RSB build error (MSYS2)
jameszxj jameszxj at gmail.com
Mon Aug 12 01:19:52 UTC 2019
Hi,
I tried to update the compiler to RSB master, and encountered an error.
command line:
   ../source-builder/sb-set-builder --dry-run --with-download 5/rtems-arm
error messgae:
config: tools/rtems-gdb-8.2.1-1.cfg
error: shell macro failed: sh -c "/mingw64/bin/python2-config --ldflags | awk 'BEGIN{FS=" "}/python/{for(i=1;i<NF;++i)if(match($i,".*lpython.*")) print "lib"substr($i,3)"*";}'": 1: }/python/{for(i=1;i<NF;++i)if(match($i,.*lpython.*)) print libsubstr($i,3)*;}': -c: line 0: unexpected EOF while looking for matching `''
}/python/{for(i=1;i<NF;++i)if(match($i,.*lpython.*)) print libsubstr($i,3)*;}': -c: line 1: syntax error: unexpected end of file
Build FAILED
Build Set: Time 0:00:47.324763
Build FAILED
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190812/bf265dbd/attachment.html>
