Mounting/Accessing SD-Card on BBB
Christian Mauderer list at c-mauderer.de
Fri Aug 16 09:03:09 UTC 2019
On 16/08/2019 10:55, Nils Hölscher wrote:
> Hi,
> It seems the problem was hardware related.
> My SD-Card connector just died.
> I hope I can get a new BBB oin a timely manner.
> Best,
> Nils
Hello Nils,
thanks for the information. That's annoying. Good luck finding a
replacement.
For a quick workaround: I haven't tried that yet but if your on-board
eMMC is still intact, you might can use that U-Boot to boot from USB.
Best regards
Christian
> On Fri, 16 Aug 2019 at 10:48, Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
>     Hello Nils,
>     thanks for the file list. I can't reproduce your problem with it.
>     On 16/08/2019 10:01, Nils Hölscher wrote:
>     > Hi,
>     > Short update.
>     > It seems the device only hangs while I am connected with the debugger.
>     Is that true for the original file system tree? You are debugging via
>     Ethernet, right? In that case I would lean more toward a problem with
>     the debugger support than the file system. Do you have enough file
>     descriptors configured?
>     Best regards
>     Christian
>     > looks like a Heisenberg bug.
>     > Best,
>     > Nils
>     > On Fri, 16 Aug 2019 at 09:50, Nils Hölscher <nilhoel1 at gmail.com
>     <mailto:nilhoel1 at gmail.com>
>     > <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>> wrote:
>     >     On Thu, 15 Aug 2019 at 19:51, Christian Mauderer
>     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>     >         Hello Nils,
>     >         maybe another bug in our FAT file system...
>     >         Please do three things:
>     >         1. Create an image of your current card (with dd or a similar
>     >         tool). FAT
>     >         bugs are sometimes hard to reproduce but it's really
>     urgent that
>     >         we fix
>     >         them. So maybe I'll ask for that image later.
>     >     I did that.
>     >     Let me know if you need the image.
>     >         2. Create a complete list of the files on your card (for
>     example the
>     >         Linux `tree -h` command), post it here and tell me what you
>     >         tried to open.
>     >     ├── [ 50K]  am335x-boneblack.dtb
>     >     ├── [ 49K]  am335x-boneblack+pruss.dtb
>     >     ├── [ 883]  AM335X-PRU-UIO-00A0.dtbo
>     >     ├── [ 649]  AM335X-PRU-UIO-BSD-00A0.dtbo
>     >     ├── [162K]  Linux-with-UIO.dtb
>     >     ├── [  44]  loob.bin
>     >     ├── [108K]  MLO
>     >     ├── [2.1M]  pru.exe.img
>     >     ├── [  12]  test.bin
>     >     ├── [471K]  u-boot.img
>     >     ├── [ 390]  uEnvLinuxfdt.txt
>     >     └── [ 560]  uEnv.txt
>     >          3. Try another name / folder for the file you wanted to
>     open.\
>     >     I moved the file in another folder and renamed it.
>     >     It now works but I got en error, I am currently investigating if
>     >     this is on the pru driver side or not.
>     >     The tree while doing this was:
>     >     ├── [  44]  loob.bin
>     >     ├── [108K]  MLO
>     >     ├── [2.0K]  test
>     >     │   └── [  12]  test2.bin
>     >     ├── [  12]  test2.bin
>     >     └── [ 560]  uEnv.txt
>     >     Thanks,
>     >     Nils
>     >         Best regards
>     >         Christian
>     >         On 15/08/2019 19:32, Nils Hölscher wrote:
>     >         > Hi Christian,
>     >         > The commands ls and cat work.
>     >         > I just tested them, this seems kinda awkward.
>     >         > Best,
>     >         > Nils
>     >         > On Thu, 15 Aug 2019 at 19:27, Christian Mauderer
>     >         > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>     >         >     Hello Nils,
>     >         >     does some other access to the file system work? Like
>     a ls
>     >         on the console
>     >         >     or creating a file. Can you do a `cat` on some text file
>     >         on the file
>     >         >     system? If not: Does it work for a file in the root file
>     >         system (should
>     >         >     be a IMFS)?
