[PATCH v3 3/3] Regenerated files from fenv.h addition
Tue Aug 6 14:05:18 UTC 2019
 newlib/libm/Makefile.in      |  12 +-
 newlib/libm/configure        |   3 +-
 newlib/libm/fenv/Makefile.in | 628 +++++++++++++++++++++++++++++++++++++++++++
 3 files changed, 636 insertions(+), 7 deletions(-)
 create mode 100644 newlib/libm/fenv/Makefile.in
diff --git a/newlib/libm/Makefile.in b/newlib/libm/Makefile.in
index 59a53b5..64e4994 100644
--- a/newlib/libm/Makefile.in
+++ b/newlib/libm/Makefile.in
@@ -80,12 +80,12 @@ LTLIBRARIES = $(noinst_LTLIBRARIES)
 am__DEPENDENCIES_1 =
 @USE_LIBTOOL_FALSE at am__DEPENDENCIES_2 = $(MATHDIR)/lib.$(aext) \
 @USE_LIBTOOL_FALSE@	common/lib.$(aext) complex/lib.$(aext) \
- at USE_LIBTOOL_FALSE@	$(am__DEPENDENCIES_1)
+ at USE_LIBTOOL_FALSE@	fenv/lib.$(aext) $(am__DEPENDENCIES_1)
 @USE_LIBTOOL_TRUE at am__DEPENDENCIES_2 =  \
 @USE_LIBTOOL_TRUE@	$(MATHDIR)/lib$(MATHDIR).$(aext) \
 @USE_LIBTOOL_TRUE@	common/libcommon.$(aext) \
 @USE_LIBTOOL_TRUE@	complex/libcomplex.$(aext) \
- at USE_LIBTOOL_TRUE@	$(am__DEPENDENCIES_1)
+ at USE_LIBTOOL_TRUE@	fenv/libfenv.$(aext) $(am__DEPENDENCIES_1)
 @USE_LIBTOOL_TRUE at libm_la_DEPENDENCIES = $(am__DEPENDENCIES_2)
 am_libm_la_OBJECTS =
 libm_la_OBJECTS = $(am_libm_la_OBJECTS)
@@ -168,7 +168,7 @@ AM_RECURSIVE_TARGETS = $(RECURSIVE_TARGETS:-recursive=) \
 	$(RECURSIVE_CLEAN_TARGETS:-recursive=) tags TAGS ctags CTAGS
 ETAGS = etags
 CTAGS = ctags
-DIST_SUBDIRS = math mathfp common complex machine
+DIST_SUBDIRS = math mathfp common complex fenv machine
 ACLOCAL = @ACLOCAL@
 AMTAR = @AMTAR@
 AR = @AR@
@@ -299,10 +299,10 @@ top_srcdir = @top_srcdir@
 AUTOMAKE_OPTIONS = cygnus
 @NEWLIB_HW_FP_FALSE at MATHDIR = math
 @NEWLIB_HW_FP_TRUE at MATHDIR = mathfp
-SUBDIRS = $(MATHDIR) common complex machine
+SUBDIRS = $(MATHDIR) common complex fenv machine
 libm_la_LDFLAGS = -Xcompiler -nostdlib
- at USE_LIBTOOL_FALSE@SUBLIBS = $(MATHDIR)/lib.$(aext) common/lib.$(aext) complex/lib.$(aext) $(LIBM_MACHINE_LIB)
- at USE_LIBTOOL_TRUE@SUBLIBS = $(MATHDIR)/lib$(MATHDIR).$(aext) common/libcommon.$(aext) complex/libcomplex.$(aext)  $(LIBM_MACHINE_LIB)
+ at USE_LIBTOOL_FALSE@SUBLIBS = $(MATHDIR)/lib.$(aext) common/lib.$(aext) complex/lib.$(aext) fenv/lib.$(aext) $(LIBM_MACHINE_LIB)
+ at USE_LIBTOOL_TRUE@SUBLIBS = $(MATHDIR)/lib$(MATHDIR).$(aext) common/libcommon.$(aext) complex/libcomplex.$(aext) fenv/libfenv.$(aext) $(LIBM_MACHINE_LIB)
 @USE_LIBTOOL_TRUE at noinst_LTLIBRARIES = libm.la
 @USE_LIBTOOL_TRUE at libm_la_SOURCES =
 @USE_LIBTOOL_TRUE at libm_la_LIBADD = $(SUBLIBS)
diff --git a/newlib/libm/configure b/newlib/libm/configure
index e8a0a99..309a668 100755
--- a/newlib/libm/configure
+++ b/newlib/libm/configure
@@ -11868,7 +11868,7 @@ fi
-ac_config_files="$ac_config_files Makefile math/Makefile mathfp/Makefile common/Makefile complex/Makefile"
+ac_config_files="$ac_config_files Makefile math/Makefile mathfp/Makefile common/Makefile complex/Makefile fenv/Makefile"
 cat >confcache <<\_ACEOF
