[PATCH v3 1/8] Pinmux : Import from FreeBSD
    Vijay Kumar Banerjee
    vijaykumar9597 at gmail.com
    Wed Aug  7 19:04:04 UTC 2019
On Sun, Aug 4, 2019 at 10:11 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> Hello Vijay,
> for the whole patch set:
> The order and groups are good now. I didn't find anything where I would
> have big problems. All patches are compilable and libbsd still compiles
> on a PowerPC target. The result is great (with some demo application I
> get an image on the screen). So I'm OK with this version of the patch set.
> I'm still not entirely happy with the pinmux because it re-initializes
> some pins that are already initialized by the BSP. But if no one has a
> better idea that can be done in a reasonable time I would accept it like
> it is. I think I would prefer it without the hack that needs an extra
> overlay. If the patch set is committed in this form, we will need a
> ticket for that (wait with creating it till the commit) so that a future
> project can work on that ticket.
Hi,
Regarding the videomode I'd like to note that the preferred video mode
isn't
selected because it performs a lot of if checks on the videomode before
setting.
My preferred mode was 1366*786, this is not set because there's a check
that does `if (hdisplay & 0xf)  return`  here hdisplay == 1366, that's why
the
available modes are sorted and the max possible mode before it is set.
In another case where the preferred mode was 1920*1024 60Hz, it was not
setting the preferred mode because the MAX_BANDWIDTH is 1280*1024*60
and hence the detected mode is the max available mode before it.
> Best regards
> Christian
> On 03/08/2019 22:19, Vijay Kumar Banerjee wrote:
> >  .../sys/arm/ti/am335x/am335x_scm_padconf.c    | 305 ++++++++++++
> >  .../sys/arm/ti/am335x/am335x_scm_padconf.h    |  47 ++
> >  freebsd/sys/arm/ti/omap4/omap4_scm_padconf.h  |  83 ++++
> >  freebsd/sys/arm/ti/ti_pinmux.c                | 463 ++++++++++++++++++
> >  freebsd/sys/arm/ti/ti_pinmux.h                |  80 +++
> >  freebsd/sys/dev/fdt/fdt_pinctrl.c             | 160 ++++++
> >  6 files changed, 1138 insertions(+)
> >  create mode 100644 freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
> >  create mode 100644 freebsd/sys/arm/ti/am335x/am335x_scm_padconf.h
> >  create mode 100644 freebsd/sys/arm/ti/omap4/omap4_scm_padconf.h
> >  create mode 100644 freebsd/sys/arm/ti/ti_pinmux.c
> >  create mode 100644 freebsd/sys/arm/ti/ti_pinmux.h
> >  create mode 100644 freebsd/sys/dev/fdt/fdt_pinctrl.c
> > diff --git a/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
> b/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
> > new file mode 100644
> > index 00000000..8823b6af
> > --- /dev/null
> > +++ b/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
> > @@ -0,0 +1,305 @@
> > +#include <machine/rtems-bsd-kernel-space.h>
> > + * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
> > + * Copyright (c) 2012 Damjan Marion <dmarion at FreeBSD.org>
> > + * All rights reserved.
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in
> the
> > + *    documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS''
> AND
> > + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE
> LIABLE
> > + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> > + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
> GOODS
> > + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> > + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
> STRICT
> > + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
> ANY WAY
> > + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
> OF
> > + * SUCH DAMAGE.
> > +#include <sys/cdefs.h>
> > +__FBSDID("$FreeBSD$");
> > +#include <sys/param.h>
> > +#include <sys/systm.h>
> > +#include <sys/kernel.h>
> > +#include <sys/module.h>
> > +#include <sys/bus.h>
> > +#include <rtems/bsd/sys/resource.h>
> > +#include <sys/rman.h>
> > +#include <sys/lock.h>
> > +#include <sys/malloc.h>
> > +#include <machine/bus.h>
> > +#include <machine/resource.h>
> > +#include <machine/intr.h>
> > +#include <sys/gpio.h>
> > +#include <arm/ti/tivar.h>
> > +#include <arm/ti/ti_pinmux.h>
> > +#include <arm/ti/am335x/am335x_scm_padconf.h>
> > +#define _PIN(r, b, gp, gm, m0, m1, m2, m3, m4, m5, m6, m7) \
> > +     {       .reg_off = r, \
> > +             .gpio_pin = gp, \
> > +             .gpio_mode = gm, \
> > +             .ballname = b, \
> > +             .muxmodes[0] = m0, \
> > +             .muxmodes[1] = m1, \
> > +             .muxmodes[2] = m2, \
> > +             .muxmodes[3] = m3, \
> > +             .muxmodes[4] = m4, \
> > +             .muxmodes[5] = m5, \
> > +             .muxmodes[6] = m6, \
> > +             .muxmodes[7] = m7, \
> > +const static struct ti_pinmux_padstate ti_padstate_devmap[] = {
> > +     {"output",              PADCONF_OUTPUT },
> > +     {"output_pullup",       PADCONF_OUTPUT_PULLUP },
> > +     {"input",               PADCONF_INPUT },
> > +     {"input_pulldown",      PADCONF_INPUT_PULLDOWN },
> > +     {"input_pullup",        PADCONF_INPUT_PULLUP },
> > +     {"i2c",                 PADCONF_INPUT_PULLUP_SLOW },
> > +     { .state = NULL }
> > +const static struct ti_pinmux_padconf ti_padconf_devmap[] = {
> > +     _PIN(0x000, "GPMC_AD0",         32, 7,"gpmc_ad0", "mmc1_dat0",
> NULL, NULL, NULL, NULL, NULL, "gpio1_0"),
> > +     _PIN(0x004, "GPMC_AD1",         33, 7,"gpmc_ad1", "mmc1_dat1",
> NULL, NULL, NULL, NULL, NULL, "gpio1_1"),
> > +     _PIN(0x008, "GPMC_AD2",         34, 7,"gpmc_ad2", "mmc1_dat2",
> NULL, NULL, NULL, NULL, NULL, "gpio1_2"),
> > +     _PIN(0x00C, "GPMC_AD3",         35, 7,"gpmc_ad3", "mmc1_dat3",
> NULL, NULL, NULL, NULL, NULL, "gpio1_3"),
> > +     _PIN(0x010, "GPMC_AD4",         36, 7,"gpmc_ad4", "mmc1_dat4",
> NULL, NULL, NULL, NULL, NULL, "gpio1_4"),
> > +     _PIN(0x014, "GPMC_AD5",         37, 7,"gpmc_ad5", "mmc1_dat5",
> NULL, NULL, NULL, NULL, NULL, "gpio1_5"),
> > +     _PIN(0x018, "GPMC_AD6",         38, 7,"gpmc_ad6", "mmc1_dat6",
> NULL, NULL, NULL, NULL, NULL, "gpio1_6"),
> > +     _PIN(0x01C, "GPMC_AD7",         39, 7,"gpmc_ad7", "mmc1_dat7",
> NULL, NULL, NULL, NULL, NULL, "gpio1_7"),
> > +     _PIN(0x020, "GPMC_AD8",         22, 7, "gpmc_ad8", "lcd_data23",
> "mmc1_dat0", "mmc2_dat4", "ehrpwm2A", NULL, NULL, "gpio0_22"),
