[PATCH] libdl/debugger: Fix the broken list delete when unloading an object module.
chrisj at rtems.org chrisj at rtems.org
Tue Aug 6 02:55:17 UTC 2019
Closes #3777
 .../start/{linkcmds => linkcmds.in}           |  0
 cpukit/libdl/rtl-debugger.c                   | 26 +++++++++----------
 cpukit/libdl/rtl-elf.c                        |  2 --
 3 files changed, 13 insertions(+), 15 deletions(-)
 rename bsps/arm/raspberrypi/start/{linkcmds => linkcmds.in} (100%)
diff --git a/bsps/arm/raspberrypi/start/linkcmds b/bsps/arm/raspberrypi/start/linkcmds.in
similarity index 100%
rename from bsps/arm/raspberrypi/start/linkcmds
rename to bsps/arm/raspberrypi/start/linkcmds.in
diff --git a/cpukit/libdl/rtl-debugger.c b/cpukit/libdl/rtl-debugger.c
index 92ab98e3c5..e6c5e161fd 100644
--- a/cpukit/libdl/rtl-debugger.c
+++ b/cpukit/libdl/rtl-debugger.c
@@ -64,13 +64,13 @@ _rtld_linkmap_add (rtems_rtl_obj* obj)
   if (_rtld_debug.r_map == NULL)
     _rtld_debug.r_map = l;
-    return true;
-  for (prev = _rtld_debug.r_map; prev->l_next != NULL; prev = prev->l_next);
-  l->l_prev = prev;
-  prev->l_next = l;
+  else
+    for (prev = _rtld_debug.r_map; prev->l_next != NULL; prev = prev->l_next);
+    l->l_prev = prev;
+    prev->l_next = l;
   return true;
@@ -79,20 +79,20 @@ void
 _rtld_linkmap_delete (rtems_rtl_obj* obj)
   struct link_map* l = obj->linkmap;
    *  link_maps are allocated together if not 1
   struct link_map* e = l + obj->obj_num - 1;
-  while (e && e->l_next) e = e->l_next;
   if (l->l_prev == NULL)
     if ((_rtld_debug.r_map = e->l_next) != NULL)
-      e->l_next->l_prev = NULL;
-    return;
+     _rtld_debug.r_map->l_prev = NULL;
+  else
+    if ((l->l_prev->l_next = e->l_next) != NULL)
+      e->l_next->l_prev = l->l_prev;
-  if ((l->l_prev->l_next = e->l_next) != NULL)
-    e->l_next->l_prev = l->l_prev;
diff --git a/cpukit/libdl/rtl-elf.c b/cpukit/libdl/rtl-elf.c
index 0389408dd0..76001d9bfc 100644
--- a/cpukit/libdl/rtl-elf.c
+++ b/cpukit/libdl/rtl-elf.c
@@ -1593,8 +1593,6 @@ rtems_rtl_elf_load_linkmap (rtems_rtl_obj* obj)
   obj->linkmap->sec_addr[rap_bss] = obj->bss_base;
   sd = obj->linkmap->sec_detail;
-  sections = &obj->sections;
-  node = rtems_chain_first (sections);
   for (m = 0; m < sect_masks; ++m)
2.19.1
