GSoC Project | Basic Support for Trace Compass
Tue Aug 6 13:28:16 UTC 2019
On 06/08/2019 15:14, Ravindra Kumar Meena wrote:
>     There is another bug here:
>     size_t api_id = ( ( cctx->thread_id_name[ item->cpu ].thread_id >> 24 )
>     & 0x7 );
>     Please make sure that you don't have an out of bounds access. Check the
>     dimensions of your array against the values you get from the line above.
> I think this can be the right way to check bound access.
> https://github.com/rmeena840/rtems-tools/commit/81bf2a9b9e57e7911d519c4719c5126e29a7adbe
No, the API classes are 1, 2, and 3. The indices into the table must be
0, 1, and 2. Don't add asserts in this path. Ignore items which have
unexpected values.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
