {
+	struct mtx		 vb_lock;	/* Buffer lock. */
+	term_pos_t		 vb_scr_size;	/* (b) Screen dimensions. */
+	int			 vb_flags;	/* (b) Flags. */
+#define	VBF_CURSOR	0x1	/* Cursor visible. */
+#define	VBF_STATIC	0x2	/* Buffer is statically allocated. */
+#define	VBF_MTX_INIT	0x4	/* Mutex initialized. */
+#define	VBF_SCROLL	0x8	/* scroll locked mode. */
+#define	VBF_HISTORY_FULL 0x10	/* All rows filled. */
+	unsigned int		 vb_history_size;
+	unsigned int		 vb_roffset;	/* (b) History rows offset. */
+	unsigned int		 vb_curroffset;	/* (b) Saved rows offset. */
+	term_pos_t		 vb_cursor;	/* (u) Cursor position. */
+	term_pos_t		 vb_mark_start;	/* (b) Copy region start. */
+	term_pos_t		 vb_mark_end;	/* (b) Copy region end. */
+	int			 vb_mark_last;	/* Last mouse event. */
+	term_rect_t		 vb_dirtyrect;	/* (b) Dirty rectangle. */
+	term_char_t		*vb_buffer;	/* (u) Data buffer. */
+	term_char_t		**vb_rows;	/* (u) Array of rows */
+#ifdef SC_HISTORY_SIZE
+#define	VBF_DEFAULT_HISTORY_SIZE	SC_HISTORY_SIZE
+#else
+#define	VBF_DEFAULT_HISTORY_SIZE	500
+#endif
+void vtbuf_lock(struct vt_buf *);
+void vtbuf_unlock(struct vt_buf *);
+void vtbuf_copy(struct vt_buf *, const term_rect_t *, const term_pos_t *);
+void vtbuf_fill(struct vt_buf *, const term_rect_t *, term_char_t);
+void vtbuf_init_early(struct vt_buf *);
+void vtbuf_init(struct vt_buf *, const term_pos_t *);
+void vtbuf_grow(struct vt_buf *, const term_pos_t *, unsigned int);
+void vtbuf_putchar(struct vt_buf *, const term_pos_t *, term_char_t);
+void vtbuf_cursor_position(struct vt_buf *, const term_pos_t *);
+void vtbuf_scroll_mode(struct vt_buf *vb, int yes);
+void vtbuf_dirty(struct vt_buf *vb, const term_rect_t *area);
+void vtbuf_undirty(struct vt_buf *, term_rect_t *);
+void vtbuf_sethistory_size(struct vt_buf *, unsigned int);
+int vtbuf_iscursor(const struct vt_buf *vb, int row, int col);
+void vtbuf_cursor_visibility(struct vt_buf *, int);
+int vtbuf_set_mark(struct vt_buf *vb, int type, int col, int row);
+int vtbuf_get_marked_len(struct vt_buf *vb);
+void vtbuf_extract_marked(struct vt_buf *vb, term_char_t *buf, int sz);
+#endif
+#define	VTB_MARK_NONE		0
+#define	VTB_MARK_END		1
+#define	VTB_MARK_START		2
+#define	VTB_MARK_WORD		3
+#define	VTB_MARK_ROW		4
+#define	VTB_MARK_EXTEND		5
+#define	VTB_MARK_MOVE		6
+#define	VTBUF_SLCK_ENABLE(vb)	vtbuf_scroll_mode((vb), 1)
+#define	VTBUF_SLCK_DISABLE(vb)	vtbuf_scroll_mode((vb), 0)
+#define	VTBUF_MAX_HEIGHT(vb) \
+	((vb)->vb_history_size)
+#define	VTBUF_GET_ROW(vb, r) \
+	((vb)->vb_rows[((vb)->vb_roffset + (r)) % VTBUF_MAX_HEIGHT(vb)])
+#define	VTBUF_GET_FIELD(vb, r, c) \
+	((vb)->vb_rows[((vb)->vb_roffset + (r)) % VTBUF_MAX_HEIGHT(vb)][(c)])
+#define	VTBUF_FIELD(vb, r, c) \
+	((vb)->vb_rows[((vb)->vb_curroffset + (r)) % VTBUF_MAX_HEIGHT(vb)][(c)])
+#define	VTBUF_ISCURSOR(vb, r, c) \
+	vtbuf_iscursor((vb), (r), (c))
+#define	VTBUF_DIRTYROW(mask, row) \
+	((mask)->vbm_row & ((uint64_t)1 << ((row) % 64)))
+#define	VTBUF_DIRTYCOL(mask, col) \
+	((mask)->vbm_col & ((uint64_t)1 << ((col) % 64)))
+#define	VTBUF_SPACE_CHAR(attr)	(' ' | (attr))
+#define	VHS_SET	0
+#define	VHS_CUR	1
+#define	VHS_END	2
+int vthistory_seek(struct vt_buf *, int offset, int whence);
+void vthistory_addlines(struct vt_buf *vb, int offset);
+void vthistory_getpos(const struct vt_buf *, unsigned int *offset);
+ * Per-window datastructure.