> > +     _PIN(0x024, "GPMC_AD9",         23, 7, "gpmc_ad9", "lcd_data22",
> "mmc1_dat1", "mmc2_dat5", "ehrpwm2B", NULL, NULL, "gpio0_23"),
> > +     _PIN(0x028, "GPMC_AD10",        26, 7, "gpmc_ad10", "lcd_data21",
> "mmc1_dat2", "mmc2_dat6", "ehrpwm2_tripzone_in", NULL, NULL, "gpio0_26"),
> > +     _PIN(0x02C, "GPMC_AD11",        27, 7, "gpmc_ad11", "lcd_data20",
> "mmc1_dat3", "mmc2_dat7", "ehrpwm0_synco", NULL, NULL, "gpio0_27"),
> > +     _PIN(0x030, "GPMC_AD12",        44, 7, "gpmc_ad12", "lcd_data19",
> "mmc1_dat4", "mmc2_dat0", "eQEP2A_in", "pr1_mii0_txd2",
> "pr1_pru0_pru_r30_14", "gpio1_12"),
> > +     _PIN(0x034, "GPMC_AD13",        45, 7, "gpmc_ad13", "lcd_data18",
> "mmc1_dat5", "mmc2_dat1", "eQEP2B_in", "pr1_mii0_txd1",
> "pr1_pru0_pru_r30_15", "gpio1_13"),
> > +     _PIN(0x038, "GPMC_AD14",        46, 7, "gpmc_ad14", "lcd_data17",
> "mmc1_dat6", "mmc2_dat2", "eQEP2_index", "pr1_mii0_txd0",
> "pr1_pru0_pru_r31_14", "gpio1_14"),
> > +     _PIN(0x03C, "GPMC_AD15",        47, 7, "gpmc_ad15", "lcd_data16",
> "mmc1_dat7", "mmc2_dat3", "eQEP2_strobe", "pr1_ecap0_ecap_capin_apwm_o",
> "pr1_pru0_pru_r31_15", "gpio1_15"),
> > +     _PIN(0x040, "GPMC_A0",          48, 7, "gpmc_a0", "gmii2_txen",
> "rgmii2_tctl", "rmii2_txen", "gpmc_a16", "pr1_mii_mt1_clk",
> "ehrpwm1_tripzone_input", "gpio1_16"),
> > +     _PIN(0x044, "GPMC_A1",          49, 7, "gpmc_a1", "gmii2_rxdv",
> "rgmii2_rctl", "mmc2_dat0", "gpmc_a17", "pr1_mii1_txd3", "ehrpwm0_synco",
> "gpio1_17"),
> > +     _PIN(0x048, "GPMC_A2",          50, 7, "gpmc_a2", "gmii2_txd3",
> "rgmii2_td3", "mmc2_dat1", "gpmc_a18", "pr1_mii1_txd2", "ehrpwm1A",
> "gpio1_18"),
> > +     _PIN(0x04C, "GPMC_A3",          51, 7, "gpmc_a3", "gmii2_txd2",
> "rgmii2_td2", "mmc2_dat2", "gpmc_a19", "pr1_mii1_txd1", "ehrpwm1B",
> "gpio1_19"),
> > +     _PIN(0x050, "GPMC_A4",          52, 7, "gpmc_a4", "gmii2_txd1",
> "rgmii2_td1", "rmii2_tdx1", "gpmc_a20", "pr1_mii1_txd0", "eQEP1A_in",
> "gpio1_20"),
> > +     _PIN(0x054, "GPMC_A5",          53, 7, "gpmc_a5", "gmii2_txd0",
> "rgmii2_td0", "rmii2_txd0", "gpmc_a21", "pr1_mii1_rxd3", "eQEP1B_in",
> "gpio1_21"),
> > +     _PIN(0x058, "GPMC_A6",          54, 7, "gpmc_a6", "gmii2_txclk",
> "rgmii2_tclk", "mmc2_dat4", "gpmc_a22", "pr1_mii1_rxd2", "eQEP1_index",
> "gpio1_22"),
> > +     _PIN(0x05C, "GPMC_A7",          55, 7, "gpmc_a7", "gmii2_rxclk",
> "rgmii2_rclk", "mmc2_dat5", "gpmc_a23", "pr1_mii1_rxd1", "eQEP1_strobe",
> "gpio1_23"),
> > +     _PIN(0x060, "GPMC_A8",          56, 7, "gpmc_a8", "gmii2_rxd3",
> "rgmii2_rd3", "mmc2_dat6", "gpmc_a24", "pr1_mii1_rxd0", "mcasp0_aclkx",
> "gpio1_24"),
> > +     _PIN(0x064, "GPMC_A9",          57, 7, "gmpc_a9", "gmii2_rxd2",
> "rgmii2_rd2", "mmc2_dat7 / rmii2_crs_dv", "gpmc_a25", "pr1_mii_mr1_clk",
> "mcasp0_fsx", "gpio1_25"),
> > +     _PIN(0x068, "GPMC_A10",         58, 7, "gmpc_a10", "gmii2_rxd1",
> "rgmii2_rd1", "rmii2_rxd1", "gpmc_a26", "pr1_mii1_rxdv", "mcasp0_arx0",
> "gpio1_26"),
> > +     _PIN(0x06C, "GPMC_A11",         59, 7, "gmpc_a11", "gmii2_rxd0",
> "rgmii2_rd0", "rmii2_rxd0", "gpmc_a27", "pr1_mii1_rxer", "mcasp0_axr1",
> "gpio1_27"),
> > +     _PIN(0x070, "GPMC_WAIT0",       30, 7, "gpmc_wait0", "gmii2_crs",
> "gpmc_csn4", "rmii2_crs_dv", "mmc1_sdcd", "pr1_mii1_col", "uart4_rxd",
> "gpio0_30"),
> > +     _PIN(0x074, "GPMC_WPn",         31, 7, "gpmc_wpn", "gmii2_rxerr",
> "gpmc_csn5", "rmii2_rxerr", "mmc2_sdcd", "pr1_mii1_txen", "uart4_txd",
> "gpio0_31"),
> > +     _PIN(0x078, "GPMC_BEn1",        60, 7, "gpmc_be1n", "gmii2_col",
> "gmpc_csn6","mmc2_dat3", "gpmc_dir", "pr1_mii1_rxlink", "mcasp0_aclkr",
> "gpio1_28"),
> > +     _PIN(0x07c, "GPMC_CSn0",        61, 7, "gpmc_csn0", NULL, NULL,
> NULL, NULL, NULL, NULL, "gpio1_29"),
> > +     _PIN(0x080, "GPMC_CSn1",        62, 7, "gpmc_csn1", "gpmc_clk",
> "mmc1_clk", "pr1_edio_data_in6", "pr1_edio_data_out6",
> "pr1_pru1_pru_r30_12", "pr1_pru1_pru_r31_12", "gpio1_30"),
> > +     _PIN(0x084, "GPMC_CSn2",        63, 7, "gpmc_csn2", "gpmc_be1n",
> "mmc1_cmd", "pr1_edio_data_in7", "pr1_edio_data_out7",
> "pr1_pru1_pru_r30_13", "pr1_pru1_pru_r31_13", "gpio1_31"),
> > +     _PIN(0x088, "GPMC_CSn3",        64, 7, "gpmc_csn3", "gpmc_a3",
> "rmii2_crs_dv", "mmc2_cmd", "pr1_mii0_crs", "pr1_mdio_data", "EMU4",
> "gpio2_0"),
> > +     _PIN(0x08c, "GPMC_CLK",         65, 7, "gpmc_clk",
> "lcd_memory_clk", "gpmc_wait1", "mmc2_clk", "pr1_mii1_crs",
> "pr1_mdio_mdclk", "mcasp0_fsr", "gpio2_1"),
> > +     _PIN(0x090, "GPMC_ADVn_ALE",    66, 7, "gpmc_advn_ale", NULL,
> "timer4", NULL, NULL, NULL, NULL, "gpio2_2"),
> > +     _PIN(0x094, "GPMC_OEn_REn",     67, 7, "gpmc_oen_ren", NULL,
> "timer7", NULL, NULL, NULL, NULL, "gpio2_3"),
> > +     _PIN(0x098, "GPMC_WEn",         68, 7, "gpmc_wen", NULL, "timer6",
> NULL, NULL, NULL, NULL, "gpio2_4"),
> > +     _PIN(0x09c, "GPMC_BEn0_CLE",    67, 7, "gpmc_ben0_cle", NULL,
> "timer5", NULL, NULL, NULL, NULL, "gpio2_5"),
> > +     _PIN(0x0a0, "LCD_DATA0",        68, 7, "lcd_data0", "gpmc_a0",
> "pr1_mii_mt0_clk", "ehrpwm2A", NULL, "pr1_pru1_pru_r30_0",
> "pr1_pru1_pru_r31_0", "gpio2_6"),
> > +     _PIN(0x0a4, "LCD_DATA1",        69, 7, "lcd_data1", "gpmc_a1",
> "pr1_mii0_txen", "ehrpwm2B", NULL, "pr1_pru1_pru_r30_1",
> "pr1_pru1_pru_r31_1", "gpio2_7"),
> > +     _PIN(0x0a8, "LCD_DATA2",        70, 7, "lcd_data2", "gpmc_a2",
> "pr1_mii0_txd3", "ehrpwm2_tripzone_input", NULL, "pr1_pru1_pru_r30_2",
> "pr1_pru1_pru_r31_2", "gpio2_8"),
> > +     _PIN(0x0ac, "LCD_DATA3",        71, 7, "lcd_data3", "gpmc_a3",
> "pr1_mii0_txd2", "ehrpwm0_synco", NULL, "pr1_pru1_pru_r30_3",
> "pr1_pru1_pru_r31_3", "gpio2_9"),
> > +     _PIN(0x0b0, "LCD_DATA4",        72, 7, "lcd_data4", "gpmc_a4",
> "pr1_mii0_txd1", "eQEP2A_in", NULL, "pr1_pru1_pru_r30_4",
> "pr1_pru1_pru_r31_4", "gpio2_10"),
> > +     _PIN(0x0b4, "LCD_DATA5",        73, 7, "lcd_data5", "gpmc_a5",
> "pr1_mii0_txd0", "eQEP2B_in", NULL, "pr1_pru1_pru_r30_5",
> "pr1_pru1_pru_r31_5", "gpio2_11"),
> > +     _PIN(0x0b8, "LCD_DATA6",        74, 7, "lcd_data6", "gpmc_a6",
> "pr1_edio_data_in6", "eQEP2_index", "pr1_edio_data_out6",
> "pr1_pru1_pru_r30_6", "pr1_pru1_pru_r31_6", "gpio2_12"),
> > +     _PIN(0x0bc, "LCD_DATA7",        75, 7, "lcd_data7", "gpmc_a7",
> "pr1_edio_data_in7", "eQEP2_strobe", "pr1_edio_data_out7",
> "pr1_pru1_pru_r30_7", "pr1_pru1_pru_r31_7", "gpio2_13"),
