RTEMS 5 gcc-fb371a33fa6 vs gcc-9.2.0
Wed Aug 14 05:02:26 UTC 2019
On 14/08/2019 01:52, Chris Johns wrote:
> On 13/8/19 3:02 pm, Sebastian Huber wrote:
>> the patch just changed GCC 9.1 to 9.2 on all targets which use GCC 9, these are
>> or1k, riscv, and x86_64.
> The change as broken MacOS due to this bug ...
> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81797
> I posted build results showing the error is still present. I had a patch in the
> previous version and it should apply.
Now I am a bit confused. This patch
https://git.rtems.org/rtems-source-builder/commit/?id=5a0dba77b13eec49f86ce3812fb74f65dfa1e98d
changes the GCC version from 9.1.0 to 9.2.0 on or1k, riscv, and x86_64.
I didn't change the patches:
https://git.rtems.org/rtems-source-builder/tree/rtems/config/tools/rtems-gcc-9.1.0-newlib-6661a67.cfg?id=5a0dba77b13eec49f86ce3812fb74f65dfa1e98d
The GCC bug doesn't seem to be a GCC 9.1.0 to 9.2.0 regression. In your
build log only riscv failed, or1k and x86_64 passed. Is this a sporadic
problem?
>> Since there will be probably no RTEMS 5 in the near future, maybe we should move
>> to GCC 9.2 in general.
> This is a catch-22, I hope to start on the release process soon but things like
> this add to the complexity and add to the time it takes.
>> If we do this on PowerPC, then the SPE is no longer supported.
> Joel has stated many times in talks I have seen that we follow the architectures
> GCC supports and if one is removed we remove support.
> Does this mean 5.1 is the last version of RTEMS to support SPE?
This was my plan.
> Should the specific BSPs be moved to tier 4 and marked for removal?
The SPE support should bit rot for a while. The chips are still in
production and used with RTEMS, e.g. by EPICS users.
>> On ARM a breaking change in compiler options is necessary.
> What options are these?
ARM changed the FPU options in GCC 8 and later.
> Also this seems back to front to me. Should all hosts be on 9.2.0 and those that
> cannot have specific versions?
Only PowerPC should stay at GCC 7 until the next RTEMS release from my
point of view. Everything else can move on.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