>     >         >     Best regards
>     >         >     Christian
>     >         >     On 15/08/2019 15:54, Nils Hölscher wrote:
>     >         >     > Hi,
>     >         >     > I when my app wants to open a file on the SD card
>     >         dev=mmcsd-0-0 rtems
>     >         >     > freezes.
>     >         >     > Exact call is:
>     >         >     > fd = open(file, O_RDONLY);
>     >         >     > With file being the pru binary I want to upload.
>     >         >     > Thanks,
>     >         >     > Nils
>     >         >     > On Tue, 13 Aug 2019 at 17:56, Christian Mauderer
>     >         >     > <christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>
>     <mailto:christian.mauderer at embedded-brains.de>>
>     >         >     <mailto:christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>>>
>     >         >     > <mailto:christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>>>>> wrote:
>     >         >     >     Hello Nils,
>     >         >     >     a third possibility: You could start a FTP server
>     >         and push the
>     >         >     file
>     >         >     >     via network.
>     >         >     >     Best regards
>     >         >     >     Christian
>     >         >     >     Am Dienstag, 13. August 2019 schrieb Nils
>     Hölscher:
>     >         >     >     > Hi,
>     >         >     >     > Thanks for the input I will try the SD card
>     first.
>     >         >     >     > That way I won't have to alter the code when I
>     >         want to run other
>     >         >     >     stuff on the pru.
>     >         >     >     > Best,
>     >         >     >     > Nils
>     >         >     >     > On Tue, 13 Aug 2019 at 17:32, Gedare Bloom
>     >         <gedare at rtems.org <mailto:gedare at rtems.org>
>     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>
>     >         >     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>
>     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>
>     >         >     >     <mailto:gedare at rtems.org
>     <mailto:gedare at rtems.org> <mailto:gedare at rtems.org
>     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>> wrote:
>     >         >     >     > You can also build the PRU image into the RTEMS
>     >         binary. See
>     >         >     >     > examples-v2.git/file_io/crc/init.c
>     >         >     >     > On Tue, Aug 13, 2019 at 8:46 AM Christian
>     Mauderer
>     >         >     >     <list at c-mauderer.de
>     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
>     >         >     >     > > Hello Nils,
>     >         >     >     > > that's a bit odd. I attached an expected
>     output
>     >         below.
>     >         >     Some guesses:
>     >         >     >     > > - Did you add FAT file system to your
>     application?
>     >         >     >     > > - Is there some odd formatting on the SD?
>     >         Normally at
>     >         >     least the FAT
>     >         >     >     > > partition used by U-Boot should be visible.
>     >         >     >     > > - Is your BDBUF configuration OK?
>     >         >     >     > > - Do you have enough file descriptors?
>     >         >     >     > > Beneath that: If you only need something where
>     >         you can put
>     >         >     some
>     >         >     >     files,
>     >         >     >     > > you can try to connect a USB stick instead.
>     >         Maybe that
>     >         >     works better.