> > +     _PIN(0x0c0, "LCD_DATA8",        76, 7, "lcd_data8", "gpmc_a12",
> "ehrpwm1_tripzone_input", "mcasp0_aclkx", "uart5_txd", "pr1_mii0_rxd3",
> "uart2_ctsn", "gpio2_14"),
> > +     _PIN(0x0c4, "LCD_DATA9",        76, 7, "lcd_data9", "gpmc_a13",
> "ehrpwm0_synco", "mcasp0_fsx", "uart5_rxd", "pr1_mii0_rxd2", "uart2_rtsn",
> "gpio2_15"),
> > +     _PIN(0x0c8, "LCD_DATA10",       77, 7, "lcd_data10", "gpmc_a14",
> "ehrpwm1A", "mcasp0_axr0", NULL, "pr1_mii0_rxd1", "uart3_ctsn", "gpio2_16"),
> > +     _PIN(0x0cc, "LCD_DATA11",       78, 7, "lcd_data11", "gpmc_a15",
> "ehrpwm1B", "mcasp0_ahclkr", "mcasp0_axr2", "pr1_mii0_rxd0", "uart3_rtsn",
> "gpio2_17"),
> > +     _PIN(0x0d0, "LCD_DATA12",       8, 7, "lcd_data12", "gpmc_a16",
> "eQEP1A_in", "mcasp0_aclkr", "mcasp0_axr2", "pr1_mii0_rxlink",
> "uart4_ctsn", "gpio0_8"),
> > +     _PIN(0x0d4, "LCD_DATA13",       9, 7, "lcd_data13", "gpmc_a17",
> "eQEP1B_in", "mcasp0_fsr", "mcasp0_axr3", "pr1_mii0_rxer", "uart4_rtsn",
> "gpio0_9"),
> > +     _PIN(0x0d8, "LCD_DATA14",       10, 7, "lcd_data14", "gpmc_a18",
> "eQEP1_index", "mcasp0_axr1", "uart5_rxd", "pr1_mii_mr0_clk", "uart5_ctsn",
> "gpio0_10"),
> > +     _PIN(0x0dc, "LCD_DATA15",       11, 7, "lcd_data15", "gpmc_a19",
> "eQEP1_strobe", "mcasp0_ahclkx", "mcasp0_axr3", "pr1_mii0_rxdv",
> "uart5_rtsn", "gpio0_11"),
> > +     _PIN(0x0e0, "LCD_VSYNC",        86, 7, "lcd_vsync", "gpmc_a8",
> "gpmc_a1", "pr1_edio_data_in2", "pr1_edio_data_out2", "pr1_pru1_pru_r30_8",
> "pr1_pru1_pru_r31_8", "gpio2_22"),
> > +     _PIN(0x0e4, "LCD_HSYNC",        87, 7, "lcd_hsync", "gmpc_a9",
> "gpmc_a2", "pr1_edio_data_in3", "pr1_edio_data_out3", "pr1_pru1_pru_r30_9",
> "pr1_pru1_pru_r31_9", "gpio2_23"),
> > +     _PIN(0x0e8, "LCD_PCLK",         88, 7, "lcd_pclk", "gpmc_a10",
> "pr1_mii0_crs", "pr1_edio_data_in4", "pr1_edio_data_out4",
> "pr1_pru1_pru_r30_10", "pr1_pru1_pru_r31_10", "gpio2_24"),
> > +     _PIN(0x0ec, "LCD_AC_BIAS_EN",   89, 7, "lcd_ac_bias_en",
> "gpmc_a11", "pr1_mii1_crs", "pr1_edio_data_in5", "pr1_edio_data_out5",
> "pr1_pru1_pru_r30_11", "pr1_pru1_pru_r31_11", "gpio2_25"),
> > +     _PIN(0x0f0, "MMC0_DAT3",        90, 7, "mmc0_dat3", "gpmc_a20",
> "uart4_ctsn", "timer5", "uart1_dcdn", "pr1_pru0_pru_r30_8",
> "pr1_pru0_pru_r31_8", "gpio2_26"),
> > +     _PIN(0x0f4, "MMC0_DAT2",        91, 7, "mmc0_dat2", "gpmc_a21",
> "uart4_rtsn", "timer6", "uart1_dsrn", "pr1_pru0_pru_r30_9",
> "pr1_pru0_pru_r31_9", "gpio2_27"),
> > +     _PIN(0x0f8, "MMC0_DAT1",        92, 7, "mmc0_dat1", "gpmc_a22",
> "uart5_ctsn", "uart3_rxd", "uart1_dtrn", "pr1_pru0_pru_r30_10",
> "pr1_pru0_pru_r31_10", "gpio2_28"),
> > +     _PIN(0x0fc, "MMC0_DAT0",        93, 7, "mmc0_dat0", "gpmc_a23",
> "uart5_rtsn", "uart3_txd", "uart1_rin", "pr1_pru0_pru_r30_11",
> "pr1_pru0_pru_r31_11", "gpio2_29"),
> > +     _PIN(0x100, "MMC0_CLK",         94, 7, "mmc0_clk", "gpmc_a24",
> "uart3_ctsn", "uart2_rxd", "dcan1_tx", "pr1_pru0_pru_r30_12",
> "pr1_pru0_pru_r31_12", "gpio2_30"),
> > +     _PIN(0x104, "MMC0_CMD",         95, 7, "mmc0_cmd", "gpmc_a25",
> "uart3_rtsn", "uart2_txd", "dcan1_rx", "pr1_pru0_pru_r30_13",
> "pr1_pru0_pru_r31_13", "gpio2_31"),
> > +     _PIN(0x108, "MII1_COL",         96, 7, "gmii1_col",
> "rmii2_refclk", "spi1_sclk", "uart5_rxd", "mcasp1_axr2", "mmc2_dat3",
> "mcasp0_axr2", "gpio3_0"),
> > +     _PIN(0x10c, "MII1_CRS",         97, 7, "gmii1_crs",
> "rmii1_crs_dv", "spi1_d0", "I2C1_SDA", "mcasp1_aclkx", "uart5_ctsn",
> "uart2_rxd", "gpio3_1"),
> > +     _PIN(0x110, "MII1_RX_ER",       98, 7, "gmii1_rxerr",
> "rmii1_rxerr", "spi1_d1", "I2C1_SCL", "mcasp1_fsx", "uart5_rtsn",
> "uart2_txd", "gpio3_2"),
> > +     _PIN(0x114, "MII1_TX_EN",       99, 7, "gmii1_txen", "rmii1_txen",
> "rgmii1_tctl", "timer4", "mcasp1_axr0", "eQEP0_index", "mmc2_cmd",
> "gpio3_3"),
> > +     _PIN(0x118, "MII1_RX_DV",       100, 7, "gmii1_rxdv",
> "cd_memory_clk", "rgmii1_rctl", "uart5_txd", "mcasp1_aclkx", "mmc2_dat0",
> "mcasp0_aclkr", "gpio3_4"),
> > +     _PIN(0x11c, "MII1_TXD3",        16, 7, "gmii1_txd3", "dcan0_tx",
> "rgmii1_td3", "uart4_rxd", "mcasp1_fsx", "mmc2_dat1", "mcasp0_fsr",
> "gpio0_16"),
> > +     _PIN(0x120, "MII1_TXD2",        17, 7, "gmii1_txd2", "dcan0_rx",
> "rgmii1_td2", "uart4_txd", "mcasp1_axr0", "mmc2_dat2", "mcasp0_ahclkx",
> "gpio0_17"),
> > +     _PIN(0x124, "MII1_TXD1",        21, 7, "gmii1_txd1", "rmii1_txd1",
> "rgmii1_td1", "mcasp1_fsr", "mcasp1_axr1", "eQEP0A_in", "mmc1_cmd",
> "gpio0_21"),
> > +     _PIN(0x128, "MII1_TXD0",        28, 7, "gmii1_txd0", "rmii1_txd0",
> "rgmii1_td0", "mcasp1_axr2", "mcasp1_aclkr", "eQEP0B_in", "mmc1_clk",
> "gpio0_28"),
> > +     _PIN(0x12c, "MII1_TX_CLK",      105, 7, "gmii1_txclk",
> "uart2_rxd", "rgmii1_tclk", "mmc0_dat7", "mmc1_dat0", "uart1_dcdn",
> "mcasp0_aclkx", "gpio3_9"),
> > +     _PIN(0x130, "MII1_RX_CLK",      106, 7, "gmii1_rxclk",
> "uart2_txd", "rgmii1_rclk", "mmc0_dat6", "mmc1_dat1", "uart1_dsrn",
> "mcasp0_fsx", "gpio3_10"),
> > +     _PIN(0x134, "MII1_RXD3",        82, 7, "gmii1_rxd3", "uart3_rxd",
> "rgmii1_rd3", "mmc0_dat5", "mmc1_dat2", "uart1_dtrn", "mcasp0_axr0",
> "gpio2_18"),
> > +     _PIN(0x138, "MII1_RXD2",        83, 7, "gmii1_rxd2", "uart3_txd",
> "rgmii1_rd2", "mmc0_dat4", "mmc1_dat3", "uart1_rin", "mcasp0_axr1",
> "gpio2_19"),
> > +     _PIN(0x13c, "MII1_RXD1",        84, 7, "gmii1_rxd1", "rmii1_rxd1",
> "rgmii1_rd1", "mcasp1_axr3", "mcasp1_fsr", "eQEP0_strobe", "mmc2_clk",
> "gpio2_20"),
> > +     _PIN(0x140, "MII1_RXD0",        85, 7, "gmii1_rxd0", "rmii1_rxd0",
> "rgmii1_rd0", "mcasp1_ahclkx", "mcasp1_ahclkr", "mcasp1_aclkr",
> "mcasp0_axr3", "gpio2_21"),
> > +     _PIN(0x144, "RMII1_REF_CLK",    29, 7, "rmii1_refclk",
> "xdma_event_intr2", "spi1_cs0", "uart5_txd", "mcasp1_axr3", "mmc0_pow",
> "mcasp1_ahclkx", "gpio0_29"),
> > +     _PIN(0x148, "MDIO",             0, 7, "mdio_data", "timer6",
> "uart5_rxd", "uart3_ctsn", "mmc0_sdcd","mmc1_cmd", "mmc2_cmd","gpio0_0"),
> > +     _PIN(0x14c, "MDC",              1, 7, "mdio_clk", "timer5",
> "uart5_txd", "uart3_rtsn", "mmc0_sdwp", "mmc1_clk", "mmc2_clk", "gpio0_1"),
> > +     _PIN(0x150, "SPI0_SCLK",        2, 7, "spi0_sclk", "uart2_rxd",
> "I2C2_SDA", "ehrpwm0A", "pr1_uart0_cts_n", "pr1_edio_sof", "EMU2",
> "gpio0_2"),
> > +     _PIN(0x154, "SPI0_D0",          3, 7, "spi0_d0", "uart2_txd",