 # This file is a shell script that caches the results of configure
@@ -12930,6 +12930,7 @@ do
     "mathfp/Makefile") CONFIG_FILES="$CONFIG_FILES mathfp/Makefile" ;;
     "common/Makefile") CONFIG_FILES="$CONFIG_FILES common/Makefile" ;;
     "complex/Makefile") CONFIG_FILES="$CONFIG_FILES complex/Makefile" ;;
+    "fenv/Makefile") CONFIG_FILES="$CONFIG_FILES fenv/Makefile" ;;
   *) as_fn_error $? "invalid argument: \`$ac_config_target'" "$LINENO" 5;;
   esac
diff --git a/newlib/libm/fenv/Makefile.in b/newlib/libm/fenv/Makefile.in
new file mode 100644
index 0000000..b9a2db9
--- /dev/null
+++ b/newlib/libm/fenv/Makefile.in
@@ -0,0 +1,628 @@
+# Makefile.in generated by automake 1.11.6 from Makefile.am.
+# @configure_input@
+# Copyright (C) 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002,
+# 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011 Free Software
+# Foundation, Inc.
+# This Makefile.in is free software; the Free Software Foundation
+# gives unlimited permission to copy and/or distribute it,
+# with or without modifications, as long as this notice is preserved.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
+# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
+# PARTICULAR PURPOSE.
+ at SET_MAKE@
+VPATH = @srcdir@
+am__make_dryrun = \
+    am__dry=no; \
+    case $$MAKEFLAGS in \
+        echo 'am--echo: ; @echo "AM"  OK' | $(MAKE) -f - 2>/dev/null \
+          | grep '^AM OK$$' >/dev/null || am__dry=yes;; \
+        for am__flg in $$MAKEFLAGS; do \
+          case $$am__flg in \
+            *n*) am__dry=yes; break;; \
+          esac; \
+        done;; \
+    esac; \
+    test $$am__dry = yes; \
+pkgdatadir = $(datadir)/@PACKAGE@
+pkgincludedir = $(includedir)/@PACKAGE@
+pkglibdir = $(libdir)/@PACKAGE@
+pkglibexecdir = $(libexecdir)/@PACKAGE@
+am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd
+install_sh_DATA = $(install_sh) -c -m 644
+install_sh_PROGRAM = $(install_sh) -c
+install_sh_SCRIPT = $(install_sh) -c
+INSTALL_HEADER = $(INSTALL_DATA)
+transform = $(program_transform_name)
+NORMAL_INSTALL = :
+PRE_INSTALL = :
+POST_INSTALL = :
+NORMAL_UNINSTALL = :
+PRE_UNINSTALL = :
+POST_UNINSTALL = :
+build_triplet = @build@
+host_triplet = @host@
+ at USE_LIBTOOL_FALSE@am__append_1 = $(AM_CFLAGS)
+DIST_COMMON = $(srcdir)/../../Makefile.shared $(srcdir)/Makefile.in \
+	$(srcdir)/Makefile.am
+subdir = fenv
+ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
+am__aclocal_m4_deps = $(top_srcdir)/../../libtool.m4 \
+	$(top_srcdir)/../../ltoptions.m4 \
+	$(top_srcdir)/../../ltsugar.m4 \
+	$(top_srcdir)/../../ltversion.m4 \
+	$(top_srcdir)/../../lt~obsolete.m4 \
+	$(top_srcdir)/../acinclude.m4 $(top_srcdir)/configure.in
+am__configure_deps = $(am__aclocal_m4_deps) $(CONFIGURE_DEPENDENCIES) \
+	$(ACLOCAL_M4)
+mkinstalldirs = $(SHELL) $(top_srcdir)/../../mkinstalldirs
+CONFIG_CLEAN_FILES =
+CONFIG_CLEAN_VPATH_FILES =
+LIBRARIES = $(noinst_LIBRARIES)
+ARFLAGS = cru
+lib_a_AR = $(AR) $(ARFLAGS)
+lib_a_LIBADD =
+am__objects_1 = lib_a-feclearexcept.$(OBJEXT) \
+	lib_a-fe_dfl_env.$(OBJEXT) lib_a-fegetenv.$(OBJEXT) \
