RISC-V Test Results
Hesham Almatary heshamelmatary at gmail.com
Fri Aug 9 10:38:24 UTC 2019
Hi Joel,
On Thu, 8 Aug 2019 at 14:34, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> If you are subscribed to the build@ mailing list, then you saw the flurry of test
> results from over night. I built every variant and ran the test suite with RTEMS
> debug on and off.  Here are some observations:
> + rv64imafd only has one test pass
I think you mean rv64imafd_medany by this? Which only has 1 test
passing. Anyway, I had a look at your run command which provides
--rtems-bsp=rv64imafd_medany_spike. However, rv64imafd BSP variant is
the ones passed to the tester instead of rv64imafd_medany, which
should definitely fail as the start address of this one is 0x70000000
and Spike's default memory base t0 0x80000000.
> + rv64_iamd_medany only has one test pass
> + Generally speaking, 17-19 tests failed or timed out on every variant with
>    551-553 passing. It would be great for someone to mark the tests in the
>    tcfg files as expected fails.
> Hopefully this gives someone incentive to look into the failures.
> I would also run them on qemu but I don't think we have an RSB recipe for a
> Qemu with RISC-V support.
> --joel
Hesham