+struct vt_window {
+	struct vt_device	*vw_device;	/* (c) Device. */
+	struct terminal		*vw_terminal;	/* (c) Terminal. */
+	struct vt_buf		 vw_buf;	/* (u) Screen buffer. */
+	struct vt_font		*vw_font;	/* (d) Graphical font. */
+	term_rect_t		 vw_draw_area;	/* (?) Drawable area. */
+	unsigned int		 vw_number;	/* (c) Window number. */
+	int			 vw_kbdmode;	/* (?) Keyboard mode. */
+	int			 vw_prev_kbdmode;/* (?) Previous mode. */
+	int			 vw_kbdstate;	/* (?) Keyboard state. */
+	int			 vw_grabbed;	/* (?) Grab count. */
+	char			*vw_kbdsq;	/* Escape sequence queue*/
+	unsigned int		 vw_flags;	/* (d) Per-window flags. */
+	int			 vw_mouse_level;/* Mouse op mode. */
+#define	VWF_BUSY	0x1	/* Busy reconfiguring device. */
+#define	VWF_OPENED	0x2	/* TTY in use. */
+#define	VWF_SCROLL	0x4	/* Keys influence scrollback. */
+#define	VWF_CONSOLE	0x8	/* Kernel message console window. */
+#define	VWF_VTYLOCK	0x10	/* Prevent window switch. */
+#define	VWF_MOUSE_HIDE	0x20	/* Disable mouse events processing. */
+#define	VWF_READY	0x40	/* Window fully initialized. */
+#define	VWF_GRAPHICS	0x80	/* Window in graphics mode (KDSETMODE). */
+#define	VWF_SWWAIT_REL	0x10000	/* Program wait for VT acquire is done. */
+#define	VWF_SWWAIT_ACQ	0x20000	/* Program wait for VT release is done. */
+	pid_t			 vw_pid;	/* Terminal holding process */
+	struct proc		*vw_proc;
+	struct vt_mode		 vw_smode;	/* switch mode */
+	struct callout		 vw_proc_dead_timer;
+	struct vt_window	*vw_switch_to;
+#define	VT_AUTO		0		/* switching is automatic */
+#define	VT_PROCESS	1		/* switching controlled by prog */
+#define	VT_KERNEL	255		/* switching controlled in kernel */
+#define	IS_VT_PROC_MODE(vw)	((vw)->vw_smode.mode == VT_PROCESS)
+ * Per-device driver routines.
