Mounting/Accessing SD-Card on BBB
Christian Mauderer list at c-mauderer.de
Fri Aug 16 09:40:39 UTC 2019
PS: If neither the SD nor the eMMC has a bootable image your BBB falls
back to serial and then USB boot anyway. So no need to change any boot pins.
On 16/08/2019 11:38, Christian Mauderer wrote:
> Hello Nils,
> if the U-Boot doesn't start from eMMC any more it won't be easy.
> Theoretically it is possible to boot via serial. See for example
> http://linuxkernel51.blogspot.com/2015/08/booting-beagle-bone-black-over-uart.html
> With that you could load an U-Boot (via X-Modem) that could start a
> system from USB (image from Beagle home page maybe could work if it can
> boot from USB) that could re-write the eMMC. Most likely it would need a
> few hours to a day to figure out the details. So you should definitively
> order a replacement as a backup solution.
> Best regards
> Christian
> On 16/08/2019 11:13, Nils Hölscher wrote:
>> Hi Christin,
>> Thanks for the hint.
>> But how can I alter the U- Boot on eMMC?
>> Problem is I have a Linux version with an U-Boot that disables emmc on
>> the emmc...
>> And I guess I cant flash emmc without SD.
>> Best,
>> Nils
>> On Fri, 16 Aug 2019 at 11:03, Christian Mauderer <list at c-mauderer.de
>> <mailto:list at c-mauderer.de>> wrote:
>>     On 16/08/2019 10:55, Nils Hölscher wrote:
>>     > Hi,
>>     > It seems the problem was hardware related.
>>     > My SD-Card connector just died.
>>     > I hope I can get a new BBB oin a timely manner.
>>     > Best,
>>     > Nils
>>     Hello Nils,
>>     thanks for the information. That's annoying. Good luck finding a
>>     replacement.
>>     For a quick workaround: I haven't tried that yet but if your on-board
>>     eMMC is still intact, you might can use that U-Boot to boot from USB.
>>     Best regards
>>     Christian
>>     > On Fri, 16 Aug 2019 at 10:48, Christian Mauderer
>>     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>>     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>>     >     Hello Nils,
>>     >     thanks for the file list. I can't reproduce your problem with it.
>>     >     On 16/08/2019 10:01, Nils Hölscher wrote:
>>     >     > Hi,
>>     >     > Short update.
>>     >     > It seems the device only hangs while I am connected with the
>>     debugger.
>>     >     Is that true for the original file system tree? You are
>>     debugging via
>>     >     Ethernet, right? In that case I would lean more toward a
>>     problem with
>>     >     the debugger support than the file system. Do you have enough file
>>     >     descriptors configured?
>>     >     Best regards
>>     >     Christian
>>     >     > looks like a Heisenberg bug.
>>     >     > Best,
>>     >     > Nils
>>     >     > On Fri, 16 Aug 2019 at 09:50, Nils Hölscher
>>     <nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>
>>     >     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>
>>     >     > <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>
>>     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>> wrote:
>>     >     >     On Thu, 15 Aug 2019 at 19:51, Christian Mauderer
>>     >     >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>>     >     >         Hello Nils,
>>     >     >         maybe another bug in our FAT file system...
>>     >     >         Please do three things:
>>     >     >         1. Create an image of your current card (with dd or
>>     a similar
>>     >     >         tool). FAT
>>     >     >         bugs are sometimes hard to reproduce but it's really
>>     >     urgent that
>>     >     >         we fix
>>     >     >         them. So maybe I'll ask for that image later.
>>     >     >     I did that.
>>     >     >     Let me know if you need the image.
>>     >     >         2. Create a complete list of the files on your card (for
>>     >     example the
>>     >     >         Linux `tree -h` command), post it here and tell me
>>     what you
>>     >     >         tried to open.
>>     >     >     ├── [ 50K]  am335x-boneblack.dtb
>>     >     >     ├── [ 49K]  am335x-boneblack+pruss.dtb
>>     >     >     ├── [ 883]  AM335X-PRU-UIO-00A0.dtbo
>>     >     >     ├── [ 649]  AM335X-PRU-UIO-BSD-00A0.dtbo
>>     >     >     ├── [162K]  Linux-with-UIO.dtb
>>     >     >     ├── [  44]  loob.bin
>>     >     >     ├── [108K]  MLO
>>     >     >     ├── [2.1M]  pru.exe.img
>>     >     >     ├── [  12]  test.bin
>>     >     >     ├── [471K]  u-boot.img
>>     >     >     ├── [ 390]  uEnvLinuxfdt.txt
>>     >     >     └── [ 560]  uEnv.txt
>>     >     >          3. Try another name / folder for the file you wanted to
>>     >     open.\
>>     >     >     I moved the file in another folder and renamed it.
