sis/gdb on Cygwin
Joel Sherrill
joel at rtems.org
Wed Aug 7 18:22:31 UTC 2019
Hi
Looks like Cygwin has libncurses but doesn't install the libtermcap.
compatibility library.
https://cygwin.com/ml/cygwin/2010-10/msg00018.html says to link against
ncurses.
gdb-8.2.1/sim/sis/../.. `echo -Dsparc-rtems5 | sed s/-rtems.//` -I.
-I../../../gdb-8.2.1/sim/sis -I../common
-I../../../gdb-8.2.1/sim/sis/../common -I../../include
-I../../../gdb-8.2.1/sim/sis/../../include -I../../bfd
-I../../../gdb-8.2.1/sim/sis/../../bfd -I../../opcodes
-I../../../gdb-8.2.1/sim/sis/../../opcodes -g -O2 -o sis \
sis.o exec.o erc32.o func.o help.o float.o grlib.o leon3.o leon2.o
../../bfd/libbfd.a ../../opcodes/libopcodes.a ../../libiberty/libiberty.a
-L../../zlib -lz ../../readline/libreadline.a `if test -r
../../libtermcap/libtermcap.a; then echo ../../libtermcap/libtermcap.a;
else echo -ltermcap; fi` -luser32 -lm
/usr/lib/gcc/x86_64-pc-cygwin/7.3.0/../../../../x86_64-pc-cygwin/bin/ld:
cannot find -ltermcap
collect2: error: ld returned 1 exit status
Is the solution to just add -lncurses to the list of libraries it looks for?
Hopefully someone has some insight into this one.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190807/8f2c21c1/attachment.html>
