GSoC 2019: POSIX Compliance - FENV Environment probably not working properly in RISCV
Wed Aug 14 14:39:11 UTC 2019
On Wed, Aug 14, 2019 at 9:35 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
> You are also getting same error :(
> I thought problem is with my system/laptop and was trying to correct things.
> Should we take the discussion to newlib?
I would like Jiri and Hesham to chime in on the next step. I don't
know the RISC-V
well enough to say if this is a bug in risc-v fenv or not.
Keep plugging at another architecture.
--joel
> Vaibhav Gupta
> On Wed, Aug 14, 2019 at 7:51 PM Joel Sherrill <joel at rtems.org> wrote:
>> I ran it on sis built from the git repository. Unfortunately, the output doesn't match that I got on Linux.
>> $ ~/sis-riscv/install/bin/sis -riscv -gdb
>>  SIS - SPARC/RISCV instruction simulator 2.17,  copyright Jiri Gaisler 2019
>>  Bug-reports to jiri at gaisler.se
>>  RISCV emulation enabled, 1 cpus online, delta 50 clocks
>> gdb: listening on port 1234 connected
>> X40000000,0:#72
>> *** BEGIN OF TEST PSXFENV 01 ***
>> *** TEST VERSION: 5.0.0.a4d7e4cee77d16b0e34ef543f0804e7eb2954137
>> *** TEST STATE: EXPECTED-PASS
>> *** TEST BUILD: RTEMS_POSIX_API
>> *** TEST TOOLS: 9.1.0 20190503 (RTEMS 5, RSB be90fb89678206e469f2f9189eb290cec49fd827, Newlib 6661a67)
>> Divide by zero and confirm fetestexcept().
>> 8
>> 0
>> 1
>> *** END OF TEST PSXFENV 01 ***
>> *** FATAL ***
>> fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
>> fatal code: 0 (0x00000000)
>> RTEMS version: 5.0.0.a4d7e4cee77d16b0e34ef543f0804e7eb2954137
>> RTEMS tools: 9.1.0 20190503 (RTEMS 5, RSB be90fb89678206e469f2f9189eb290cec49fd827, Newlib 6661a67)
>> executing thread ID: 0x08a010001
>> executing thread name: UI1
>> On Wed, Aug 14, 2019 at 7:55 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>>> On Wed, Aug 14, 2019 at 6:22 PM Hesham Almatary <heshamelmatary at gmail.com> wrote:
>>>> On Sun, 11 Aug 2019 at 16:49, Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>>>> > Configure command I used to build BSP:
>>>> > $ /home/varodek/development/rtems/kernel/rtems/configure --prefix=/home/varodek/development/rtems/5 --enable-maintainer-mode --target=riscv-rtems5 --enable-rtemsbsp=rv32imac --enable-tests --enable-posix --disable-networking --enable-cxx RISCV_ENABLE_HTIF_SUPPORT=1
>>>> RISCV_ENABLE_HTIF_SUPPORT=1 should only be used if you're going to run
>>>> on a Spike platform. I see you're using virt below
>>> Yah this was the time I was doing all kind of experiments to run the hello  world thing.
>>> I have disabled HTIF now.
>>>> > Qemu command I used to run test:
>>>> > $ qemu-system-riscv32 -no-reboot -nographic -machine virt -m 256M -kernel psxfenv01.exe
>>>> > Makefile.am
>>>> > + if TEST_psxfenv01
>>>> > + psx_tests += psxfenv01
>>>> > + psxfenv01_SOURCES = psxfenv01/init.c
>>>> > + psxfenv01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxfenv01) \
>>>> > +       $(support_includes)
>>>> > + psxfenv01_LDADD = -lm $(LDADD)
>>>> > + endif
>>>> > On Sun, Aug 11, 2019 at 8:36 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>>>> >> My code of testsuite:
>>>> >>   /* Test 'FE_DIVBYZERO' */
>>>> >>   puts( "\nDivide by zero and confirm fetestexcept()." );
>>>> >>   a = 0.0;
>>>> >>   b = 1.0;
>>>> >>   c = b/a;
>>>> >>   printf("\n%d",FE_DIVBYZERO);
>>>> >>   fegetexceptflag(&excepts,FE_ALL_EXCEPT);
>>>> >>   printf("\n%d",excepts);
>>>> >>   r = feraiseexcept(FE_DIVBYZERO);
>>>> >>   printf("\n%d\n",r);
>>>> >>   rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
>>>> >> OUTPUT
>>>> >> 8
>>>> >> 0
>>>> >> 1
>>>> >> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/psxtests/psxfenv01/init.c: 84 fetestexcept( FE_DIVBYZERO )
>>>> >> EXPECTED OUTPUT
>>>> >> 8
>>>> >> 8
>>>> >> 0
>>>> >> - fetestexcept( FE_DIVBYZERO ), should return a non-zero value as division-by-zero was performed.
>>>> >> - feraiseexcept(FE_DIVBYZERO); is also not working. It should return zero when successful
>>>> >> Thank You
>>>> >> Vaibhav Gupta
>>>> > _______________________________________________
>>>> > devel mailing list
>>>> > devel at rtems.org
>>>> > http://lists.rtems.org/mailman/listinfo/devel
>>>> Hesham
>>> devel mailing list
>>> devel at rtems.org
