Chapter/section numbers in document internal references
Mon Aug 12 14:06:13 UTC 2019
On 08/08/2019 08:52, Sebastian Huber wrote:
> On 06/08/2019 10:23, Sebastian Huber wrote:
>> On 06/08/2019 10:05, Chris Johns wrote:
>>> On 6/8/19 4:36 pm, Sebastian Huber wrote:
>>>> Hello,
>>>> when you use document internal references, e.g.
>>>> :ref:`RSB`
>>>> then this is turned into:
>>>> "Chapter 12 - RTEMS Source Builder"
>>>> I think this "Chapter 12 - " prefix makes it harder to read the
>>>> document. In a
>>>> default configuration of Sphinx this stuff is not included. Would it
>>>> be possible
>>>> to remove this from the RTEMS customization?
>>> What are you suggesting instead? Could you put something online so I
>>> could compare?
>>> I did play around with this but I cannot remember all the variations
>>> and why I
>>> selected this one.
>> To see the default behaviour, please create a new document with
>> sphinx-quickstart and copy the attached index.rst over the default.
>> Run "make latexpdf".
>> On page 1 you see "See Section.". With the RTEMS style you would
>> probably see "See Chapter 1 - Section".
> Here is an example in the RTEMS style:
> https://docs.rtems.org/branches/master/user/support/bugs.html
> I think the "Chapter/Section X" prefix makes it harder to read.
I manage to figure out where this comes from:
common/rtemsext.py
Could we please remove this?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
