Not able to run riscv-rv32imac testsuites
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Tue Aug 6 15:34:56 UTC 2019
Awesome, thanks!
On Tue, Aug 6, 2019 at 8:50 PM Hesham Almatary <hesham.almatary at cl.cam.ac.uk>
wrote:
> Hi Vaibhav,
> * I recommend you use rv64* because of a potential 32-bit HTIF issue on
> Spike.
> * Make sure you install Spike correctly [1] and it's in your path or
> also qemu-system-riscv* instead.
> * If you're building RTEMS for Spike (i.e., rv*_spike), make sure to
> add RISCV_ENABLE_HTIF_SUPPORT to your configure line [2] when you
> build RTEMS.
> * It might be easier to try rv64* on QEMU (i.e., no Spike) instead.
> [1] https://github.com/riscv/riscv-isa-sim
> [2] https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html
> On Tue, 6 Aug 2019 at 14:52, Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > I am getting following error:
> > $ rtems-test --rtems-bsp=rv32imac_spike
> --rtems-tools=$HOME/development/rtems/5
> ~/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
> > RTEMS Testing - Tester, 5.0.not_released
> > Command Line: /home/varodek/development/rtems/5/bin/rtems-test
> --rtems-bsp=rv32imac_spike --rtems-tools=/home/varodek/development/rtems/5
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
> > Host: Linux varodek 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20
> 15:00:46 UTC 2019 x86_64
> > Python: 3.7.3 (default, Mar 26 2019, 21:43:19) [GCC 8.2.1 20181127]
> > Host: Linux-5.0.9-arch1-1-ARCH-x86_64-with-arch (Linux varodek
> 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46 UTC 2019 x86_64 )
> > [ 2/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv32/rv32imac:
> capture.exe
> > [ 3/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv32/rv32imac:
> cdtest.exe
> > [ 4/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv32/rv32imac:
> cxx_iostream.exe
> > [ 1/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv32/rv32imac:
> base_sp.exe
> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/capture.exe:
> exit-code:2
> exit-code:2
> > warning: switched to dry run due to errors
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cxx_iostream.exe:
> exit-code:2
> exit-code:2
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cdtest.exe:
> exit-code:2
> exit-code:2
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/base_sp.exe:
> exit-code:2
> exit-code:2
> base_sp.exe
> > Result: invalid Time: 0:00:00.032377 base_sp.exe
> > => run: spike --isa=RV32IMAC
> capture.exe
> > Result: invalid Time: 0:00:00.037950 capture.exe
> cdtest.exe
> > Result: invalid Time: 0:00:00.038061 cdtest.exe
> cxx_iostream.exe
> > Result: invalid Time: 0:00:00.034353 cxx_iostream.exe
> > [ 7/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:4 W:0 | riscv32/rv32imac:
> minimum.exe
> > [ 8/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:4 W:0 | riscv32/rv32imac:
> nsecs.exe
> > [ 5/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:4 W:0 | riscv32/rv32imac:
> fileio.exe
> > [ 6/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:4 W:0 | riscv32/rv32imac:
> hello.exe
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/minimum.exe:
> exit-code:2
> exit-code:2
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/nsecs.exe:
> exit-code:2
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/fileio.exe:
> exit-code:2
> exit-code:2
> exit-code:2
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/hello.exe:
> exit-code:2
> exit-code:2
> fileio.exe
> > Result: invalid Time: 0:00:00.009235 fileio.exe
> hello.exe
> > Result: invalid Time: 0:00:00.005886 hello.exe
> minimum.exe
> nsecs.exe
> > Result: invalid Time: 0:00:00.011045 nsecs.exe
> > [ 9/11] p:1 f:0 u:0 e:0 I:0 B:0 t:0 i:7 W:0 | riscv32/rv32imac:
> paranoia.exe
> > [10/11] p:1 f:0 u:0 e:0 I:0 B:0 t:0 i:7 W:0 | riscv32/rv32imac:
> ticker.exe
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/paranoia.exe:
> exit-code:2
> exit-code:2
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/ticker.exe:
> exit-code:2
> exit-code:2
> > [11/11] p:1 f:0 u:0 e:0 I:0 B:0 t:0 i:8 W:0 | riscv32/rv32imac:
> unlimited.exe
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/unlimited.exe:
> exit-code:2
> exit-code:2
> paranoia.exe
> > Result: invalid Time: 0:00:00.011650 paranoia.exe
> ticker.exe
> > Result: invalid Time: 0:00:00.009872 ticker.exe
> unlimited.exe
> > Result: invalid Time: 0:00:00.002352 unlimited.exe
> > Passed: 1
> > Failed: 0
> > User Input: 0
> > Expected Fail: 0
> > Indeterminate: 0
> > Benchmark: 0
> > Timeout: 0
> > Invalid: 10
> > Wrong Version: 0
> > Wrong Build: 0
> > Wrong Tools: 0
> > Total: 11
> > Invalid:
> > capture.exe
> > cdtest.exe
> > cxx_iostream.exe
> > base_sp.exe
> > nsecs.exe
> > fileio.exe
> > hello.exe
> > paranoia.exe
> > ticker.exe
> > unlimited.exe
> > Average test time: 0:00:00.093749
> > Testing time : 0:00:01.031239
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190806/e9355bc3/attachment-0001.html>
