GSoC Project | Basic Support for Trace Compass
Mon Aug 12 10:55:58 UTC 2019
On 12/08/2019 12:27, Ravindra Kumar Meena wrote:
>     This is too complicated:
>     +    strcpy( filename, "event_" );
>            snprintf( file_index, sizeof( file_index ), "%ld", i );
>            strcat( filename, file_index );
>     In addition, the strcpy() and strcat() functions are dangerous to use.
>     Why don't you simply use:
>     snprintf( filename, sizeof( filename ), "event_%zu", i );
>     The i is of type size_t, so %ld is not the right format. Firstly, the
>     signedness is wrong, secondly using "l" is not portable.
> Okay
> https://github.com/rmeena840/rtems-tools/commit/1ffbe7d5dcea741a3e7ceec8ded869d38c20081f
> Have a look.
> What's the procedure for getting code merged? Do I have to raise PR on
> GitHub or simply send a patch on devel?
First we have to integrate the initial support for the rtems-record program:
https://lists.rtems.org/pipermail/devel/2019-August/027278.html
Then you can rebase your work on top of it and send a single patch to
devel at rtems.org for the normal patch review.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