> "I2C2_SCL", "ehrpwm0B", "pr1_uart0_rts_n", "pr1_edio_latch_in", "EMU3",
> "gpio0_3"),
> > +     _PIN(0x158, "SPI0_D1",          4, 7, "spi0_d1", "mmc1_sdwp",
> "I2C1_SDA", "ehrpwm0_tripzone_input", "pr1_uart0_rxd", "pr1_edio_data_in0",
> "pr1_edio_data_out0", "gpio0_4"),
> > +     _PIN(0x15c, "SPI0_CS0",         5, 7, "spi0_cs0", "mmc2_sdwp",
> "I2C1_SCL", "ehrpwm0_synci", "pr1_uart0_txd", "pr1_edio_data_in1",
> "pr1_edio_data_out1", "gpio0_5"),
> > +     _PIN(0x160, "SPI0_CS1",         6, 7, "spi0_cs1", "uart3_rxd",
> "eCAP1_in_PWM1_out", "mcc0_pow", "xdm_event_intr2", "mmc0_sdcd", "EMU4",
> "gpio0_6"),
> > +     _PIN(0x164, "ECAP0_IN_PWM0_OUT",7, 7, "eCAP0_in_PWM0_out",
> "uart3_txd", "spi1_cs1", "pr1_ecap0_ecap_capin_apwm_o", "spi1_sclk",
> "mmc0_sdwp", "xdma_event_intr2", "gpio0_7"),
> > +     _PIN(0x168, "UART0_CTSn",       40, 7, "uart0_ctsn", "uart4_rxd",
> "dcan1_tx", "I2C1_SDA", "spi1_d0", "timer7", "pr1_edc_sync0_out",
> "gpio1_8"),
> > +     _PIN(0x16c, "UART0_RTSn",       41, 7, "uart0_rtsn", "uart4_txd",
> "dcan1_rx", "I2C1_SCL", "spi1_d1", "spi1_cs0", "pr1_edc_sync1_out",
> "gpio1_9"),
> > +     _PIN(0x170, "UART0_rxd",        42, 7, "uart0_rxd", "spi1_cs0",
> "dcan0_tx", "I2C2_SDA", "eCAP2_in_PWM2_out", "pr1_pru1_pru_r30_14",
> "pr1_pru1_pru_r31_14", "gpio1_10"),
> > +     _PIN(0x174, "UART0_txd",        43, 7, "uart0_txd", "spi1_cs1",
> "dcan0_rx", "I2C2_SCL", "eCAP1_in_PWM1_out", "pr1_pru1_pru_r30_15",
> "pr1_pru1_pru_r31_15", "gpio1_11"),
> > +     _PIN(0x178, "UART1_CTSn",       12, 7, "uart1_ctsn",
> "timer6_mux1", "dcan0_tx", "I2C2_SDA", "spi1_cs0", "pr1_uart0_cts_n",
> "pr1_edc_latch0_in", "gpio0_12"),
> > +     _PIN(0x17c, "UART1_RTSn",       13, 7, "uart1_rtsn",
> "timer5_mux1", "dcan0_rx", "I2C2_SCL", "spi1_cs1", "pr1_uart0_rts_n",
> "pr1_edc_latch1_in", "gpio0_13"),
> > +     _PIN(0x180, "UART1_RXD",        14, 7, "uart1_rxd", "mmc1_sdwp",
> "dcan1_tx", "I2C1_SDA", NULL, "pr1_uart0_rxd", "pr1_pru1_pru_r31_16",
> "gpio0_14"),
> > +     _PIN(0x184, "UART1_TXD",        15, 7, "uart1_txd", "mmc2_sdwp",
> "dcan1_rx", "I2C1_SCL", NULL, "pr1_uart0_txd", "pr1_pru0_pru_r31_16",
> "gpio0_15"),
> > +     _PIN(0x188, "I2C0_SDA",         101, 7, "I2C0_SDA", "timer4",
> "uart2_ctsn", "eCAP2_in_PWM2_out", NULL, NULL, NULL, "gpio3_5"),
> > +     _PIN(0x18c, "I2C0_SCL",         102, 7, "I2C0_SCL", "timer7",
> "uart2_rtsn", "eCAP1_in_PWM1_out", NULL, NULL, NULL, "gpio3_6"),
> > +     _PIN(0x190, "MCASP0_ACLKX",     110, 7, "mcasp0_aclkx",
> "ehrpwm0A", NULL, "spi1_sclk", "mmc0_sdcd", "pr1_pru0_pru_r30_0",
> "pr1_pru0_pru_r31_0", "gpio3_14"),
> > +     _PIN(0x194, "MCASP0_FSX",       111, 7, "mcasp0_fsx", "ehrpwm0B",
> NULL, "spi1_d0", "mmc1_sdcd", "pr1_pru0_pru_r30_1", "pr1_pru0_pru_r31_1",
> "gpio3_15"),
> > +     _PIN(0x198, "MCASP0_AXR0",      112, 7, "mcasp0_axr0",
> "ehrpwm0_tripzone_input", NULL, "spi1_d1", "mmc2_sdcd",
> "pr1_pru0_pru_r30_2", "pr1_pru0_pru_r31_2", "gpio3_16"),
> > +     _PIN(0x19c, "MCASP0_AHCLKR",    113, 7, "mcasp0_ahclkr",
> "ehrpwm0_synci", "mcasp0_axr2", "spi1_cs0", "eCAP2_in_PWM2_out",
> "pr1_pru0_pru_r30_3", "pr1_pru0_pru_r31_3", "gpio3_17"),
> > +     _PIN(0x1a0, "MCASP0_ACLKR",     114, 7, "mcasp0_aclkr",
> "eQEP0A_in", "mcasp0_axr2", "mcasp1_aclkx", "mmc0_sdwp",
> "pr1_pru0_pru_r30_4", "pr1_pru0_pru_r31_4", "gpio3_18"),
> > +     _PIN(0x1a4, "MCASP0_FSR",       115, 7, "mcasp0_fsr", "eQEP0B_in",
> "mcasp0_axr3", "mcasp1_fsx", "EMU2", "pr1_pru0_pru_r30_5",
> "pr1_pru0_pru_r31_5", "gpio3_19"),
> > +     _PIN(0x1a8, "MCASP0_AXR1",      116, 7, "mcasp0_axr1",
> "eQEP0_index", NULL, "mcasp1_axr0", "EMU3", "pr1_pru0_pru_r30_6",
> "pr1_pru0_pru_r31_6", "gpio3_20"),
> > +     _PIN(0x1ac, "MCASP0_AHCLKX",    117, 7, "mcasp0_ahclkx",
> "eQEP0_strobe", "mcasp0_axr3", "mcasp1_axr1", "EMU4", "pr1_pru0_pru_r30_7",
> "pr1_pru0_pru_r31_7", "gpio3_21"),
> > +     _PIN(0x1b0, "XDMA_EVENT_INTR0", 19, 7, "xdma_event_intr0", NULL,
> "timer4", "clkout1", "spi1_cs1", "pr1_pru1_pru_r31_16", "EMU2", "gpio0_19"),
> > +     _PIN(0x1b4, "XDMA_EVENT_INTR1", 20, 7, "xdma_event_intr1", NULL,
> "tclkin", "clkout2", "timer7", "pr1_pru0_pru_r31_16", "EMU3", "gpio0_20"),
> > +#if 0
> > +     _PIN(0x1b8, "nresetin_out",     0, 0, NULL, NULL, NULL, NULL,
> NULL, NULL, NULL, NULL),
> > +     _PIN(0x1bc, "porz",             0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x1c0, "nnmi",             0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x1c4, "osc0_in",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x1c8, "osc0_out",         0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x1cc, "osc0_vss",         0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x1d0, "tms",              0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x1d4, "tdi",              0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x1d8, "tdo",              0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x1dc, "tck",              0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x1e0, "ntrst",            0, 0, NULL, NULL, NULL, NULL,
> > +#endif
> > +     _PIN(0x1e4, "EMU0",             103, 7, "EMU0", NULL, NULL, NULL,
> NULL, NULL, NULL, "gpio3_7"),
> > +     _PIN(0x1e8, "EMU1",             104, 0, "EMU1", NULL, NULL, NULL,
> NULL, NULL, NULL, "gpio3_8"),
> > +#if 0
> > +     _PIN(0x1ec, "osc1_in",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x1f0, "osc1_out",         0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x1f4, "osc1_vss",         0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x1f8, "rtc_porz",         0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x1fc, "pmic_power_en",    0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x200, "ext_wakeup",       0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x204, "enz_kaldo_1p8v",   0, 0, NULL, NULL, NULL, NULL,
> > +#endif
> > +     _PIN(0x208, "USB0_DM",          0, 0, "USB0_DM", NULL, NULL, NULL,
> > +     _PIN(0x20c, "USB0_DP",          0, 0, "USB0_DP", NULL, NULL, NULL,
> > +     _PIN(0x210, "USB0_CE",          0, 0, "USB0_CE", NULL, NULL, NULL,
> > +     _PIN(0x214, "USB0_ID",          0, 0, "USB0_ID", NULL, NULL, NULL,
> > +     _PIN(0x218, "USB0_VBUS",        0, 0, "USB0_VBUS", NULL, NULL,
> NULL, NULL, NULL, NULL, NULL),
