[PATCH v2 7/8] am335x display drivers: Import from FreeBSD
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri Aug 2 21:00:09 UTC 2019
 freebsd/sys/arm/ti/am335x/am335x_ecap.c  |  202 ++++
 freebsd/sys/arm/ti/am335x/am335x_lcd.c   | 1085 ++++++++++++++++++++++
 freebsd/sys/arm/ti/am335x/am335x_lcd.h   |   60 ++
 freebsd/sys/arm/ti/am335x/am335x_pwm.h   |   35 +
 freebsd/sys/arm/ti/am335x/am335x_pwmss.c |  165 ++++
 freebsd/sys/sys/consio.h                 |  468 ++++++++++
 freebsd/sys/sys/fbio.h                   |  622 +++++++++++++
 freebsd/sys/sys/terminal.h               |  240 +++++
 8 files changed, 2877 insertions(+)
 create mode 100644 freebsd/sys/arm/ti/am335x/am335x_ecap.c
 create mode 100644 freebsd/sys/arm/ti/am335x/am335x_lcd.c
 create mode 100644 freebsd/sys/arm/ti/am335x/am335x_lcd.h
 create mode 100644 freebsd/sys/arm/ti/am335x/am335x_pwm.h
 create mode 100644 freebsd/sys/arm/ti/am335x/am335x_pwmss.c
 create mode 100644 freebsd/sys/sys/consio.h
 create mode 100644 freebsd/sys/sys/fbio.h
 create mode 100644 freebsd/sys/sys/terminal.h
diff --git a/freebsd/sys/arm/ti/am335x/am335x_ecap.c b/freebsd/sys/arm/ti/am335x/am335x_ecap.c
new file mode 100644
index 00000000..9ebc51db
--- /dev/null
+++ b/freebsd/sys/arm/ti/am335x/am335x_ecap.c
@@ -0,0 +1,202 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2013 Oleksandr Tymoshenko <gonzo at freebsd.org>
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/bus.h>
+#include <sys/kernel.h>
+#include <sys/limits.h>
+#include <sys/lock.h>
+#include <sys/module.h>
+#include <sys/mutex.h>
+#include <rtems/bsd/sys/resource.h>
+#include <sys/rman.h>
+#include <sys/sysctl.h>
+#include <machine/bus.h>
+#include <dev/ofw/openfirm.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include "am335x_pwm.h"
+#define	ECAP_TSCTR		0x00
+#define	ECAP_CAP1		0x08
+#define	ECAP_CAP2		0x0C
+#define	ECAP_CAP3		0x10
+#define	ECAP_CAP4		0x14
+#define	ECAP_ECCTL2		0x2A
+#define		ECCTL2_MODE_APWM		(1 << 9)
+#define		ECCTL2_SYNCO_SEL		(3 << 6)
+#define		ECCTL2_TSCTRSTOP_FREERUN	(1 << 4)
+#define	ECAP_READ2(_sc, reg)	bus_read_2((_sc)->sc_mem_res, reg);
+#define	ECAP_WRITE2(_sc, reg, value)	\
+    bus_write_2((_sc)->sc_mem_res, reg, value);
+#define	ECAP_READ4(_sc, reg)	bus_read_4((_sc)->sc_mem_res, reg);
+#define	ECAP_WRITE4(_sc, reg, value)	\
+    bus_write_4((_sc)->sc_mem_res, reg, value);
+#define	PWM_LOCK(_sc)		mtx_lock(&(_sc)->sc_mtx)
+#define	PWM_UNLOCK(_sc)		mtx_unlock(&(_sc)->sc_mtx)
+#define	PWM_LOCK_INIT(_sc)	mtx_init(&(_sc)->sc_mtx, \
+    device_get_nameunit(_sc->sc_dev), "am335x_ecap softc", MTX_DEF)
+#define	PWM_LOCK_DESTROY(_sc)	mtx_destroy(&(_sc)->sc_mtx)
+static device_probe_t am335x_ecap_probe;
+static device_attach_t am335x_ecap_attach;
+static device_detach_t am335x_ecap_detach;
+struct am335x_ecap_softc {
+	device_t		sc_dev;
+	struct mtx		sc_mtx;
+	struct resource		*sc_mem_res;
+	int			sc_mem_rid;
+static device_method_t am335x_ecap_methods[] = {
+	DEVMETHOD(device_probe,		am335x_ecap_probe),
+	DEVMETHOD(device_attach,	am335x_ecap_attach),
+	DEVMETHOD(device_detach,	am335x_ecap_detach),
+	DEVMETHOD_END
+static driver_t am335x_ecap_driver = {
+	"am335x_ecap",
+	am335x_ecap_methods,
+	sizeof(struct am335x_ecap_softc),
+static devclass_t am335x_ecap_devclass;
+ * API function to set period/duty cycles for ECAPx
+int
+am335x_pwm_config_ecap(int unit, int period, int duty)
+	device_t dev;
+	struct am335x_ecap_softc *sc;
+	uint16_t reg;
+	dev = devclass_get_device(am335x_ecap_devclass, unit);
+	if (dev == NULL)
+		return (ENXIO);
+	if (duty > period)
+		return (EINVAL);
+	if (period == 0)
+		return (EINVAL);
+	sc = device_get_softc(dev);
+	PWM_LOCK(sc);
+	reg = ECAP_READ2(sc, ECAP_ECCTL2);
+	reg |= ECCTL2_MODE_APWM | ECCTL2_TSCTRSTOP_FREERUN | ECCTL2_SYNCO_SEL;
+	ECAP_WRITE2(sc, ECAP_ECCTL2, reg);
+	/* CAP3 in APWM mode is APRD shadow register */
+	ECAP_WRITE4(sc, ECAP_CAP3, period - 1);
+	/* CAP4 in APWM mode is ACMP shadow register */
+	ECAP_WRITE4(sc, ECAP_CAP4, duty);
+	/* Restart counter */
+	ECAP_WRITE4(sc, ECAP_TSCTR, 0);
+	PWM_UNLOCK(sc);
+	return (0);
+static int
+am335x_ecap_probe(device_t dev)
+	if (!ofw_bus_status_okay(dev))
+		return (ENXIO);
+	if (!ofw_bus_is_compatible(dev, "ti,am33xx-ecap"))
+		return (ENXIO);
+	device_set_desc(dev, "AM335x eCAP");
+	return (BUS_PROBE_DEFAULT);
+static int
+am335x_ecap_attach(device_t dev)
+	sc->sc_dev = dev;
+	PWM_LOCK_INIT(sc);
+	sc->sc_mem_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY,
+	    &sc->sc_mem_rid, RF_ACTIVE);
+	if (sc->sc_mem_res == NULL) {
+		device_printf(dev, "cannot allocate memory resources\n");
+		goto fail;
+	return (0);
+fail:
+	PWM_LOCK_DESTROY(sc);
+	return (ENXIO);
+static int
+am335x_ecap_detach(device_t dev)
+	PWM_LOCK(sc);
+	if (sc->sc_mem_res)
+		bus_release_resource(dev, SYS_RES_MEMORY,
+		    sc->sc_mem_rid, sc->sc_mem_res);
+	PWM_UNLOCK(sc);
+	return (0);
+DRIVER_MODULE(am335x_ecap, am335x_pwmss, am335x_ecap_driver, am335x_ecap_devclass, 0, 0);
+MODULE_VERSION(am335x_ecap, 1);
+MODULE_DEPEND(am335x_ecap, am335x_pwmss, 1, 1, 1);
diff --git a/freebsd/sys/arm/ti/am335x/am335x_lcd.c b/freebsd/sys/arm/ti/am335x/am335x_lcd.c
index 00000000..7c0dd63e
--- /dev/null
+++ b/freebsd/sys/arm/ti/am335x/am335x_lcd.c
@@ -0,0 +1,1085 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright 2013 Oleksandr Tymoshenko <gonzo at freebsd.org>
+ * are met:
+ * SUCH DAMAGE.
+#include <rtems/bsd/local/opt_syscons.h>
+#include <sys/clock.h>
+#include <sys/eventhandler.h>
+#include <sys/time.h>
+#include <vm/vm.h>
+#include <vm/pmap.h>
+#include <sys/fbio.h>
+#include <sys/consio.h>
+#include <dev/fdt/fdt_common.h>
+#include <dev/videomode/videomode.h>
+#include <dev/videomode/edidvar.h>
+#include <dev/fb/fbreg.h>
+#ifdef DEV_SC
+#include <dev/syscons/syscons.h>
+#else /* VT */
+#include <dev/vt/vt.h>
+#endif
+#include <arm/ti/ti_prcm.h>
+#include <arm/ti/ti_scm.h>
+#include "am335x_lcd.h"
+#include <rtems/bsd/local/fb_if.h>
+#include <rtems/bsd/local/hdmi_if.h>
+#define	LCD_PID			0x00
+#define	LCD_CTRL		0x04
+#define		CTRL_DIV_MASK		0xff
+#define		CTRL_DIV_SHIFT		8
+#define		CTRL_AUTO_UFLOW_RESTART	(1 << 1)
+#define		CTRL_RASTER_MODE	1
+#define		CTRL_LIDD_MODE		0
+#define	LCD_LIDD_CTRL		0x0C
+#define	LCD_LIDD_CS0_CONF	0x10
+#define	LCD_LIDD_CS0_ADDR	0x14
+#define	LCD_LIDD_CS0_DATA	0x18
+#define	LCD_LIDD_CS1_CONF	0x1C
+#define	LCD_LIDD_CS1_ADDR	0x20
+#define	LCD_LIDD_CS1_DATA	0x24
+#define	LCD_RASTER_CTRL		0x28
+#define		RASTER_CTRL_TFT24_UNPACKED	(1 << 26)
+#define		RASTER_CTRL_TFT24		(1 << 25)
+#define		RASTER_CTRL_STN565		(1 << 24)
+#define		RASTER_CTRL_TFTPMAP		(1 << 23)
+#define		RASTER_CTRL_NIBMODE		(1 << 22)
+#define		RASTER_CTRL_PALMODE_SHIFT	20
+#define		PALETTE_PALETTE_AND_DATA	0x00
+#define		PALETTE_PALETTE_ONLY		0x01
+#define		PALETTE_DATA_ONLY		0x02
+#define		RASTER_CTRL_REQDLY_SHIFT	12
+#define		RASTER_CTRL_MONO8B		(1 << 9)
+#define		RASTER_CTRL_RBORDER		(1 << 8)
+#define		RASTER_CTRL_LCDTFT		(1 << 7)
+#define		RASTER_CTRL_LCDBW		(1 << 1)
+#define		RASTER_CTRL_LCDEN		(1 << 0)
+#define	LCD_RASTER_TIMING_0	0x2C
+#define		RASTER_TIMING_0_HBP_SHIFT	24
+#define		RASTER_TIMING_0_HFP_SHIFT	16
+#define		RASTER_TIMING_0_HSW_SHIFT	10
+#define		RASTER_TIMING_0_PPLLSB_SHIFT	4
+#define		RASTER_TIMING_0_PPLMSB_SHIFT	3
+#define	LCD_RASTER_TIMING_1	0x30
+#define		RASTER_TIMING_1_VBP_SHIFT	24
+#define		RASTER_TIMING_1_VFP_SHIFT	16
+#define		RASTER_TIMING_1_VSW_SHIFT	10
+#define		RASTER_TIMING_1_LPP_SHIFT	0
+#define	LCD_RASTER_TIMING_2	0x34
+#define		RASTER_TIMING_2_HSWHI_SHIFT	27
+#define		RASTER_TIMING_2_LPP_B10_SHIFT	26
+#define		RASTER_TIMING_2_PHSVS		(1 << 25)
+#define		RASTER_TIMING_2_PHSVS_RISE	(1 << 24)
+#define		RASTER_TIMING_2_PHSVS_FALL	(0 << 24)
+#define		RASTER_TIMING_2_IOE		(1 << 23)
+#define		RASTER_TIMING_2_IPC		(1 << 22)
+#define		RASTER_TIMING_2_IHS		(1 << 21)
+#define		RASTER_TIMING_2_IVS		(1 << 20)
+#define		RASTER_TIMING_2_ACBI_SHIFT	16
+#define		RASTER_TIMING_2_ACB_SHIFT	8
+#define		RASTER_TIMING_2_HBPHI_SHIFT	4
+#define		RASTER_TIMING_2_HFPHI_SHIFT	0
+#define	LCD_RASTER_SUBPANEL	0x38
+#define	LCD_RASTER_SUBPANEL2	0x3C
+#define	LCD_LCDDMA_CTRL		0x40
+#define		LCDDMA_CTRL_DMA_MASTER_PRIO_SHIFT		16
+#define		LCDDMA_CTRL_TH_FIFO_RDY_SHIFT	8
+#define		LCDDMA_CTRL_BURST_SIZE_SHIFT	4
+#define		LCDDMA_CTRL_BYTES_SWAP		(1 << 3)
+#define		LCDDMA_CTRL_BE			(1 << 1)
+#define		LCDDMA_CTRL_FB0_ONLY		0
+#define		LCDDMA_CTRL_FB0_FB1		(1 << 0)
+#define	LCD_LCDDMA_FB0_BASE	0x44
+#define	LCD_LCDDMA_FB0_CEILING	0x48
+#define	LCD_LCDDMA_FB1_BASE	0x4C
+#define	LCD_LCDDMA_FB1_CEILING	0x50
+#define	LCD_SYSCONFIG		0x54
+#define		SYSCONFIG_STANDBY_FORCE		(0 << 4)
+#define		SYSCONFIG_STANDBY_NONE		(1 << 4)
+#define		SYSCONFIG_STANDBY_SMART		(2 << 4)
+#define		SYSCONFIG_IDLE_FORCE		(0 << 2)
+#define		SYSCONFIG_IDLE_NONE		(1 << 2)
+#define		SYSCONFIG_IDLE_SMART		(2 << 2)
