RISC-V Test Results
Fri Aug 9 11:47:33 UTC 2019
On 08/08/2019 15:33, Joel Sherrill wrote:
> Hi
> If you are subscribed to the build@ mailing list, then you saw the
> flurry of test
> results from over night. I built every variant and ran the test suite
> with RTEMS
> debug on and off.  Here are some observations:
> + rv64imafd only has one test pass
> + rv64_iamd_medany only has one test pass
> + Generally speaking, 17-19 tests failed or timed out on every variant with
>     551-553 passing. It would be great for someone to mark the tests in the
>     tcfg files as expected fails.
The BSP runs on hardware and simulators. Some test may pass on real
hardware. So, marking them as expected fails is not right.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