> > +     _PIN(0x21c, "USB0_DRVVBUS",     18, 7, "USB0_DRVVBUS", NULL, NULL,
> NULL, NULL, NULL, NULL, "gpio0_18"),
> > +     _PIN(0x220, "USB1_DM",          0, 0, "USB1_DM", NULL, NULL, NULL,
> > +     _PIN(0x224, "USB1_DP",          0, 0, "USB1_DP", NULL, NULL, NULL,
> > +     _PIN(0x228, "USB1_CE",          0, 0, "USB1_CE", NULL, NULL, NULL,
> > +     _PIN(0x22c, "USB1_ID",          0, 0, "USB1_ID", NULL, NULL, NULL,
> > +     _PIN(0x230, "USB1_VBUS",        0, 0, "USB1_VBUS", NULL, NULL,
> > +     _PIN(0x234, "USB1_DRVVBUS",     109, 7, "USB1_DRVVBUS", NULL,
> NULL, NULL, NULL, NULL, NULL, "gpio3_13"),
> > +#if 0
> > +     _PIN(0x238, "ddr_resetn",       0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x23c, "ddr_csn0",         0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x240, "ddr_cke",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x244, "ddr_ck",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x248, "ddr_nck",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x24c, "ddr_casn",         0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x250, "ddr_rasn",         0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x254, "ddr_wen",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x258, "ddr_ba0",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x25c, "ddr_ba1",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x260, "ddr_ba2",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x264, "ddr_a0",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x268, "ddr_a1",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x26c, "ddr_a2",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x270, "ddr_a3",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x274, "ddr_a4",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x278, "ddr_a5",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x27c, "ddr_a6",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x280, "ddr_a7",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x284, "ddr_a8",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x288, "ddr_a9",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x28c, "ddr_a10",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x290, "ddr_a11",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x294, "ddr_a12",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x298, "ddr_a13",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x29c, "ddr_a14",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2a0, "ddr_a15",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2a4, "ddr_odt",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2a8, "ddr_d0",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2ac, "ddr_d1",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2b0, "ddr_d2",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2b4, "ddr_d3",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2b8, "ddr_d4",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2bc, "ddr_d5",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2c0, "ddr_d6",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2c4, "ddr_d7",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2c8, "ddr_d8",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2cc, "ddr_d9",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2d0, "ddr_d10",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2d4, "ddr_d11",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2d8, "ddr_d12",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2dc, "ddr_d13",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2e0, "ddr_d14",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2e4, "ddr_d15",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2e8, "ddr_dqm0",         0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2ec, "ddr_dqm1",         0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2f0, "ddr_dqs0",         0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2f4, "ddr_dqsn0",        0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2f8, "ddr_dqs1",         0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x2fc, "ddr_dqsn1",        0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x300, "ddr_vref",         0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x304, "ddr_vtp",          0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x308, "ddr_strben0",      0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x30c, "ddr_strben1",      0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x32c, "ain0",             0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x328, "ain1",             0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x324, "ain2",             0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x320, "ain3",             0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x31c, "ain4",             0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x318, "ain5",             0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x314, "ain6",             0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x310, "ain7",             0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x330, "vrefp",            0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x334, "vrefn",            0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x338, "avdd",             0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x33c, "avss",             0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x340, "iforce",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x344, "vsense",           0, 0, NULL, NULL, NULL, NULL,
> > +     _PIN(0x348, "testout",          0, 0, NULL, NULL, NULL, NULL,
> > +#endif
> > +     {  .ballname = NULL  },
> > +const struct ti_pinmux_device ti_am335x_pinmux_dev = {
> > +     .padconf_muxmode_mask   = 0x7,
> > +     .padconf_sate_mask      = 0x78,
> > +     .padstate               = ti_padstate_devmap,
> > +     .padconf                = ti_padconf_devmap,
> > diff --git a/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.h
> b/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.h
> > index 00000000..b1fa22ba
> > --- /dev/null
> > +++ b/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.h
> > @@ -0,0 +1,47 @@
> > + * are met:
> the
> distribution.
> AND
> PURPOSE
> LIABLE
> CONSEQUENTIAL
> GOODS
> STRICT
> ANY WAY
> OF
> > + * SUCH DAMAGE.