+	lib_a-fegetexceptflag.$(OBJEXT) lib_a-fegetround.$(OBJEXT) \
+	lib_a-feholdexcept.$(OBJEXT) lib_a-feraiseexcept.$(OBJEXT) \
+	lib_a-fesetenv.$(OBJEXT) lib_a-fesetexceptflag.$(OBJEXT) \
+	lib_a-fesetround.$(OBJEXT) lib_a-fetestexcept.$(OBJEXT) \
+	lib_a-feupdateenv.$(OBJEXT)
+ at USE_LIBTOOL_FALSE@am_lib_a_OBJECTS = $(am__objects_1)
+lib_a_OBJECTS = $(am_lib_a_OBJECTS)
+LTLIBRARIES = $(noinst_LTLIBRARIES)
+libcommon_la_LIBADD =
+am__objects_2 = feclearexcept.lo fe_dfl_env.lo fegetenv.lo \
+	fegetexceptflag.lo fegetround.lo feholdexcept.lo \
+	feraiseexcept.lo fesetenv.lo fesetexceptflag.lo fesetround.lo \
+	fetestexcept.lo feupdateenv.lo
+ at USE_LIBTOOL_TRUE@am_libcommon_la_OBJECTS = $(am__objects_2)
+libcommon_la_OBJECTS = $(am_libcommon_la_OBJECTS)
+libcommon_la_LINK = $(LIBTOOL) --tag=CC $(AM_LIBTOOLFLAGS) \
+	$(LIBTOOLFLAGS) --mode=link $(CCLD) $(AM_CFLAGS) $(CFLAGS) \
+	$(libcommon_la_LDFLAGS) $(LDFLAGS) -o $@
+ at USE_LIBTOOL_TRUE@am_libcommon_la_rpath =
+DEFAULT_INCLUDES = -I. at am__isrc@
+depcomp =
+am__depfiles_maybe =
+COMPILE = $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) \
+	$(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS)
+LTCOMPILE = $(LIBTOOL) --tag=CC $(AM_LIBTOOLFLAGS) $(LIBTOOLFLAGS) \
+	--mode=compile $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) \
+	$(AM_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS)
+CCLD = $(CC)
+LINK = $(LIBTOOL) --tag=CC $(AM_LIBTOOLFLAGS) $(LIBTOOLFLAGS) \
+	--mode=link $(CCLD) $(AM_CFLAGS) $(CFLAGS) $(AM_LDFLAGS) \
+	$(LDFLAGS) -o $@
+SOURCES = $(lib_a_SOURCES) $(libcommon_la_SOURCES)
+am__can_run_installinfo = \
+  case $$AM_UPDATE_INFO_DIR in \
+    n|no|NO) false;; \
+    *) (install-info --version) >/dev/null 2>&1;; \
+  esac
+DATA = $(noinst_DATA)
+ETAGS = etags
+CTAGS = ctags
+ACLOCAL = @ACLOCAL@
+AMTAR = @AMTAR@
+AR = @AR@
+AS = @AS@
+AUTOCONF = @AUTOCONF@
+AUTOHEADER = @AUTOHEADER@
+AUTOMAKE = @AUTOMAKE@
+AWK = @AWK@
+CC = @CC@
+CCAS = @CCAS@
+CCASFLAGS = @CCASFLAGS@
+CCDEPMODE = @CCDEPMODE@
+CFLAGS = @CFLAGS@
+CPP = @CPP@
+CPPFLAGS = @CPPFLAGS@
+CYGPATH_W = @CYGPATH_W@
+DEFS = @DEFS@
+DEPDIR = @DEPDIR@
+DLLTOOL = @DLLTOOL@
+DSYMUTIL = @DSYMUTIL@
+DUMPBIN = @DUMPBIN@
+ECHO_C = @ECHO_C@
+ECHO_N = @ECHO_N@
+ECHO_T = @ECHO_T@
+EGREP = @EGREP@
+EXEEXT = @EXEEXT@
+FGREP = @FGREP@
+GREP = @GREP@
+INSTALL = @INSTALL@
+INSTALL_DATA = @INSTALL_DATA@
+INSTALL_PROGRAM = @INSTALL_PROGRAM@
+INSTALL_SCRIPT = @INSTALL_SCRIPT@
+INSTALL_STRIP_PROGRAM = @INSTALL_STRIP_PROGRAM@
+LD = @LD@
+LDFLAGS = @LDFLAGS@
+LIBM_MACHINE_LIB = @LIBM_MACHINE_LIB@
+LIBOBJS = @LIBOBJS@
+LIBS = @LIBS@
+LIBTOOL = @LIBTOOL@
+LIPO = @LIPO@
+LN_S = @LN_S@
+LTLIBOBJS = @LTLIBOBJS@
+MAINT = @MAINT@
+MAKEINFO = @MAKEINFO@
+MKDIR_P = @MKDIR_P@
+NEWLIB_CFLAGS = @NEWLIB_CFLAGS@
+NM = @NM@
+NMEDIT = @NMEDIT@
+NO_INCLUDE_LIST = @NO_INCLUDE_LIST@
+OBJDUMP = @OBJDUMP@
+OBJEXT = @OBJEXT@
+OTOOL = @OTOOL@
+OTOOL64 = @OTOOL64@
+PACKAGE = @PACKAGE@
+PACKAGE_BUGREPORT = @PACKAGE_BUGREPORT@
+PACKAGE_NAME = @PACKAGE_NAME@
