rtems-tester with griscv
Joel Sherrill
joel at rtems.org
Mon Aug 12 22:04:00 UTC 2019
On Mon, Aug 12, 2019 at 4:23 PM Jiri Gaisler <jiri at gaisler.se> wrote:
> You should probably use --rtems-bsp=griscv-sis . The griscv bsp uses the
> (now deleted) built-in sis in gdb...
Thanks. That seems to have worked.
<dreading finding all the getting started instructions that show using the
sis inside gdb and fixing them>
--joel
> I am preparing a patch to purge the stale tester bsps ...
> Jiri.
> On 8/12/19 8:22 PM, Joel Sherrill wrote:
> Hi
> Running riscv-rtems5-sis by hand, hello.exe runs. But when I try it with
> rtems-tester, nothign passes and the tester hangs. I killed python after
> about 30 minutes of CPU time.
> + /home/joel/rtems-work/rtems-tools//tester/rtems-test
> --rtems-tools=/home/joel/rtems-work/tools/5 --rtems-bsp=griscv
> --log=run.log .
> RTEMS Testing - Tester, 5 (30a5cd65cc54)
> [ 1/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv:
> base_sp.exe
> [ 8/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv:
> nsecs.exe
> [ 2/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv:
> capture.exe
> [ 6/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv:
> hello.exe
> [ 5/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv:
> fileio.exe
> [ 4/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv:
> cxx_iostream.exe
> [ 3/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv:
> cdtest.exe
> [10/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv:
> ticker.exe
> [ 7/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv:
> minimum.exe
> [ 9/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv:
> paranoia.exe
> [11/11] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | riscv/griscv:
> unlimited.exe
> ^Cabort: user terminated
> Any ideas?
> Thanks.
> --joel
> devel mailing listdevel at rtems.orghttp://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190812/ae0c4086/attachment.html>
