Chapter/section numbers in document internal references
Thu Aug 8 06:52:44 UTC 2019
On 06/08/2019 10:23, Sebastian Huber wrote:
> On 06/08/2019 10:05, Chris Johns wrote:
>> On 6/8/19 4:36 pm, Sebastian Huber wrote:
>>> Hello,
>>> when you use document internal references, e.g.
>>> :ref:`RSB`
>>> then this is turned into:
>>> "Chapter 12 - RTEMS Source Builder"
>>> I think this "Chapter 12 - " prefix makes it harder to read the
>>> document. In a
>>> default configuration of Sphinx this stuff is not included. Would it
>>> be possible
>>> to remove this from the RTEMS customization?
>> What are you suggesting instead? Could you put something online so I
>> could compare?
>> I did play around with this but I cannot remember all the variations
>> and why I
>> selected this one.
> To see the default behaviour, please create a new document with
> sphinx-quickstart and copy the attached index.rst over the default. Run
> "make latexpdf".
> On page 1 you see "See Section.". With the RTEMS style you would
> probably see "See Chapter 1 - Section".
Here is an example in the RTEMS style:
https://docs.rtems.org/branches/master/user/support/bugs.html
I think the "Chapter/Section X" prefix makes it harder to read.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
