GSoC 2019: POSIX Compliance - FENV Environment probably not working properly in RISCV
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Wed Aug 14 12:54:36 UTC 2019
On Wed, Aug 14, 2019 at 6:22 PM Hesham Almatary <heshamelmatary at gmail.com>
wrote:
> On Sun, 11 Aug 2019 at 16:49, Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > Configure command I used to build BSP:
> > $ /home/varodek/development/rtems/kernel/rtems/configure
> --prefix=/home/varodek/development/rtems/5 --enable-maintainer-mode
> --target=riscv-rtems5 --enable-rtemsbsp=rv32imac --enable-tests
> --enable-posix --disable-networking --enable-cxx RISCV_ENABLE_HTIF_SUPPORT=1
> RISCV_ENABLE_HTIF_SUPPORT=1 should only be used if you're going to run
> on a Spike platform. I see you're using virt below
Yah this was the time I was doing all kind of experiments to run the hello
world thing.
I have disabled HTIF now.
> > Qemu command I used to run test:
> > $ qemu-system-riscv32 -no-reboot -nographic -machine virt -m 256M
> -kernel psxfenv01.exe
> > Makefile.am
> > + if TEST_psxfenv01
> > + psx_tests += psxfenv01
> > + psxfenv01_SOURCES = psxfenv01/init.c
> > + psxfenv01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxfenv01) \
> > + $(support_includes)
> > + psxfenv01_LDADD = -lm $(LDADD)
> > + endif
> > On Sun, Aug 11, 2019 at 8:36 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >> My code of testsuite:
> >> /* Test 'FE_DIVBYZERO' */
> >> puts( "\nDivide by zero and confirm fetestexcept()." );
> >> a = 0.0;
> >> b = 1.0;
> >> c = b/a;
> >> printf("\n%d",FE_DIVBYZERO);
> >> fegetexceptflag(&excepts,FE_ALL_EXCEPT);
> >> printf("\n%d",excepts);
> >> r = feraiseexcept(FE_DIVBYZERO);
> >> printf("\n%d\n",r);
> >> rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
> >> OUTPUT
> >> 8
> >> 0
> >> 1
> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/psxtests/psxfenv01/init.c:
> 84 fetestexcept( FE_DIVBYZERO )
> >> EXPECTED OUTPUT
> >> 8
> >> 8
> >> 0
> >> - fetestexcept( FE_DIVBYZERO ), should return a non-zero value as
> division-by-zero was performed.
> >> - feraiseexcept(FE_DIVBYZERO); is also not working. It should return
> zero when successful
> >> Thank You
> >> Vaibhav Gupta
> > devel mailing list
> > devel at rtems.org
> Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190814/0f587224/attachment.html>