>>     >     >     It now works but I got en error, I am currently
>>     investigating if
>>     >     >     this is on the pru driver side or not.
>>     >     >     The tree while doing this was:
>>     >     >     ├── [108K]  MLO
>>     >     >     ├── [2.0K]  test
>>     >     >     │   └── [  12]  test2.bin
>>     >     >     ├── [  12]  test2.bin
>>     >     >     Thanks,
>>     >     >     Nils
>>     >     >         Best regards
>>     >     >         Christian
>>     >     >         On 15/08/2019 19:32, Nils Hölscher wrote:
>>     >     >         > Hi Christian,
>>     >     >         > The commands ls and cat work.
>>     >     >         > I just tested them, this seems kinda awkward.
>>     >     >         > Best,
>>     >     >         > Nils
>>     >     >         > On Thu, 15 Aug 2019 at 19:27, Christian Mauderer
>>     >     >         <list at c-mauderer.de <mailto:list at c-mauderer.de>
>>     >     >         > <mailto:list at c-mauderer.de
>>     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
>>     >     >         >     Hello Nils,
>>     >     >         >     does some other access to the file system
>>     work? Like
>>     >     a ls
>>     >     >         on the console
>>     >     >         >     or creating a file. Can you do a `cat` on some
>>     text file
>>     >     >         on the file
>>     >     >         >     system? If not: Does it work for a file in the
>>     root file
>>     >     >         system (should
>>     >     >         >     be a IMFS)?
>>     >     >         >     Best regards
>>     >     >         >     Christian
>>     >     >         >     On 15/08/2019 15:54, Nils Hölscher wrote:
>>     >     >         >     > Hi,
>>     >     >         >     > I when my app wants to open a file on the SD
>>     card
>>     >     >         dev=mmcsd-0-0 rtems
>>     >     >         >     > freezes.
>>     >     >         >     > Exact call is:
>>     >     >         >     > fd = open(file, O_RDONLY);
>>     >     >         >     > With file being the pru binary I want to upload.
>>     >     >         >     > Thanks,
>>     >     >         >     > Nils
>>     >     >         >     > On Tue, 13 Aug 2019 at 17:56, Christian Mauderer
>>     >     >         >     > <christian.mauderer at embedded-brains.de
>>     <mailto:christian.mauderer at embedded-brains.de>
>>     <mailto:christian.mauderer at embedded-brains.de>>
>>     >     >         <mailto:christian.mauderer at embedded-brains.de
>>     <mailto:christian.mauderer at embedded-brains.de>>>
>>     >     >         >     <mailto:christian.mauderer at embedded-brains.de
>>     <mailto:christian.mauderer at embedded-brains.de>>>>
>>     <mailto:christian.mauderer at embedded-brains.de>>>>>> wrote:
>>     >     >         >     >     Hello Nils,
>>     >     >         >     >     a third possibility: You could start a
>>     FTP server
>>     >     >         and push the
>>     >     >         >     file
>>     >     >         >     >     via network.
>>     >     >         >     >     Best regards
>>     >     >         >     >     Christian
>>     >     >         >     >     Am Dienstag, 13. August 2019 schrieb Nils
>>     >     Hölscher:
>>     >     >         >     >     > Hi,
>>     >     >         >     >     > Thanks for the input I will try the SD
>>     card
>>     >     first.
>>     >     >         >     >     > That way I won't have to alter the
>>     code when I
>>     >     >         want to run other
>>     >     >         >     >     stuff on the pru.