+#define	LCD_IRQSTATUS_RAW	0x58
+#define	LCD_IRQSTATUS		0x5C
+#define	LCD_IRQENABLE_SET	0x60
+#define	LCD_IRQENABLE_CLEAR	0x64
+#define		IRQ_EOF1		(1 << 9)
+#define		IRQ_EOF0		(1 << 8)
+#define		IRQ_PL			(1 << 6)
+#define		IRQ_FUF			(1 << 5)
+#define		IRQ_ACB			(1 << 3)
+#define		IRQ_SYNC_LOST		(1 << 2)
+#define		IRQ_RASTER_DONE		(1 << 1)
+#define		IRQ_FRAME_DONE		(1 << 0)
+#define	LCD_END_OF_INT_IND	0x68
+#define	LCD_CLKC_ENABLE		0x6C
+#define		CLKC_ENABLE_DMA		(1 << 2)
+#define		CLKC_ENABLE_LDID	(1 << 1)
+#define		CLKC_ENABLE_CORE	(1 << 0)
+#define	LCD_CLKC_RESET		0x70
+#define		CLKC_RESET_MAIN		(1 << 3)
+#define		CLKC_RESET_DMA		(1 << 2)
+#define		CLKC_RESET_LDID		(1 << 1)
+#define		CLKC_RESET_CORE		(1 << 0)
+#define	LCD_LOCK(_sc)		mtx_lock(&(_sc)->sc_mtx)
+#define	LCD_UNLOCK(_sc)		mtx_unlock(&(_sc)->sc_mtx)
+#define	LCD_LOCK_INIT(_sc)	mtx_init(&(_sc)->sc_mtx, \
+    device_get_nameunit(_sc->sc_dev), "am335x_lcd", MTX_DEF)
+#define	LCD_LOCK_DESTROY(_sc)	mtx_destroy(&(_sc)->sc_mtx);
+#define	LCD_READ4(_sc, reg)	bus_read_4((_sc)->sc_mem_res, reg);
+#define	LCD_WRITE4(_sc, reg, value)	\
+/* Backlight is controlled by eCAS interface on PWM unit 0 */
+#define	PWM_UNIT	0
+#define	PWM_PERIOD	100
+#define	MODE_HBP(mode)	((mode)->htotal - (mode)->hsync_end)
+#define	MODE_HFP(mode)	((mode)->hsync_start - (mode)->hdisplay)
+#define	MODE_HSW(mode)	((mode)->hsync_end - (mode)->hsync_start)
+#define	MODE_VBP(mode)	((mode)->vtotal - (mode)->vsync_end)
+#define	MODE_VFP(mode)	((mode)->vsync_start - (mode)->vdisplay)
+#define	MODE_VSW(mode)	((mode)->vsync_end - (mode)->vsync_start)
+#define	MAX_PIXEL_CLOCK	126000
+#define	MAX_BANDWIDTH	(1280*1024*60)
+struct am335x_lcd_softc {
+	device_t		sc_dev;
+	struct fb_info		sc_fb_info;
+	struct resource		*sc_irq_res;
+	void			*sc_intr_hl;
+	int			sc_backlight;
+	struct sysctl_oid	*sc_oid;
+	struct panel_info	sc_panel;
+	/* Framebuffer */
+	bus_dma_tag_t		sc_dma_tag;
+	bus_dmamap_t		sc_dma_map;
+	size_t			sc_fb_size;
+	bus_addr_t		sc_fb_phys;
+	uint8_t			*sc_fb_base;
+	/* HDMI framer */
+	phandle_t		sc_hdmi_framer;
+	eventhandler_tag	sc_hdmi_evh;
+static void
+am335x_fb_dmamap_cb(void *arg, bus_dma_segment_t *segs, int nseg, int err)
+	bus_addr_t *addr;
+	if (err)
+		return;
+	addr = (bus_addr_t*)arg;
+	*addr = segs[0].ds_addr;
+static uint32_t
+am335x_lcd_calc_divisor(uint32_t reference, uint32_t freq)
+	uint32_t div, i;
+	uint32_t delta, min_delta;
+	min_delta = freq;
+	div = 255;
+	/* Raster mode case: divisors are in range from 2 to 255 */
+	for (i = 2; i < 255; i++) {
+		delta = abs(reference/i - freq);
+		if (delta < min_delta) {
+			div = i;
+			min_delta = delta;
+	return (div);
+static int
+am335x_lcd_sysctl_backlight(SYSCTL_HANDLER_ARGS)
+	struct am335x_lcd_softc *sc = (struct am335x_lcd_softc*)arg1;
+	int error;
+	int backlight;
+	backlight = sc->sc_backlight;
+	error = sysctl_handle_int(oidp, &backlight, 0, req);
+	if (error != 0 || req->newptr == NULL)
+		return (error);
+	if (backlight < 0)
+		backlight = 0;
+	if (backlight > 100)
+		backlight = 100;
+	LCD_LOCK(sc);
+	error = am335x_pwm_config_ecap(PWM_UNIT, PWM_PERIOD,
+	    backlight*PWM_PERIOD/100);
+	if (error == 0)
+		sc->sc_backlight = backlight;
+	LCD_UNLOCK(sc);
+	return (error);
+static uint32_t
+am335x_mode_vrefresh(const struct videomode *mode)
+	uint32_t refresh;
+	/* Calculate vertical refresh rate */
+        refresh = (mode->dot_clock * 1000 / mode->htotal);
+	refresh = (refresh + mode->vtotal / 2) / mode->vtotal;
+	if (mode->flags & VID_INTERLACE)
+		refresh *= 2;
+	if (mode->flags & VID_DBLSCAN)
+		refresh /= 2;
+	return refresh;
+static int
+am335x_mode_is_valid(const struct videomode *mode)
+	uint32_t hbp, hfp, hsw;
+	uint32_t vbp, vfp, vsw;
+	if (mode->dot_clock > MAX_PIXEL_CLOCK)
+		return (0);
+	if (mode->hdisplay & 0xf)
+		return (0);
+	if (mode->vdisplay > 2048)
+		return (0);
+	/* Check ranges for timing parameters */
+	hbp = MODE_HBP(mode) - 1;
+	hfp = MODE_HFP(mode) - 1;
+	hsw = MODE_HSW(mode) - 1;
+	vbp = MODE_VBP(mode);
+	vfp = MODE_VFP(mode);
+	vsw = MODE_VSW(mode) - 1;
+	if (hbp > 0x3ff)
+		return (0);
+	if (hfp > 0x3ff)
+		return (0);
+	if (hsw > 0x3ff)
+		return (0);
+	if (vbp > 0xff)
+		return (0);
+	if (vfp > 0xff)
+		return (0);
+	if (vsw > 0x3f)
+		return (0);
+	if (mode->vdisplay*mode->hdisplay*am335x_mode_vrefresh(mode)
+	    > MAX_BANDWIDTH)
+		return (0);
+	return (1);
+static void
+am335x_read_hdmi_property(device_t dev)
+	phandle_t node, xref;
+	phandle_t endpoint;
+	phandle_t hdmi_xref;
+	struct am335x_lcd_softc *sc;
+	node = ofw_bus_get_node(dev);
+	sc->sc_hdmi_framer = 0;
+	 * Old FreeBSD way of referencing to HDMI framer
+	if (OF_getencprop(node, "hdmi", &hdmi_xref, sizeof(hdmi_xref)) != -1) {
+		sc->sc_hdmi_framer = hdmi_xref;
+		return;
+	 * Use bindings described in Linux docs:
+	 * bindings/media/video-interfaces.txt
+	 * We assume that the only endpoint in LCDC node
+	 * is HDMI framer.
+	node = ofw_bus_find_child(node, "port");
+	/* No media bindings */
+	if (node == 0)
+		return;
+	for (endpoint = OF_child(node); endpoint != 0; endpoint = OF_peer(endpoint)) {
+		if (OF_getencprop(endpoint, "remote-endpoint", &xref, sizeof(xref)) != -1) {
+			/* port/port at 0/endpoint at 0 */
+			node = OF_node_from_xref(xref);
+			/* port/port at 0 */
+			node = OF_parent(node);
+			/* port */
+			/* actual owner of port, in our case HDMI framer */
+			sc->sc_hdmi_framer = OF_xref_from_node(OF_parent(node));
+			if (sc->sc_hdmi_framer != 0)
+				return;
+static int
+am335x_read_property(device_t dev, phandle_t node, const char *name, uint32_t *val)
+	pcell_t cell;
+	if ((OF_getencprop(node, name, &cell, sizeof(cell))) <= 0) {
+		device_printf(dev, "missing '%s' attribute in LCD panel info\n",
+		    name);
+		return (ENXIO);
+	*val = cell;
+	return (0);
+static int
+am335x_read_timing(device_t dev, phandle_t node, struct panel_info *panel)
+	int error;
+	phandle_t timings_node, timing_node, native;
+	timings_node = ofw_bus_find_child(node, "display-timings");
+	if (timings_node == 0) {
+		device_printf(dev, "no \"display-timings\" node\n");
+		return (-1);
+	if (OF_searchencprop(timings_node, "native-mode", &native,
+	    sizeof(native)) == -1) {
+		device_printf(dev, "no \"native-mode\" reference in \"timings\" node\n");
+		return (-1);
+	timing_node = OF_node_from_xref(native);
+	error = 0;
+	if ((error = am335x_read_property(dev, timing_node,
+	    "hactive", &panel->panel_width)))
+		goto out;
+	    "vactive", &panel->panel_height)))
+		goto out;
+	    "hfront-porch", &panel->panel_hfp)))
+		goto out;
+	    "hback-porch", &panel->panel_hbp)))
+		goto out;
+	    "hsync-len", &panel->panel_hsw)))
+		goto out;
+	    "vfront-porch", &panel->panel_vfp)))
+		goto out;
+	    "vback-porch", &panel->panel_vbp)))
+		goto out;
+	    "vsync-len", &panel->panel_vsw)))
+		goto out;
+	    "clock-frequency", &panel->panel_pxl_clk)))
+		goto out;
+	    "pixelclk-active", &panel->pixelclk_active)))
+		goto out;
+	    "hsync-active", &panel->hsync_active)))
+		goto out;
+	    "vsync-active", &panel->vsync_active)))
+		goto out;
+out:
+	return (error);
+static int
+am335x_read_panel_info(device_t dev, phandle_t node, struct panel_info *panel)
+	phandle_t panel_info_node;
+	panel_info_node = ofw_bus_find_child(node, "panel-info");
+	if (panel_info_node == 0)
+		return (-1);
+	am335x_read_property(dev, panel_info_node,
+	    "ac-bias", &panel->ac_bias);
+	    "ac-bias-intrpt", &panel->ac_bias_intrpt);
+	    "dma-burst-sz", &panel->dma_burst_sz);
+	    "bpp", &panel->bpp);
+	    "fdd", &panel->fdd);
+	    "sync-edge", &panel->sync_edge);
+	    "sync-ctrl", &panel->sync_ctrl);
+	return (0);
+static void
+am335x_lcd_intr(void *arg)
+	struct am335x_lcd_softc *sc = arg;
+	uint32_t reg;
+	reg = LCD_READ4(sc, LCD_IRQSTATUS);
+	LCD_WRITE4(sc, LCD_IRQSTATUS, reg);
+	/* Read value back to make sure it reached the hardware */
+	if (reg & IRQ_SYNC_LOST) {
+		reg = LCD_READ4(sc, LCD_RASTER_CTRL);
+		reg &= ~RASTER_CTRL_LCDEN;
+		LCD_WRITE4(sc, LCD_RASTER_CTRL, reg);
+		reg |= RASTER_CTRL_LCDEN;
+		goto done;
+	if (reg & IRQ_PL) {
+		goto done;
+	if (reg & IRQ_EOF0) {
+		LCD_WRITE4(sc, LCD_LCDDMA_FB0_BASE, sc->sc_fb_phys);
+		LCD_WRITE4(sc, LCD_LCDDMA_FB0_CEILING, sc->sc_fb_phys + sc->sc_fb_size - 1);
+		reg &= ~IRQ_EOF0;
+	if (reg & IRQ_EOF1) {
+		LCD_WRITE4(sc, LCD_LCDDMA_FB1_BASE, sc->sc_fb_phys);
+		LCD_WRITE4(sc, LCD_LCDDMA_FB1_CEILING, sc->sc_fb_phys + sc->sc_fb_size - 1);
+		reg &= ~IRQ_EOF1;
+	if (reg & IRQ_FUF) {
+		/* TODO: Handle FUF */
+	if (reg & IRQ_ACB) {
+		/* TODO: Handle ACB */
+done:
+	LCD_WRITE4(sc, LCD_END_OF_INT_IND, 0);
+	reg = LCD_READ4(sc, LCD_END_OF_INT_IND);
+static const struct videomode *
+am335x_lcd_pick_mode(struct edid_info *ei)
+	const struct videomode *videomode;
+	const struct videomode *m;
+	int n;
+	/* Get standard VGA as default */
+	videomode = NULL;
+	 * Pick a mode.