>     >         >     >     > > Best regards
>     >         >     >     > > Christian
>     >         >     >     > > media listener: event = DISK ATTACH, state =
>     >         INQUIRY, src
>     >         >     = mmcsd
>     >         SUCCESS, src =
>     >         >     >     mmcsd, dest
>     >         >     >     > > = /dev/mmcsd-0
>     >         >     >     > > media listener: event = MOUNT, state =
>     INQUIRY,
>     >         src =
>     >         >     /dev/mmcsd-0
>     >         >     >     > > mmcsd0: 4GB <SDHC TO 15.15 SN 000002F6 MFG
>     >         02/2017 by 25
>     >         >     DY> at mmc0
>     >         >     >     > > 24.0MHz/4bit/65535-block
>     FAILED, src =
>     >         >     /dev/mmcsd-0
>     >         >     >     > > media listener: event = PARTITION INQUIRY,
>     state =
>     >         >     INQUIRY, src =
>     >         >     >     > > /dev/mmcsd-0
>     state =
>     >         >     SUCCESS, src =
>     >         >     >     > > media listener: event = PARTITION ATTACH,
>     state
>     >         = INQUIRY,
>     >         >     src =
>     state
>     >         = SUCCESS,
>     >         >     src =
>     >         >     >     > > /dev/mmcsd-0, dest = /dev/mmcsd-0-0
>     INQUIRY,
>     >         src =
>     >         >     /dev/mmcsd-0-0
>     SUCCESS,
>     >         src =
>     >         >     >     /dev/mmcsd-0-0,
>     >         >     >     > > dest = /media/mmcsd-0-0
>     >         INQUIRY, src
>     >         >     = mmcsd
>     >         SUCCESS, src =
>     >         >     >     mmcsd, dest
>     >         >     >     > > = /dev/mmcsd-1
>     INQUIRY,
>     >         src =
>     >         >     /dev/mmcsd-1
>     >         >     >     > > mmcsd1: 4GB <MMCHC MMC04G 5.8 SN 160D224B MFG
>     >         09/2014 by 112
>     >         >     >     0x0000> at
>     >         >     >     > > mmc1 48.0MHz/8bit/65535-block
>     FAILED, src =
>     >         >     /dev/mmcsd-1
>     state =
>     >         >     INQUIRY, src =
>     >         >     >     > > /dev/mmcsd-1
>     state
>     >         = FAILED,
>     >         >     src =
>     >         INQUIRY, src =
>     >         >     >     mmcsd1boot
>     >         >     >     > > mmcsd1boot0: 2MB partion 1 at mmcsd1
>     >         >     >     > > mmcsd1boot1: 2MB partion 2 at mmcsd1
>     >         >     >     > > mmcsd1rpmb: 131kB partion 3 at mmcsd1
>     >         >     >     > > On 13/08/2019 13:30, Nils Hölscher wrote:
>     >         >     >     > > > Hi,
>     >         >     >     > > > Thanks for the help.
>     >         >     >     > > > I tried to use your code, but I always get
>     >         "ERROR: SD
>     >         >     could not be
>     >         >     >     > > > mounted after timeout".
>     >         >     >     > > > Even after raising the waiting time.
>     >         >     >     > > > The sources I use start here:
>       https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/main.c#L110
>     >         >     >     > > > And my uart output is:
>     >         >     >     > > > waiting for SD...
>     >         >     >     > > > usbus0: 480Mbps High Speed USB v2.0
>     >         >     >     > > > usbus1: 480Mbps High Speed USB v2.0
>     >         >     >     > > > media listener: event = DISK ATTACH, state =
>     >         INQUIRY,
>     >         >     src = mmcsd
>     >         SUCCESS, src =
>     >         >     >     mmcsd, dest
>     >         >     >     > > > = /dev/mmcsd-0
>     >         >     >     > > > media listener: event = MOUNT, state =
>     >         INQUIRY, src =
>     >         >     /dev/mmcsd-0
>     >         >     >     > > > ugen0.1: <Mentor Graphics OTG Root HUB>
>     at usbus0
>     >         >     >     > > > ugen1.1: <Mentor Graphics OTG Root HUB>
>     at usbus1
>     >         >     >     > > > uhub0: <Mentor Graphics OTG Root HUB, class
>     >         9/0, rev
>     >         >     >     2.00/1.00, addr 1>
>     >         >     >     > > > on usbus0
>     >         >     >     > > > uhub1: <Mentor Graphics OTG Root HUB, class
>     >         9/0, rev
>     >         >     >     > > > on usbus1
>     FAILED,
>     >         src =
>     >         >     /dev/mmcsd-0
>     >         >     >     > > > media listener: event = PARTITION
>     INQUIRY, state =
>     >         >     INQUIRY, src =
>     >         >     >     > > > /dev/mmcsd-0
>     INQUIRY, state =