>>     >     >         >     >     > Best,
>>     >     >         >     >     > Nils
>>     >     >         >     >     > On Tue, 13 Aug 2019 at 17:32, Gedare Bloom
>>     >     >         <gedare at rtems.org <mailto:gedare at rtems.org>
>>     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>
>>     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>
>>     >     >         >     <mailto:gedare at rtems.org
>>     <mailto:gedare at rtems.org> <mailto:gedare at rtems.org
>>     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>
>>     >     >         >     >     <mailto:gedare at rtems.org
>>     >     >         <mailto:gedare at rtems.org <mailto:gedare at rtems.org>
>>     <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>>> wrote:
>>     >     >         >     >     > You can also build the PRU image into
>>     the RTEMS
>>     >     >         binary. See
>>     >     >         >     >     > examples-v2.git/file_io/crc/init.c
>>     >     >         >     >     > On Tue, Aug 13, 2019 at 8:46 AM Christian
>>     >     Mauderer
>>     >     >         >     >     <list at c-mauderer.de
>>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
>>     >     >         >     >     > > Hello Nils,
>>     >     >         >     >     > > that's a bit odd. I attached an expected
>>     >     output
>>     >     >         below.
>>     >     >         >     Some guesses:
>>     >     >         >     >     > > - Did you add FAT file system to your
>>     >     application?
>>     >     >         >     >     > > - Is there some odd formatting on
>>     the SD?
>>     >     >         Normally at
>>     >     >         >     least the FAT
>>     >     >         >     >     > > partition used by U-Boot should be
>>     visible.
>>     >     >         >     >     > > - Is your BDBUF configuration OK?
>>     >     >         >     >     > > - Do you have enough file descriptors?
>>     >     >         >     >     > > Beneath that: If you only need
>>     something where
>>     >     >         you can put
>>     >     >         >     some
>>     >     >         >     >     files,
>>     >     >         >     >     > > you can try to connect a USB stick
>>     instead.
>>     >     >         Maybe that
>>     >     >         >     works better.
>>     >     >         >     >     > > Best regards
>>     >     >         >     >     > > Christian
>>     >     >         >     >     > > media listener: event = DISK ATTACH,
>>     state =
>>     >     >         INQUIRY, src
>>     >     >         >     = mmcsd
>>     state =
>>     >     >         SUCCESS, src =
>>     >     >         >     >     mmcsd, dest
>>     >     >         >     >     > > = /dev/mmcsd-0
>>     >     >         >     >     > > media listener: event = MOUNT, state =
>>     >     INQUIRY,
>>     >     >         src =
>>     >     >         >     /dev/mmcsd-0
>>     >     >         >     >     > > mmcsd0: 4GB <SDHC TO 15.15 SN
>>     000002F6 MFG
>>     >     >         02/2017 by 25
>>     >     >         >     DY> at mmc0
>>     >     >         >     >     > > 24.0MHz/4bit/65535-block
>>     >     FAILED, src =
>>     >     >         >     /dev/mmcsd-0
>>     >     >         >     >     > > media listener: event = PARTITION
>>     INQUIRY,
>>     >     state =
>>     >     >         >     INQUIRY, src =
>>     >     >         >     >     > > /dev/mmcsd-0
>>     INQUIRY,
>>     >     state =
>>     >     >         >     SUCCESS, src =
>>     ATTACH,
>>     >     state
>>     >     >         = INQUIRY,
>>     >     >         >     src =
>>     ATTACH,
>>     >     state
>>     >     >         = SUCCESS,
>>     >     >         >     src =
>>     >     >         >     >     > > /dev/mmcsd-0, dest = /dev/mmcsd-0-0
>>     >     INQUIRY,
>>     >     >         src =
>>     >     >         >     /dev/mmcsd-0-0
>>     >     SUCCESS,
>>     >     >         src =
>>     >     >         >     >     /dev/mmcsd-0-0,
>>     >     >         >     >     > > dest = /media/mmcsd-0-0
>>     state =
>>     >     >         INQUIRY, src
>>     >     >         >     = mmcsd
>>     state =
>>     >     >         SUCCESS, src =
>>     >     >         >     >     mmcsd, dest
>>     >     >         >     >     > > = /dev/mmcsd-1
>>     >     INQUIRY,
>>     >     >         src =
>>     >     >         >     /dev/mmcsd-1
>>     >     >         >     >     > > mmcsd1: 4GB <MMCHC MMC04G 5.8 SN
>>     160D224B MFG
>>     >     >         09/2014 by 112
>>     >     >         >     >     0x0000> at
>>     >     >         >     >     > > mmc1 48.0MHz/8bit/65535-block
>>     >     FAILED, src =
>>     >     >         >     /dev/mmcsd-1
>>     INQUIRY,
>>     >     state =
>>     >     >         >     INQUIRY, src =
>>     >     >         >     >     > > /dev/mmcsd-1
>>     INQUIRY,
>>     >     state
>>     >     >         = FAILED,
>>     >     >         >     src =
>>     state =
>>     >     >         INQUIRY, src =
>>     >     >         >     >     mmcsd1boot
>>     >     >         >     >     > > mmcsd1boot0: 2MB partion 1 at mmcsd1
>>     >     >         >     >     > > mmcsd1boot1: 2MB partion 2 at mmcsd1
>>     >     >         >     >     > > mmcsd1rpmb: 131kB partion 3 at mmcsd1
>>     >     >         >     >     > > On 13/08/2019 13:30, Nils Hölscher
>>     wrote:
>>     >     >         >     >     > > > Hi,
>>     >     >         >     >     > > > Thanks for the help.