+	if (ei->edid_preferred_mode != NULL) {
+		if (am335x_mode_is_valid(ei->edid_preferred_mode))
+			videomode = ei->edid_preferred_mode;
+	if (videomode == NULL) {
+		m = ei->edid_modes;
+		sort_modes(ei->edid_modes,
+		    &ei->edid_preferred_mode,
+		    ei->edid_nmodes);
+		for (n = 0; n < ei->edid_nmodes; n++)
+			if (am335x_mode_is_valid(&m[n])) {
+				videomode = &m[n];
+				break;
+	return videomode;
+static int
+am335x_lcd_configure(struct am335x_lcd_softc *sc)
+	int div;
+	uint32_t reg, timing0, timing1, timing2;
+	uint32_t burst_log;
+	size_t dma_size;
+	uint32_t width, height;
+	unsigned int ref_freq;
+	int err;
+	 * try to adjust clock to get double of requested frequency
+	 * HDMI/DVI displays are very sensitive to error in frequncy value
+	if (ti_prcm_clk_set_source_freq(LCDC_CLK, sc->sc_panel.panel_pxl_clk*2)) {
+		device_printf(sc->sc_dev, "can't set source frequency\n");
+		return (ENXIO);
+	if (ti_prcm_clk_get_source_freq(LCDC_CLK, &ref_freq)) {
+		device_printf(sc->sc_dev, "can't get reference frequency\n");
+		return (ENXIO);
+	/* Panle initialization */
+	dma_size = round_page(sc->sc_panel.panel_width*sc->sc_panel.panel_height*sc->sc_panel.bpp/8);
+	 * Now allocate framebuffer memory
+	err = bus_dma_tag_create(
+	    bus_get_dma_tag(sc->sc_dev),
+	    4, 0,		/* alignment, boundary */
+	    BUS_SPACE_MAXADDR_32BIT,	/* lowaddr */
+	    BUS_SPACE_MAXADDR,		/* highaddr */
+	    NULL, NULL,			/* filter, filterarg */
+	    dma_size, 1,			/* maxsize, nsegments */
+	    dma_size, 0,			/* maxsegsize, flags */
+	    NULL, NULL,			/* lockfunc, lockarg */
+	    &sc->sc_dma_tag);
+	if (err)
+		goto done;
+	err = bus_dmamem_alloc(sc->sc_dma_tag, (void **)&sc->sc_fb_base,
+	    BUS_DMA_COHERENT, &sc->sc_dma_map);
+	if (err) {
+		device_printf(sc->sc_dev, "cannot allocate framebuffer\n");
+		goto done;
+	err = bus_dmamap_load(sc->sc_dma_tag, sc->sc_dma_map, sc->sc_fb_base,
+	    dma_size, am335x_fb_dmamap_cb, &sc->sc_fb_phys, BUS_DMA_NOWAIT);
+	if (err) {
+		device_printf(sc->sc_dev, "cannot load DMA map\n");
+		goto done;
+	/* Make sure it's blank */
+	memset(sc->sc_fb_base, 0x0, dma_size);
+	/* Calculate actual FB Size */
+	sc->sc_fb_size = sc->sc_panel.panel_width*sc->sc_panel.panel_height*sc->sc_panel.bpp/8;
+	/* Only raster mode is supported */
+	reg = CTRL_RASTER_MODE;
+	div = am335x_lcd_calc_divisor(ref_freq, sc->sc_panel.panel_pxl_clk);
+	reg |= (div << CTRL_DIV_SHIFT);
+	LCD_WRITE4(sc, LCD_CTRL, reg);
+	/* Set timing */
+	timing0 = timing1 = timing2 = 0;
+	hbp = sc->sc_panel.panel_hbp - 1;
+	hfp = sc->sc_panel.panel_hfp - 1;
+	hsw = sc->sc_panel.panel_hsw - 1;
+	vbp = sc->sc_panel.panel_vbp;
+	vfp = sc->sc_panel.panel_vfp;
+	vsw = sc->sc_panel.panel_vsw - 1;
+	height = sc->sc_panel.panel_height - 1;
+	width = sc->sc_panel.panel_width - 1;
+	/* Horizontal back porch */
+	timing0 |= (hbp & 0xff) << RASTER_TIMING_0_HBP_SHIFT;
+	timing2 |= ((hbp >> 8) & 3) << RASTER_TIMING_2_HBPHI_SHIFT;
+	/* Horizontal front porch */
+	timing0 |= (hfp & 0xff) << RASTER_TIMING_0_HFP_SHIFT;
+	timing2 |= ((hfp >> 8) & 3) << RASTER_TIMING_2_HFPHI_SHIFT;
+	/* Horizontal sync width */
+	timing0 |= (hsw & 0x3f) << RASTER_TIMING_0_HSW_SHIFT;
+	timing2 |= ((hsw >> 6) & 0xf) << RASTER_TIMING_2_HSWHI_SHIFT;
+	/* Vertical back porch, front porch, sync width */
+	timing1 |= (vbp & 0xff) << RASTER_TIMING_1_VBP_SHIFT;
+	timing1 |= (vfp & 0xff) << RASTER_TIMING_1_VFP_SHIFT;
+	timing1 |= (vsw & 0x3f) << RASTER_TIMING_1_VSW_SHIFT;
+	/* Pixels per line */
+	timing0 |= ((width >> 10) & 1)
+	    << RASTER_TIMING_0_PPLMSB_SHIFT;
+	timing0 |= ((width >> 4) & 0x3f)
+	    << RASTER_TIMING_0_PPLLSB_SHIFT;
+	/* Lines per panel */
+	timing1 |= (height & 0x3ff)
+	    << RASTER_TIMING_1_LPP_SHIFT;
+	timing2 |= ((height >> 10 ) & 1)
+	    << RASTER_TIMING_2_LPP_B10_SHIFT;
+	/* clock signal settings */
+	if (sc->sc_panel.sync_ctrl)
+		timing2 |= RASTER_TIMING_2_PHSVS;
+	if (sc->sc_panel.sync_edge)
+		timing2 |= RASTER_TIMING_2_PHSVS_RISE;
+	else
+		timing2 |= RASTER_TIMING_2_PHSVS_FALL;
+	if (sc->sc_panel.hsync_active == 0)
+		timing2 |= RASTER_TIMING_2_IHS;
+	if (sc->sc_panel.vsync_active == 0)
+		timing2 |= RASTER_TIMING_2_IVS;
+	if (sc->sc_panel.pixelclk_active == 0)
+		timing2 |= RASTER_TIMING_2_IPC;
+	/* AC bias */
+	timing2 |= (sc->sc_panel.ac_bias << RASTER_TIMING_2_ACB_SHIFT);
+	timing2 |= (sc->sc_panel.ac_bias_intrpt << RASTER_TIMING_2_ACBI_SHIFT);
+	LCD_WRITE4(sc, LCD_RASTER_TIMING_0, timing0);
+	LCD_WRITE4(sc, LCD_RASTER_TIMING_1, timing1);
+	LCD_WRITE4(sc, LCD_RASTER_TIMING_2, timing2);
+	/* DMA settings */
+	reg = LCDDMA_CTRL_FB0_FB1;
+	/* Find power of 2 for current burst size */
+	switch (sc->sc_panel.dma_burst_sz) {
+	case 1:
+		burst_log = 0;
+		break;
+	case 2:
+		burst_log = 1;
+		break;
+	case 4:
+		burst_log = 2;
+		break;
+	case 8:
+		burst_log = 3;
+		break;
+	case 16:
+	default:
+		burst_log = 4;
+		break;
+	reg |= (burst_log << LCDDMA_CTRL_BURST_SIZE_SHIFT);
+	/* XXX: FIFO TH */
+	reg |= (0 << LCDDMA_CTRL_TH_FIFO_RDY_SHIFT);
+	LCD_WRITE4(sc, LCD_LCDDMA_CTRL, reg);
+	/* Enable LCD */
+	reg = RASTER_CTRL_LCDTFT;
+	reg |= (sc->sc_panel.fdd << RASTER_CTRL_REQDLY_SHIFT);
+	reg |= (PALETTE_DATA_ONLY << RASTER_CTRL_PALMODE_SHIFT);
+	if (sc->sc_panel.bpp >= 24)
+		reg |= RASTER_CTRL_TFT24;
+	if (sc->sc_panel.bpp == 32)
+		reg |= RASTER_CTRL_TFT24_UNPACKED;
+	LCD_WRITE4(sc, LCD_CLKC_ENABLE,
+	    CLKC_ENABLE_DMA | CLKC_ENABLE_LDID | CLKC_ENABLE_CORE);
+	LCD_WRITE4(sc, LCD_CLKC_RESET, CLKC_RESET_MAIN);
+	DELAY(100);
+	LCD_WRITE4(sc, LCD_CLKC_RESET, 0);
+	reg = IRQ_EOF1 | IRQ_EOF0 | IRQ_FUF | IRQ_PL |
+	    IRQ_ACB | IRQ_SYNC_LOST |  IRQ_RASTER_DONE |
+	    IRQ_FRAME_DONE;
+	LCD_WRITE4(sc, LCD_IRQENABLE_SET, reg);
+	LCD_WRITE4(sc, LCD_SYSCONFIG,
+	    SYSCONFIG_STANDBY_SMART | SYSCONFIG_IDLE_SMART);
+	sc->sc_fb_info.fb_name = device_get_nameunit(sc->sc_dev);
+	sc->sc_fb_info.fb_vbase = (intptr_t)sc->sc_fb_base;
+	sc->sc_fb_info.fb_pbase = sc->sc_fb_phys;
+	sc->sc_fb_info.fb_size = sc->sc_fb_size;
+	sc->sc_fb_info.fb_bpp = sc->sc_fb_info.fb_depth = sc->sc_panel.bpp;
+	sc->sc_fb_info.fb_stride = sc->sc_panel.panel_width*sc->sc_panel.bpp / 8;
+	sc->sc_fb_info.fb_width = sc->sc_panel.panel_width;
+	sc->sc_fb_info.fb_height = sc->sc_panel.panel_height;
+#ifdef	DEV_SC
+	err = (sc_attach_unit(device_get_unit(sc->sc_dev),
+	    device_get_flags(sc->sc_dev) | SC_AUTODETECT_KBD));
+	if (err) {
+		device_printf(sc->sc_dev, "failed to attach syscons\n");
+		goto fail;
+	am335x_lcd_syscons_setup((vm_offset_t)sc->sc_fb_base, sc->sc_fb_phys, &panel);
+#else /* VT */
+	device_t fbd = device_add_child(sc->sc_dev, "fbd",
+	device_get_unit(sc->sc_dev));
+	if (fbd != NULL) {
+		if (device_probe_and_attach(fbd) != 0)
+			device_printf(sc->sc_dev, "failed to attach fbd device\n");
+	} else
+		device_printf(sc->sc_dev, "failed to add fbd child\n");
+#endif
+done:
+	return (err);
+static void
+am335x_lcd_hdmi_event(void *arg, device_t hdmi, int event)
+	struct videomode hdmi_mode;
+	device_t hdmi_dev;
+	uint8_t *edid;
+	uint32_t edid_len;
+	struct edid_info ei;
+	sc = arg;
+	/* Nothing to work with */
+	if (!sc->sc_hdmi_framer) {
+		device_printf(sc->sc_dev, "HDMI event without HDMI framer set\n");
+		return;
+	hdmi_dev = OF_device_from_xref(sc->sc_hdmi_framer);
+	if (!hdmi_dev) {
+		device_printf(sc->sc_dev, "no actual device for \"hdmi\" property\n");
+		return;
+	edid = NULL;
+	edid_len = 0;
+	if (HDMI_GET_EDID(hdmi_dev, &edid, &edid_len) != 0) {
+		device_printf(sc->sc_dev, "failed to get EDID info from HDMI framer\n");
+		return;
+	videomode = NULL;
+	if (edid_parse(edid, &ei) == 0) {
+		edid_print(&ei);
+		videomode = am335x_lcd_pick_mode(&ei);
+	} else
+		device_printf(sc->sc_dev, "failed to parse EDID\n");
+	/* Use standard VGA as fallback */
+		videomode = pick_mode_by_ref(640, 480, 60);
+		device_printf(sc->sc_dev, "failed to find usable videomode");
+		return;
+	device_printf(sc->sc_dev, "detected videomode: %dx%d @ %dKHz\n", videomode->hdisplay,
+		videomode->vdisplay, am335x_mode_vrefresh(videomode));
+	sc->sc_panel.panel_width = videomode->hdisplay;
+	sc->sc_panel.panel_height = videomode->vdisplay;
+	sc->sc_panel.panel_hfp = videomode->hsync_start - videomode->hdisplay;
+	sc->sc_panel.panel_hbp = videomode->htotal - videomode->hsync_end;
+	sc->sc_panel.panel_hsw = videomode->hsync_end - videomode->hsync_start;
+	sc->sc_panel.panel_vfp = videomode->vsync_start - videomode->vdisplay;
+	sc->sc_panel.panel_vbp = videomode->vtotal - videomode->vsync_end;
+	sc->sc_panel.panel_vsw = videomode->vsync_end - videomode->vsync_start;
+	sc->sc_panel.pixelclk_active = 1;
+	/* logic for HSYNC should be reversed */
+	if (videomode->flags & VID_NHSYNC)
+		sc->sc_panel.hsync_active = 1;
+	else
+		sc->sc_panel.hsync_active = 0;
