Chapter/section numbers in document internal references
Sebastian Huber
Tue Aug 6 08:23:29 UTC 2019
On 06/08/2019 10:05, Chris Johns wrote:
> On 6/8/19 4:36 pm, Sebastian Huber wrote:
>> Hello,
>> when you use document internal references, e.g.
>> :ref:`RSB`
>> then this is turned into:
>> "Chapter 12 - RTEMS Source Builder"
>> I think this "Chapter 12 - " prefix makes it harder to read the document. In a
>> default configuration of Sphinx this stuff is not included. Would it be possible
>> to remove this from the RTEMS customization?
> What are you suggesting instead? Could you put something online so I could compare?
> I did play around with this but I cannot remember all the variations and why I
> selected this one.
To see the default behaviour, please create a new document with
sphinx-quickstart and copy the attached index.rst over the default. Run
"make latexpdf".
On page 1 you see "See Section.". With the RTEMS style you would
probably see "See Chapter 1 - Section".
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
.. Test documentation master file, created by
sphinx-quickstart on Tue Aug 6 10:18:55 2019.
You can adapt this file completely to your liking, but it should at least
contain the root `toctree` directive.
Welcome to Test's documentation!
See :ref:`Section`.
.. toctree::
:maxdepth: 2
:caption: Contents:
.. _Section:
Section
Some content.
Indices and tables
* :ref:`genindex`
* :ref:`modindex`
* :ref:`search`
Type: application/pdf
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190806/d7e501ad/attachment-0001.pdf>