+PACKAGE_STRING = @PACKAGE_STRING@
+PACKAGE_TARNAME = @PACKAGE_TARNAME@
+PACKAGE_URL = @PACKAGE_URL@
+PACKAGE_VERSION = @PACKAGE_VERSION@
+PATH_SEPARATOR = @PATH_SEPARATOR@
+RANLIB = @RANLIB@
+READELF = @READELF@
+SED = @SED@
+SET_MAKE = @SET_MAKE@
+SHELL = @SHELL@
+STRIP = @STRIP@
+VERSION = @VERSION@
+abs_builddir = @abs_builddir@
+abs_srcdir = @abs_srcdir@
+abs_top_builddir = @abs_top_builddir@
+abs_top_srcdir = @abs_top_srcdir@
+ac_ct_CC = @ac_ct_CC@
+ac_ct_DUMPBIN = @ac_ct_DUMPBIN@
+aext = @aext@
+am__include = @am__include@
+am__leading_dot = @am__leading_dot@
+am__quote = @am__quote@
+am__tar = @am__tar@
+am__untar = @am__untar@
+bindir = @bindir@
+build = @build@
+build_alias = @build_alias@
+build_cpu = @build_cpu@
+build_os = @build_os@
+build_vendor = @build_vendor@
+builddir = @builddir@
+datadir = @datadir@
+datarootdir = @datarootdir@
+docdir = @docdir@
+dvidir = @dvidir@
+exec_prefix = @exec_prefix@
+host = @host@
+host_alias = @host_alias@
+host_cpu = @host_cpu@
+host_os = @host_os@
+host_vendor = @host_vendor@
+htmldir = @htmldir@
+includedir = @includedir@
+infodir = @infodir@
+install_sh = @install_sh@
+libdir = @libdir@
+libexecdir = @libexecdir@
+libm_machine_dir = @libm_machine_dir@
+localedir = @localedir@
+localstatedir = @localstatedir@
+lpfx = @lpfx@
+machine_dir = @machine_dir@
+mandir = @mandir@
+mkdir_p = @mkdir_p@
+newlib_basedir = @newlib_basedir@
+oext = @oext@
+oldincludedir = @oldincludedir@
+pdfdir = @pdfdir@
+prefix = @prefix@
+program_transform_name = @program_transform_name@
+psdir = @psdir@
+sbindir = @sbindir@
+sharedstatedir = @sharedstatedir@
+srcdir = @srcdir@
+subdirs = @subdirs@
+sys_dir = @sys_dir@
+sysconfdir = @sysconfdir@
+target_alias = @target_alias@
+top_build_prefix = @top_build_prefix@
+top_builddir = @top_builddir@
+top_srcdir = @top_srcdir@
+AUTOMAKE_OPTIONS = cygnus
+INCLUDES = $(NEWLIB_CFLAGS) $(CROSS_CFLAGS) $(TARGET_CFLAGS)
+src = feclearexcept.c fe_dfl_env.c fegetenv.c fegetexceptflag.c \
+	fegetround.c feholdexcept.c feraiseexcept.c fesetenv.c \
+	fesetexceptflag.c fesetround.c fetestexcept.c feupdateenv.c
+libcommon_la_LDFLAGS = -Xcompiler -nostdlib
+lib_a_CFLAGS = -fbuiltin -fno-math-errno $(am__append_1)
+ at USE_LIBTOOL_TRUE@noinst_LTLIBRARIES = libcommon.la
+ at USE_LIBTOOL_TRUE@libcommon_la_SOURCES = $(src)
+ at USE_LIBTOOL_FALSE@noinst_DATA =
+ at USE_LIBTOOL_TRUE@noinst_DATA = objectlist.awk.in
+ at USE_LIBTOOL_FALSE@noinst_LIBRARIES = lib.a
+ at USE_LIBTOOL_FALSE@lib_a_SOURCES = $(src)
+# documentation rules
+SUFFIXES = .def .xml
+CHEW = ${top_builddir}/../doc/makedoc -f $(top_srcdir)/../doc/doc.str
+DOCBOOK_CHEW = ${top_srcdir}/../doc/makedocbook.py
+DOCBOOK_OUT_FILES = $(CHEWOUT_FILES:.def=.xml)
+DOCBOOK_CHAPTERS = $(CHAPTERS:.tex=.xml)
+CLEANFILES = $(CHEWOUT_FILES) $(DOCBOOK_OUT_FILES)
+CHEWOUT_FILES = feclearexcept.def fe_dfl_env.def fegetenv.def \
+	fegetexceptflag.def fegetround.def feholdexcept.def \
+	feraiseexcept.def fesetenv.def fesetexceptflag.def fesetround.def \
