[PATCH] rtems/rtems-kernel-nexus.c: LibBSD init now uses all pass levels.
Nils Hölscher
nilhoel1 at gmail.com
Fri Aug 9 13:53:43 UTC 2019
I observed all Modules loading in the last fdt pass.
The reason was, nexus bus loading with BUS_PASS_DEFAULT.
rtemsbsd/rtems/rtems-kernel-nexus.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/rtemsbsd/rtems/rtems-kernel-nexus.c b/rtemsbsd/rtems/rtems-kernel-nexus.c
index 15b0f84d..197f23f6 100644
--- a/rtemsbsd/rtems/rtems-kernel-nexus.c
+++ b/rtemsbsd/rtems/rtems-kernel-nexus.c
@@ -394,4 +394,4 @@ static driver_t nexus_driver = {
static devclass_t nexus_devclass;
-DRIVER_MODULE(nexus, root, nexus_driver, nexus_devclass, 0, 0);
+EARLY_DRIVER_MODULE_ORDERED(nexus, root, nexus_driver, nexus_devclass, 0, 0, SI_ORDER_FIRST, BUS_PASS_BUS);
2.22.0
