[PATCH 2/2] user: Move support sections to top level
Mon Aug 5 13:33:46 UTC 2019
This is a preparation step to move the bug reporting procedure from the
wiki to the user manual and to add a contributing section.
 user/index.rst                      |   1 +
 user/overview/index.rst             | 120 ------------------------------------
 user/support/bugs.rst               |  22 +++++++
 user/support/contrib.rst            |  14 +++++
 user/support/index.rst              |  16 +++++
 user/support/support-commercial.rst |  22 +++++++
 user/support/support-project.rst    |  80 ++++++++++++++++++++++++
 7 files changed, 155 insertions(+), 120 deletions(-)
 create mode 100644 user/support/bugs.rst
 create mode 100644 user/support/contrib.rst
 create mode 100644 user/support/index.rst
 create mode 100644 user/support/support-commercial.rst
 create mode 100644 user/support/support-project.rst
diff --git a/user/index.rst b/user/index.rst
index 2eb6065..6491c6c 100644
--- a/user/index.rst
+++ b/user/index.rst
@@ -29,6 +29,7 @@ RTEMS User Manual (|version|).
     overview/index
     start/index
+    support/index
     hosts/index
     installation/index
diff --git a/user/overview/index.rst b/user/overview/index.rst
index ee7c59b..550724a 100644
--- a/user/overview/index.rst
+++ b/user/overview/index.rst
@@ -270,126 +270,6 @@ architecture or BSP. The RTEMS Project encourages users and organizations to
 fill this role for the community. The :ref:`RTEMS Source Builder <RSB>`
 provides some aid to :ref:`build and deploy tool binaries <RSBDeployment>`.
-Support
-.. index:: Support
-RTEMS offers a variety of support options.
-This section covers all options available to both users and developers.  If you
-believe this is a bug report please submit it to the bug tracker otherwise the
-developers mailing list is the default location to send the report.
-RTEMS Project Support
-.. index:: RTEMS Project Support
-The following support channels are provided by the RTEMS Project and provide
-direct access to the RTEMS community.
-Bug Tracker
-.. index:: Bugs
-.. index:: Reporting bugs
-The bug tracker can be found at the :r:url:`bugs`.
-See the `Submission Guidelines <http://devel.rtems.org/wiki/NewTicket/>`_ for
-details on submitting a ticket.
-Be sure to do a cursory search for any tickets that may be relevant to your
-problem.
-If you are unsure about your issue status submit a ticket and we will help you
-sort it out.
-Documentation
-The latest user documentation can always be found at the :r:url:`docs`.
-.. _support-mailing-lists:
-Mailing Lists
-.. index:: Community
-.. index:: Mailing lists
-We have several mailing lists for RTEMS users and developers.
-	* :r:list:`announce`
-		* Announcements for major and other project-related issues.
-	* :r:list:`bugs`
-		* Bugs email from :r:url:`bugs`.
-	* :r:list:`devel`
-		* Developers list, this is for developers of RTEMS itself.
-	* :r:list:`build`
-		* Results from the testing and building of RTEMS.
-	* :r:list:`users`
-		* Users of RTEMS.
-	* :r:list:`vc`
-		* Commits to the RTEMS master repository.
-IRC
-.. index:: IRC
-RTEMS IRC is available on the Freenode network. See the `Freenode
-<http://www.freenode.net/>`_ web site for details on connecting, selecting a
-nickname, and general usage tips. If you are new to IRC it is recommended
-reading.
-These are the current IRC channels.
-  **#rtems**
-This is a general channel for all things RTEMS. You can just hang out with
-other RTEMS users and developers to talk about RTEMS, using RTEMS or to make
-contact with other RTEMS users.
-The ``#rtems`` channel is logged. You can find the logs at
-http://www.rtems.org/irclogs/. You can search the logs using Google by adding:
-  **site:rtems.org inurl:irclogs**
-to your search terms.
-Developers
-.. index:: Developers
-Developers can find help and support on the mailing lists, see
-:ref:`support-mailing-lists`.
-Technical documents including design, :r:url:`gsoc`, :r:url:`socis` can be
-found on the :r:url:`devel`.
-Commercial Support Services
-The wider RTEMS community has developers and organizations who can provide
-commercial support services. These services range from training, implementing
-new features in RTEMS, deployment of RTEMS< helping establish a new project
-environment for a team, to application and system design.
-The RTEMS Project does not endorse or promote any provider of these services
-and we recommend you use a search engine to locate a suitable provider. If you
-are unsure please contact a provider and see what is available.
-If you develop a new feature or you have someone do this for you we recommend
-you have the work submitted to the project and merged. Once accepted into the
-project the work will be maintained as part of the development process within
-the project and this is a benefit for.
