Tabs in Source Files [C, H]
Wed Aug 7 15:43:27 UTC 2019
On Wed, Aug 7, 2019 at 8:31 AM Sebastian Huber
> ----- Am 7. Aug 2019 um 16:24 schrieb joel joel at rtems.org:
> > On Wed, Aug 7, 2019 at 8:59 AM Sebastian Huber <
> >> ----- Am 7. Aug 2019 um 15:41 schrieb joel joel at rtems.org:
> >> > Hi
> >> > While looking at assembly language formatting, I decided to grep for tabs
> >> > in source
> >> > files. In cpukit and testsuites, there are a LOT of files with tabs.
> >> > $ find cpukit testsuites/ -name "*.[ch]" | xargs -e grep -rlP "\t" | grep
> >> > -v libnetworking | grep -v pppd | grep -v contrib | wc -l
> >> > 530
> >> > That may be picking up a few extra files but that's still a lot of files.
> >> > Any comments?
> >> My approach to white space in source files would be to pick up the best
> >> source code formatter available, select a configuration which fits best to
> >> the existing style, run it over the code (excluding code which we want to
> >> keep in synchronization with an upstream) and later run every commit
> >> through it.
> > I'm not disagreeing with you but no one has ever found a formatter and
> > defined a style that matches.
> Yes, we invested some time to evaluate clang-format early this year and failed to produce useful results. They even rejected to accept potential contributions to support this style because it seemed to be to exotic. I don't have a problems with the RTEMS style. But I think in the long run a style supported by a good formatter which is ubiquitously used (e.g. Linux, BSD, Google, GNU) would be beneficial. If you use an ubiquitous style, you make it easier for new contributors.
Considering our relationship with the BSDs, adopting that style might
make the most sense if we decide to go that route.
It will cause a lot of churn in the repo though, some care must be taken.
> devel mailing list
> devel at rtems.org
