GSoC Project | Basic Support for Trace Compass
    Sebastian Huber
    Tue Aug  6 11:45:24 UTC 2019
On 06/08/2019 13:41, Ravindra Kumar Meena wrote:
>      > Done
>     https://github.com/rmeena840/rtems-tools/commit/8ceb3ccb97422044fb30b3c562fc736cf0686d48
>     Ok, good. Now please use this table to populate the thread names in the
>     sched_switch event.
> Do we have to populate it at the end of the file when print_item() has
> done its job?
> And this table is not CPU specific so I am not sure in which CPU file
> should I populate it?
No, when you emit a sched_switch event in print_item() you replace the
snprintf( item_data_str, sizeof( item_data_str ), "%08"PRIx64,
with a memcpy() from the corresponding thread_names entry.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