+typedef int vd_init_t(struct vt_device *vd);
+typedef int vd_probe_t(struct vt_device *vd);
+typedef void vd_fini_t(struct vt_device *vd, void *softc);
+typedef void vd_postswitch_t(struct vt_device *vd);
+typedef void vd_blank_t(struct vt_device *vd, term_color_t color);
+typedef void vd_bitblt_text_t(struct vt_device *vd, const struct vt_window *vw,
+    const term_rect_t *area);
+typedef void vd_invalidate_text_t(struct vt_device *vd,
+typedef void vd_bitblt_bmp_t(struct vt_device *vd, const struct vt_window *vw,
+    const uint8_t *pattern, const uint8_t *mask,
+    unsigned int width, unsigned int height,
+    unsigned int x, unsigned int y, term_color_t fg, term_color_t bg);
+typedef int vd_fb_ioctl_t(struct vt_device *, u_long, caddr_t, struct thread *);
+typedef int vd_fb_mmap_t(struct vt_device *, vm_ooffset_t, vm_paddr_t *, int,
+    vm_memattr_t *);
+typedef void vd_drawrect_t(struct vt_device *, int, int, int, int, int,
+    term_color_t);
+typedef void vd_setpixel_t(struct vt_device *, int, int, term_color_t);
+typedef void vd_suspend_t(struct vt_device *);
+typedef void vd_resume_t(struct vt_device *);
+struct vt_driver {
+	char		 vd_name[16];
+	/* Console attachment. */
+	vd_probe_t	*vd_probe;
+	vd_init_t	*vd_init;
+	vd_fini_t	*vd_fini;
+	/* Drawing. */
+	vd_blank_t	*vd_blank;
+	vd_drawrect_t	*vd_drawrect;
+	vd_setpixel_t	*vd_setpixel;
+	vd_bitblt_text_t *vd_bitblt_text;
+	vd_invalidate_text_t *vd_invalidate_text;
+	vd_bitblt_bmp_t	*vd_bitblt_bmp;
+	/* Framebuffer ioctls, if present. */
+	vd_fb_ioctl_t	*vd_fb_ioctl;
+	/* Framebuffer mmap, if present. */
+	vd_fb_mmap_t	*vd_fb_mmap;
+	/* Update display setting on vt switch. */
+	vd_postswitch_t	*vd_postswitch;
+	/* Suspend/resume handlers. */
+	vd_suspend_t	*vd_suspend;
+	vd_resume_t	*vd_resume;
+	/* Priority to know which one can override */
+	int		vd_priority;
+#define	VD_PRIORITY_DUMB	10
+#define	VD_PRIORITY_GENERIC	100
+#define	VD_PRIORITY_SPECIFIC	1000
+ * Console device madness.
+ * Utility macro to make early vt(4) instances work.
+extern struct vt_device vt_consdev;
+extern struct terminal vt_consterm;
+extern const struct terminal_class vt_termclass;
+void vt_upgrade(struct vt_device *vd);
+#define	PIXEL_WIDTH(w)	((w) / 8)
+#define	PIXEL_HEIGHT(h)	((h) / 16)
+#ifndef VT_FB_MAX_WIDTH
+#define	VT_FB_MAX_WIDTH	4096
+#endif
+#ifndef VT_FB_MAX_HEIGHT
+#define	VT_FB_MAX_HEIGHT	2400
+#endif
+/* name argument is not used yet. */
+#define VT_DRIVER_DECLARE(name, drv) DATA_SET(vt_drv_set, drv)
+ * Fonts.
+ * Remapping tables are used to map Unicode points to glyphs.  They need
+ * to be sorted, because vtfont_lookup() performs a binary search.  Each
+ * font has two remapping tables, for normal and bold.  When a character
+ * is not present in bold, it uses a normal glyph.  When no glyph is
+ * available, it uses glyph 0, which is normally equal to U+FFFD.
+struct vt_font_map {
+	uint32_t		 vfm_src;
+	uint16_t		 vfm_dst;
+	uint16_t		 vfm_len;
+struct vt_font {
+	struct vt_font_map	*vf_map[VFNT_MAPS];
+	uint8_t			*vf_bytes;
+	unsigned int		 vf_height, vf_width;
+	unsigned int		 vf_map_count[VFNT_MAPS];
+	unsigned int		 vf_refcount;
+struct vt_mouse_cursor {
+	uint8_t map[64 * 64 / 8];
+	uint8_t mask[64 * 64 / 8];
+	uint8_t width;
+	uint8_t height;
+#endif
+const uint8_t	*vtfont_lookup(const struct vt_font *vf, term_char_t c);
+struct vt_font	*vtfont_ref(struct vt_font *vf);
+void		 vtfont_unref(struct vt_font *vf);
+int		 vtfont_load(vfnt_t *f, struct vt_font **ret);
+/* Sysmouse. */
+void sysmouse_process_event(mouse_info_t *mi);
+void vt_mouse_event(int type, int x, int y, int event, int cnt, int mlevel);
+void vt_mouse_state(int show);
+#endif
