[PATCH] user/exe: Add link reference in device-tree
Christian Mauderer list at c-mauderer.de
Sun Aug 11 15:24:58 UTC 2019
Pushed. Thanks for the fix.
Gedare mentioned that you should be on the copyright list of the user
manual (see [1]). Can you please create a patch for that too?
Best regards
Christian
[1]: https://lists.rtems.org/pipermail/devel/2019-August/027204.html
On 09/08/2019 10:06, Vijay Kumar Banerjee wrote:
>  user/bsps/arm/beagle.rst | 2 +-
>  user/exe/device-tree.rst | 2 ++
>  2 files changed, 3 insertions(+), 1 deletion(-)
> diff --git a/user/bsps/arm/beagle.rst b/user/bsps/arm/beagle.rst
> index 6c8796b..87c6ecf 100644
> --- a/user/bsps/arm/beagle.rst
> +++ b/user/bsps/arm/beagle.rst
> @@ -40,7 +40,7 @@ from the libbsd HEAD of freebsd-org. For example if the HEAD is at
>  Then the right Device Tree Source (DTS) file is:
>  https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/gnu/dts/arm/am335x-boneblack.dts
> -Please refer to the :ref:`device-tree` to know more about building and applying
> +Please refer to the :ref:`DeviceTree` to know more about building and applying
>  the Device Trees.
>  Writing the uEnv.txt file
> diff --git a/user/exe/device-tree.rst b/user/exe/device-tree.rst
> index bd21552..d6a4378 100644
> --- a/user/exe/device-tree.rst
> +++ b/user/exe/device-tree.rst
> @@ -2,6 +2,8 @@
>  .. Copyright (C) 2019 Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> +.. _DeviceTree:
>  Device Tree
>  .. index:: Device Tree