> > + * $FreeBSD$
> > +#ifndef AM335X_SCM_PADCONF_H
> > +#define AM335X_SCM_PADCONF_H
> > +#define SLEWCTRL     (0x01 << 6) /* faster(0) or slower(1) slew rate. */
> > +#define RXACTIVE     (0x01 << 5) /* Input enable value for the Pad */
> > +#define PULLTYPESEL  (0x01 << 4) /* Pad pullup/pulldown type selection
> > +#define PULLUDEN     (0x01 << 3) /* Pullup/pulldown disabled */
> > +#define PADCONF_OUTPUT                       (PULLUDEN)
> > +#define PADCONF_OUTPUT_PULLUP                (PULLTYPESEL)
> > +#define PADCONF_OUTPUT_PULLDOWN              (0)
> > +#define PADCONF_INPUT                        (RXACTIVE | PULLUDEN)
> > +#define PADCONF_INPUT_PULLUP         (RXACTIVE | PULLTYPESEL)
> > +#define PADCONF_INPUT_PULLDOWN               (RXACTIVE)
> > +#define PADCONF_INPUT_PULLUP_SLOW    (PADCONF_INPUT_PULLUP | SLEWCTRL)
> > +extern const struct ti_pinmux_device ti_am335x_pinmux_dev;
> > +#endif /* AM335X_SCM_PADCONF_H */
> > diff --git a/freebsd/sys/arm/ti/omap4/omap4_scm_padconf.h
> b/freebsd/sys/arm/ti/omap4/omap4_scm_padconf.h
> > index 00000000..adee0a79
> > --- /dev/null
> > +++ b/freebsd/sys/arm/ti/omap4/omap4_scm_padconf.h
> > @@ -0,0 +1,83 @@
> > + * Copyright (c) 2011
> > + *   Ben Gray <ben.r.gray at gmail.com>.
> > + * are met:
> the
> distribution.
> > + * 3. The name of the company nor the name of the author may be used to
> > + *    endorse or promote products derived from this software without
> specific
> > + *    prior written permission.
> > + * THIS SOFTWARE IS PROVIDED BY BEN GRAY ``AS IS'' AND ANY EXPRESS OR
> > + * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
> WARRANTIES
> > + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
> DISCLAIMED.
> > + * IN NO EVENT SHALL BEN GRAY BE LIABLE FOR ANY DIRECT, INDIRECT,
> INCIDENTAL,
> > + * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
> LIMITED TO,
> > + * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
> PROFITS;
> > + * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
> LIABILITY,
> > + * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
> OR
> > + * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
> IF
> > + * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> > + * $FreeBSD$
> > +#ifndef OMAP4_SCM_PADCONF_H
> > +#define      OMAP4_SCM_PADCONF_H
> > +#define CONTROL_PADCONF_WAKEUP_EVENT     (1UL << 15)
> > +#define CONTROL_PADCONF_WAKEUP_ENABLE    (1UL << 14)
> > +#define CONTROL_PADCONF_OFF_PULL_UP      (1UL << 13)
> > +#define CONTROL_PADCONF_OFF_PULL_ENABLE  (1UL << 12)
> > +#define CONTROL_PADCONF_OFF_OUT_HIGH     (1UL << 11)
> > +#define CONTROL_PADCONF_OFF_OUT_ENABLE   (1UL << 10)
> > +#define CONTROL_PADCONF_OFF_ENABLE       (1UL << 9)
> > +#define CONTROL_PADCONF_INPUT_ENABLE     (1UL << 8)
> > +#define CONTROL_PADCONF_PULL_UP          (1UL << 4)
> > +#define CONTROL_PADCONF_PULL_ENABLE      (1UL << 3)
> > +#define CONTROL_PADCONF_MUXMODE_MASK     (0x7)
> > +#define CONTROL_PADCONF_SATE_MASK        ( CONTROL_PADCONF_WAKEUP_EVENT
> CONTROL_PADCONF_WAKEUP_ENABLE \
> > +                                         | CONTROL_PADCONF_OFF_PULL_UP \
> CONTROL_PADCONF_OFF_PULL_ENABLE \
> > +                                         | CONTROL_PADCONF_OFF_OUT_HIGH
> CONTROL_PADCONF_OFF_OUT_ENABLE \
> > +                                         | CONTROL_PADCONF_OFF_ENABLE \
> > +                                         | CONTROL_PADCONF_INPUT_ENABLE
> > +                                         | CONTROL_PADCONF_PULL_UP \
> > +                                         | CONTROL_PADCONF_PULL_ENABLE )
> > +/* Active pin states */
> > +#define PADCONF_PIN_OUTPUT              0
> > +#define PADCONF_PIN_INPUT               CONTROL_PADCONF_INPUT_ENABLE
> > +#define PADCONF_PIN_INPUT_PULLUP        ( CONTROL_PADCONF_INPUT_ENABLE \
> > +                                        | CONTROL_PADCONF_PULL_ENABLE \
> > +                                        | CONTROL_PADCONF_PULL_UP)
> > +#define PADCONF_PIN_INPUT_PULLDOWN      ( CONTROL_PADCONF_INPUT_ENABLE \
> > +/* Off mode states */
> > +#define PADCONF_PIN_OFF_NONE            0
> > +#define PADCONF_PIN_OFF_OUTPUT_HIGH      ( CONTROL_PADCONF_OFF_ENABLE \
> > +                                        | CONTROL_PADCONF_OFF_OUT_HIGH)
> > +#define PADCONF_PIN_OFF_OUTPUT_LOW      ( CONTROL_PADCONF_OFF_ENABLE \
> CONTROL_PADCONF_OFF_OUT_ENABLE)
> > +#define PADCONF_PIN_OFF_INPUT_PULLUP    ( CONTROL_PADCONF_OFF_ENABLE \
> > +                                        | CONTROL_PADCONF_OFF_PULL_UP)
> > +#define PADCONF_PIN_OFF_INPUT_PULLDOWN  ( CONTROL_PADCONF_OFF_ENABLE \
> CONTROL_PADCONF_OFF_PULL_ENABLE)
> > +#define PADCONF_PIN_OFF_WAKEUPENABLE CONTROL_PADCONF_WAKEUP_ENABLE
> > +extern const struct ti_pinmux_device omap4_pinmux_dev;
> > +#endif /* OMAP4_SCM_PADCONF_H */
> > diff --git a/freebsd/sys/arm/ti/ti_pinmux.c
> b/freebsd/sys/arm/ti/ti_pinmux.c
> > index 00000000..af47d074
> > --- /dev/null
> > +++ b/freebsd/sys/arm/ti/ti_pinmux.c
> > @@ -0,0 +1,463 @@
> > + * Copyright (c) 2010
> > + * are met:
> the
> distribution.
> > + * 3. All advertising materials mentioning features or use of this
> software
> > + *    must display the following acknowledgement:
> > + *   This product includes software developed by Ben Gray.
> > + * 4. The name of the company nor the name of the author may be used to
> specific
> WARRANTIES
> DISCLAIMED.
> INCIDENTAL,
> LIMITED TO,
> PROFITS;
> LIABILITY,
> OR
> IF
> > + * Exposes pinmux module to pinctrl-compatible interface
> > +#include <sys/mutex.h>
> > +#include <dev/ofw/openfirm.h>
> > +#include <dev/ofw/ofw_bus.h>
> > +#include <dev/ofw/ofw_bus_subr.h>
> > +#include <dev/fdt/fdt_pinctrl.h>
> > +#include <arm/ti/omap4/omap4_scm_padconf.h>
> > +#include <arm/ti/ti_cpuid.h>
> > +#include "ti_pinmux.h"
> > +struct pincfg {
> > +     uint32_t reg;
> > +     uint32_t conf;
> > +static struct resource_spec ti_pinmux_res_spec[] = {
> > +     { SYS_RES_MEMORY,       0,      RF_ACTIVE },    /* Control memory
> window */
> > +     { -1, 0 }
> > +static struct ti_pinmux_softc *ti_pinmux_sc;
> > +#define      ti_pinmux_read_2(sc, reg)               \
> > +    bus_space_read_2((sc)->sc_bst, (sc)->sc_bsh, (reg))
> > +#define      ti_pinmux_write_2(sc, reg, val)         \
> > +    bus_space_write_2((sc)->sc_bst, (sc)->sc_bsh, (reg), (val))
> > +#define      ti_pinmux_read_4(sc, reg)               \
> > +    bus_space_read_4((sc)->sc_bst, (sc)->sc_bsh, (reg))
> > +#define      ti_pinmux_write_4(sc, reg, val)         \
> > +    bus_space_write_4((sc)->sc_bst, (sc)->sc_bsh, (reg), (val))
> > + *   ti_padconf_devmap - Array of pins, should be defined one per SoC
> > + *   This array is typically defined in one of the targeted
> *_scm_pinumx.c
> > + *   files and is specific to the given SoC platform. Each entry in the
> array
> > + *   corresponds to an individual pin.
> > +static const struct ti_pinmux_device *ti_pinmux_dev;
> > + *   ti_pinmux_padconf_from_name - searches the list of pads and
> returns entry
> > + *                                with matching ball name.