+#define	VT_MOUSE_SHOW 1
+#define	VT_MOUSE_HIDE 0
+/* Utilities. */
+void	vt_compute_drawable_area(struct vt_window *);
+void	vt_determine_colors(term_char_t c, int cursor,
+	    term_color_t *fg, term_color_t *bg);
+int	vt_is_cursor_in_area(const struct vt_device *vd,
+void	vt_termsize(struct vt_device *, struct vt_font *, term_pos_t *);
+void	vt_winsize(struct vt_device *, struct vt_font *, struct winsize *);
+/* Logos-on-boot. */
+#define	VT_LOGOS_DRAW_BEASTIE		0
+#define	VT_LOGOS_DRAW_ALT_BEASTIE	1
+#define	VT_LOGOS_DRAW_ORB		2
+extern int vt_draw_logo_cpus;
+extern int vt_splash_cpu;
+extern int vt_splash_ncpu;
+extern int vt_splash_cpu_style;
+extern int vt_splash_cpu_duration;
+extern const unsigned int vt_logo_sprite_height;
+extern const unsigned int vt_logo_sprite_width;
+void vtterm_draw_cpu_logos(struct vt_device *);
+#endif /* !_DEV_VT_VT_H_ */
diff --git a/freebsd/sys/teken/teken.h b/freebsd/sys/teken/teken.h
index 00000000..0a3928a9
--- /dev/null
+++ b/freebsd/sys/teken/teken.h
@@ -0,0 +1,221 @@
+ * Copyright (c) 2008-2009 Ed Schouten <ed at FreeBSD.org>
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _TEKEN_H_
+#define	_TEKEN_H_
+#include <sys/types.h>
+ * libteken: terminal emulation library.
+ * This library converts an UTF-8 stream of bytes to terminal drawing
+ * commands.
+typedef uint32_t teken_char_t;
+typedef unsigned short teken_unit_t;
+typedef unsigned char teken_format_t;
+#define	TF_BOLD		0x01	/* Bold character. */
+#define	TF_UNDERLINE	0x02	/* Underline character. */
+#define	TF_BLINK	0x04	/* Blinking character. */
+#define	TF_REVERSE	0x08	/* Reverse rendered character. */
+#define	TF_CJK_RIGHT	0x10	/* Right-hand side of CJK character. */
+typedef unsigned char teken_color_t;
+#define	TC_BLACK	0
+#define	TC_RED		1
+#define	TC_GREEN	2
+#define	TC_BROWN	3
+#define	TC_BLUE		4
+#define	TC_MAGENTA	5
+#define	TC_CYAN		6
+#define	TC_WHITE	7
+#define	TC_NCOLORS	8
+#define	TC_LIGHT	8	/* ORed with the others. */
+typedef struct {
+	teken_unit_t	tp_row;
+	teken_unit_t	tp_col;
+} teken_pos_t;
+typedef struct {
+	teken_pos_t	tr_begin;
+	teken_pos_t	tr_end;
+} teken_rect_t;
+typedef struct {
+	teken_format_t	ta_format;
+	teken_color_t	ta_fgcolor;
+	teken_color_t	ta_bgcolor;
+} teken_attr_t;
+typedef struct {
+	teken_unit_t	ts_begin;
+	teken_unit_t	ts_end;
+} teken_span_t;
+typedef struct __teken teken_t;
+typedef void teken_state_t(teken_t *, teken_char_t);
+ * Drawing routines supplied by the user.
+typedef void tf_bell_t(void *);
+typedef void tf_cursor_t(void *, const teken_pos_t *);
+typedef void tf_putchar_t(void *, const teken_pos_t *, teken_char_t,
+    const teken_attr_t *);
+typedef void tf_fill_t(void *, const teken_rect_t *, teken_char_t,
+typedef void tf_copy_t(void *, const teken_rect_t *, const teken_pos_t *);
+typedef void tf_pre_input_t(void *);
+typedef void tf_post_input_t(void *);
+typedef void tf_param_t(void *, int, unsigned int);
+#define	TP_SHOWCURSOR	0
+#define	TP_KEYPADAPP	1
+#define	TP_AUTOREPEAT	2
+#define	TP_SWITCHVT	3
+#define	TP_132COLS	4
+#define	TP_SETBELLPD	5
+#define	TP_SETBELLPD_PITCH(pd)		((pd) >> 16)
+#define	TP_SETBELLPD_DURATION(pd)	((pd) & 0xffff)
+#define	TP_MOUSE	6
+#define	TP_SETBORDER	7
+#define	TP_SETLOCALCURSOR	8
+#define	TP_SETGLOBALCURSOR	9
+typedef void tf_respond_t(void *, const void *, size_t);
+typedef struct {
+	tf_bell_t	*tf_bell;
+	tf_cursor_t	*tf_cursor;
+	tf_putchar_t	*tf_putchar;
+	tf_fill_t	*tf_fill;
+	tf_copy_t	*tf_copy;
+	tf_pre_input_t	*tf_pre_input;
+	tf_post_input_t	*tf_post_input;
+	tf_param_t	*tf_param;
+	tf_respond_t	*tf_respond;
+} teken_funcs_t;
+typedef teken_char_t teken_scs_t(const teken_t *, teken_char_t);
+ * Terminal state.
