GSoC Project | Basic Support for Trace Compass
Tue Aug 6 06:03:12 UTC 2019
On 06/08/2019 07:27, Sebastian Huber wrote:
> On 06/08/2019 07:20, Ravindra Kumar Meena wrote:
>>      > Have made changes. Simplified the code.
>> https://github.com/rmeena840/rtems-tools/commit/9e09be40db85e4e903118f8eb5eb1ea1e41baf46
>>     Yes, this moves into the right direction:
>>     +      for( i = 0; i < THREAD_NAME_SIZE - 1; i++ ){
>>     +        if( cctx->thread_names[ api_id ][ thread_id ][ i ] ==
>> 0x00 ){
>>     +          cctx->thread_names[ api_id ][ thread_id ][ i ] = (
>>     thread_name  & 0xff );
>>     +          thread_name = ( thread_name >> 8 );
>>     On a 32-bit target you may get up to 4 RTEMS_RECORD_THREAD_NAME
>> events,
>>     on a 64-bit target you may get up to 2 RTEMS_RECORD_THREAD_NAME
>> events.
>>     Your code overwrites the data from previous name events and only the
>>     last one is visible. You have to add the name index (i) to
>>     thread_id_name.
>> The overwrites thing is taken care of by :
>> if( cctx->thread_names[ api_id ][ thread_id ][ i ] == 0x00 )
>> If thread_name is received for the same api_id and thread_id then it
>> will write only in empty char position.
> For example this sequence of events is generated in case the thread name
> exceeds 8 chars:
> THREAD_ID:a01001e
> THREAD_NAME:737769363a207461
> THREAD_NAME:736b2071756575
> The decoded thread name is "swi6: task queu"
> For each RTEMS_RECORD_THREAD_NAME event you start the loop at i == 0, so
> you overwrite your previous data.
The thread name encoding was difficult to decode. I changed it like this:
https://git.rtems.org/rtems/commit/?id=cc91fae43a71ccb5f47fa7ed179dd86c53e290ae
I pushed new raw data to the repository.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
