Not able to run riscv-rv32imac testsuites
Tue Aug 6 09:06:39 UTC 2019
On 06/08/2019 10:54, Vaibhav Gupta wrote:
> Getting this error:
> $ rtems-test --rtems-bsp=rv32imac
> --rtems-tools=$HOME/development/rtems/5
> ~/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
> RTEMS Testing - Tester, 5.0.not_released
>   Command Line: /home/varodek/development/rtems/5/bin/rtems-test
> --rtems-bsp=rv32imac --rtems-tools=/home/varodek/development/rtems/5
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
>   Host: Linux varodek 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20
> 15:00:46 UTC 2019 x86_64
>   Python: 3.7.3 (default, Mar 26 2019, 21:43:19) [GCC 8.2.1 20181127]
> Host: Linux-5.0.9-arch1-1-ARCH-x86_64-with-arch (Linux varodek
> 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46 UTC 2019 x86_64 )
> error: cannot find bsp configuration file: rv32imac.ini
Ok, maybe you can try one of these:
find -name '*rv*ini' | sort
./tester/rtems/testing/bsps/rv32iac_spike.ini
./tester/rtems/testing/bsps/rv32imac_spike.ini
./tester/rtems/testing/bsps/rv32imafc_spike.ini
./tester/rtems/testing/bsps/rv32imafdc_spike.ini
./tester/rtems/testing/bsps/rv32imafd_spike.ini
./tester/rtems/testing/bsps/rv32im_spike.ini
./tester/rtems/testing/bsps/rv32i_spike.ini
./tester/rtems/testing/bsps/rv64imac_medany_spike.ini
./tester/rtems/testing/bsps/rv64imac_spike.ini
./tester/rtems/testing/bsps/rv64imafdc_medany_spike.ini
./tester/rtems/testing/bsps/rv64imafdc_spike.ini
./tester/rtems/testing/bsps/rv64imafd_medany.ini
./tester/rtems/testing/bsps/rv64imafd_medany_spike.ini
./tester/rtems/testing/bsps/rv64imafd_spike.ini
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