>>     >     >         >     >     > > > I tried to use your code, but I
>>     always get
>>     >     >         "ERROR: SD
>>     >     >         >     could not be
>>     >     >         >     >     > > > mounted after timeout".
>>     >     >         >     >     > > > Even after raising the waiting time.
>>     >     >         >     >     > > > The sources I use start here:
>>        https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/main.c#L110
>>     >     >         >     >     > > > And my uart output is:
>>     >     >         >     >     > > > waiting for SD...
>>     >     >         >     >     > > > usbus0: 480Mbps High Speed USB v2.0
>>     >     >         >     >     > > > usbus1: 480Mbps High Speed USB v2.0
>>     >     >         >     >     > > > media listener: event = DISK
>>     ATTACH, state =
>>     >     >         INQUIRY,
>>     >     >         >     src = mmcsd
>>     ATTACH, state =
>>     >     >         SUCCESS, src =
>>     >     >         >     >     mmcsd, dest
>>     >     >         >     >     > > > = /dev/mmcsd-0
>>     >     >         >     >     > > > media listener: event = MOUNT, state =
>>     >     >         INQUIRY, src =
>>     >     >         >     /dev/mmcsd-0
>>     >     >         >     >     > > > ugen0.1: <Mentor Graphics OTG Root
>>     HUB>
>>     >     at usbus0
>>     >     >         >     >     > > > ugen1.1: <Mentor Graphics OTG Root
>>     HUB>
>>     >     at usbus1
>>     >     >         >     >     > > > uhub0: <Mentor Graphics OTG Root
>>     HUB, class
>>     >     >         9/0, rev
>>     >     >         >     >     2.00/1.00, addr 1>
>>     >     >         >     >     > > > on usbus0
>>     >     >         >     >     > > > uhub1: <Mentor Graphics OTG Root
>>     HUB, class
>>     >     >         9/0, rev
>>     >     >         >     >     > > > on usbus1
>>     >     FAILED,
>>     >     >         src =
>>     >     >         >     /dev/mmcsd-0
>>     >     >         >     >     > > > media listener: event = PARTITION
>>     >     INQUIRY, state =
>>     >     >         >     INQUIRY, src =
>>     >     >         >     >     > > > /dev/mmcsd-0
>>     >     INQUIRY, state =
>>     >     >         >     SUCCESS, src =
>>     >     ATTACH, state =
>>     >     >         >     INQUIRY, src =
>>     >     ATTACH, state =
>>     >     >         >     SUCCESS, src =
>>     >     >         >     >     > > > /dev/mmcsd-0, dest = /dev/mmcsd-0-0
>>     >     >         INQUIRY, src =
>>     >     FAILED,
>>     >     >         src =
>>     ATTACH, state =
>>     >     >         INQUIRY,
>>     >     >         >     src = mmcsd
>>     ATTACH, state =
>>     >     >         SUCCESS, src =
>>     >     >         >     >     mmcsd, dest
>>     >     >         >     >     > > > = /dev/mmcsd-1
>>     >     >         INQUIRY, src =
>>     >     >         >     /dev/mmcsd-1
>>     >     FAILED,
>>     >     >         src =
>>     >     >         >     /dev/mmcsd-1
>>     >     INQUIRY, state =
>>     >     >         >     INQUIRY, src =
>>     >     >         >     >     > > > /dev/mmcsd-1
>>     >     INQUIRY, state =
>>     >     >         >     SUCCESS, src =
>>     >     ATTACH, state =
>>     >     >         >     INQUIRY, src =
>>     >     ATTACH, state =
>>     >     >         >     SUCCESS, src =
>>     >     >         >     >     > > > /dev/mmcsd-1, dest = /dev/mmcsd-1-0
>>     >     >         INQUIRY, src =
>>     >     >         >     >     /dev/mmcsd-1-0
>>     >     FAILED,
>>     >     >         src =
>>     ATTACH, state =
>>     >     >         INQUIRY, src =
>>     >     >         >     >     mmcsd1boot
>>     >     >         >     >     > > > uhub0: 1 port with 1 removable,
>>     self powered
>>     >     >         >     >     > > > uhub1: 1 port with 1 removable,
