[PATCH v3 1/3] Miscellaneous Makefile.in regenerated
Tue Aug 6 14:05:16 UTC 2019
 newlib/libc/machine/msp430/Makefile.in  |  1 -
 newlib/libc/machine/riscv/Makefile.in   | 21 +++++++-------
 newlib/libc/search/Makefile.in          | 50 ++++++++++++---------------------
 newlib/libm/machine/aarch64/Makefile.in |  7 +++--
 4 files changed, 33 insertions(+), 46 deletions(-)
diff --git a/newlib/libc/machine/msp430/Makefile.in b/newlib/libc/machine/msp430/Makefile.in
index 6f837c9..efbdf7c 100644
--- a/newlib/libc/machine/msp430/Makefile.in
+++ b/newlib/libc/machine/msp430/Makefile.in
@@ -198,7 +198,6 @@ pdfdir = @pdfdir@
 prefix = @prefix@
 program_transform_name = @program_transform_name@
 psdir = @psdir@
-runstatedir = @runstatedir@
 sbindir = @sbindir@
 sharedstatedir = @sharedstatedir@
 srcdir = @srcdir@
diff --git a/newlib/libc/machine/riscv/Makefile.in b/newlib/libc/machine/riscv/Makefile.in
index 304dd35..e6dee87 100644
--- a/newlib/libc/machine/riscv/Makefile.in
+++ b/newlib/libc/machine/riscv/Makefile.in
@@ -69,9 +69,9 @@ LIBRARIES = $(noinst_LIBRARIES)
 ARFLAGS = cru
 lib_a_AR = $(AR) $(ARFLAGS)
 lib_a_LIBADD =
-am_lib_a_OBJECTS = lib_a-memset.$(OBJEXT) lib_a-memcpy.$(OBJEXT) \
-	lib_a-memcpy-asm.$(OBJEXT) \
-	lib_a-memmove.$(OBJEXT) lib_a-memmove-stub.$(OBJEXT) \
+am_lib_a_OBJECTS = lib_a-memmove.$(OBJEXT) \
+	lib_a-memmove-stub.$(OBJEXT) lib_a-memset.$(OBJEXT) \
+	lib_a-memcpy-asm.$(OBJEXT) lib_a-memcpy.$(OBJEXT) \
 	lib_a-strlen.$(OBJEXT) lib_a-strcpy.$(OBJEXT) \
 	lib_a-strcmp.$(OBJEXT) lib_a-setjmp.$(OBJEXT) \
 	lib_a-ieeefp.$(OBJEXT) lib_a-ffs.$(OBJEXT)
@@ -200,8 +200,9 @@ AUTOMAKE_OPTIONS = cygnus
 INCLUDES = $(NEWLIB_CFLAGS) $(CROSS_CFLAGS) $(TARGET_CFLAGS)
 AM_CCASFLAGS = $(INCLUDES)
 noinst_LIBRARIES = lib.a
-lib_a_SOURCES = memcpy-asm.S memmove.S memmove-stub.c memset.S memcpy.c strlen.c \
+lib_a_SOURCES = memmove.S memmove-stub.c memset.S memcpy-asm.S memcpy.c strlen.c \
 	strcpy.c strcmp.S setjmp.S ieeefp.c ffs.c
 lib_a_CCASFLAGS = $(AM_CCASFLAGS)
 lib_a_CFLAGS = $(AM_CFLAGS)
 ACLOCAL_AMFLAGS = -I ../../.. -I ../../../..