> > + *   @ballname: the name of the ball
> > + *   RETURNS:
> > + *   A pointer to the matching padconf or NULL if the ball wasn't found.
> > +static const struct ti_pinmux_padconf*
> > +ti_pinmux_padconf_from_name(const char *ballname)
> > +     const struct ti_pinmux_padconf *padconf;
> > +     padconf = ti_pinmux_dev->padconf;
> > +     while (padconf->ballname != NULL) {
> > +             if (strcmp(ballname, padconf->ballname) == 0)
> > +                     return(padconf);
> > +             padconf++;
> > +     return (NULL);
> > + *   ti_pinmux_padconf_set_internal - sets the muxmode and state for a
> pad/pin
> > + *   @padconf: pointer to the pad structure
> > + *   @muxmode: the name of the mode to use for the pin, i.e. "uart1_rx"
> > + *   @state: the state to put the pad/pin in, i.e. PADCONF_PIN_???
> > + *   LOCKING:
> > + *   Internally locks it's own context.
> > + *   RETURNS:
> > + *   0 on success.
> > + *   EINVAL if pin requested is outside valid range or already in use.
> > +static int
> > +ti_pinmux_padconf_set_internal(struct ti_pinmux_softc *sc,
> > +    const struct ti_pinmux_padconf *padconf,
> > +    const char *muxmode, unsigned int state)
> > +     unsigned int mode;
> > +     uint16_t reg_val;
> > +     /* populate the new value for the PADCONF register */
> > +     reg_val = (uint16_t)(state & ti_pinmux_dev->padconf_sate_mask);
> > +     /* find the new mode requested */
> > +     for (mode = 0; mode < 8; mode++) {
> > +             if ((padconf->muxmodes[mode] != NULL) &&
> > +                 (strcmp(padconf->muxmodes[mode], muxmode) == 0)) {
> > +                     break;
> > +     /* couldn't find the mux mode */
> > +     if (mode >= 8) {
> > +             printf("Invalid mode \"%s\"\n", muxmode);
> > +             return (EINVAL);
> > +     /* set the mux mode */
> > +     reg_val |= (uint16_t)(mode & ti_pinmux_dev->padconf_muxmode_mask);
> > +     if (bootverbose)
> > +             device_printf(sc->sc_dev, "setting internal %x for %s\n",
> > +                 reg_val, muxmode);
> > +     /* write the register value (16-bit writes) */
> > +     ti_pinmux_write_2(sc, padconf->reg_off, reg_val);
> > +     return (0);
> > + *   ti_pinmux_padconf_set - sets the muxmode and state for a pad/pin
> > + *   @padname: the name of the pad, i.e. "c12"
> > + *   LOCKING:
> > + *   RETURNS:
> > + *   0 on success.
> > +int
> > +ti_pinmux_padconf_set(const char *padname, const char *muxmode,
> unsigned int state)
> > +     if (!ti_pinmux_sc)
> > +             return (ENXIO);
> > +     /* find the pin in the devmap */
> > +     padconf = ti_pinmux_padconf_from_name(padname);
> > +     if (padconf == NULL)
> > +             return (EINVAL);
> > +     return (ti_pinmux_padconf_set_internal(ti_pinmux_sc, padconf,
> muxmode, state));
> > + *   ti_pinmux_padconf_get - gets the muxmode and state for a pad/pin
> > + *   @muxmode: upon return will contain the name of the muxmode of the
> pin
> > + *   @state: upon return will contain the state of the pad/pin
> > + *   LOCKING:
> > + *   RETURNS:
> > + *   0 on success.
> > +int
> > +ti_pinmux_padconf_get(const char *padname, const char **muxmode,
> > +    unsigned int *state)
> > +     uint16_t reg_val;
> > +             return (ENXIO);
> > +             return (EINVAL);
> > +     /* read the register value (16-bit reads) */
> > +     reg_val = ti_pinmux_read_2(ti_pinmux_sc, padconf->reg_off);
> > +     /* save the state */
> > +     if (state)
> > +             *state = (reg_val & ti_pinmux_dev->padconf_sate_mask);
> > +     /* save the mode */
> > +     if (muxmode)
> > +             *muxmode = padconf->muxmodes[(reg_val &
> ti_pinmux_dev->padconf_muxmode_mask)];
> > +     return (0);
> > + *   ti_pinmux_padconf_set_gpiomode - converts a pad to GPIO mode.
> > + *   @gpio: the GPIO pin number (0-195)
> > + *   LOCKING:
> > + *   RETURNS:
> > + *   0 on success.
> > +int
> > +ti_pinmux_padconf_set_gpiomode(uint32_t gpio, unsigned int state)
> > +     uint16_t reg_val;
> > +             return (ENXIO);
> > +     /* find the gpio pin in the padconf array */
> > +             if (padconf->gpio_pin == gpio)
> > +                     break;
> > +             padconf++;
> > +     if (padconf->ballname == NULL)
> > +             return (EINVAL);
> > +     reg_val |= (uint16_t)(padconf->gpio_mode &
> > +     ti_pinmux_write_2(ti_pinmux_sc, padconf->reg_off, reg_val);
> > +     return (0);
> > + *   ti_pinmux_padconf_get_gpiomode - gets the current GPIO mode of the
> pin
> > + *   LOCKING:
> > + *   RETURNS:
> > + *   0 on success.
> > + *   EINVAL if pin requested is outside valid range or not configured
> as GPIO.
> > +int
> > +ti_pinmux_padconf_get_gpiomode(uint32_t gpio, unsigned int *state)
> > +     uint16_t reg_val;
> > +             return (ENXIO);
> > +                     break;
> > +             padconf++;
> > +             return (EINVAL);
> > +     /* read the current register settings */
> > +     /* check to make sure the pins is configured as GPIO in the first
> state */
> > +     if ((reg_val & ti_pinmux_dev->padconf_muxmode_mask) !=
> padconf->gpio_mode)
> > +             return (EINVAL);
> > +     /* read and store the reset of the state, i.e. pull-up, pull-down,
> etc */
> > +     if (state)
> > +     return (0);
> > +static int
> > +ti_pinmux_configure_pins(device_t dev, phandle_t cfgxref)
> > +     struct pincfg *cfgtuples, *cfg;
> > +     phandle_t cfgnode;
> > +     int i, ntuples;
> > +     static struct ti_pinmux_softc *sc;
> > +     sc = device_get_softc(dev);
> > +     cfgnode = OF_node_from_xref(cfgxref);
> > +     ntuples = OF_getencprop_alloc_multi(cfgnode, "pinctrl-single,pins",
> > +         sizeof(*cfgtuples), (void **)&cfgtuples);
> > +     if (ntuples < 0)
> > +             return (ENOENT);
> > +     if (ntuples == 0)
> > +             return (0); /* Empty property is not an error. */
> > +     for (i = 0, cfg = cfgtuples; i < ntuples; i++, cfg++) {
> > +             if (bootverbose) {
> > +                     char name[32];
> > +                     OF_getprop(cfgnode, "name", &name, sizeof(name));
> > +                     printf("%16s: muxreg 0x%04x muxval 0x%02x\n",
> > +                         name, cfg->reg, cfg->conf);
> > +             ti_pinmux_write_2(sc, cfg->reg, cfg->conf);
> > +     OF_prop_free(cfgtuples);
> > +     return (0);
> > + * Device part of OMAP SCM driver
> > +static int
> > +ti_pinmux_probe(device_t dev)
> > +     if (!ofw_bus_status_okay(dev))
> > +             return (ENXIO);
> > +     if (!ofw_bus_is_compatible(dev, "pinctrl-single"))
> > +             return (ENXIO);
> > +     if (ti_pinmux_sc) {
> > +             printf("%s: multiple pinctrl modules in device tree data,
> ignoring\n",
> > +                 __func__);
> > +             return (EEXIST);
> > +     switch (ti_chip()) {
> > +#ifdef SOC_OMAP4
> > +     case CHIP_OMAP_4:
> > +             ti_pinmux_dev = &omap4_pinmux_dev;
> > +             break;
> > +#endif
> > +#ifdef SOC_TI_AM335X
> > +     case CHIP_AM335X:
> > +             ti_pinmux_dev = &ti_am335x_pinmux_dev;
> > +             break;
> > +#endif
> > +     default:
> > +             printf("Unknown CPU in pinmux\n");
> > +             return (ENXIO);
> > +     device_set_desc(dev, "TI Pinmux Module");
> > +     return (BUS_PROBE_DEFAULT);
> > + *   ti_pinmux_attach - attaches the pinmux to the simplebus
> > + *   @dev: new device
> > + *   RETURNS
> > + *   Zero on success or ENXIO if an error occuried.
