[PATCH] user: Improve bug report section
Thu Aug 8 07:02:03 UTC 2019
On 06/08/2019 21:22, Joel Sherrill wrote:
> FWIW the pages converted by the high school students during Google Code-in
> to be in the SW Eng Guide were from Wiki pages which ultimately need to be
> deleted. There needs to be a pass to compare Rest version against the Wiki
> version and then delete the Wiki version. And anytime a Wiki document is
> deleted,
> it is very likely links on other pages (including rtems.org
> <http://rtems.org> top) need to be changed.
Should a converted page get removed or should its content be replaced
with a redirect to the corresponding section in the manuals?
This page contains some content which should also move to the user
manual bug reporting section:
https://devel.rtems.org/wiki/NewTicket
Everything in
https://devel.rtems.org/wiki/NewTicket#RequiredInformation
and below.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