@@ -270,18 +271,18 @@ lib_a-memmove.o: memmove.S
 lib_a-memmove.obj: memmove.S
 	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CCASFLAGS) $(CCASFLAGS) -c -o lib_a-memmove.obj `if test -f 'memmove.S'; then $(CYGPATH_W) 'memmove.S'; else $(CYGPATH_W) '$(srcdir)/memmove.S'; fi`
-lib_a-memcpy-asm.o: memcpy-asm.S
-	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CCASFLAGS) $(CCASFLAGS) -c -o lib_a-memcpy-asm.o `test -f 'memcpy-asm.S' || echo '$(srcdir)/'`memcpy-asm.S
-lib_a-memcpy-asm.obj: memcpy-asm.S
-	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CCASFLAGS) $(CCASFLAGS) -c -o lib_a-memcpy-asm.obj `if test -f 'memcpy-asm.S'; then $(CYGPATH_W) 'memcpy-asm.S'; else $(CYGPATH_W) '$(srcdir)/memcpy-asm.S'; fi`
 lib_a-memset.o: memset.S
 	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CCASFLAGS) $(CCASFLAGS) -c -o lib_a-memset.o `test -f 'memset.S' || echo '$(srcdir)/'`memset.S
 lib_a-memset.obj: memset.S
 	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CCASFLAGS) $(CCASFLAGS) -c -o lib_a-memset.obj `if test -f 'memset.S'; then $(CYGPATH_W) 'memset.S'; else $(CYGPATH_W) '$(srcdir)/memset.S'; fi`
+lib_a-memcpy-asm.o: memcpy-asm.S
+	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CCASFLAGS) $(CCASFLAGS) -c -o lib_a-memcpy-asm.o `test -f 'memcpy-asm.S' || echo '$(srcdir)/'`memcpy-asm.S
+lib_a-memcpy-asm.obj: memcpy-asm.S
+	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CCASFLAGS) $(CCASFLAGS) -c -o lib_a-memcpy-asm.obj `if test -f 'memcpy-asm.S'; then $(CYGPATH_W) 'memcpy-asm.S'; else $(CYGPATH_W) '$(srcdir)/memcpy-asm.S'; fi`
 lib_a-strcmp.o: strcmp.S
 	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CCASFLAGS) $(CCASFLAGS) -c -o lib_a-strcmp.o `test -f 'strcmp.S' || echo '$(srcdir)/'`strcmp.S
diff --git a/newlib/libc/search/Makefile.in b/newlib/libc/search/Makefile.in
index 8077a5f..4330472 100644
--- a/newlib/libc/search/Makefile.in
+++ b/newlib/libc/search/Makefile.in
@@ -1,8 +1,9 @@
-# Makefile.in generated by automake 1.12.2 from Makefile.am.
+# Makefile.in generated by automake 1.11.6 from Makefile.am.
 # @configure_input@
-# Copyright (C) 1994-2012 Free Software Foundation, Inc.
+# Copyright (C) 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002,
+# 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011 Free Software
+# Foundation, Inc.
 # This Makefile.in is free software; the Free Software Foundation
 # gives unlimited permission to copy and/or distribute it,
 # with or without modifications, as long as this notice is preserved.
@@ -53,11 +54,15 @@ POST_UNINSTALL = :
 build_triplet = @build@
 host_triplet = @host@
 DIST_COMMON = $(srcdir)/../../Makefile.shared $(srcdir)/Makefile.in \
-	$(srcdir)/Makefile.am $(top_srcdir)/../../mkinstalldirs
+	$(srcdir)/Makefile.am
 subdir = search
 ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
-am__aclocal_m4_deps = $(top_srcdir)/../acinclude.m4 \
-	$(top_srcdir)/configure.in
+am__aclocal_m4_deps = $(top_srcdir)/../../libtool.m4 \
+	$(top_srcdir)/../../ltoptions.m4 \
+	$(top_srcdir)/../../ltsugar.m4 \
+	$(top_srcdir)/../../ltversion.m4 \
+	$(top_srcdir)/../../lt~obsolete.m4 \
+	$(top_srcdir)/../acinclude.m4 $(top_srcdir)/configure.in
 am__configure_deps = $(am__aclocal_m4_deps) $(CONFIGURE_DEPENDENCIES) \
