sis/gdb on Cygwin
Jiri Gaisler
jiri at gaisler.se
Fri Aug 9 18:34:02 UTC 2019
On 8/9/19 3:24 PM, Joel Sherrill wrote:
> I thought I saw a patch pushed yesterday afternoon but a fresh build
> today shows the same
> breakage.
> Jiri .. feel free to push a fix for this and I will test when I get back.
The problem right now is that RSB has some breakage which causes the
stand-alone version of sis not to be installed. If I push the patch,
then no sis at all will be installed. I will try to find some time to
look at the cygwin build problem, until Chris gets some time to look at
the RSB issue ...
> On Thu, Aug 8, 2019 at 2:37 PM Joel Sherrill <joel at rtems.org
> <mailto:joel at rtems.org>> wrote:
> This is really easy to fix and hopefully Jiri can produce a patch
> since I am about to leave for the weekend.
> The git master has this in erc32 configure.ac
> <http://configure.ac>. It should be in both sis/configure.ac
> <http://configure.ac> and erc32/configure.ac <http://configure.ac>
> in our gdb 8.2.1 with patches.
> # Keep in sync with gdb's configure.ac <http://configure.ac> list.
> AC_SEARCH_LIBS(tgetent, [termcap tinfo curses ncurses],
> [TERMCAP=$ac_cv_search_tgetent], [TERMCAP=""])
> if test x$sim_cv_os_cygwin = xyes; then
> TERMCAP="${TERMCAP} -luser32"
> fi
> AC_SUBST(TERMCAP)
> The gdb version we are using has some old hack-ish code specific
> to Cygwin and termcap which is
> now not needed. Unfortunately, that same code is in
> sis/configure.ac <http://configure.ac>.
> Please and thank you. :)
> --joel
> On Wed, Aug 7, 2019 at 8:37 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 8/8/19 5:46 am, Joel Sherrill wrote:
> > On Wed, Aug 7, 2019 at 2:33 PM Jiri Gaisler <jiri at gaisler.se
> <mailto:jiri at gaisler.se>
> > <mailto:jiri at gaisler.se <mailto:jiri at gaisler.se>>> wrote:
> > On 8/7/19 8:22 PM, Joel Sherrill wrote:
> > > Hi
> > > Looks like Cygwin has libncurses but doesn't install
> the libtermcap.
> > > compatibility library.
> > > https://cygwin.com/ml/cygwin/2010-10/msg00018.html
> says to link
> > > against ncurses.
> > > gdb-8.2.1/sim/sis/../.. `echo -Dsparc-rtems5 | sed
> s/-rtems.//` -I.
> > > -I../../../gdb-8.2.1/sim/sis -I../common
> > > -I../../../gdb-8.2.1/sim/sis/../common -I../../include
> > > -I../../../gdb-8.2.1/sim/sis/../../include -I../../bfd
> > > -I../../../gdb-8.2.1/sim/sis/../../bfd -I../../opcodes
> > > -I../../../gdb-8.2.1/sim/sis/../../opcodes -g -O2 -o
> sis \
> > > sis.o exec.o erc32.o func.o help.o float.o grlib.o
> leon3.o leon2.o
> > > ../../bfd/libbfd.a ../../opcodes/libopcodes.a
> > > ../../libiberty/libiberty.a -L../../zlib -lz
> > > ../../readline/libreadline.a `if test -r
> > > ../../libtermcap/libtermcap.a; then echo
> > > ../../libtermcap/libtermcap.a; else echo -ltermcap;
> fi` -luser32 -lm
> /usr/lib/gcc/x86_64-pc-cygwin/7.3.0/../../../../x86_64-pc-cygwin/bin/ld:
> > > cannot find -ltermcap
> > > collect2: error: ld returned 1 exit status
> > > Is the solution to just add -lncurses to the list of
> libraries it
> > > looks for?
> > > Hopefully someone has some insight into this one.
> > How about a patch that disables building sis inside gdb
> and only use the
> > newer stand-alone sis version?
> +1
> > As long as the rtems tester supports it, I am cool with that.
> It should. Please find the existing `sis` run or gdb INI
> configuration files and
> replace with SIS. I suspect you can get down to one INI config
> rather than the
> run and gdb versions we currently have.
> > My goal is to begin to do regular builds and test sweeps on
> Cygwin
> > and Mingw and report to build at . So the RSB and tester need
> to work. :)
> Nice.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190809/ddacc144/attachment.html>