+	if (videomode->flags & VID_NVSYNC)
+		sc->sc_panel.vsync_active = 0;
+	else
+		sc->sc_panel.vsync_active = 1;
+	sc->sc_panel.panel_pxl_clk = videomode->dot_clock * 1000;
+	am335x_lcd_configure(sc);
+	memcpy(&hdmi_mode, videomode, sizeof(hdmi_mode));
+	hdmi_mode.hskew = videomode->hsync_end - videomode->hsync_start;
+	hdmi_mode.flags |= VID_HSKEW;
+	HDMI_SET_VIDEOMODE(hdmi_dev, &hdmi_mode);
+static int
+am335x_lcd_probe(device_t dev)
+#ifdef DEV_SC
+	int err;
+#endif
+		return (ENXIO);
+	if (!ofw_bus_is_compatible(dev, "ti,am33xx-tilcdc"))
+		return (ENXIO);
+	device_set_desc(dev, "AM335x LCD controller");
+#ifdef DEV_SC
+	err = sc_probe_unit(device_get_unit(dev),
+	    device_get_flags(dev) | SC_AUTODETECT_KBD);
+	if (err != 0)
+		return (err);
+#endif
+static int
+am335x_lcd_attach(device_t dev)
+	int err;
+	int rid;
+	struct sysctl_ctx_list *ctx;
+	struct sysctl_oid *tree;
+	phandle_t root, panel_node;
+	err = 0;
+	sc->sc_dev = dev;
+	am335x_read_hdmi_property(dev);
+	root = OF_finddevice("/");
+	if (root == -1) {
+		device_printf(dev, "failed to get FDT root node\n");
+		return (ENXIO);
+	sc->sc_panel.ac_bias = 255;
+	sc->sc_panel.ac_bias_intrpt = 0;
+	sc->sc_panel.dma_burst_sz = 16;
+	sc->sc_panel.bpp = 16;
+	sc->sc_panel.fdd = 128;
+	sc->sc_panel.sync_edge = 0;
+	sc->sc_panel.sync_ctrl = 1;
+	panel_node = fdt_find_compatible(root, "ti,tilcdc,panel", 1);
+	if (panel_node != 0) {
+		device_printf(dev, "using static panel info\n");
+		if (am335x_read_panel_info(dev, panel_node, &sc->sc_panel)) {
+			device_printf(dev, "failed to read panel info\n");
+			return (ENXIO);
+		if (am335x_read_timing(dev, panel_node, &sc->sc_panel)) {
+			device_printf(dev, "failed to read timings\n");
+			return (ENXIO);
+	ti_prcm_clk_enable(LCDC_CLK);
+	rid = 0;
+	sc->sc_mem_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid,
+	    RF_ACTIVE);
+	if (!sc->sc_mem_res) {
+		device_printf(dev, "cannot allocate memory window\n");
+		return (ENXIO);
+	rid = 0;
+	sc->sc_irq_res = bus_alloc_resource_any(dev, SYS_RES_IRQ, &rid,
+	    RF_ACTIVE);
+	if (!sc->sc_irq_res) {
+		bus_release_resource(dev, SYS_RES_MEMORY, 0, sc->sc_mem_res);
+		device_printf(dev, "cannot allocate interrupt\n");
+		return (ENXIO);
+	if (bus_setup_intr(dev, sc->sc_irq_res, INTR_TYPE_MISC | INTR_MPSAFE,
+			NULL, am335x_lcd_intr, sc,
+			&sc->sc_intr_hl) != 0) {
+		bus_release_resource(dev, SYS_RES_IRQ, rid,
+		    sc->sc_irq_res);
+		bus_release_resource(dev, SYS_RES_MEMORY, rid,
+		    sc->sc_mem_res);
+		device_printf(dev, "Unable to setup the irq handler.\n");
+		return (ENXIO);
+	LCD_LOCK_INIT(sc);
+	/* Init backlight interface */
+	ctx = device_get_sysctl_ctx(sc->sc_dev);
+	tree = device_get_sysctl_tree(sc->sc_dev);
+	sc->sc_oid = SYSCTL_ADD_PROC(ctx, SYSCTL_CHILDREN(tree), OID_AUTO,
+	    "backlight", CTLTYPE_INT | CTLFLAG_RW, sc, 0,
+	    am335x_lcd_sysctl_backlight, "I", "LCD backlight");
+	sc->sc_backlight = 0;
+	/* Check if eCAS interface is available at this point */
+	if (am335x_pwm_config_ecap(PWM_UNIT,
+	    PWM_PERIOD, PWM_PERIOD) == 0)
+		sc->sc_backlight = 100;
+	else
+		sc->sc_hdmi_evh = EVENTHANDLER_REGISTER(hdmi_event,
+		    am335x_lcd_hdmi_event, sc, EVENTHANDLER_PRI_ANY);
+	return (0);
+static int
+am335x_lcd_detach(device_t dev)
+	/* Do not let unload driver */
+	return (EBUSY);
+static struct fb_info *
+am335x_lcd_fb_getinfo(device_t dev)
+	return (&sc->sc_fb_info);
+static device_method_t am335x_lcd_methods[] = {
+	DEVMETHOD(device_probe,		am335x_lcd_probe),
+	DEVMETHOD(device_attach,	am335x_lcd_attach),
+	DEVMETHOD(device_detach,	am335x_lcd_detach),
+	/* Framebuffer service methods */
+	DEVMETHOD(fb_getinfo,		am335x_lcd_fb_getinfo),
+	DEVMETHOD_END
+static driver_t am335x_lcd_driver = {
+	"fb",
+	am335x_lcd_methods,
+	sizeof(struct am335x_lcd_softc),
+static devclass_t am335x_lcd_devclass;
+DRIVER_MODULE(am335x_lcd, simplebus, am335x_lcd_driver, am335x_lcd_devclass, 0, 0);
+MODULE_VERSION(am335x_lcd, 1);
+MODULE_DEPEND(am335x_lcd, simplebus, 1, 1, 1);
diff --git a/freebsd/sys/arm/ti/am335x/am335x_lcd.h b/freebsd/sys/arm/ti/am335x/am335x_lcd.h
index 00000000..f230a930
--- /dev/null
+++ b/freebsd/sys/arm/ti/am335x/am335x_lcd.h
@@ -0,0 +1,60 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef __AM335X_LCD_H__
+#define __AM335X_LCD_H__
+struct panel_info {
+	/* Timing part */
+	uint32_t panel_width;
+	uint32_t panel_height;
+	uint32_t panel_hfp;
+	uint32_t panel_hbp;
+	uint32_t panel_hsw;
+	uint32_t panel_vfp;
+	uint32_t panel_vbp;
+	uint32_t panel_vsw;
+	uint32_t hsync_active;
+	uint32_t vsync_active;
+	uint32_t panel_pxl_clk;
+	uint32_t ac_bias;
+	uint32_t ac_bias_intrpt;
+	uint32_t dma_burst_sz;
+	uint32_t bpp;
+	uint32_t fdd;
+	uint32_t sync_edge;
+	uint32_t sync_ctrl;
+	uint32_t pixelclk_active;
+int am335x_lcd_syscons_setup(vm_offset_t vaddr, vm_paddr_t paddr,
+    struct panel_info *panel);
+#endif /* __AM335X_LCD_H__ */
diff --git a/freebsd/sys/arm/ti/am335x/am335x_pwm.h b/freebsd/sys/arm/ti/am335x/am335x_pwm.h
index 00000000..956913dc
--- /dev/null
+++ b/freebsd/sys/arm/ti/am335x/am335x_pwm.h
@@ -0,0 +1,35 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef __AM335X_PWM_H__
+#define __AM335X_PWM_H__
+int am335x_pwm_config_ecap(int unit, int period, int duty);
+#endif /* __AM335X_PWM_H__ */
diff --git a/freebsd/sys/arm/ti/am335x/am335x_pwmss.c b/freebsd/sys/arm/ti/am335x/am335x_pwmss.c
index 00000000..f9249989
--- /dev/null
+++ b/freebsd/sys/arm/ti/am335x/am335x_pwmss.c
@@ -0,0 +1,165 @@
+ * are met:
+ * SUCH DAMAGE.
+#include <dev/fdt/simplebus.h>
+#include <arm/ti/ti_hwmods.h>
+#include "am335x_scm.h"
+#define	PWMSS_IDVER		0x00
+#define	PWMSS_SYSCONFIG		0x04
+#define	PWMSS_CLKCONFIG		0x08
+#define		CLKCONFIG_EPWMCLK_EN	(1 << 8)
+#define	PWMSS_CLKSTATUS		0x0C
+static device_probe_t am335x_pwmss_probe;
+static device_attach_t am335x_pwmss_attach;
+static device_detach_t am335x_pwmss_detach;
+struct am335x_pwmss_softc {
+	struct simplebus_softc	sc_simplebus;
+	device_t		sc_dev;
+	clk_ident_t		sc_clk;
+static device_method_t am335x_pwmss_methods[] = {
+	DEVMETHOD(device_probe,		am335x_pwmss_probe),
+	DEVMETHOD(device_attach,	am335x_pwmss_attach),
+	DEVMETHOD(device_detach,	am335x_pwmss_detach),
+	DEVMETHOD_END
+static int
+am335x_pwmss_probe(device_t dev)
+		return (ENXIO);
+	if (!ofw_bus_is_compatible(dev, "ti,am33xx-pwmss"))
+		return (ENXIO);
+	device_set_desc(dev, "AM335x PWM");
+static int
+am335x_pwmss_attach(device_t dev)
+	struct am335x_pwmss_softc *sc;
+	uint32_t reg, id;
+	phandle_t node;
+	sc->sc_dev = dev;
+	sc->sc_clk = ti_hwmods_get_clock(dev);
+	if (sc->sc_clk == INVALID_CLK_IDENT) {
+		device_printf(dev, "failed to get device id based on ti,hwmods\n");
+		return (EINVAL);
+	ti_prcm_clk_enable(sc->sc_clk);
+	ti_scm_reg_read_4(SCM_PWMSS_CTRL, &reg);
+	switch (sc->sc_clk) {
+		case PWMSS0_CLK:
+			id = 0;
+			break;
+		case PWMSS1_CLK:
+			id = 1;
+			break;
+		case PWMSS2_CLK:
+			id = 2;
+			break;
+		default:
+			device_printf(dev, "unknown pwmss clock id: %d\n", sc->sc_clk);
+			return (EINVAL);
+	reg |= (1 << id);
+	ti_scm_reg_write_4(SCM_PWMSS_CTRL, reg);
+	if (node == -1)
+		return (ENXIO);
+	simplebus_init(dev, node);
+	 * Allow devices to identify.
+	bus_generic_probe(dev);
+	 * Now walk the OFW tree and attach top-level devices.
+	for (node = OF_child(node); node > 0; node = OF_peer(node))
+		simplebus_add_device(dev, node, 0, NULL, -1, NULL);
+	return (bus_generic_attach(dev));
+static int
+am335x_pwmss_detach(device_t dev)
+	return (0);
+DEFINE_CLASS_1(am335x_pwmss, am335x_pwmss_driver, am335x_pwmss_methods,
+    sizeof(struct am335x_pwmss_softc), simplebus_driver);
+static devclass_t am335x_pwmss_devclass;
+DRIVER_MODULE(am335x_pwmss, simplebus, am335x_pwmss_driver, am335x_pwmss_devclass, 0, 0);
+MODULE_VERSION(am335x_pwmss, 1);
diff --git a/freebsd/sys/sys/consio.h b/freebsd/sys/sys/consio.h
index 00000000..5dfedc4b
--- /dev/null
+++ b/freebsd/sys/sys/consio.h
@@ -0,0 +1,468 @@
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 1991-1996 Søren Schmidt
+ * are met:
+ *    in this position and unchanged.
+ * 3. The name of the author may not be used to endorse or promote products
+ *    derived from this software without specific prior written permission
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef	_SYS_CONSIO_H_
+#define	_SYS_CONSIO_H_
+#ifndef _KERNEL
+#include <sys/types.h>
+#endif
+#include <sys/ioccom.h>
+ * Console ioctl commands.  Some commands are named as KDXXXX, GIO_XXX, and
+ * PIO_XXX, rather than CONS_XXX, for historical and compatibility reasons.
+ * Some other CONS_XXX commands are works as wrapper around frame buffer
+ * ioctl commands FBIO_XXX.  Do not try to change all these commands,
+ * otherwise we shall have compatibility problems.