+	fetestexcept.def feupdateenv.def
+CHAPTERS =
+all: all-am
+.SUFFIXES:
+.SUFFIXES: .def .xml .c .lo .o .obj
+$(srcdir)/Makefile.in: @MAINTAINER_MODE_TRUE@ $(srcdir)/Makefile.am $(srcdir)/../../Makefile.shared $(am__configure_deps)
+	@for dep in $?; do \
+	  case '$(am__configure_deps)' in \
+	    *$$dep*) \
+	      ( cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh ) \
+	        && { if test -f $@; then exit 0; else break; fi; }; \
+	      exit 1;; \
+	  esac; \
+	done; \
+	echo ' cd $(top_srcdir) && $(AUTOMAKE) --cygnus fenv/Makefile'; \
+	$(am__cd) $(top_srcdir) && \
+	  $(AUTOMAKE) --cygnus fenv/Makefile
+.PRECIOUS: Makefile
+Makefile: $(srcdir)/Makefile.in $(top_builddir)/config.status
+	@case '$?' in \
+	  *config.status*) \
+	    cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh;; \
+	    echo ' cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe)'; \
+	    cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe);; \
+	esac;
+$(srcdir)/../../Makefile.shared:
+$(top_builddir)/config.status: $(top_srcdir)/configure $(CONFIG_STATUS_DEPENDENCIES)
+$(top_srcdir)/configure: @MAINTAINER_MODE_TRUE@ $(am__configure_deps)
+$(ACLOCAL_M4): @MAINTAINER_MODE_TRUE@ $(am__aclocal_m4_deps)
+$(am__aclocal_m4_deps):
+clean-noinstLIBRARIES:
+	-test -z "$(noinst_LIBRARIES)" || rm -f $(noinst_LIBRARIES)
+lib.a: $(lib_a_OBJECTS) $(lib_a_DEPENDENCIES) $(EXTRA_lib_a_DEPENDENCIES)
+	-rm -f lib.a
+	$(lib_a_AR) lib.a $(lib_a_OBJECTS) $(lib_a_LIBADD)
+	$(RANLIB) lib.a
+clean-noinstLTLIBRARIES:
+	-test -z "$(noinst_LTLIBRARIES)" || rm -f $(noinst_LTLIBRARIES)
+	@list='$(noinst_LTLIBRARIES)'; for p in $$list; do \
+	  dir="`echo $$p | sed -e 's|/[^/]*$$||'`"; \
+	  test "$$dir" != "$$p" || dir=.; \
+	  echo "rm -f \"$${dir}/so_locations\""; \
+	  rm -f "$${dir}/so_locations"; \
+	done
+libcommon.la: $(libcommon_la_OBJECTS) $(libcommon_la_DEPENDENCIES) $(EXTRA_libcommon_la_DEPENDENCIES)
+	$(libcommon_la_LINK) $(am_libcommon_la_rpath) $(libcommon_la_OBJECTS) $(libcommon_la_LIBADD) $(LIBS)
+mostlyclean-compile:
+	-rm -f *.$(OBJEXT)
+distclean-compile:
+	-rm -f *.tab.c
+.c.o:
+	$(COMPILE) -c $<
+.c.obj:
+	$(COMPILE) -c `$(CYGPATH_W) '$<'`
+.c.lo:
+	$(LTCOMPILE) -c -o $@ $<
+lib_a-feclearexcept.o: feclearexcept.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feclearexcept.o `test -f 'feclearexcept.c' || echo '$(srcdir)/'`feclearexcept.c
+lib_a-feclearexcept.obj: feclearexcept.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feclearexcept.obj `if test -f 'feclearexcept.c'; then $(CYGPATH_W) 'feclearexcept.c'; else $(CYGPATH_W) '$(srcdir)/feclearexcept.c'; fi`
+lib_a-fe_dfl_env.o: fe_dfl_env.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fe_dfl_env.o `test -f 'fe_dfl_env.c' || echo '$(srcdir)/'`fe_dfl_env.c
+lib_a-fe_dfl_env.obj: fe_dfl_env.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fe_dfl_env.obj `if test -f 'fe_dfl_env.c'; then $(CYGPATH_W) 'fe_dfl_env.c'; else $(CYGPATH_W) '$(srcdir)/fe_dfl_env.c'; fi`