>>     self powered
>>     >     >         >     >     > > > ERROR: SD could not be mounted
>>     after timeout
>>     >     >         >     >     > > > Thanks,
>>     >     >         >     >     > > > Nils
>>     >     >         >     >     > > > On Mon, 12 Aug 2019 at 18:01,
>>     Christian
>>     >     Mauderer
>>     >     >         >     >     > > > <mailto:list at c-mauderer.de
>>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>> wrote:
>>     >     >         >     >     > > >     On 12/08/2019 07:28, Nils Hölscher
>>     >     wrote:
>>     >     >         >     >     > > >     > Hi,
>>     >     >         >     >     > > >     > Can anyone help me with this?
>>     >     >         >     >     > > >     > I need to access the BBB's
>>     SD-Card, so
>>     >     >         that I can load
>>     >     >         >     >     my pru
>>     >     >         >     >     > > >     example on
>>     >     >         >     >     > > >     > the pru.
>>     >     >         >     >     > > >     > Thanks,
>>     >     >         >     >     > > >     > Nils
>>     >     >         >     >     > > >     Hello Nils,
>>     >     >         >     >     > > >     take a look at the following
>>     >     application:
>>          https://gitlab.com/c-mauderer/rtems-bbb/blob/master/apps/wifi-sample/init.c#L64
>>          https://gitlab.com/c-mauderer/rtems-bbb/blob/master/apps/wifi-sample/libbsdhelper.c#L122
>>     >     >         >     >     > > >     You should mainly need the stuff
>>     >     from the
>>     >     >         >     >     libbsdhelper_init_sd_card()
>>     >     >         >     >     > > >     and libbsdhelper_wait_for_sd().
>>     >     >         >     >     > > >     Please note that the SD card
>>     needs quite
>>     >     >         some time to
>>     >     >         >     >     initialize on BBB.
>>     >     >         >     >     > > >     I haven't had a look at it why
>>     that
>>     >     is the
>>     >     >         case.
>>     >     >         >     >     > > >     Best regards
>>     >     >         >     >     > > >     Christian
>>     >     _______________________________________________
>>     >     >         >     >     > > > users mailing list
>>     >     >         >     >     > > > users at rtems.org
>>     <mailto:users at rtems.org> <mailto:users at rtems.org
>>     <mailto:users at rtems.org>>
>>     >     <mailto:users at rtems.org <mailto:users at rtems.org>
>>     <mailto:users at rtems.org <mailto:users at rtems.org>>>
>>     >     >         <mailto:users at rtems.org <mailto:users at rtems.org>
>>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>
>>     >     >         >     <mailto:users at rtems.org
>>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>>
>>     >     http://lists.rtems.org/mailman/listinfo/users
>>     >     >         >     >     embedded brains GmbH
>>     >     >         >     >     Herr Christian Mauderer
>>     >     >         >     >     Dornierstr. 4
>>     >     >         >     >     D-82178 Puchheim
>>     >     >         >     >     Germany
>>     >     >         >     >     email:
>>     >     >         >     >     Phone: +49-89-18 94 741 - 18
>>     >     >         >     >     Fax:   +49-89-18 94 741 - 08
>>     >     >         >     >     PGP: Public key available on request.
>>     >     >         >     >     Diese Nachricht ist keine geschäftliche
>>     Mitteilung
>>     >     >         im Sinne
>>     >     >         >     des EHUG.
>>     >     >         >     > _______________________________________________
>>     >     >         >     > users at rtems.org <mailto:users at rtems.org>
>>     >     >         >     > http://lists.rtems.org/mailman/listinfo/users
> devel mailing list
> devel at rtems.org