+/* get/set video mode */
+#define KD_TEXT		0		/* set text mode restore fonts  */
+#define KD_TEXT0	0		/* ditto			*/
+#define KD_GRAPHICS	1		/* set graphics mode 		*/
+#define KD_TEXT1	2		/* set text mode !restore fonts */
+#define KD_PIXEL	3		/* set pixel mode		*/
+#define KDGETMODE	_IOR('K', 9, int)
+#define KDSETMODE	_IOWINT('K', 10)
+/* set border color */
+#define KDSBORDER	_IOWINT('K', 13)
+/* set up raster(pixel) text mode */
+struct _scr_size {
+	int		scr_size[3];
+typedef struct _scr_size	scr_size_t;
+#define KDRASTER	_IOW('K', 100, scr_size_t)
+/* get/set screen char map */
+struct _scrmap {
+	char		scrmap[256];
+typedef struct _scrmap	scrmap_t;
+#define GIO_SCRNMAP	_IOR('k', 2, scrmap_t)
+#define PIO_SCRNMAP	_IOW('k', 3, scrmap_t)
+/* get the current text attribute */
+#define GIO_ATTR	_IOR('a', 0, int)
+/* get the current text color */
+#define GIO_COLOR	_IOR('c', 0, int)
+/* get the adapter type (equivalent to FBIO_ADPTYPE) */
+#define CONS_CURRENT	_IOR('c', 1, int)
+/* get the current video mode (equivalent to FBIO_GETMODE) */
+#define CONS_GET	_IOR('c', 2, int)
+/* not supported? */
+#define CONS_IO		_IO('c', 3)
+/* set blank time interval */
+#define CONS_BLANKTIME	_IOW('c', 4, int)
+/* set/get the screen saver (these ioctls are current noop) */
+struct ssaver	{
+#define MAXSSAVER	16
+	char		name[MAXSSAVER];
+	int		num;
+	long		time;
+typedef struct ssaver	ssaver_t;
+#define CONS_SSAVER	_IOW('c', 5, ssaver_t)
+#define CONS_GSAVER	_IOWR('c', 6, ssaver_t)
+ * Set the text cursor type.
+ * This is an old interface extended to support the CONS_HIDDEN_CURSOR bit.
+ * New code should use CONS_CURSORSHAPE.  CONS_CURSOR_ATTRS gives the 3
+ * bits supported by the (extended) old interface.  The old interface is
+ * especially unusable for hiding the cursor (even with its extension)
+ * since it changes the cursor on all vtys.
+#define CONS_CURSORTYPE	_IOW('c', 7, int)
+/* set the bell type to audible or visual */
+#define CONS_VISUAL_BELL (1 << 0)
+#define CONS_QUIET_BELL	(1 << 1)
+#define CONS_BELLTYPE	_IOW('c', 8, int)
+/* set the history (scroll back) buffer size (in lines) */
+#define CONS_HISTORY	_IOW('c', 9, int)
+/* clear the history (scroll back) buffer */
+#define CONS_CLRHIST	_IO('c', 10)
+/* mouse cursor ioctl */
+struct mouse_data {
+	int		x;
+	int 		y;
+	int 		z;
+	int 		buttons;
+typedef struct mouse_data mouse_data_t;
+struct mouse_mode {
+	int		mode;
+	int		signal;
+typedef struct mouse_mode mouse_mode_t;
+struct mouse_event {
+	int		id;			/* one based */
+	int		value;
+typedef struct mouse_event mouse_event_t;
+struct mouse_info {
+	int		operation;
+#define MOUSE_SHOW	0x01
+#define MOUSE_HIDE	0x02
+#define MOUSE_MOVEABS	0x03
+#define MOUSE_MOVEREL	0x04
+#define MOUSE_GETINFO	0x05
+#define MOUSE_MODE	0x06
+#define MOUSE_ACTION	0x07
+#define MOUSE_MOTION_EVENT	0x08
+#define MOUSE_BUTTON_EVENT	0x09
+#define MOUSE_MOUSECHAR	0x0a
+	union {
+		mouse_data_t	data;
+		mouse_mode_t	mode;
+		mouse_event_t	event;
+		int		mouse_char;
+	}		u;
+typedef struct mouse_info mouse_info_t;
+#define CONS_MOUSECTL	_IOWR('c', 10, mouse_info_t)
+/* see if the vty has been idle */
+#define CONS_IDLE	_IOR('c', 11, int)
+/* set the screen saver mode */
+#define CONS_NO_SAVER	(-1)
+#define CONS_LKM_SAVER	0
+#define CONS_USR_SAVER	1
+#define CONS_SAVERMODE	_IOW('c', 12, int)
+/* start the screen saver */
+#define CONS_SAVERSTART	_IOW('c', 13, int)
+/* set the text cursor shape (see also CONS_CURSORTYPE above) */
+#define CONS_BLINK_CURSOR	(1 << 0)
+#define CONS_CHAR_CURSOR	(1 << 1)
+#define CONS_HIDDEN_CURSOR	(1 << 2)
+#define CONS_CURSOR_ATTRS	(CONS_BLINK_CURSOR | CONS_CHAR_CURSOR |	\
+				 CONS_HIDDEN_CURSOR)
+#define CONS_CHARCURSOR_COLORS	(1 << 26)
+#define CONS_MOUSECURSOR_COLORS	(1 << 27)
+#define CONS_DEFAULT_CURSOR	(1 << 28)
+#define CONS_SHAPEONLY_CURSOR	(1 << 29)
+#define CONS_RESET_CURSOR	(1 << 30)
+#define CONS_LOCAL_CURSOR	(1U << 31)
+struct cshape {
+	/* shape[0]: flags, shape[1]: base, shape[2]: height */
+	int		shape[3];
+#define CONS_GETCURSORSHAPE _IOWR('c', 14, struct cshape)
+#define CONS_SETCURSORSHAPE _IOW('c', 15, struct cshape)
+/* set/get font data */
+struct fnt8 {
+	char		fnt8x8[8*256];
+typedef struct fnt8	fnt8_t;
+struct fnt14 {
+	char		fnt8x14[14*256];
+typedef struct fnt14	fnt14_t;
+struct fnt16 {
+	char		fnt8x16[16*256];
+typedef struct fnt16	fnt16_t;
+struct vfnt_map {
+	uint32_t	src;
+	uint16_t	dst;
+	uint16_t	len;
+typedef struct vfnt_map	vfnt_map_t;
+#define VFNT_MAP_NORMAL		0
+#define VFNT_MAP_NORMAL_RIGHT	1
+#define VFNT_MAP_BOLD		2
+#define VFNT_MAP_BOLD_RIGHT	3
+#define VFNT_MAPS		4
+struct vfnt {
+	vfnt_map_t	*map[VFNT_MAPS];
+	uint8_t		*glyphs;
+	unsigned int	map_count[VFNT_MAPS];
+	unsigned int	glyph_count;
+	unsigned int	width;
+	unsigned int	height;
+typedef struct vfnt	vfnt_t;
+#define PIO_FONT8x8	_IOW('c', 64, fnt8_t)
+#define GIO_FONT8x8	_IOR('c', 65, fnt8_t)
+#define PIO_FONT8x14	_IOW('c', 66, fnt14_t)
+#define GIO_FONT8x14	_IOR('c', 67, fnt14_t)
+#define PIO_FONT8x16	_IOW('c', 68, fnt16_t)
+#define GIO_FONT8x16	_IOR('c', 69, fnt16_t)
+#define PIO_VFONT	_IOW('c', 70, vfnt_t)
+#define GIO_VFONT	_IOR('c', 71, vfnt_t)
+#define PIO_VFONT_DEFAULT _IO('c', 72)
+/* get video mode information */
+struct colors	{
+	char		fore;
+	char		back;
+struct vid_info {
+	short		size;
+	short		m_num;
+	u_short		font_size;
+	u_short		mv_row, mv_col;
+	u_short		mv_rsz, mv_csz;
+	u_short		mv_hsz;
+	struct colors	mv_norm,
+			mv_rev,
+			mv_grfc;
+	u_char		mv_ovscan;
+	u_char		mk_keylock;
+typedef struct vid_info vid_info_t;
+#define CONS_GETINFO    _IOWR('c', 73, vid_info_t)
+/* get version */
+#define CONS_GETVERS	_IOR('c', 74, int)
+/* get the video adapter index (equivalent to FBIO_ADAPTER) */
+#define CONS_CURRENTADP	_IOR('c', 100, int)
+/* get the video adapter information (equivalent to FBIO_ADPINFO) */
+#define CONS_ADPINFO	_IOWR('c', 101, video_adapter_info_t)
+/* get the video mode information (equivalent to FBIO_MODEINFO) */
+#define CONS_MODEINFO	_IOWR('c', 102, video_info_t)
+/* find a video mode (equivalent to FBIO_FINDMODE) */
+#define CONS_FINDMODE	_IOWR('c', 103, video_info_t)
+/* set the frame buffer window origin (equivalent to FBIO_SETWINORG) */
+#define CONS_SETWINORG	_IOWINT('c', 104)
+/* use the specified keyboard */
+#define CONS_SETKBD	_IOWINT('c', 110)
+/* release the current keyboard */
+#define CONS_RELKBD	_IO('c', 111)
+struct scrshot {
+	int		x;
+	int		y;
+	int		xsize;
+	int		ysize;
+	u_int16_t*	buf;
+typedef struct scrshot scrshot_t;
+/* Snapshot the current video buffer */
+#define CONS_SCRSHOT	_IOWR('c', 105, scrshot_t)
+/* get/set the current terminal emulator info. */
+#define TI_NAME_LEN	32
+#define TI_DESC_LEN	64
+struct term_info {
+	int		ti_index;
+	int		ti_flags;
+	u_char		ti_name[TI_NAME_LEN];
+	u_char		ti_desc[TI_DESC_LEN];
+typedef struct term_info term_info_t;
+#define CONS_GETTERM	_IOWR('c', 112, term_info_t)
+#define CONS_SETTERM	_IOW('c', 113, term_info_t)
+ * Vty switching ioctl commands.
+/* get the next available vty */
+#define VT_OPENQRY	_IOR('v', 1, int)
+/* set/get vty switching mode */
+#ifndef _VT_MODE_DECLARED
+#define	_VT_MODE_DECLARED
+struct vt_mode {
+	char		mode;
+#define VT_AUTO		0		/* switching is automatic 	*/
+#define VT_PROCESS	1		/* switching controlled by prog */
+#define VT_KERNEL	255		/* switching controlled in kernel */
+	char		waitv;		/* not implemented yet 	SOS	*/
+	short		relsig;
+	short		acqsig;
+	short		frsig;		/* not implemented yet	SOS	*/
+typedef struct vt_mode vtmode_t;
+#endif /* !_VT_MODE_DECLARED */
+#define VT_SETMODE	_IOW('v', 2, vtmode_t)
+#define VT_GETMODE	_IOR('v', 3, vtmode_t)
+/* acknowledge release or acquisition of a vty */
+#define VT_FALSE	0
+#define VT_TRUE		1
+#define VT_ACKACQ	2
+#define VT_RELDISP	_IOWINT('v', 4)
+/* activate the specified vty */
+#define VT_ACTIVATE	_IOWINT('v', 5)
+/* wait until the specified vty is activate */
+#define VT_WAITACTIVE	_IOWINT('v', 6)
+/* get the currently active vty */
+#define VT_GETACTIVE	_IOR('v', 7, int)
+/* get the index of the vty */
+#define VT_GETINDEX	_IOR('v', 8, int)
+/* prevent switching vtys */
+#define VT_LOCKSWITCH	_IOW('v', 9, int)
+ * Video mode switching ioctl.  See sys/fbio.h for mode numbers.