+lib_a-fegetenv.o: fegetenv.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetenv.o `test -f 'fegetenv.c' || echo '$(srcdir)/'`fegetenv.c
+lib_a-fegetenv.obj: fegetenv.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetenv.obj `if test -f 'fegetenv.c'; then $(CYGPATH_W) 'fegetenv.c'; else $(CYGPATH_W) '$(srcdir)/fegetenv.c'; fi`
+lib_a-fegetexceptflag.o: fegetexceptflag.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetexceptflag.o `test -f 'fegetexceptflag.c' || echo '$(srcdir)/'`fegetexceptflag.c
+lib_a-fegetexceptflag.obj: fegetexceptflag.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetexceptflag.obj `if test -f 'fegetexceptflag.c'; then $(CYGPATH_W) 'fegetexceptflag.c'; else $(CYGPATH_W) '$(srcdir)/fegetexceptflag.c'; fi`
+lib_a-fegetround.o: fegetround.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetround.o `test -f 'fegetround.c' || echo '$(srcdir)/'`fegetround.c
+lib_a-fegetround.obj: fegetround.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetround.obj `if test -f 'fegetround.c'; then $(CYGPATH_W) 'fegetround.c'; else $(CYGPATH_W) '$(srcdir)/fegetround.c'; fi`
+lib_a-feholdexcept.o: feholdexcept.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feholdexcept.o `test -f 'feholdexcept.c' || echo '$(srcdir)/'`feholdexcept.c
+lib_a-feholdexcept.obj: feholdexcept.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feholdexcept.obj `if test -f 'feholdexcept.c'; then $(CYGPATH_W) 'feholdexcept.c'; else $(CYGPATH_W) '$(srcdir)/feholdexcept.c'; fi`
+lib_a-feraiseexcept.o: feraiseexcept.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feraiseexcept.o `test -f 'feraiseexcept.c' || echo '$(srcdir)/'`feraiseexcept.c
+lib_a-feraiseexcept.obj: feraiseexcept.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feraiseexcept.obj `if test -f 'feraiseexcept.c'; then $(CYGPATH_W) 'feraiseexcept.c'; else $(CYGPATH_W) '$(srcdir)/feraiseexcept.c'; fi`
+lib_a-fesetenv.o: fesetenv.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetenv.o `test -f 'fesetenv.c' || echo '$(srcdir)/'`fesetenv.c
+lib_a-fesetenv.obj: fesetenv.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetenv.obj `if test -f 'fesetenv.c'; then $(CYGPATH_W) 'fesetenv.c'; else $(CYGPATH_W) '$(srcdir)/fesetenv.c'; fi`
+lib_a-fesetexceptflag.o: fesetexceptflag.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetexceptflag.o `test -f 'fesetexceptflag.c' || echo '$(srcdir)/'`fesetexceptflag.c
+lib_a-fesetexceptflag.obj: fesetexceptflag.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetexceptflag.obj `if test -f 'fesetexceptflag.c'; then $(CYGPATH_W) 'fesetexceptflag.c'; else $(CYGPATH_W) '$(srcdir)/fesetexceptflag.c'; fi`
+lib_a-fesetround.o: fesetround.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetround.o `test -f 'fesetround.c' || echo '$(srcdir)/'`fesetround.c
+lib_a-fesetround.obj: fesetround.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetround.obj `if test -f 'fesetround.c'; then $(CYGPATH_W) 'fesetround.c'; else $(CYGPATH_W) '$(srcdir)/fesetround.c'; fi`