> > +static int
> > +ti_pinmux_attach(device_t dev)
> > +     struct ti_pinmux_softc *sc = device_get_softc(dev);
> > +#if 0
> > +     if (ti_pinmux_sc)
> > +             return (ENXIO);
> > +#endif
> > +     sc->sc_dev = dev;
> > +     if (bus_alloc_resources(dev, ti_pinmux_res_spec, sc->sc_res)) {
> > +             device_printf(dev, "could not allocate resources\n");
> > +             return (ENXIO);
> > +     sc->sc_bst = rman_get_bustag(sc->sc_res[0]);
> > +     sc->sc_bsh = rman_get_bushandle(sc->sc_res[0]);
> > +     if (ti_pinmux_sc == NULL)
> > +             ti_pinmux_sc = sc;
> > +     fdt_pinctrl_register(dev, "pinctrl-single,pins");
> > +     fdt_pinctrl_configure_tree(dev);
> > +     return (0);
> > +static device_method_t ti_pinmux_methods[] = {
> > +     DEVMETHOD(device_probe,         ti_pinmux_probe),
> > +     DEVMETHOD(device_attach,        ti_pinmux_attach),
> > +        /* fdt_pinctrl interface */
> > +     DEVMETHOD(fdt_pinctrl_configure, ti_pinmux_configure_pins),
> > +     { 0, 0 }
> > +static driver_t ti_pinmux_driver = {
> > +     "ti_pinmux",
> > +     ti_pinmux_methods,
> > +     sizeof(struct ti_pinmux_softc),
> > +static devclass_t ti_pinmux_devclass;
> > +DRIVER_MODULE(ti_pinmux, simplebus, ti_pinmux_driver,
> ti_pinmux_devclass, 0, 0);
> > diff --git a/freebsd/sys/arm/ti/ti_pinmux.h
> b/freebsd/sys/arm/ti/ti_pinmux.h
> > index 00000000..c299c494
> > --- /dev/null
> > +++ b/freebsd/sys/arm/ti/ti_pinmux.h
> > @@ -0,0 +1,80 @@
> > + * are met:
> the
> distribution.
> software
> specific
> WARRANTIES
> DISCLAIMED.
> INCIDENTAL,
> LIMITED TO,
> PROFITS;
> LIABILITY,
> OR
> IF
> > + * $FreeBSD$
> > + *   Functions to configure the PIN multiplexing on the chip.
> > + *   This is different from the GPIO module in that it is used to
> configure the
> > + *   pins between modules not just GPIO input output.
> > +#ifndef _TI_PINMUX_H_
> > +#define _TI_PINMUX_H_
> > +struct ti_pinmux_padconf {
> > +     uint16_t    reg_off;
> > +     uint16_t    gpio_pin;
> > +     uint16_t    gpio_mode;
> > +     const char  *ballname;
> > +     const char  *muxmodes[8];
> > +struct ti_pinmux_padstate {
> > +     const char  *state;
> > +     uint16_t    reg;
> > +struct ti_pinmux_device {
> > +     uint16_t                padconf_muxmode_mask;
> > +     uint16_t                padconf_sate_mask;
> > +     const struct ti_pinmux_padstate *padstate;
> > +struct ti_pinmux_softc {
> > +     device_t                sc_dev;
> > +     struct resource *       sc_res[4];
> > +     bus_space_tag_t         sc_bst;
> > +     bus_space_handle_t      sc_bsh;
> > +int ti_pinmux_padconf_set(const char *padname, const char *muxmode,
> > +    unsigned int state);
> > +int ti_pinmux_padconf_get(const char *padname, const char **muxmode,
> > +    unsigned int *state);
> > +int ti_pinmux_padconf_set_gpiomode(uint32_t gpio, unsigned int state);
> > +int ti_pinmux_padconf_get_gpiomode(uint32_t gpio, unsigned int *state);
> > +#endif /* _TI_SCM_H_ */
> > diff --git a/freebsd/sys/dev/fdt/fdt_pinctrl.c
> b/freebsd/sys/dev/fdt/fdt_pinctrl.c
> > index 00000000..c2e0c612
> > --- /dev/null
> > +++ b/freebsd/sys/dev/fdt/fdt_pinctrl.c
> > @@ -0,0 +1,160 @@
> > + * Copyright (c) 2014 Ian Lepore <ian at freebsd.org>
> > + * are met:
> the
> distribution.
> AND
> PURPOSE
> LIABLE
> CONSEQUENTIAL
> GOODS
> STRICT
> ANY WAY
> OF
> > + * SUCH DAMAGE.
> > + * $FreeBSD$
> > +#include <rtems/bsd/local/fdt_pinctrl_if.h>
> > +#include <dev/fdt/fdt_common.h>
> > +int
> > +fdt_pinctrl_configure(device_t client, u_int index)
> > +     device_t pinctrl;
> > +     phandle_t *configs;
> > +     int i, nconfigs;
> > +     char name[16];
> > +     snprintf(name, sizeof(name), "pinctrl-%u", index);
> > +     nconfigs = OF_getencprop_alloc_multi(ofw_bus_get_node(client),
> name,
> > +         sizeof(*configs), (void **)&configs);
> > +     if (nconfigs < 0)
> > +             return (ENOENT);
> > +     if (nconfigs == 0)
> > +             return (0); /* Empty property is documented as valid. */
> > +     for (i = 0; i < nconfigs; i++) {
> > +             if ((pinctrl = OF_device_from_xref(configs[i])) != NULL)
> > +                     FDT_PINCTRL_CONFIGURE(pinctrl, configs[i]);
> > +     OF_prop_free(configs);
> > +     return (0);
> > +int
> > +fdt_pinctrl_configure_by_name(device_t client, const char * name)
> > +     char * names;
> > +     int i, offset, nameslen;
> > +     nameslen = OF_getprop_alloc(ofw_bus_get_node(client),
> "pinctrl-names",
> > +         (void **)&names);
> > +     if (nameslen <= 0)
> > +             return (ENOENT);
> > +     for (i = 0, offset = 0; offset < nameslen; i++) {
> > +             if (strcmp(name, &names[offset]) == 0)
> > +                     break;
> > +             offset += strlen(&names[offset]) + 1;
> > +     OF_prop_free(names);
> > +     if (offset < nameslen)
> > +             return (fdt_pinctrl_configure(client, i));
> > +     else
> > +             return (ENOENT);
> > +static int
> > +pinctrl_register_children(device_t pinctrl, phandle_t parent,
> > +    const char *pinprop)
> > +     phandle_t node;
> > +      * Recursively descend from parent, looking for nodes that have the
> > +      * given property, and associate the pinctrl device_t with each
> one.
> > +     for (node = OF_child(parent); node != 0; node = OF_peer(node)) {
> > +             pinctrl_register_children(pinctrl, node, pinprop);
> > +             if (pinprop == NULL || OF_hasprop(node, pinprop)) {
> > +                     OF_device_register_xref(OF_xref_from_node(node),
> > +                         pinctrl);
> > +     return (0);
> > +int
> > +fdt_pinctrl_register(device_t pinctrl, const char *pinprop)
> > +     phandle_t node;
> > +     int ret;
> > +     TSENTER();
> > +     node = ofw_bus_get_node(pinctrl);
> > +     OF_device_register_xref(OF_xref_from_node(node), pinctrl);
> > +     ret = pinctrl_register_children(pinctrl, node, pinprop);
> > +     TSEXIT();
> > +     return (ret);
> > +static int
> > +pinctrl_configure_children(device_t pinctrl, phandle_t parent)
> > +     phandle_t node, *configs;
> > +     int i, nconfigs;
> > +     TSENTER();
> > +             if (!ofw_bus_node_status_okay(node))
> > +                     continue;
> > +             pinctrl_configure_children(pinctrl, node);
> > +             nconfigs = OF_getencprop_alloc_multi(node, "pinctrl-0",
> > +             if (nconfigs <= 0)
> > +                     continue;
> > +                     char name[32];
> > +                     OF_getprop(node, "name", &name, sizeof(name));
> > +                     printf("Processing %d pin-config node(s) in
> pinctrl-0 for %s\n",
> > +                         nconfigs, name);
> > +                     if (OF_device_from_xref(configs[i]) == pinctrl)
> > +     TSEXIT();
> > +     return (0);
> > +int
> > +fdt_pinctrl_configure_tree(device_t pinctrl)
> > +     return (pinctrl_configure_children(pinctrl, OF_peer(0)));
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190808/fca91d7b/attachment-0001.html>
