[PATCH v1] Add steps to test Newlib patch.
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Thu Aug 15 19:32:40 UTC 2019
On Thu, Aug 15, 2019 at 8:51 PM Gedare Bloom <gedare at rtems.org> wrote:
> Is this a duplicate of the other "patch v1 Add steps to test Newlib
> patch." or this one replaces it?
This one replaces it. Actually I replaced all the previous ones with mine.
The commands, steps I have written are based on what worked for me for
number of times.
I build the toolchain twice when RSB got updated, but my changes were not
pushed so had to
use patches in RSB. And these steps worked perfectly both times.
-Vaibhav
> On Wed, Aug 14, 2019 at 11:45 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> Update the checksum to be used for the Newlib patches.
>> Earlier it was msd5, but it is depreciated for security
>> reasons. Now RSB accepts sha512.
>> user/rsb/project-sets.rst | 41 +++++++++++++++++++++++++++++++++------
>> 1 file changed, 35 insertions(+), 6 deletions(-)
>> diff --git a/user/rsb/project-sets.rst b/user/rsb/project-sets.rst
>> index 5ffce26..b01857e 100644
>> --- a/user/rsb/project-sets.rst
>> +++ b/user/rsb/project-sets.rst
>> @@ -261,17 +261,46 @@ in the ``source-builder/config`` template
>> configuration files.
>> To test a patch simply copy it to your local ``patches`` directory. The
>> RSB
>> will see the patch is present and will not attempt to download it. Once
>> you are
>> happy with the patch submit it to the project and a core developer will
>> review
>> -it and add it to the RTEMS Tools git repository. For example, to test a
>> local
>> -patch for newlib, add the following two lines to the .cfg file in
>> -``rtems/config/tools/`` that is included by the bset you use:
>> +it and add it to the RTEMS Tools git repository.
>> +Testing a Newlib Patch
>> +To test a local patch for newlib, you need to add the following
>> +two lines to the ``.cfg`` file in ``rsb/rtems/config/tools/`` that is
>> included
>> +by the bset you use:
>> +.. topic:: Steps:
>> + 1. Create patches for the changes you want to test. (Note: For RSB,
>> before
>> + creating Newlib patch, you must run ``autoreconf -fvi`` in the
>> required
>> + directory after you make changes to the code. This is not required
>> when
>> + you create patch to send to ``newlib-devel``. But if you want RSB
>> to
>> + address your changes, your patch should also include regenerated
>> files.)
>> + 2. Calculate ``sha512`` of your patch.
>> + 3. Place the patches in ``rsb/rtems/patches`` directory.
>> + 4. Open the ``.bset`` file used by your BSP in ``rsb/rtems/config``.
>> + For example, for ``rtems5``, ``SPARC``, the file will be
>> + ``rsb/rtems/config/5/rtems-sparc.bset``.
>> + 5. Inside it you will find the name of ``.cfg`` file for Newlib, used
>> by
>> + your BSP.
>> + For example, I found ``tools/rtems-gcc-7.4.0-newlib-1d35a003f``.
>> + 6. Edit your ``.cfg`` file. In my case it will be,
>> + ``rsb/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg``. And
>> + add the information about your patch as mentioned below.
>> .. code-block:: spec
>> - %patch add newlib file://0001-this-is-a-newlib-patch.patch <1>
>> - %hash md5 0001-this-is-a-newlib-patch.diff
>> 77d070878112783292461bd6e7db17fb <2>
>> + %patch add newlib -p1 file://0001-Port-ndbm.patch <1>
>> + %hash sha512 0001-Port-ndbm.patch
>> 7d999ceeea4f3dc82e8e0aadc09d983a7a68b44470da8a3d61ab6fc558fdba6f2c2de3acc2f32c0b0b97fcc9ab799c27e87afe046544a69519881f947e7881d1
>> <2>
>> .. topic:: Items:
>> 1. The diff file prepended with ``file://`` to tell RSB this is a
>> local file.
>> - 2. The output from md5sum on the diff file.
>> + 2. The output from sha512sum on the patch file.
>> 2.21.0
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190816/9961c5b3/attachment-0001.html>