+lib_a-fetestexcept.o: fetestexcept.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fetestexcept.o `test -f 'fetestexcept.c' || echo '$(srcdir)/'`fetestexcept.c
+lib_a-fetestexcept.obj: fetestexcept.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fetestexcept.obj `if test -f 'fetestexcept.c'; then $(CYGPATH_W) 'fetestexcept.c'; else $(CYGPATH_W) '$(srcdir)/fetestexcept.c'; fi`
+lib_a-feupdateenv.o: feupdateenv.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feupdateenv.o `test -f 'feupdateenv.c' || echo '$(srcdir)/'`feupdateenv.c
+lib_a-feupdateenv.obj: feupdateenv.c
+	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feupdateenv.obj `if test -f 'feupdateenv.c'; then $(CYGPATH_W) 'feupdateenv.c'; else $(CYGPATH_W) '$(srcdir)/feupdateenv.c'; fi`
+mostlyclean-libtool:
+	-rm -f *.lo
+clean-libtool:
+	-rm -rf .libs _libs
+ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES)
+	list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \
+	unique=`for i in $$list; do \
+	    if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \
+	  done | \
+	  $(AWK) '{ files[$$0] = 1; nonempty = 1; } \
+	      END { if (nonempty) { for (i in files) print i; }; }'`; \
+	mkid -fID $$unique
+tags: TAGS
+TAGS:  $(HEADERS) $(SOURCES)  $(TAGS_DEPENDENCIES) \
+		$(TAGS_FILES) $(LISP)
+	set x; \
+	here=`pwd`; \
+	  done | \
+	shift; \
+	if test -z "$(ETAGS_ARGS)$$*$$unique"; then :; else \
+	  test -n "$$unique" || unique=$$empty_fix; \
+	  if test $$# -gt 0; then \
+	    $(ETAGS) $(ETAGSFLAGS) $(AM_ETAGSFLAGS) $(ETAGS_ARGS) \
+	      "$$@" $$unique; \
+	  else \
+	      $$unique; \
+	  fi; \
+	fi
+ctags: CTAGS
+CTAGS:  $(HEADERS) $(SOURCES)  $(TAGS_DEPENDENCIES) \
+	  done | \
+	test -z "$(CTAGS_ARGS)$$unique" \
+	  || $(CTAGS) $(CTAGSFLAGS) $(AM_CTAGSFLAGS) $(CTAGS_ARGS) \
+	     $$unique
+GTAGS:
+	here=`$(am__cd) $(top_builddir) && pwd` \
+	  && $(am__cd) $(top_srcdir) \
+	  && gtags -i $(GTAGS_ARGS) "$$here"
+distclean-tags:
+	-rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
+check-am:
+check: check-am
+all-am: Makefile $(LIBRARIES) $(LTLIBRARIES) $(DATA)
+installdirs:
+install: install-am
+install-exec: install-exec-am
+install-data: install-data-am
+uninstall: uninstall-am
+install-am: all-am
+	@$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am
+installcheck: installcheck-am
+install-strip:
+	if test -z '$(STRIP)'; then \
+	  $(MAKE) $(AM_MAKEFLAGS) INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)" \
+	    install_sh_PROGRAM="$(INSTALL_STRIP_PROGRAM)" INSTALL_STRIP_FLAG=-s \
+	      install; \
+	else \
+	    "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'" install; \
+	fi
+mostlyclean-generic:
+clean-generic:
+	-test -z "$(CLEANFILES)" || rm -f $(CLEANFILES)
+distclean-generic:
+	-test -z "$(CONFIG_CLEAN_FILES)" || rm -f $(CONFIG_CLEAN_FILES)
+	-test . = "$(srcdir)" || test -z "$(CONFIG_CLEAN_VPATH_FILES)" || rm -f $(CONFIG_CLEAN_VPATH_FILES)
+maintainer-clean-generic:
+	@echo "This command is intended for maintainers to use"
+	@echo "it deletes files that may require special tools to rebuild."