+#define SW_B40x25 	_IO('S', M_B40x25)
+#define SW_C40x25  	_IO('S', M_C40x25)
+#define SW_B80x25  	_IO('S', M_B80x25)
+#define SW_C80x25  	_IO('S', M_C80x25)
+#define SW_BG320   	_IO('S', M_BG320)
+#define SW_CG320   	_IO('S', M_CG320)
+#define SW_BG640   	_IO('S', M_BG640)
+#define SW_EGAMONO80x25 _IO('S', M_EGAMONO80x25)
+#define SW_CG320_D    	_IO('S', M_CG320_D)
+#define SW_CG640_E    	_IO('S', M_CG640_E)
+#define SW_EGAMONOAPA 	_IO('S', M_EGAMONOAPA)
+#define SW_CG640x350  	_IO('S', M_CG640x350)
+#define SW_ENH_MONOAPA2 _IO('S', M_ENHMONOAPA2)
+#define SW_ENH_CG640  	_IO('S', M_ENH_CG640)
+#define SW_ENH_B40x25  	_IO('S', M_ENH_B40x25)
+#define SW_ENH_C40x25  	_IO('S', M_ENH_C40x25)
+#define SW_ENH_B80x25  	_IO('S', M_ENH_B80x25)
+#define SW_ENH_C80x25  	_IO('S', M_ENH_C80x25)
+#define SW_ENH_B80x43  	_IO('S', M_ENH_B80x43)
+#define SW_ENH_C80x43  	_IO('S', M_ENH_C80x43)
+#define SW_MCAMODE    	_IO('S', M_MCA_MODE)
+#define SW_VGA_C40x25	_IO('S', M_VGA_C40x25)
+#define SW_VGA_C80x25	_IO('S', M_VGA_C80x25)
+#define SW_VGA_C80x30	_IO('S', M_VGA_C80x30)
+#define SW_VGA_C80x50	_IO('S', M_VGA_C80x50)
+#define SW_VGA_C80x60	_IO('S', M_VGA_C80x60)
+#define SW_VGA_M80x25	_IO('S', M_VGA_M80x25)
+#define SW_VGA_M80x30	_IO('S', M_VGA_M80x30)
+#define SW_VGA_M80x50	_IO('S', M_VGA_M80x50)
+#define SW_VGA_M80x60	_IO('S', M_VGA_M80x60)
+#define SW_VGA11	_IO('S', M_VGA11)
+#define SW_BG640x480	_IO('S', M_VGA11)
+#define SW_VGA12	_IO('S', M_VGA12)
+#define SW_CG640x480	_IO('S', M_VGA12)
+#define SW_VGA13	_IO('S', M_VGA13)
+#define SW_VGA_CG320	_IO('S', M_VGA13)
+#define SW_VGA_CG640	_IO('S', M_VGA_CG640)
+#define SW_VGA_MODEX	_IO('S', M_VGA_MODEX)
+#define SW_VGA_C90x25	_IO('S', M_VGA_C90x25)
+#define SW_VGA_M90x25	_IO('S', M_VGA_M90x25)
+#define SW_VGA_C90x30	_IO('S', M_VGA_C90x30)
+#define SW_VGA_M90x30	_IO('S', M_VGA_M90x30)
+#define SW_VGA_C90x43	_IO('S', M_VGA_C90x43)
+#define SW_VGA_M90x43	_IO('S', M_VGA_M90x43)
+#define SW_VGA_C90x50	_IO('S', M_VGA_C90x50)
+#define SW_VGA_M90x50	_IO('S', M_VGA_M90x50)
+#define SW_VGA_C90x60	_IO('S', M_VGA_C90x60)
+#define SW_VGA_M90x60	_IO('S', M_VGA_M90x60)
+#define SW_TEXT_80x25	_IO('S', M_TEXT_80x25)
+#define SW_TEXT_80x30	_IO('S', M_TEXT_80x30)
+#define SW_TEXT_80x43	_IO('S', M_TEXT_80x43)
+#define SW_TEXT_80x50	_IO('S', M_TEXT_80x50)
+#define SW_TEXT_80x60	_IO('S', M_TEXT_80x60)
+#define SW_TEXT_132x25	_IO('S', M_TEXT_132x25)
+#define SW_TEXT_132x30	_IO('S', M_TEXT_132x30)
+#define SW_TEXT_132x43	_IO('S', M_TEXT_132x43)
+#define SW_TEXT_132x50	_IO('S', M_TEXT_132x50)
+#define SW_TEXT_132x60	_IO('S', M_TEXT_132x60)
+#define SW_VESA_CG640x400	_IO('V', M_VESA_CG640x400 - M_VESA_BASE)
+#define SW_VESA_CG640x480	_IO('V', M_VESA_CG640x480 - M_VESA_BASE)
+#define SW_VESA_800x600		_IO('V', M_VESA_800x600 - M_VESA_BASE)
+#define SW_VESA_CG800x600	_IO('V', M_VESA_CG800x600 - M_VESA_BASE)
+#define SW_VESA_1024x768	_IO('V', M_VESA_1024x768 - M_VESA_BASE)
+#define SW_VESA_CG1024x768	_IO('V', M_VESA_CG1024x768 - M_VESA_BASE)
+#define SW_VESA_1280x1024	_IO('V', M_VESA_1280x1024 - M_VESA_BASE)
+#define SW_VESA_CG1280x1024	_IO('V', M_VESA_CG1280x1024 - M_VESA_BASE)
+#define SW_VESA_C80x60		_IO('V', M_VESA_C80x60 - M_VESA_BASE)
+#define SW_VESA_C132x25		_IO('V', M_VESA_C132x25 - M_VESA_BASE)
+#define SW_VESA_C132x43		_IO('V', M_VESA_C132x43 - M_VESA_BASE)
+#define SW_VESA_C132x50		_IO('V', M_VESA_C132x50 - M_VESA_BASE)
+#define SW_VESA_C132x60		_IO('V', M_VESA_C132x60 - M_VESA_BASE)
+#define SW_VESA_32K_320		_IO('V', M_VESA_32K_320 - M_VESA_BASE)
+#define SW_VESA_64K_320		_IO('V', M_VESA_64K_320 - M_VESA_BASE)
+#define SW_VESA_FULL_320	_IO('V', M_VESA_FULL_320 - M_VESA_BASE)
+#define SW_VESA_32K_640		_IO('V', M_VESA_32K_640 - M_VESA_BASE)
+#define SW_VESA_64K_640		_IO('V', M_VESA_64K_640 - M_VESA_BASE)
+#define SW_VESA_FULL_640	_IO('V', M_VESA_FULL_640 - M_VESA_BASE)
+#define SW_VESA_32K_800		_IO('V', M_VESA_32K_800 - M_VESA_BASE)
+#define SW_VESA_64K_800		_IO('V', M_VESA_64K_800 - M_VESA_BASE)
+#define SW_VESA_FULL_800	_IO('V', M_VESA_FULL_800 - M_VESA_BASE)
+#define SW_VESA_32K_1024	_IO('V', M_VESA_32K_1024 - M_VESA_BASE)
+#define SW_VESA_64K_1024	_IO('V', M_VESA_64K_1024 - M_VESA_BASE)
+#define SW_VESA_FULL_1024	_IO('V', M_VESA_FULL_1024 - M_VESA_BASE)
+#define SW_VESA_32K_1280	_IO('V', M_VESA_32K_1280 - M_VESA_BASE)
+#define SW_VESA_64K_1280	_IO('V', M_VESA_64K_1280 - M_VESA_BASE)
+#define SW_VESA_FULL_1280	_IO('V', M_VESA_FULL_1280 - M_VESA_BASE)
+#endif /* !_SYS_CONSIO_H_ */
diff --git a/freebsd/sys/sys/fbio.h b/freebsd/sys/sys/fbio.h
index 00000000..4cc0cc6d
--- /dev/null
+++ b/freebsd/sys/sys/fbio.h
@@ -0,0 +1,622 @@
+ * Copyright (c) 1992, 1993
+ *	The Regents of the University of California.  All rights reserved.
+ * This code is derived from software developed by the Computer Systems
+ * Engineering group at Lawrence Berkeley Laboratory under DARPA
+ * contract BG 91-66 and contributed to Berkeley.
+ * are met:
+ * 3. Neither the name of the University nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * SUCH DAMAGE.
+ *	@(#)fbio.h	8.2 (Berkeley) 10/30/93
+ * $FreeBSD$
+#ifndef _SYS_FBIO_H_
+#define _SYS_FBIO_H_
+#ifndef _KERNEL
+#else
+#endif
+ * Frame buffer ioctls (from Sprite, trimmed to essentials for X11).
+ * Frame buffer type codes.
+#define	FBTYPE_SUN1BW		0	/* multibus mono */
+#define	FBTYPE_SUN1COLOR	1	/* multibus color */
+#define	FBTYPE_SUN2BW		2	/* memory mono */
+#define	FBTYPE_SUN2COLOR	3	/* color w/rasterop chips */
+#define	FBTYPE_SUN2GP		4	/* GP1/GP2 */
+#define	FBTYPE_SUN5COLOR	5	/* RoadRunner accelerator */
+#define	FBTYPE_SUN3COLOR	6	/* memory color */
+#define	FBTYPE_MEMCOLOR		7	/* memory 24-bit */
+#define	FBTYPE_SUN4COLOR	8	/* memory color w/overlay */
+#define	FBTYPE_NOTSUN1		9	/* reserved for customer */
+#define	FBTYPE_NOTSUN2		10	/* reserved for customer */
+#define	FBTYPE_PCIMISC		11	/* (generic) PCI misc. disp. */
+#define	FBTYPE_SUNFAST_COLOR	12	/* accelerated 8bit */
+#define	FBTYPE_SUNROP_COLOR	13	/* MEMCOLOR with rop h/w */
+#define	FBTYPE_SUNFB_VIDEO	14	/* Simple video mixing */
+#define	FBTYPE_RESERVED5	15	/* reserved, do not use */
+#define	FBTYPE_RESERVED4	16	/* reserved, do not use */
+#define	FBTYPE_SUNGP3		17
+#define	FBTYPE_SUNGT		18
+#define	FBTYPE_SUNLEO		19	/* zx Leo */
+#define	FBTYPE_MDA		20
+#define	FBTYPE_HERCULES		21
+#define	FBTYPE_CGA		22
+#define	FBTYPE_EGA		23
+#define	FBTYPE_VGA		24
+#define	FBTYPE_TGA		26
+#define	FBTYPE_TGA2		27
+#define	FBTYPE_MDICOLOR		28	/* cg14 */
+#define	FBTYPE_TCXCOLOR		29	/* SUNW,tcx */
+#define	FBTYPE_CREATOR		30
+#define	FBTYPE_LASTPLUSONE	31	/* max number of fbs (change as add) */
+ * Frame buffer descriptor as returned by FBIOGTYPE.
+struct fbtype {
+	int	fb_type;	/* as defined above */
+	int	fb_height;	/* in pixels */
+	int	fb_width;	/* in pixels */
+	int	fb_depth;	/* bits per pixel */
+	int	fb_cmsize;	/* size of color map (entries) */
+	int	fb_size;	/* total size in bytes */
+#define	FBIOGTYPE	_IOR('F', 0, struct fbtype)
+#define	FBTYPE_GET_STRIDE(_fb)	((_fb)->fb_size / (_fb)->fb_height)
+#define	FBTYPE_GET_BPP(_fb)	((_fb)->fb_bpp)
+#define	FBTYPE_GET_BYTESPP(_fb)	((_fb)->fb_bpp / 8)
+#ifdef	_KERNEL
+struct fb_info;
+typedef int fb_enter_t(void *priv);
+typedef int fb_leave_t(void *priv);
+typedef int fb_setblankmode_t(void *priv, int mode);
+struct fb_info {
+	/* Raw copy of fbtype. Do not change. */
+	int		fb_depth;	/* bits to define color */
+	struct cdev 	*fb_cdev;
+	device_t	 fb_fbd_dev;	/* "fbd" device. */
+	device_t	 fb_video_dev;	/* Video adapter. */
+	fb_enter_t	*enter;
+	fb_leave_t	*leave;
+	fb_setblankmode_t *setblankmode;
+	uintptr_t	fb_pbase;	/* For FB mmap. */
+	uintptr_t	fb_vbase;	/* if NULL, use fb_write/fb_read. */
+	void		*fb_priv;	/* First argument for read/write. */
+	const char	*fb_name;
+	uint32_t	fb_flags;
+#define	FB_FLAG_NOMMAP		1	/* mmap unsupported. */
+#define	FB_FLAG_NOWRITE		2	/* disable writes for the time being */
+#define	FB_FLAG_MEMATTR		4	/* override memattr for mmap */
+	vm_memattr_t	fb_memattr;
+	int		fb_stride;
+	int		fb_bpp;		/* bits per pixel */
+	uint32_t	fb_cmap[16];
+int fbd_list(void);
+int fbd_register(struct fb_info *);
+int fbd_unregister(struct fb_info *);
+static inline int
+register_framebuffer(struct fb_info *info)
+	EVENTHANDLER_INVOKE(register_framebuffer, info);
+	return (0);
+static inline int
+unregister_framebuffer(struct fb_info *info)
+	EVENTHANDLER_INVOKE(unregister_framebuffer, info);
+	return (0);
+#endif
+#ifdef notdef
+ * General purpose structure for passing info in and out of frame buffers
+ * (used for gp1) -- unsupported.
+struct fbinfo {
+	int	fb_physaddr;	/* physical frame buffer address */
+	int	fb_hwwidth;	/* fb board width */
+	int	fb_hwheight;	/* fb board height */
+	int	fb_addrdelta;	/* phys addr diff between boards */
+	u_char	*fb_ropaddr;	/* fb virtual addr */
+	int	fb_unit;	/* minor devnum of fb */
+#define	FBIOGINFO	_IOR('F', 2, struct fbinfo)
+#endif
+ * Color map I/O.
+struct fbcmap {
+	int	index;		/* first element (0 origin) */
+	int	count;		/* number of elements */
+	u_char	*red;		/* red color map elements */
+	u_char	*green;		/* green color map elements */
+	u_char	*blue;		/* blue color map elements */
+#define	FBIOPUTCMAP	_IOW('F', 3, struct fbcmap)
+#define	FBIOGETCMAP	_IOW('F', 4, struct fbcmap)
+ * Set/get attributes.
+#define	FB_ATTR_NDEVSPECIFIC	8	/* no. of device specific values */
+#define	FB_ATTR_NEMUTYPES	4	/* no. of emulation types */
+struct fbsattr {
+	int	flags;			/* flags; see below */
+	int	emu_type;		/* emulation type (-1 if unused) */
+	int	dev_specific[FB_ATTR_NDEVSPECIFIC];	/* catchall */
+#define	FB_ATTR_AUTOINIT	1	/* emulation auto init flag */
+#define	FB_ATTR_DEVSPECIFIC	2	/* dev. specific stuff valid flag */
+struct fbgattr {
+	int	real_type;		/* real device type */
+	int	owner;			/* PID of owner, 0 if myself */
+	struct	fbtype fbtype;		/* fbtype info for real device */
+	struct	fbsattr sattr;		/* see above */
+	int	emu_types[FB_ATTR_NEMUTYPES];	/* possible emulations */
+						/* (-1 if unused) */
+#define	FBIOSATTR	_IOW('F', 5, struct fbsattr)
+#define	FBIOGATTR	_IOR('F', 6, struct fbgattr)
+ * Video control.
+#define	FBVIDEO_OFF		0
+#define	FBVIDEO_ON		1
+#define	FBIOSVIDEO	_IOW('F', 7, int)
+#define	FBIOGVIDEO	_IOR('F', 8, int)
+/* vertical retrace */
+#define	FBIOVERTICAL	_IO('F', 9)
+ * Hardware cursor control (for, e.g., CG6).  A rather complex and icky
+ * interface that smells like VMS, but there it is....
