[PATCH] rtems/rtems-kernel-nexus.c: LibBSD init now uses all pass levels.
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Aug 12 05:41:08 UTC 2019
On 12/08/2019 00:23, Chris Johns wrote:
> On 10/8/19 4:33 am, Christian Mauderer wrote:
>> thanks for the patch. It sounds like we will get a behaviour that is
>> more similar to FreeBSD one with it.
> Yes.
>> But it has the potential to have a
>> big influence on existing BSPs so it would be good to have some more
>> feedback for it before merging it.
> Do you have specific BSPs in mind? If we agree this behaviour is more like
> FreeBSD would that mean a BSP that breaks needs to be fixed?
> Chris
Hello Chris,
I would consider a BSP broken that has a problem with the change. So
yes: It should be fixed in that case.
I haven't had a specific BSP in mind. Every BSP that currently uses an
EARLY.*MODULE would be an candidate. Luckily it's not that many:
> grep "EARLY.*MODULE" -r --exclude-dir=freebsd-org . -l
./freebsd/sys/sys/bus.h
./freebsd/sys/dev/iicbus/ofw_iicbus.c
./freebsd/sys/dev/pci/pci_pci.c
./freebsd/sys/dev/pci/pci.c
./freebsd/sys/dev/gpio/ofw_gpiobus.c
./freebsd/sys/dev/gpio/gpiobus.c
./freebsd/sys/dev/ofw/ofwbus.c
./freebsd/sys/dev/fdt/simplebus.c
./freebsd/sys/arm/freescale/imx/imx_gpio.c
./freebsd/sys/arm/ti/am335x/am335x_prcm.c
./freebsd/sys/arm/ti/ti_scm.c
So: BBB, i.MX, everything using PCI
It's not that much and most are active ones. So it shouldn't be a
problem as long as the maintainers of these BSPs know that they should
take a look at that if they have strange problems. Beagle is covered by
Nils' work. For i.MX and some PCI BSPs we should give Sebastian a hint
(just added him on CC). I'm not sure who else uses PCI. Maybe x86?
Best regards
Christian
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