>     >         >     SUCCESS, src =
>     ATTACH, state =
>     >         >     INQUIRY, src =
>     ATTACH, state =
>     >         >     SUCCESS, src =
>     >         >     >     > > > /dev/mmcsd-0, dest = /dev/mmcsd-0-0
>     >         INQUIRY, src =
>     >         >     >     /dev/mmcsd-0-0
>     FAILED,
>     >         src =
>     >         >     >     /dev/mmcsd-0-0
>     >         INQUIRY,
>     >         >     src = mmcsd
>     >         SUCCESS, src =
>     >         >     >     mmcsd, dest
>     >         >     >     > > > = /dev/mmcsd-1
>     >         INQUIRY, src =
>     >         >     /dev/mmcsd-1
>     FAILED,
>     >         src =
>     >         >     /dev/mmcsd-1
>     INQUIRY, state =
>     >         >     INQUIRY, src =
>     >         >     >     > > > /dev/mmcsd-1
>     INQUIRY, state =
>     >         >     SUCCESS, src =
>     ATTACH, state =
>     >         >     INQUIRY, src =
>     ATTACH, state =
>     >         >     SUCCESS, src =
>     >         >     >     > > > /dev/mmcsd-1, dest = /dev/mmcsd-1-0
>     >         INQUIRY, src =
>     >         >     >     /dev/mmcsd-1-0
>     FAILED,
>     >         src =
>     >         >     >     /dev/mmcsd-1-0
>     >         INQUIRY, src =
>     >         >     >     mmcsd1boot
>     >         >     >     > > > uhub0: 1 port with 1 removable, self powered
>     >         >     >     > > > uhub1: 1 port with 1 removable, self powered
>     >         >     >     > > > ERROR: SD could not be mounted after timeout
>     >         >     >     > > > Thanks,
>     >         >     >     > > > Nils
>     >         >     >     > > > On Mon, 12 Aug 2019 at 18:01, Christian
>     Mauderer
>     >         >     >     > > > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
>     >         >     >     > > >     On 12/08/2019 07:28, Nils Hölscher
>     wrote:
>     >         >     >     > > >     > Hi,
>     >         >     >     > > >     > Can anyone help me with this?
>     >         >     >     > > >     > I need to access the BBB's SD-Card, so
>     >         that I can load
>     >         >     >     my pru
>     >         >     >     > > >     example on
>     >         >     >     > > >     > the pru.
>     >         >     >     > > >     > Thanks,
>     >         >     >     > > >     > Nils
>     >         >     >     > > >     Hello Nils,
>     >         >     >     > > >     take a look at the following
>     application:
>         https://gitlab.com/c-mauderer/rtems-bbb/blob/master/apps/wifi-sample/init.c#L64
>         https://gitlab.com/c-mauderer/rtems-bbb/blob/master/apps/wifi-sample/libbsdhelper.c#L122
>     >         >     >     > > >     You should mainly need the stuff
>     from the
>     >         >     >     libbsdhelper_init_sd_card()
>     >         >     >     > > >     and libbsdhelper_wait_for_sd().
>     >         >     >     > > >     Please note that the SD card needs quite
>     >         some time to
>     >         >     >     initialize on BBB.
>     >         >     >     > > >     I haven't had a look at it why that
>     is the
>     >         case.
>     >         >     >     > > >     Best regards
>     >         >     >     > > >     Christian
>     _______________________________________________
>     >         >     >     > > > users mailing list
>     >         >     >     > > > users at rtems.org <mailto:users at rtems.org>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>
>     >         >     <mailto:users at rtems.org <mailto:users at rtems.org>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>
>     http://lists.rtems.org/mailman/listinfo/users
>     >         >     >     > > http://lists.rtems.org/mailman/listinfo/users
>     >         >     >     embedded brains GmbH
>     >         >     >     Herr Christian Mauderer
>     >         >     >     Dornierstr. 4
>     >         >     >     D-82178 Puchheim
>     >         >     >     Germany
>     >         >     >     email: christian.mauderer at embedded-brains.de
>     >         >     >     Phone: +49-89-18 94 741 - 18
>     >         >     >     Fax:   +49-89-18 94 741 - 08
>     >         >     >     PGP: Public key available on request.
>     >         >     >     Diese Nachricht ist keine geschäftliche Mitteilung
>     >         im Sinne
>     >         >     des EHUG.
>     >         >     > _______________________________________________
