[PATCH v2 8/8] am335x display drivers: Port to RTEMS
Christian Mauderer list at c-mauderer.de
Sat Aug 3 12:04:24 UTC 2019
Correction: It seems that three files got lost. I had to create the
following three:
rtemsbsd/include/rtems/bsd/local/opt_syscons.h
rtemsbsd/include/rtems/bsd/local/opt_teken.h
rtemsbsd/include/rtems/bsd/local/opt_splash.h
On 03/08/2019 14:02, Christian Mauderer wrote:
> Seems that one file got lost since the last version of the patch set:
> Waf: Entering directory
> `/home/christian/rtems/rtems-bbb/libs/rtems-libbsd/build/arm-rtems5-beagleboneblack-noIPSec'
> [1422/2156] Compiling freebsd/sys/dev/fb/fbd.c
> [1786/2156] Compiling freebsd/sys/arm/ti/am335x/am335x_lcd.c
> In file included from ../../freebsd/sys/dev/vt/vt.h:49:0,
>                  from ../../freebsd/sys/dev/fb/fbd.c:55:
> ../../freebsd/sys/sys/terminal.h:46:10: fatal error:
> rtems/bsd/local/opt_syscons.h: No such file or directory
>  #include <rtems/bsd/local/opt_syscons.h>
> compilation terminated.
> ../../freebsd/sys/arm/ti/am335x/am335x_lcd.c:34:10: fatal error:
> Waf: Leaving directory
> Build failed
> On 02/08/2019 23:00, Vijay Kumar Banerjee wrote:
>>  libbsd.py                                             | 8 ++++++++
>>  rtemsbsd/include/bsp/nexus-devices.h                  | 2 ++
>>  rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h | 2 ++
>>  3 files changed, 12 insertions(+)
>> diff --git a/libbsd.py b/libbsd.py
>> index f94f7b3d..96cc4e3b 100644
>> --- a/libbsd.py
>> +++ b/libbsd.py
>> @@ -802,6 +802,11 @@ class display(builder.Module):
>>                  'sys/dev/vt/vt.h',
>>                  'sys/dev/fb/fbreg.h',
>>                  'sys/teken/teken.h',
>> +                'sys/arm/ti/am335x/am335x_lcd.h',
>> +                'sys/arm/ti/am335x/am335x_pwm.h',
>> +                'sys/sys/fbio.h',
>> +                'sys/sys/consio.h',
>> +                'sys/sys/terminal.h',
>>          self.addKernelSpaceSourceFiles(
>> @@ -813,6 +818,9 @@ class display(builder.Module):
>>                  'sys/dev/videomode/videomode.c',
>>                  'sys/dev/fb/fb.c',
>>                  'sys/dev/fb/fbd.c',
>> +                'sys/arm/ti/am335x/am335x_lcd.c',
>> +                'sys/arm/ti/am335x/am335x_pwmss.c',
>> +                'sys/arm/ti/am335x/am335x_ecap.c',
>>              mm.generator['source']()
>> diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
>> index ebf1ba13..e9da3be1 100644
>> --- a/rtemsbsd/include/bsp/nexus-devices.h
>> +++ b/rtemsbsd/include/bsp/nexus-devices.h
>> @@ -56,6 +56,8 @@ SYSINIT_DRIVER_REFERENCE(simplebus, ofwbus);
>>  SYSINIT_DRIVER_REFERENCE(ti_scm, simplebus);
>>  SYSINIT_DRIVER_REFERENCE(ti_pinmux, simplebus);
>>  SYSINIT_DRIVER_REFERENCE(am335x_prcm, simplebus);
>> +SYSINIT_DRIVER_REFERENCE(am335x_pwmss, simplebus);
>> +SYSINIT_DRIVER_REFERENCE(am335x_lcd, simplebus);
>>  SYSINIT_DRIVER_REFERENCE(usbss, simplebus);
>>  SYSINIT_DRIVER_REFERENCE(musbotg, usbss);
>>  SYSINIT_DRIVER_REFERENCE(sdhci_ti, simplebus);
>> diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
>> index ee643d59..03078328 100644
>> --- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
>> +++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
>> @@ -46,6 +46,8 @@
>>  #define	altq_remove _bsd_altq_remove
>>  #define	altq_remove_queue _bsd_altq_remove_queue
>>  #define	altqs_inactive_open _bsd_altqs_inactive_open
>> +#define	am335x_pwm_config_ecap _bsd_am335x_pwm_config_ecap
>> +#define	am335x_pwmss_driver _bsd_am335x_pwmss_driver
>>  #define	arp_announce_ifaddr _bsd_arp_announce_ifaddr
>>  #define	arp_ifinit _bsd_arp_ifinit
>>  #define	arprequest _bsd_arprequest
> devel mailing list
> devel at rtems.org