 Real-time Application Systems
diff --git a/user/support/bugs.rst b/user/support/bugs.rst
new file mode 100644
index 0000000..1ad1b5f
--- /dev/null
+++ b/user/support/bugs.rst
@@ -0,0 +1,22 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2019 embedded brains GmbH
+.. Copyright (C) 2019 Sebastian Huber
+.. Copyright (C) 2016 Chris Johns <chrisj at rtems.org>
+.. index:: bugs
+.. index:: reporting bugs
+Bugs
+The bug tracker can be found at the :r:url:`bugs`.
+See the `Submission Guidelines <http://devel.rtems.org/wiki/NewTicket/>`_ for
+details on submitting a ticket.
+Be sure to do a cursory search for any tickets that may be relevant to your
+problem.
+If you are unsure about your issue status submit a ticket and we will help you
+sort it out.
diff --git a/user/support/contrib.rst b/user/support/contrib.rst
index 0000000..f75b867
--- /dev/null
+++ b/user/support/contrib.rst
@@ -0,0 +1,14 @@
+.. index:: community; developers
+Contributing
+Developers can find help and support on the :r:list:`devel`.
+Technical documents including design, :r:url:`gsoc`, :r:url:`socis` can be
+found on the :r:url:`devel`.
diff --git a/user/support/index.rst b/user/support/index.rst
index 0000000..6147c06
--- /dev/null
+++ b/user/support/index.rst
@@ -0,0 +1,16 @@
+.. index:: support
+Support and Contributing
+.. toctree::
+    support-project
+    bugs
+    contrib
+    support-commercial
diff --git a/user/support/support-commercial.rst b/user/support/support-commercial.rst
index 0000000..d3aebaa
--- /dev/null
+++ b/user/support/support-commercial.rst
@@ -0,0 +1,22 @@
+.. index:: support; commercial
+Commercial Support Services
+The wider RTEMS community has developers and organizations who can provide
+commercial support services. These services range from training, implementing
+new features in RTEMS, deployment of RTEMS, helping establish a new project
+environment for a team, to application and system design.
+The RTEMS Project does not endorse or promote any provider of these services
+and we recommend you use a search engine to locate a suitable provider. If you
+are unsure please contact a provider and see what is available.
+If you develop a new feature or you have someone do this for you we recommend
+you have the work submitted to the project and merged. Once accepted into the
+project the work will be maintained as part of the development process within
+the project and this is a benefit for.
diff --git a/user/support/support-project.rst b/user/support/support-project.rst
index 0000000..b782029
--- /dev/null
+++ b/user/support/support-project.rst
@@ -0,0 +1,80 @@
+.. index:: support; RTEMS Project
+RTEMS Project Support
+.. index:: community; users mailing list
+.. index:: mailing lists; users
+Users Mailing List
+RTEMS offers a variety of support options and ways to contribute to the
+project.  Users can ask their questions on the :r:list:`users`.  This is a low
+frequency mailing list intended for topics related to the use of RTEMS.  If you
+are new to RTEMS, please join the list and ask whatever you want.
+.. index:: documentation
+Documentation
+You find the latest set of manuals at the :r:url:`docs`.
+.. index:: mailing lists; announce
+.. index:: mailing lists; bugs
+.. index:: mailing lists; build
+.. index:: mailing lists; devel
+.. index:: mailing lists; vc
+All Mailing Lists
+We have several mailing lists for RTEMS users and developers:
+* :r:list:`announce`: Announcements for major and other project-related issues.
+* :r:list:`bugs`: Emails generated by the :r:url:`bugs`.
+* :r:list:`devel`: For developers of RTEMS itself.
+* :r:list:`build`: Results from building and testing of RTEMS.
+* :r:list:`users`: For users of RTEMS.
+* :r:list:`vc`: Commits to the RTEMS Project repositories.
+IRC
+.. index:: community; IRC
+.. index:: IRC
+RTEMS IRC is available on the Freenode network. See the `Freenode
+<http://www.freenode.net/>`_ web site for details on connecting, selecting a
+nickname, and general usage tips. If you are new to IRC it is recommended
+reading.
+These is currently only one IRC channel available for RTEMS:
+  **#rtems**
+This is a general channel for all things RTEMS. You can just hang out with
+other RTEMS users and developers to talk about RTEMS, using RTEMS or to make
+contact with other RTEMS users.
+The ``#rtems`` channel is logged. You can find the logs at:
+   http://www.rtems.org/irclogs/
+You can search the logs using Google by adding
+   **site:rtems.org inurl:irclogs**
+to your search terms.
2.16.4