 	$(ACLOCAL_M4)
 mkinstalldirs = $(SHELL) $(top_srcdir)/../../mkinstalldirs
@@ -182,10 +187,8 @@ LIBTOOL = @LIBTOOL@
 LIPO = @LIPO@
 LN_S = @LN_S@
 LTLIBOBJS = @LTLIBOBJS@
-LT_SYS_LIBRARY_PATH = @LT_SYS_LIBRARY_PATH@
 MAINT = @MAINT@
 MAKEINFO = @MAKEINFO@
-MANIFEST_TOOL = @MANIFEST_TOOL@
 MKDIR_P = @MKDIR_P@
 NEWLIB_CFLAGS = @NEWLIB_CFLAGS@
 NM = @NM@
@@ -214,7 +217,6 @@ abs_builddir = @abs_builddir@
 abs_srcdir = @abs_srcdir@
 abs_top_builddir = @abs_top_builddir@
 abs_top_srcdir = @abs_top_srcdir@
-ac_ct_AR = @ac_ct_AR@
 ac_ct_CC = @ac_ct_CC@
 ac_ct_DUMPBIN = @ac_ct_DUMPBIN@
 aext = @aext@
@@ -374,14 +376,12 @@ lib.a: $(lib_a_OBJECTS) $(lib_a_DEPENDENCIES) $(EXTRA_lib_a_DEPENDENCIES)
 clean-noinstLTLIBRARIES:
 	-test -z "$(noinst_LTLIBRARIES)" || rm -f $(noinst_LTLIBRARIES)
-	@list='$(noinst_LTLIBRARIES)'; \
-	locs=`for p in $$list; do echo $$p; done | \
-	      sed 's|^[^/]*$$|.|; s|/[^/]*$$||; s|$$|/so_locations|' | \
-	      sort -u`; \
-	test -z "$$locs" || { \
-	  echo rm -f $${locs}; \
-	  rm -f $${locs}; \
+	@list='$(noinst_LTLIBRARIES)'; for p in $$list; do \
+	  dir="`echo $$p | sed -e 's|/[^/]*$$||'`"; \
+	  test "$$dir" != "$$p" || dir=.; \
+	  echo "rm -f \"$${dir}/so_locations\""; \
+	  rm -f "$${dir}/so_locations"; \
+	done
 libsearch.la: $(libsearch_la_OBJECTS) $(libsearch_la_DEPENDENCIES) $(EXTRA_libsearch_la_DEPENDENCIES)
 	$(libsearch_la_LINK) $(am_libsearch_la_rpath) $(libsearch_la_OBJECTS) $(libsearch_la_LIBADD) $(LIBS)
@@ -563,20 +563,6 @@ GTAGS:
 	  && $(am__cd) $(top_srcdir) \
 	  && gtags -i $(GTAGS_ARGS) "$$here"
-cscopelist:  $(HEADERS) $(SOURCES) $(LISP)
-	list='$(SOURCES) $(HEADERS) $(LISP)'; \
-	case "$(srcdir)" in \
-	  [\\/]* | ?:[\\/]*) sdir="$(srcdir)" ;; \
-	  *) sdir=$(subdir)/$(srcdir) ;; \
-	esac; \
-	for i in $$list; do \
-	  if test -f "$$i"; then \
-	    echo "$(subdir)/$$i"; \
-	  else \
-	    echo "$$sdir/$$i"; \
-	  fi; \
-	done >> $(top_builddir)/cscope.files
 distclean-tags:
 	-rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
 check-am:
@@ -687,7 +673,7 @@ uninstall-am:
 .PHONY: CTAGS GTAGS all all-am check check-am clean clean-generic \
 	clean-libtool clean-noinstLIBRARIES clean-noinstLTLIBRARIES \
-	cscopelist ctags distclean distclean-compile distclean-generic \
+	ctags distclean distclean-compile distclean-generic \
 	distclean-libtool distclean-tags dvi dvi-am html html-am info \
 	info-am install install-am install-data install-data-am \
 	install-dvi install-dvi-am install-exec install-exec-am \
diff --git a/newlib/libm/machine/aarch64/Makefile.in b/newlib/libm/machine/aarch64/Makefile.in
index d31237e..ac85b3f 100644
--- a/newlib/libm/machine/aarch64/Makefile.in
+++ b/newlib/libm/machine/aarch64/Makefile.in
@@ -52,9 +52,10 @@ PRE_UNINSTALL = :
 POST_UNINSTALL = :
-DIST_COMMON = $(srcdir)/../../../Makefile.shared $(srcdir)/Makefile.in \
-	$(srcdir)/Makefile.am $(top_srcdir)/configure \
-	$(am__configure_deps) $(srcdir)/../../../../mkinstalldirs
+DIST_COMMON = $(srcdir)/../../../Makefile.shared INSTALL \
+	$(srcdir)/Makefile.in $(srcdir)/Makefile.am \
+	$(top_srcdir)/configure $(am__configure_deps) \
+	$(srcdir)/../../../../mkinstalldirs
 subdir = .
 am__aclocal_m4_deps = $(top_srcdir)/../../../acinclude.m4 \
1.8.3.1
