PRU libBSD shell command "pructl"
Nils Hölscher nilhoel1 at gmail.com
Tue Aug 13 13:52:15 UTC 2019
Hi,
Last time we discussed about the PRU-Shell command, we decided it should be
realised as a libBSD shell command.
The reason was the driver being located in libBSD.
I tried developing the command in my App first.
But this would be more work, than just directly developing in libBSD.
So my questions are:
Where should I locate the libpru and pructl files?
Will be porting from these repos, they are actually programs for FreeBSD.
https://bitbucket.org/rpaulo/pructl/src/default/
https://bitbucket.org/rpaulo/libpru/src/default/
Also I would like to ask, where to register the command?
I saw the netcmds-config.h
<https://github.com/RTEMS/rtems-libbsd/blob/4ed60d9076b23307cc86da136562cdc741370d50/rtemsbsd/include/rtems/netcmds-config.h>
and
similar files but I am not sure where the pructl command would go.
Thanks,
Nils
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190813/fbfe880c/attachment.html>