+clean: clean-am
+clean-am: clean-generic clean-libtool clean-noinstLIBRARIES \
+	clean-noinstLTLIBRARIES mostlyclean-am
+distclean: distclean-am
+	-rm -f Makefile
+distclean-am: clean-am distclean-compile distclean-generic \
+	distclean-tags
+dvi: dvi-am
+dvi-am:
+html: html-am
+html-am:
+info: info-am
+info-am:
+install-data-am:
+install-dvi: install-dvi-am
+install-dvi-am:
+install-exec-am:
+install-html: install-html-am
+install-html-am:
+install-info: install-info-am
+install-info-am:
+install-man:
+install-pdf: install-pdf-am
+install-pdf-am:
+install-ps: install-ps-am
+install-ps-am:
+installcheck-am:
+maintainer-clean: maintainer-clean-am
+	-rm -f Makefile
+maintainer-clean-am: distclean-am maintainer-clean-generic
+mostlyclean: mostlyclean-am
+mostlyclean-am: mostlyclean-compile mostlyclean-generic \
+	mostlyclean-libtool
+pdf: pdf-am
+pdf-am:
+ps: ps-am
+ps-am:
+uninstall-am:
+.MAKE: install-am install-strip
+.PHONY: CTAGS GTAGS all all-am check check-am clean clean-generic \
+	clean-libtool clean-noinstLIBRARIES clean-noinstLTLIBRARIES \
+	ctags distclean distclean-compile distclean-generic \
+	distclean-libtool distclean-tags dvi dvi-am html html-am info \
+	info-am install install-am install-data install-data-am \
+	install-dvi install-dvi-am install-exec install-exec-am \
+	install-html install-html-am install-info install-info-am \
+	install-man install-pdf install-pdf-am install-ps \
+	install-ps-am install-strip installcheck installcheck-am \
+	installdirs maintainer-clean maintainer-clean-generic \
+	mostlyclean mostlyclean-compile mostlyclean-generic \
+	mostlyclean-libtool pdf pdf-am ps ps-am tags uninstall \
+	uninstall-am
+objectlist.awk.in: $(noinst_LTLIBRARIES)
+	-rm -f objectlist.awk.in
+	for i in `ls *.lo` ; \
+	do \
+	  echo $$i `pwd`/$$i >> objectlist.awk.in ; \
+	done
+.c.def:
+	$(CHEW) < $< > $*.def || ( rm $*.def && false )
+	@touch stmp-def
+TARGETDOC ?= ../tmp.texi
+doc: $(CHEWOUT_FILES)
+	for chapter in $(CHAPTERS) ; \
+	do \
+	  cat $(srcdir)/$$chapter >> $(TARGETDOC) ; \
+	done
+.c.xml:
+	$(DOCBOOK_CHEW) < $< > $*.xml || ( rm $*.xml && false )
+	@touch stmp-xml
+docbook: $(DOCBOOK_OUT_FILES)
+	for chapter in $(DOCBOOK_CHAPTERS) ; \
+	do \
+	  ${top_srcdir}/../doc/chapter-texi2docbook.py <$(srcdir)/$${chapter%.xml}.tex >../$$chapter ; \
+	done
+# A partial dependency list.
+$(lib_a_OBJECTS): $(srcdir)/../../libc/include/fenv.h
+# Tell versions [3.59,3.63) of GNU make to not export all variables.
+# Otherwise a system limit (for SysV at least) may be exceeded.
+.NOEXPORT:
1.8.3.1
