[PATCH] dtc.bset: update to 1.4.1 to match qemu
Thu Aug 15 21:39:23 UTC 2019
On 16/8/19 1:24 am, Gedare Bloom wrote:
> FWIW: I had to build dtc by hand recently. It might be worth it to
> work up an RSB script for host tooling to help users/developers work
> with DT.
There is support ...
https://git.rtems.org/rtems-source-builder/tree/bare/config/devel/dtc.bset
The version in the buildset is not 1.4.1. To use ...
 cd bare
 ../source-builder/sb-setbuilder --prefix=/x/y/z devel/dtc
The issue I had was building it on Windows. In the end I settled on using the
msys2 (cygwin) build.
