[PATCH 1/2] sb/download: Add support for a base64 hash string
chrisj at rtems.org chrisj at rtems.org
Thu Aug 15 03:44:39 UTC 2019
 source-builder/sb/download.py | 10 ++++++++--
 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/source-builder/sb/download.py b/source-builder/sb/download.py
index d8061e6..1fb0155 100644
--- a/source-builder/sb/download.py
+++ b/source-builder/sb/download.py
@@ -24,6 +24,7 @@
 from __future__ import print_function
+import base64
 import hashlib
 import os
 import re
@@ -110,8 +111,13 @@ def _hash_check(file_, absfile, macros, remove = True):
             raise
         if _in is not None:
             _in.close()
-        log.output('checksums: %s: %s => %s' % (file_, hasher.hexdigest(), hash[1]))
-        if hasher.hexdigest() != hash[1]:
+        hash_hex = hasher.hexdigest()
+        hash_base64 = base64.b64encode(hasher.digest()).decode('utf-8')
+        log.output('checksums: %s: (hex: %s) (b64: %s) => %s' % (file_,
+        hash_hex,
+        hash_base64,
+        hash[1]))
+        if hash_hex != hash[1] and hash_base64 != hash[1]:
             log.warning('checksum error: %s' % (file_))
             failed = True
         if failed and remove:
2.20.1
