RISC-V Test Results
Thu Aug 8 13:33:54 UTC 2019
Hi
If you are subscribed to the build@ mailing list, then you saw the flurry
of test
results from over night. I built every variant and ran the test suite with
RTEMS
debug on and off.  Here are some observations:
+ rv64imafd only has one test pass
+ rv64_iamd_medany only has one test pass
+ Generally speaking, 17-19 tests failed or timed out on every variant with
   551-553 passing. It would be great for someone to mark the tests in the
   tcfg files as expected fails.
Hopefully this gives someone incentive to look into the failures.
I would also run them on qemu but I don't think we have an RSB recipe for a
Qemu with RISC-V support.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190808/81037132/attachment.html>
