Chapter/section numbers in document internal references
Tue Aug 13 17:31:02 UTC 2019
----- Am 13. Aug 2019 um 19:05 schrieb Gedare Bloom gedare at gwmail.gwu.edu:
> If you can make different rules for HTML than PDF, the Chapter part could
> be omitted in HTML since one will expect the link to work. PDF should be
> usable even without links.
> I'd change it to use for example "Chapter 3.3" format of Ch#.Sec#.subsec#.
> this is more like a textbook reference then.
I am in favour of the standard Sphinx latex_show_pagerefs option:
https://lists.rtems.org/pipermail/devel/2019-August/027308.html