+struct fbcurpos {
+	short	x;
+	short	y;
+struct fbcursor {
+	short	set;		/* flags; see below */
+	short	enable;		/* nonzero => cursor on, 0 => cursor off */
+	struct	fbcurpos pos;	/* position on display */
+	struct	fbcurpos hot;	/* hot-spot within cursor */
+	struct	fbcmap cmap;	/* cursor color map */
+	struct	fbcurpos size;	/* number of valid bits in image & mask */
+	caddr_t	image;		/* cursor image bits */
+	caddr_t	mask;		/* cursor mask bits */
+#define	FB_CUR_SETCUR	0x01	/* set on/off (i.e., obey fbcursor.enable) */
+#define	FB_CUR_SETPOS	0x02	/* set position */
+#define	FB_CUR_SETHOT	0x04	/* set hot-spot */
+#define	FB_CUR_SETCMAP	0x08	/* set cursor color map */
+#define	FB_CUR_SETSHAPE	0x10	/* set size & bits */
+#define	FB_CUR_SETALL	(FB_CUR_SETCUR | FB_CUR_SETPOS | FB_CUR_SETHOT | \
+			 FB_CUR_SETCMAP | FB_CUR_SETSHAPE)
+/* controls for cursor attributes & shape (including position) */
+#define	FBIOSCURSOR	_IOW('F', 24, struct fbcursor)
+#define	FBIOGCURSOR	_IOWR('F', 25, struct fbcursor)
+/* controls for cursor position only */
+#define	FBIOSCURPOS	_IOW('F', 26, struct fbcurpos)
+#define	FBIOGCURPOS	_IOW('F', 27, struct fbcurpos)
+/* get maximum cursor size */
+#define	FBIOGCURMAX	_IOR('F', 28, struct fbcurpos)
+ * Video board information
+struct brd_info {
+	u_short		accessible_width; /* accessible bytes in scanline */
+	u_short		accessible_height; /* number of accessible scanlines */
+	u_short		line_bytes;	/* number of bytes/scanline */
+	u_short		hdb_capable;	/* can this thing hardware db? */
+	u_short		vmsize;		/* video memory size */
+	u_char		boardrev;	/* board revision # */
+	u_char		pad0;
+	u_long		pad1;
+#define	FBIOGXINFO	_IOR('F', 39, struct brd_info)
+ * Monitor information
+struct mon_info {
+	u_long		mon_type;	/* bit array */
+#define MON_TYPE_STEREO		0x8	/* stereo display */
+#define MON_TYPE_0_OFFSET	0x4	/* black level 0 ire instead of 7.5 */
+#define MON_TYPE_OVERSCAN	0x2	/* overscan */
+#define MON_TYPE_GRAY		0x1	/* greyscale monitor */
+	u_long		pixfreq;	/* pixel frequency in Hz */
+	u_long		hfreq;		/* horizontal freq in Hz */
+	u_long		vfreq;		/* vertical freq in Hz */
+	u_long		vsync;		/* vertical sync in scanlines */
+	u_long		hsync;		/* horizontal sync in pixels */
+	/* these are in pixel units */
+	u_short		hfporch;	/* horizontal front porch */
+	u_short		hbporch;	/* horizontal back porch */
+	u_short		vfporch;	/* vertical front porch */
+	u_short		vbporch;	/* vertical back porch */
+#define	FBIOMONINFO	_IOR('F', 40, struct mon_info)
+ * Color map I/O.
+struct fbcmap_i {
+	unsigned int	flags;
+#define	FB_CMAP_BLOCK	(1 << 0)	/* wait for vertical refresh */
+#define	FB_CMAP_KERNEL	(1 << 1)	/* called within kernel */
+	int		id;		/* color map id */
+#define	FBIOPUTCMAPI	_IOW('F', 41, struct fbcmap_i)
+#define	FBIOGETCMAPI	_IOW('F', 42, struct fbcmap_i)
+/* The new style frame buffer ioctls. */
+/* video mode information block */
+struct video_info {
+    int			vi_mode;	/* mode number, see below */
+    int			vi_flags;
+#define V_INFO_COLOR	(1 << 0)
+#define V_INFO_GRAPHICS	(1 << 1)
+#define V_INFO_LINEAR	(1 << 2)
+#define V_INFO_VESA	(1 << 3)
+#define	V_INFO_NONVGA	(1 << 4)
+#define	V_INFO_CWIDTH9	(1 << 5)
+    int			vi_width;
+    int			vi_height;
+    int			vi_cwidth;
+    int			vi_cheight;
+    int			vi_depth;
+    int			vi_planes;
+    vm_offset_t		vi_window;	/* physical address */
+    size_t		vi_window_size;
+    size_t		vi_window_gran;
+    vm_offset_t		vi_buffer;	/* physical address */
+    size_t		vi_buffer_size;
+    int			vi_mem_model;
+#define V_INFO_MM_OTHER  (-1)
+#define V_INFO_MM_TEXT	 0
+#define V_INFO_MM_PLANAR 1
+#define V_INFO_MM_PACKED 2
+#define V_INFO_MM_DIRECT 3
+#define V_INFO_MM_CGA	 100
+#define V_INFO_MM_HGC	 101
+#define V_INFO_MM_VGAX	 102
+    /* for MM_PACKED and MM_DIRECT only */
+    int			vi_pixel_size;	/* in bytes */
+    /* for MM_DIRECT only */
+    int			vi_pixel_fields[4];	/* RGB and reserved fields */
+    int			vi_pixel_fsizes[4];
+    /* reserved */
+    u_char		vi_reserved[64];
+    vm_offset_t		vi_registers;	/* physical address */
+    vm_offset_t		vi_registers_size;
+typedef struct video_info video_info_t;
+/* adapter infromation block */
+struct video_adapter {
+    int			va_index;
+    int			va_type;
+#define KD_OTHER	0		/* unknown */
+#define KD_MONO		1		/* monochrome adapter */
+#define KD_HERCULES	2		/* hercules adapter */
+#define KD_CGA		3		/* color graphics adapter */
+#define KD_EGA		4		/* enhanced graphics adapter */
+#define KD_VGA		5		/* video graphics adapter */
+#define KD_TGA		7		/* TGA */
+#define KD_TGA2		8		/* TGA2 */
+    char		*va_name;
+    int			va_unit;
+    int			va_minor;
+    int			va_flags;
+#define V_ADP_COLOR	(1 << 0)
+#define V_ADP_MODECHANGE (1 << 1)
+#define V_ADP_STATESAVE	(1 << 2)
+#define V_ADP_STATELOAD	(1 << 3)
+#define V_ADP_FONT	(1 << 4)
+#define V_ADP_PALETTE	(1 << 5)
+#define V_ADP_BORDER	(1 << 6)
+#define V_ADP_VESA	(1 << 7)
+#define V_ADP_BOOTDISPLAY (1 << 8)
+#define V_ADP_PROBED	(1 << 16)
+#define V_ADP_INITIALIZED (1 << 17)
+#define V_ADP_REGISTERED (1 << 18)
+#define V_ADP_ATTACHED	(1 << 19)
+#define	V_ADP_DAC8	(1 << 20)
+#define	V_ADP_CWIDTH9	(1 << 21)
+    vm_offset_t		va_io_base;
+    int			va_io_size;
+    vm_offset_t		va_crtc_addr;
+    vm_offset_t		va_mem_base;
+    int			va_mem_size;
+    vm_offset_t		va_window;	/* virtual address */
+    size_t		va_window_size;
+    size_t		va_window_gran;
+    u_int		va_window_orig;
+    vm_offset_t		va_buffer;	/* virtual address */
+    size_t		va_buffer_size;
+    int			va_initial_mode;
+    int			va_initial_bios_mode;
+    int			va_mode;
+    struct video_info	va_info;
+    int			va_line_width;
+    struct {
+	int		x;
+	int		y;
+    } 			va_disp_start;
+    void		*va_token;
+    int			va_model;
+    int			va_little_bitian;
+    int			va_little_endian;
+    int			va_buffer_alias;
+    vm_offset_t		va_registers;	/* virtual address */
+    vm_offset_t		va_registers_size;
+typedef struct video_adapter video_adapter_t;
+struct video_adapter_info {
+    int			va_index;
+    int			va_type;
+    char		va_name[16];
+    int			va_unit;
+    int			va_flags;
+    int			va_io_size;
+    int			va_mem_size;
+    vm_offset_t		va_unused0;
+    int			va_mode;
+    struct {
+	int		x;
+	int		y;
+    } 			va_disp_start;
+    /* reserved */
+    u_char		va_reserved[64];
+typedef struct video_adapter_info video_adapter_info_t;
+/* some useful video adapter index */
+#define V_ADP_PRIMARY	0
+#define V_ADP_SECONDARY	1
+/* video mode numbers */
+#define M_B40x25	0	/* black & white 40 columns */
+#define M_C40x25	1	/* color 40 columns */
+#define M_B80x25	2	/* black & white 80 columns */
+#define M_C80x25	3	/* color 80 columns */
+#define M_BG320		4	/* black & white graphics 320x200 */
+#define M_CG320		5	/* color graphics 320x200 */
+#define M_BG640		6	/* black & white graphics 640x200 hi-res */
+#define M_EGAMONO80x25  7       /* ega-mono 80x25 */
+#define M_CG320_D	13	/* ega mode D */
+#define M_CG640_E	14	/* ega mode E */
+#define M_EGAMONOAPA	15	/* ega mode F */
+#define M_CG640x350	16	/* ega mode 10 */
+#define M_ENHMONOAPA2	17	/* ega mode F with extended memory */
+#define M_ENH_CG640	18	/* ega mode 10* */
+#define M_ENH_B40x25    19      /* ega enhanced black & white 40 columns */
+#define M_ENH_C40x25    20      /* ega enhanced color 40 columns */
+#define M_ENH_B80x25    21      /* ega enhanced black & white 80 columns */
+#define M_ENH_C80x25    22      /* ega enhanced color 80 columns */
+#define M_VGA_C40x25	23	/* vga 8x16 font on color */
+#define M_VGA_C80x25	24	/* vga 8x16 font on color */
+#define M_VGA_M80x25	25	/* vga 8x16 font on mono */
+#define M_VGA11		26	/* vga 640x480 2 colors */
+#define M_BG640x480	26
+#define M_VGA12		27	/* vga 640x480 16 colors */
+#define M_CG640x480	27
+#define M_VGA13		28	/* vga 320x200 256 colors */
+#define M_VGA_CG320	28
+#define M_VGA_C80x50	30	/* vga 8x8 font on color */
+#define M_VGA_M80x50	31	/* vga 8x8 font on color */
+#define M_VGA_C80x30	32	/* vga 8x16 font on color */
+#define M_VGA_M80x30	33	/* vga 8x16 font on color */
+#define M_VGA_C80x60	34	/* vga 8x8 font on color */
+#define M_VGA_M80x60	35	/* vga 8x8 font on color */
+#define M_VGA_CG640	36	/* vga 640x400 256 color */
+#define M_VGA_MODEX	37	/* vga 320x240 256 color */
+#define M_VGA_C90x25	40	/* vga 8x16 font on color */
+#define M_VGA_M90x25	41	/* vga 8x16 font on mono */
+#define M_VGA_C90x30	42	/* vga 8x16 font on color */
+#define M_VGA_M90x30	43	/* vga 8x16 font on mono */
+#define M_VGA_C90x43	44	/* vga 8x8 font on color */
+#define M_VGA_M90x43	45	/* vga 8x8 font on mono */
+#define M_VGA_C90x50	46	/* vga 8x8 font on color */
+#define M_VGA_M90x50	47	/* vga 8x8 font on mono */
+#define M_VGA_C90x60	48	/* vga 8x8 font on color */
+#define M_VGA_M90x60	49	/* vga 8x8 font on mono */
+#define M_ENH_B80x43	0x70	/* ega black & white 80x43 */
+#define M_ENH_C80x43	0x71	/* ega color 80x43 */
+#define M_HGC_P0	0xe0	/* hercules graphics - page 0 @ B0000 */
+#define M_HGC_P1	0xe1	/* hercules graphics - page 1 @ B8000 */
+#define M_MCA_MODE	0xff	/* monochrome adapter mode */
+#define M_TEXT_80x25	200	/* generic text modes */
+#define M_TEXT_80x30	201
+#define M_TEXT_80x43	202
+#define M_TEXT_80x50	203
+#define M_TEXT_80x60	204
+#define M_TEXT_132x25	205
+#define M_TEXT_132x30	206
+#define M_TEXT_132x43	207
+#define M_TEXT_132x50	208
+#define M_TEXT_132x60	209
+#define M_VESA_BASE		0x100	/* VESA mode number base */
+#define M_VESA_CG640x400	0x100	/* 640x400, 256 color */
+#define M_VESA_CG640x480	0x101	/* 640x480, 256 color */
+#define M_VESA_800x600		0x102	/* 800x600, 16 color */
+#define M_VESA_CG800x600	0x103	/* 800x600, 256 color */
+#define M_VESA_1024x768		0x104	/* 1024x768, 16 color */
+#define M_VESA_CG1024x768	0x105	/* 1024x768, 256 color */
+#define M_VESA_1280x1024	0x106	/* 1280x1024, 16 color */
+#define M_VESA_CG1280x1024	0x107	/* 1280x1024, 256 color */
+#define M_VESA_C80x60		0x108	/* 8x8 font */
+#define M_VESA_C132x25		0x109	/* 8x16 font */
+#define M_VESA_C132x43		0x10a	/* 8x14 font */
+#define M_VESA_C132x50		0x10b	/* 8x8 font */
+#define M_VESA_C132x60		0x10c	/* 8x8 font */
+#define M_VESA_32K_320		0x10d	/* 320x200, 5:5:5 */
+#define M_VESA_64K_320		0x10e	/* 320x200, 5:6:5 */
+#define M_VESA_FULL_320		0x10f	/* 320x200, 8:8:8 */
+#define M_VESA_32K_640		0x110	/* 640x480, 5:5:5 */
+#define M_VESA_64K_640		0x111	/* 640x480, 5:6:5 */
+#define M_VESA_FULL_640		0x112	/* 640x480, 8:8:8 */
+#define M_VESA_32K_800		0x113	/* 800x600, 5:5:5 */
+#define M_VESA_64K_800		0x114	/* 800x600, 5:6:5 */
+#define M_VESA_FULL_800		0x115	/* 800x600, 8:8:8 */
+#define M_VESA_32K_1024		0x116	/* 1024x768, 5:5:5 */
+#define M_VESA_64K_1024		0x117	/* 1024x768, 5:6:5 */
+#define M_VESA_FULL_1024	0x118	/* 1024x768, 8:8:8 */
+#define M_VESA_32K_1280		0x119	/* 1280x1024, 5:5:5 */
+#define M_VESA_64K_1280		0x11a	/* 1280x1024, 5:6:5 */
+#define M_VESA_FULL_1280	0x11b	/* 1280x1024, 8:8:8 */
+#define M_VESA_MODE_MAX		0x1ff
+struct video_display_start {
+	int		x;
+	int		y;
+typedef struct video_display_start video_display_start_t;
+struct video_color_palette {
+	int		index;		/* first element (zero-based) */
+	u_char		*red;		/* red */
+	u_char		*green;		/* green */
+	u_char		*blue;		/* blue */
+	u_char		*transparent;	/* may be NULL */
+typedef struct video_color_palette video_color_palette_t;
+/* adapter info. */
+#define FBIO_ADAPTER	_IOR('F', 100, int)
+#define FBIO_ADPTYPE	_IOR('F', 101, int)
+#define FBIO_ADPINFO	_IOR('F', 102, struct video_adapter_info)
+/* video mode control */
+#define FBIO_MODEINFO	_IOWR('F', 103, struct video_info)
+#define FBIO_FINDMODE	_IOWR('F', 104, struct video_info)
+#define FBIO_GETMODE	_IOR('F', 105, int)
+#define FBIO_SETMODE	_IOW('F', 106, int)
+/* get/set frame buffer window origin */
+#define FBIO_GETWINORG	_IOR('F', 107, u_int)
+#define FBIO_SETWINORG	_IOW('F', 108, u_int)
+/* get/set display start address */
+#define FBIO_GETDISPSTART	_IOR('F', 109, video_display_start_t)
+#define FBIO_SETDISPSTART	_IOW('F', 110, video_display_start_t)
+/* get/set scan line width */
+#define FBIO_GETLINEWIDTH	_IOR('F', 111, u_int)
+#define FBIO_SETLINEWIDTH	_IOW('F', 112, u_int)
+/* color palette control */
+#define FBIO_GETPALETTE	_IOW('F', 113, video_color_palette_t)
+#define FBIO_SETPALETTE	_IOW('F', 114, video_color_palette_t)
+/* blank display */
+#define V_DISPLAY_ON		0
+#define V_DISPLAY_BLANK		1
+#define V_DISPLAY_STAND_BY	2
+#define V_DISPLAY_SUSPEND	3
+#define FBIO_BLANK	_IOW('F', 115, int)
+#endif /* !_SYS_FBIO_H_ */
diff --git a/freebsd/sys/sys/terminal.h b/freebsd/sys/sys/terminal.h
new file mode 100644
index 00000000..e3413a79
--- /dev/null
+++ b/freebsd/sys/sys/terminal.h
@@ -0,0 +1,240 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2009 The FreeBSD Foundation
+ * All rights reserved.
