RSB build error (MSYS2)
Mon Aug 12 01:33:51 UTC 2019
On 12/8/19 11:19 am, jameszxj wrote:
> Hi,
> I tried to update the compiler to RSB master, and encountered an error.
> command line:
>    ../source-builder/sb-set-builder --dry-run --with-download 5/rtems-arm
> error messgae:
> config: tools/rtems-gdb-8.2.1-1.cfg
> error: shell macro failed: sh -c "/mingw64/bin/python2-config --ldflags | awk
> 'BEGIN{FS=" "}/python/{for(i=1;i<NF;++i)if(match($i,".*lpython.*")) print
> "lib"substr($i,3)"*";}'": 1:
> }/python/{for(i=1;i<NF;++i)if(match($i,.*lpython.*)) print libsubstr($i,3)*;}':
> -c: line 0: unexpected EOF while looking for matching `''
> -c: line 1: syntax error: unexpected end of file
> Build FAILED
> Build Set: Time 0:00:47.324763
> Build FAILED
Can you please create a ticket for this?
Thanks