+struct __teken {
+	const teken_funcs_t *t_funcs;
+	void		*t_softc;
+	teken_state_t	*t_nextstate;
+	unsigned int	 t_stateflags;
+#define T_NUMSIZE	8
+	unsigned int	 t_nums[T_NUMSIZE];
+	unsigned int	 t_curnum;
+	teken_pos_t	 t_cursor;
+	teken_attr_t	 t_curattr;
+	teken_pos_t	 t_saved_cursor;
+	teken_attr_t	 t_saved_curattr;
+	teken_attr_t	 t_defattr;
+	teken_pos_t	 t_winsize;
+	/* For DECSTBM. */
+	teken_span_t	 t_scrollreg;
+	/* For DECOM. */
+	teken_span_t	 t_originreg;
+#define	T_NUMCOL	160
+	unsigned int	 t_tabstops[T_NUMCOL / (sizeof(unsigned int) * 8)];
+	unsigned int	 t_utf8_left;
+	teken_char_t	 t_utf8_partial;
+	teken_char_t	 t_last;
+	unsigned int	 t_curscs;
+	teken_scs_t	*t_saved_curscs;
+	teken_scs_t	*t_scs[2];
+/* Initialize teken structure. */
+void	teken_init(teken_t *, const teken_funcs_t *, void *);
+/* Deliver character input. */
+void	teken_input(teken_t *, const void *, size_t);
+/* Get/set teken attributes. */
+const teken_pos_t *teken_get_cursor(const teken_t *);
+const teken_attr_t *teken_get_curattr(const teken_t *);
+const teken_attr_t *teken_get_defattr(const teken_t *);
+void	teken_get_defattr_cons25(const teken_t *, int *, int *);
+const teken_pos_t *teken_get_winsize(const teken_t *);
+void	teken_set_cursor(teken_t *, const teken_pos_t *);
+void	teken_set_curattr(teken_t *, const teken_attr_t *);
+void	teken_set_defattr(teken_t *, const teken_attr_t *);
+void	teken_set_winsize(teken_t *, const teken_pos_t *);
+void	teken_set_winsize_noreset(teken_t *, const teken_pos_t *);
+/* Key input escape sequences. */
+#define	TKEY_UP		0x00
+#define	TKEY_DOWN	0x01
+#define	TKEY_LEFT	0x02
+#define	TKEY_RIGHT	0x03
+#define	TKEY_HOME	0x04
+#define	TKEY_END	0x05
+#define	TKEY_INSERT	0x06
+#define	TKEY_DELETE	0x07
+#define	TKEY_PAGE_UP	0x08
+#define	TKEY_PAGE_DOWN	0x09
+#define	TKEY_F1		0x0a
+#define	TKEY_F2		0x0b
+#define	TKEY_F3		0x0c
+#define	TKEY_F4		0x0d
+#define	TKEY_F5		0x0e
+#define	TKEY_F6		0x0f
+#define	TKEY_F7		0x10
+#define	TKEY_F8		0x11
+#define	TKEY_F9		0x12
+#define	TKEY_F10	0x13
+#define	TKEY_F11	0x14
+#define	TKEY_F12	0x15
+const char *teken_get_sequence(const teken_t *, unsigned int);
+/* Legacy features. */
+void	teken_set_8bit(teken_t *);
+void	teken_set_cons25(teken_t *);
+void	teken_set_cons25keys(teken_t *);
+/* Color conversion. */
+teken_color_t teken_256to16(teken_color_t);
+teken_color_t teken_256to8(teken_color_t);
+#endif /* !_TEKEN_H_ */
2.20.1