+ * This software was developed by Ed Schouten under sponsorship from the
+ * FreeBSD Foundation.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _SYS_TERMINAL_H_
+#define	_SYS_TERMINAL_H_
+#include <sys/param.h>
+#include <sys/_lock.h>
+#include <sys/_mutex.h>
+#include <sys/cons.h>
+#include <sys/linker_set.h>
+#include <sys/ttycom.h>
+#include <teken/teken.h>
+#include <rtems/bsd/local/opt_syscons.h>
+#include <rtems/bsd/local/opt_teken.h>
+struct terminal;
+struct thread;
+struct tty;
+ * The terminal layer is an abstraction on top of the TTY layer and the
+ * console interface.  It can be used by system console drivers to
+ * easily interact with the kernel console and TTYs.
+ * Terminals contain terminal emulators, which means console drivers
+ * don't need to implement their own terminal emulator. The terminal
+ * emulator deals with UTF-8 exclusively. This means that term_char_t,
+ * the data type used to store input/output characters will always
+ * contain Unicode codepoints.
+ * To save memory usage, the top bits of term_char_t will contain other
+ * attributes, like colors. Right now term_char_t is composed as
+ * follows:
+ *  Bits  Meaning
+ *  0-20: Character value
+ * 21-25: Bold, underline, blink, reverse, right part of CJK fullwidth character
+ * 26-28: Foreground color
+ * 29-31: Background color
+typedef uint32_t term_char_t;
+#define	TCHAR_CHARACTER(c)	((c) & 0x1fffff)
+#define	TCHAR_FORMAT(c)		(((c) >> 21) & 0x1f)
+#define	TCHAR_FGCOLOR(c)	(((c) >> 26) & 0x7)
+#define	TCHAR_BGCOLOR(c)	(((c) >> 29) & 0x7)
+typedef teken_attr_t term_attr_t;
+typedef teken_color_t term_color_t;
+#define	TCOLOR_FG(c)	(((c) & 0x7) << 26)
+#define	TCOLOR_BG(c)	(((c) & 0x7) << 29)
+#define	TCOLOR_LIGHT(c)	((c) | 0x8)
+#define	TCOLOR_DARK(c)	((c) & ~0x8)
+#define	TFORMAT(c)	(((c) & 0x1f) << 21)
+/* syscons(4) compatible color attributes for foreground text */
+#define	FG_BLACK		TCOLOR_FG(TC_BLACK)
+#define	FG_BLUE			TCOLOR_FG(TC_BLUE)
+#define	FG_GREEN		TCOLOR_FG(TC_GREEN)
+#define	FG_CYAN			TCOLOR_FG(TC_CYAN)
+#define	FG_RED			TCOLOR_FG(TC_RED)
+#define	FG_MAGENTA		TCOLOR_FG(TC_MAGENTA)
+#define	FG_BROWN		TCOLOR_FG(TC_BROWN)
+#define	FG_LIGHTGREY		TCOLOR_FG(TC_WHITE)
+#define	FG_DARKGREY		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_BLACK))
+#define	FG_LIGHTBLUE		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_BLUE))
+#define	FG_LIGHTGREEN		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_GREEN))
+#define	FG_LIGHTCYAN		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_CYAN))
+#define	FG_LIGHTRED		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_RED))
+#define	FG_LIGHTMAGENTA		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_MAGENTA))
+#define	FG_YELLOW		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_BROWN))
+#define	FG_WHITE		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_WHITE))
+#define	FG_BLINK		TFORMAT(TF_BLINK)
+/* syscons(4) compatible color attributes for text background */
+#define	BG_BLACK		TCOLOR_BG(TC_BLACK)
+#define	BG_BLUE			TCOLOR_BG(TC_BLUE)
+#define	BG_GREEN		TCOLOR_BG(TC_GREEN)
+#define	BG_CYAN			TCOLOR_BG(TC_CYAN)
+#define	BG_RED			TCOLOR_BG(TC_RED)
+#define	BG_MAGENTA		TCOLOR_BG(TC_MAGENTA)
+#define	BG_BROWN		TCOLOR_BG(TC_BROWN)
+#define	BG_LIGHTGREY		TCOLOR_BG(TC_WHITE)
+#define	BG_DARKGREY		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_BLACK))
+#define	BG_LIGHTBLUE		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_BLUE))
+#define	BG_LIGHTGREEN		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_GREEN))
+#define	BG_LIGHTCYAN		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_CYAN))
+#define	BG_LIGHTRED		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_RED))
+#define	BG_LIGHTMAGENTA		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_MAGENTA))
+#define	BG_YELLOW		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_BROWN))
+#define	BG_WHITE		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_WHITE))
+#ifndef TERMINAL_NORM_ATTR
+#ifdef SC_NORM_ATTR
+#define	TERMINAL_NORM_ATTR	SC_NORM_ATTR
+#else
+#define	TERMINAL_NORM_ATTR	(FG_LIGHTGREY | BG_BLACK)
+#endif
+#endif
+#ifndef TERMINAL_KERN_ATTR
+#ifdef SC_KERNEL_CONS_ATTR
+#define	TERMINAL_KERN_ATTR	SC_KERNEL_CONS_ATTR
+#else
+#define	TERMINAL_KERN_ATTR	(FG_WHITE | BG_BLACK)
+#endif
+#endif
+typedef teken_pos_t term_pos_t;
+typedef teken_rect_t term_rect_t;
+typedef void tc_cursor_t(struct terminal *tm, const term_pos_t *p);
+typedef void tc_putchar_t(struct terminal *tm, const term_pos_t *p,
+    term_char_t c);
+typedef void tc_fill_t(struct terminal *tm, const term_rect_t *r,
+    term_char_t c);
+typedef void tc_copy_t(struct terminal *tm, const term_rect_t *r,
+    const term_pos_t *p);
+typedef void tc_pre_input_t(struct terminal *tm);
+typedef void tc_post_input_t(struct terminal *tm);
+typedef void tc_param_t(struct terminal *tm, int cmd, unsigned int arg);
+typedef void tc_done_t(struct terminal *tm);
+typedef void tc_cnprobe_t(struct terminal *tm, struct consdev *cd);
+typedef int tc_cngetc_t(struct terminal *tm);
+typedef void tc_cngrab_t(struct terminal *tm);
+typedef void tc_cnungrab_t(struct terminal *tm);
+typedef void tc_opened_t(struct terminal *tm, int opened);
+typedef int tc_ioctl_t(struct terminal *tm, u_long cmd, caddr_t data,
+    struct thread *td);
+typedef int tc_mmap_t(struct terminal *tm, vm_ooffset_t offset,
+    vm_paddr_t * paddr, int nprot, vm_memattr_t *memattr);
+typedef void tc_bell_t(struct terminal *tm);
+struct terminal_class {
+	/* Terminal emulator. */
+	tc_cursor_t	*tc_cursor;
+	tc_putchar_t	*tc_putchar;
+	tc_fill_t	*tc_fill;
+	tc_copy_t	*tc_copy;
+	tc_pre_input_t	*tc_pre_input;
+	tc_post_input_t	*tc_post_input;
+	tc_param_t	*tc_param;
+	tc_done_t	*tc_done;
+	/* Low-level console interface. */
+	tc_cnprobe_t	*tc_cnprobe;
+	tc_cngetc_t	*tc_cngetc;
+	/* DDB & panic handling. */
+	tc_cngrab_t	*tc_cngrab;
+	tc_cnungrab_t	*tc_cnungrab;
+	/* Misc. */
+	tc_opened_t	*tc_opened;
+	tc_ioctl_t	*tc_ioctl;
+	tc_mmap_t	*tc_mmap;
+	tc_bell_t	*tc_bell;
+struct terminal {
+	const struct terminal_class *tm_class;
+	void		*tm_softc;
+	struct mtx	 tm_mtx;
+	struct tty	*tm_tty;
+	teken_t		 tm_emulator;
+	struct winsize	 tm_winsize;
+	unsigned int	 tm_flags;
+#define	TF_MUTE		0x1	/* Drop incoming data. */
+#define	TF_BELL		0x2	/* Bell needs to be sent. */
+#define	TF_CONS		0x4	/* Console device (needs spinlock). */
+	struct consdev	*consdev;
+#ifdef _KERNEL
+struct terminal *terminal_alloc(const struct terminal_class *tc, void *softc);
+void	terminal_maketty(struct terminal *tm, const char *fmt, ...);
+void	terminal_set_cursor(struct terminal *tm, const term_pos_t *pos);
+void	terminal_set_winsize_blank(struct terminal *tm,
+    const struct winsize *size, int blank, const term_attr_t *attr);
+void	terminal_set_winsize(struct terminal *tm, const struct winsize *size);
+void	terminal_mute(struct terminal *tm, int yes);
+void	terminal_input_char(struct terminal *tm, term_char_t c);
+void	terminal_input_raw(struct terminal *tm, char c);
+void	terminal_input_special(struct terminal *tm, unsigned int k);
+void	termcn_cnregister(struct terminal *tm);
+/* Kernel console helper interface. */
+extern const struct consdev_ops termcn_cnops;
+#define	TERMINAL_DECLARE_EARLY(name, class, softc)			\
+	static struct terminal name = {					\
+		.tm_class = &class,					\
+		.tm_softc = softc,					\
+		.tm_flags = TF_CONS,					\
+	CONSOLE_DEVICE(name ## _consdev, termcn_cnops, &name)
+#endif /* _KERNEL */
+#endif /* !_SYS_TERMINAL_H_ */
2.20.1
