RISC-V Test Results
Sun Aug 11 06:51:02 UTC 2019
On 9/8/19 9:47 pm, Sebastian Huber wrote:
> On 08/08/2019 15:33, Joel Sherrill wrote:
>> Hi
>> If you are subscribed to the build@ mailing list, then you saw the flurry of test
>> results from over night. I built every variant and ran the test suite with RTEMS
>> debug on and off.  Here are some observations:
>> + rv64imafd only has one test pass
>> + rv64_iamd_medany only has one test pass
>> + Generally speaking, 17-19 tests failed or timed out on every variant with
>>     551-553 passing. It would be great for someone to mark the tests in the
>>     tcfg files as expected fails.
> The BSP runs on hardware and simulators.
Interesting.
> Some test may pass on real hardware.
Sure.
> So, marking them as expected fails is not right.
Agreed. I expect to see regressions in simulator from time to time so hardware
is a only way we can validate our test results.
If a BSP can run on both hardware and simulation the hardware results should
have precedent over simulation. This means the we tag against the hardware
results in this case.
